[GRASS-SVN] r35406 - grass/trunk/vector/v.buffer2
Wed Jan 14 12:55:29 EST 2009
Author: martinl
Date: 2009-01-14 12:55:29 -0500 (Wed, 14 Jan 2009)
New Revision: 35406
   grass/trunk/vector/v.buffer2/main.c
v.buffer2: cosmetics in guisections
	   (merge from devbr6, r35405)
Modified: grass/trunk/vector/v.buffer2/main.c
--- grass/trunk/vector/v.buffer2/main.c	2009-01-14 07:38:37 UTC (rev 35405)
+++ grass/trunk/vector/v.buffer2/main.c	2009-01-14 17:55:29 UTC (rev 35406)
@@ -153,8 +153,10 @@
     type_opt = G_define_standard_option(G_OPT_V_TYPE);
     type_opt->options = "point,line,boundary,centroid,area";
     type_opt->answer = "point,line,area";
+    type_opt->guisection = _("Selection");
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    field_opt->guisection = _("Selection");
     dista_opt = G_define_option();
     dista_opt->key = "distance";
@@ -162,6 +164,7 @@
     dista_opt->required = NO;
     dista_opt->description =
 	_("Buffer distance along major axis in map units");
+    dista_opt->guisection = _("Distance");
     distb_opt = G_define_option();
     distb_opt->key = "minordistance";
@@ -169,7 +172,7 @@
     distb_opt->required = NO;
     distb_opt->description =
 	_("Buffer distance along minor axis in map units");
-    distb_opt->guisection = _("Advanced");
+    distb_opt->guisection = _("Distance");
     angle_opt = G_define_option();
     angle_opt->key = "angle";
@@ -177,15 +180,12 @@
     angle_opt->required = NO;
     angle_opt->answer = "0";
     angle_opt->description = _("Angle of major axis in degrees");
-    angle_opt->guisection = _("Advanced");
-    bufcol_opt = G_define_option();
-    bufcol_opt->key = "bufcol";
-    bufcol_opt->type = TYPE_STRING;
-    bufcol_opt->required = NO;
+    bufcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+    bufcol_opt->key = "bufcolumn";
     bufcol_opt->description =
-	_("Attribute column to use for buffer distances");
-    bufcol_opt->guisection = _("Advanced");
+	_("Name of column to use for buffer distances");
+    bufcol_opt->guisection = _("Distance");
     scale_opt = G_define_option();
     scale_opt->key = "scale";
@@ -193,16 +193,15 @@
     scale_opt->required = NO;
     scale_opt->answer = "1.0";
     scale_opt->description = _("Scaling factor for attribute column values");
-    scale_opt->guisection = _("Advanced");
     tol_opt = G_define_option();
     tol_opt->key = "tolerance";
     tol_opt->type = TYPE_DOUBLE;
     tol_opt->required = NO;
     tol_opt->answer = "0.01";
-    tol_opt->guisection = _("Advanced");
     tol_opt->description =
 	_("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
+    tol_opt->guisection = _("Distance");
     straight_flag = G_define_flag();
     straight_flag->key = 's';
