[GRASS-SVN] r35277 - grass/trunk
Wed Jan 7 15:31:01 EST 2009
Author: glynn
Date: 2009-01-07 15:31:01 -0500 (Wed, 07 Jan 2009)
New Revision: 35277
   grass/trunk/configure
   grass/trunk/configure.in
Test for cairo-xlib-xrender when X11 is enabled
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-01-07 20:01:35 UTC (rev 35276)
+++ grass/trunk/configure	2009-01-07 20:31:01 UTC (rev 35277)
@@ -51,9 +51,9 @@
 ac_help="$ac_help
   --with-lapack           support LAPACK functionality (default: no)"
 ac_help="$ac_help
-  --with-cairo            support Cairo functionality (default: no)"
+  --with-cairo            support Cairo functionality (default: yes)"
 ac_help="$ac_help
-  --with-freetype         support FreeType functionality (default: no)"
+  --with-freetype         support FreeType functionality (default: yes)"
 ac_help="$ac_help
   --with-nls              support NLS functionality (default: no)"
 ac_help="$ac_help
@@ -2926,7 +2926,7 @@
   withval="$with_cairo"
 else
-  with_cairo=no
+  with_cairo=yes
 fi
@@ -2936,7 +2936,7 @@
   withval="$with_freetype"
 else
-  with_freetype=no
+  with_freetype=yes
 fi
@@ -13394,13 +13394,19 @@
 if test -n "$USE_CAIRO"; then
+if test -n "$USE_X11"; then
+	cairo=cairo\ cairo-xlib-xrender
+else
+	cairo=cairo
+fi
 # With Cairo includes directory
-CAIROINC=`pkg-config --cflags cairo`
+CAIROINC=`pkg-config --cflags $cairo`
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13404: checking for location of cairo includes" >&5
+echo "configure:13410: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13426,15 +13432,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13430: checking for $ac_hdr" >&5
+echo "configure:13436: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 13433 "configure"
+#line 13439 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13466,11 +13472,11 @@
 # With Cairo library directory
-CAIROLIB=`pkg-config --libs cairo`
+CAIROLIB=`pkg-config --libs $cairo`
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13474: checking for location of cairo library" >&5
+echo "configure:13480: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13490,7 +13496,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13494: checking for cairo linking flags" >&5
+echo "configure:13500: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13506,10 +13512,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13510: checking for cairo_create" >&5
+echo "configure:13516: checking for cairo_create" >&5
-#line 13513 "configure"
+#line 13519 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char cairo_create(); below.  */
@@ -13532,7 +13538,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13575,7 +13581,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13579: checking whether to use FreeType" >&5
+echo "configure:13585: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13594,7 +13600,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13598: checking for location of FreeType includes" >&5
+echo "configure:13604: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13620,15 +13626,15 @@
 do
-echo "configure:13624: checking for $ac_hdr" >&5
+echo "configure:13630: checking for $ac_hdr" >&5
-#line 13627 "configure"
+#line 13633 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13638: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13662,7 +13668,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13666: checking for location of FreeType library" >&5
+echo "configure:13672: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13687,13 +13693,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13691: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13697: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfreetype  $LIBS"
-#line 13697 "configure"
+#line 13703 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13704,7 +13710,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13745,7 +13751,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13749: checking whether to use NLS" >&5
+echo "configure:13755: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13765,10 +13771,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13769: checking for gettext" >&5
+echo "configure:13775: checking for gettext" >&5
-#line 13772 "configure"
+#line 13778 "configure"
     which can conflict with char gettext(); below.  */
@@ -13791,7 +13797,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13809,13 +13815,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13813: checking for gettext in -lintl" >&5
+echo "configure:13819: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13819 "configure"
+#line 13825 "configure"
@@ -13826,7 +13832,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13861,7 +13867,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13865: checking whether to use C++" >&5
+echo "configure:13871: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13877,7 +13883,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13881: checking for $ac_word" >&5
+echo "configure:13887: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13906,7 +13912,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13910: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13916: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13917,12 +13923,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13921 "configure"
+#line 13927 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13948,19 +13954,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13952: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13958: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13957: checking whether we are using GNU C++" >&5
+echo "configure:13963: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13978,7 +13984,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13982: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13988: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14019,7 +14025,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14023: checking whether to use openDWG" >&5
+echo "configure:14029: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14039,7 +14045,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14043: checking for location of openDGW includes" >&5
+echo "configure:14049: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14065,15 +14071,15 @@
 do
-echo "configure:14069: checking for $ac_hdr" >&5
+echo "configure:14075: checking for $ac_hdr" >&5
-#line 14072 "configure"
+#line 14078 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14107,7 +14113,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14111: checking for location of openDWG library" >&5
+echo "configure:14117: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14148,7 +14154,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14152: checking whether to use POSIX threads" >&5
+echo "configure:14158: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14168,7 +14174,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14172: checking for location of POSIX threads includes" >&5
+echo "configure:14178: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14194,15 +14200,15 @@
 do
-echo "configure:14198: checking for $ac_hdr" >&5
+echo "configure:14204: checking for $ac_hdr" >&5
-#line 14201 "configure"
+#line 14207 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14206: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14236,7 +14242,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14240: checking for location of POSIX threads library" >&5
+echo "configure:14246: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14261,10 +14267,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14265: checking for pthread_create" >&5
+echo "configure:14271: checking for pthread_create" >&5
-#line 14268 "configure"
+#line 14274 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14287,7 +14293,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14314,13 +14320,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14318: checking for pthread_create in -lpthread" >&5
+echo "configure:14324: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14324 "configure"
+#line 14330 "configure"
@@ -14331,7 +14337,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14387,7 +14393,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14391: checking for special C compiler options needed for large files" >&5
+echo "configure:14397: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14395,7 +14401,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14399 "configure"
+#line 14405 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14411,7 +14417,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14420,7 +14426,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14424 "configure"
+#line 14430 "configure"
@@ -14436,7 +14442,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14440: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14446: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14456,11 +14462,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14460: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14466: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14464 "configure"
+#line 14470 "configure"
@@ -14476,14 +14482,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14480: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14486: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14487 "configure"
+#line 14493 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14501,7 +14507,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14505: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14520,11 +14526,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14524: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14530: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14528 "configure"
+#line 14534 "configure"
@@ -14540,14 +14546,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14544: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14550: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14551 "configure"
+#line 14557 "configure"
 #define _LARGE_FILES 1
@@ -14565,7 +14571,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14575: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14584,25 +14590,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14588: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14594: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14592 "configure"
+#line 14598 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14599: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14606 "configure"
+#line 14612 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14611,7 +14617,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14615: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14621: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14632,10 +14638,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14636: checking if system supports Large Files at all" >&5
+echo "configure:14642: checking if system supports Large Files at all" >&5
-#line 14639 "configure"
+#line 14645 "configure"
 #include <stdio.h>
@@ -14667,7 +14673,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14671: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14677: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14696,7 +14702,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14700: checking whether to use Python" >&5
+echo "configure:14706: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14716,7 +14722,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14720: checking for $ac_word" >&5
+echo "configure:14726: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14761,15 +14767,15 @@
 do
-echo "configure:14765: checking for $ac_hdr" >&5
+echo "configure:14771: checking for $ac_hdr" >&5
-#line 14768 "configure"
+#line 14774 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14809,7 +14815,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:14813: checking for $ac_word" >&5
+echo "configure:14819: checking for $ac_word" >&5
 case "$SWIG" in
@@ -14855,7 +14861,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14859: checking whether to use wxWidgets" >&5
+echo "configure:14865: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14875,7 +14881,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14879: checking for $ac_word" >&5
+echo "configure:14885: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14923,7 +14929,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14927: checking wxWidgets version" >&5
+echo "configure:14933: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14946,15 +14952,15 @@
 do
-echo "configure:14950: checking for $ac_hdr" >&5
+echo "configure:14956: checking for $ac_hdr" >&5
-#line 14953 "configure"
+#line 14959 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14990,15 +14996,15 @@
 do
-echo "configure:14994: checking for $ac_hdr" >&5
+echo "configure:15000: checking for $ac_hdr" >&5
-#line 14997 "configure"
+#line 15003 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-01-07 20:01:35 UTC (rev 35276)
+++ grass/trunk/configure.in	2009-01-07 20:31:01 UTC (rev 35277)
@@ -189,8 +189,8 @@
 LOC_ARG_WITH(fftw, FFTW)
 LOC_ARG_WITH(blas, BLAS, no)
 LOC_ARG_WITH(lapack, LAPACK, no)
-LOC_ARG_WITH(cairo, Cairo, no)
-LOC_ARG_WITH(freetype, FreeType, no)
+LOC_ARG_WITH(cairo, Cairo)
+LOC_ARG_WITH(freetype, FreeType)
 LOC_ARG_WITH(nls, NLS, no)
 LOC_ARG_WITH(readline, Readline, no)
 LOC_ARG_WITH(opendwg, openDWG, no)
@@ -1392,9 +1392,15 @@
+else
+	cairo=cairo
+fi
 LOC_CHECK_INC_PATH(cairo,cairo,CAIROINC)
@@ -1402,7 +1408,7 @@
 LOC_CHECK_LIB_PATH(cairo,cairo,CAIROLIB)
 LOC_CHECK_LDFLAGS(cairo,cairo,CAIROLIB)
