[GRASS-SVN] r35461 - grass/trunk/vector/v.voronoi
    svn_grass at osgeo.org
    Sat Jan 17 10:06:01 EST 2009
Author: neteler
Date: 2009-01-17 10:06:01 -0500 (Sat, 17 Jan 2009)
New Revision: 35461
Added:
   grass/trunk/vector/v.voronoi/main.c
Removed:
   grass/trunk/vector/v.voronoi/delaunay_DEPRECATED
   grass/trunk/vector/v.voronoi/dt_main.c
   grass/trunk/vector/v.voronoi/v.delaunay.html
   grass/trunk/vector/v.voronoi/vo_main.c
   grass/trunk/vector/v.voronoi/Makefile
   grass/trunk/vector/v.voronoi/README
removed outdated delaunay part
Modified: grass/trunk/vector/v.voronoi/Makefile
--- grass/trunk/vector/v.voronoi/Makefile	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/Makefile	2009-01-17 15:06:01 UTC (rev 35461)
@@ -1,24 +1,18 @@
 MODULE_TOPDIR = ../..
-VORONOI = v.voronoi
-# DELAUNAY = v.delaunay
+PGM = v.voronoi
-PROGRAMS = $(VORONOI)
-# $(DELAUNAY)
 SWEEP_OBJS = sw_edgelist.o sw_geometry.o sw_heap.o sw_main.o sw_memory.o sw_output.o \
              sw_voronoi.o
-v_voronoi_OBJS = vo_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
+v_voronoi_OBJS = vo_main.o vo_extend.o vo_write.o $(SWEEP_OBJS)
-# v_delaunay_OBJS = dt_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
 LIBES = $(VECTLIB) $(GISLIB)
 DEPENDENCIES= $(VECTDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
-include $(MODULE_TOPDIR)/include/Make/Multi.make
+include $(MODULE_TOPDIR)/include/Make/Module.make
-default: multi
+default: cmd
Modified: grass/trunk/vector/v.voronoi/README
--- grass/trunk/vector/v.voronoi/README	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/README	2009-01-17 15:06:01 UTC (rev 35461)
@@ -58,3 +58,10 @@
 - TODO: complete it for Voronoi if desired
 Benjamin Ducke
+Jan 2009
+Removed delaunay part as rewritten in ../v.delaunay2/
+Markus Neteler
Deleted: grass/trunk/vector/v.voronoi/delaunay_DEPRECATED
--- grass/trunk/vector/v.voronoi/delaunay_DEPRECATED	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/delaunay_DEPRECATED	2009-01-17 15:06:01 UTC (rev 35461)
@@ -1,2 +0,0 @@
-no longer maintained.
-Continued in ../v.delaunay2/
Deleted: grass/trunk/vector/v.voronoi/dt_main.c
--- grass/trunk/vector/v.voronoi/dt_main.c	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/dt_main.c	2009-01-17 15:06:01 UTC (rev 35461)
@@ -1,158 +0,0 @@
-/*-s.delaunay
-** Author: James Darrell McCauley (mccauley at ecn.purdue.edu)
-**         USDA Fellow
-**         Department of Agricultural Engineering
-**         Purdue University
-**         West Lafayette, Indiana 47907-1146 USA
-** Permission to use, copy, modify, and distribute this software and its
-** documentation for any purpose and without fee is hereby granted. This
-** software is provided "as is" without express or implied warranty.
-** Modification History:
-** 06 Feb 93 - James Darrell McCauley <mccauley at ecn.purdue.edu> pieced
-**             this together from stuff he found on netlib (see the manpage).
-** 4 2008: Benjamin Ducke - 3D support + better memory management
-#include <stdio.h>
-#include <string.h>
-#include <stdlib.h>
-#include <unistd.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/Vect.h>
-#include <grass/glocale.h>
-#include "sw_defs.h"
-#include "defs.h"
-int main(int argc, char **argv)
-    struct Flag *reg_flag, *line_flag;
-    struct Option *in_opt, *out_opt;
-    struct GModule *module;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
-    int nareas, area;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    module->keywords = _("vector");
-    module->description = _("Creates a Delaunay triangulation from an input "
-			    "vector map containing points or centroids.");
-    in_opt = G_define_standard_option(G_OPT_V_INPUT);
-    out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    reg_flag = G_define_flag();
-    reg_flag->key = 'r';
-    reg_flag->description = _("Use only points in current region");
-    line_flag = G_define_flag();
-    line_flag->key = 'l';
-    line_flag->description =
-	_("Output triangulation as a graph (lines), not areas");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    if (line_flag->answer)
-	Type = GV_LINE;
-    else
-	Type = GV_BOUNDARY;
-    All = reg_flag->answer ? 0 : 1;
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
-    /* open files */
-    Vect_set_open_level(2);
-    Vect_open_old(&In, in_opt->answer, "");
-    /* check if we have a 3D input points map */
-    mode3d = 0;
-    if (Vect_is_3d(&In)) {
-	mode3d = 1;
-    if (mode3d) {
-	if (0 > Vect_open_new(&Out, out_opt->answer, 1)) {
-	    G_fatal_error(_("Unable to create vector map <%s>"),
-			  out_opt->answer);
-    else {
-	if (0 > Vect_open_new(&Out, out_opt->answer, 0)) {
-			  out_opt->answer);
-    Vect_hist_copy(&In, &Out);
-    Vect_hist_command(&Out);
-    Vect_build_partial(&Out, GV_BUILD_BASE);
-    /* initialize working region */
-    G_get_window(&Window);
-    G_percent(0, 100, 1);
-    Vect_region_box(&Window, &Box);
-    freeinit(&sfl, sizeof *sites);
-    readsites();
-    siteidx = 0;
-    geominit();
-    triangulate = 1;
-    plot = 0;
-    debug = 0;
-    voronoi(triangulate, nextone);
-    Vect_close(&In);
-    Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES);
-    nareas = Vect_get_num_areas(&Out);
-    G_debug(3, "nareas = %d", nareas);
-    for (area = 1; area <= nareas; area++) {
-	double x, y, z, angle, slope;
-	int ret;
-	G_percent(area, nareas, 2);
-	Vect_reset_line(Points);
-	Vect_reset_cats(Cats);
-	ret = Vect_get_point_in_area(&Out, area, &x, &y);
-	if (ret < 0) {
-	    G_warning(_("Cannot calculate area centroid"));
-	    continue;
-	ret = Vect_tin_get_z(&Out, x, y, &z, &angle, &slope);
-	G_debug(3, "area centroid z: %f", z);
-	if (ret < 0) {
-	    G_warning(_("Cannot calculate area centroid z coordinate"));
-	    continue;
-	Vect_append_point(Points, x, y, z);
-	Vect_cat_set(Cats, 1, area);
-	Vect_write_line(&Out, GV_CENTROID, Points, Cats);
-    Vect_build_partial(&Out, GV_BUILD_NONE);
-    Vect_build(&Out);
-    Vect_close(&Out);
-    exit(EXIT_SUCCESS);
Copied: grass/trunk/vector/v.voronoi/main.c (from rev 35460, grass/trunk/vector/v.voronoi/vo_main.c)
--- grass/trunk/vector/v.voronoi/main.c	                        (rev 0)
+++ grass/trunk/vector/v.voronoi/main.c	2009-01-17 15:06:01 UTC (rev 35461)
@@ -0,0 +1,354 @@
+ * MODULE:       v.voronoi
+ * AUTHOR(S):    James McCauley <mccauley ecn.purdue.edu>, s.voronoi, based
+ *                     on netlib code (see README) (original contributor)
+ *               Andrea Aime <aaime libero.it>
+ *               Radim Blazek <radim.blazek gmail.com> (GRASS 5.1 v.voronoi)
+ *               Glynn Clements <glynn gclements.plus.com>,
+ *               Markus Neteler <neteler itc.it>
+ * PURPOSE:      produce a Voronoi diagram using vector points
+ * COPYRIGHT:    (C) 1993-2006 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+/*-s.voronoi
+** Author: James Darrell McCauley (mccauley at ecn.purdue.edu)
+**         USDA Fellow
+**         Department of Agricultural Engineering
+**         Purdue University
+**         West Lafayette, Indiana 47907-1146 USA
+** Permission to use, copy, modify, and distribute this software and its
+** documentation for any purpose and without fee is hereby granted. This
+** software is provided "as is" without express or implied warranty.
+** Modification History:
+** 06 Feb 93 - James Darrell McCauley <mccauley at ecn.purdue.edu> pieced
+**             this together from stuff he found on netlib (see the manpage).
+#include <stdio.h>
+#include <string.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#include "sw_defs.h"
+#include "defs.h"
+typedef struct
+    double x, y;
+} COOR;
+int cmp(void *a, void *b)
+    COOR *ca = (COOR *) a;
+    COOR *cb = (COOR *) b;
+    double thresh = 1e-10;
+    double ma, mb;
+    /* calculate measure */
+    ma = mb = 0.0;
+    if (fabs(ca->y - Box.S) < thresh) {	/* bottom */
+	ma = ca->x - Box.W;
+    else if (fabs(ca->x - Box.E) < thresh) {	/* right */
+	ma = (Box.E - Box.W) + (ca->y - Box.S);
+    else if (fabs(ca->y - Box.N) < thresh) {	/* top */
+	ma = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - ca->x);
+    else {			/* left */
+	ma = 2 * (Box.E - Box.W) + (Box.N - Box.S) + (Box.N - ca->y);
+    if (fabs(cb->y - Box.S) < thresh) {	/* bottom */
+	mb = cb->x - Box.W;
+    else if (fabs(cb->x - Box.E) < thresh) {	/* right */
+	mb = (Box.E - Box.W) + (cb->y - Box.S);
+    else if (fabs(cb->y - Box.N) < thresh) {	/* top */
+	mb = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - cb->x);
+    else {			/* left */
+	mb = 2 * (Box.E - Box.W) + (Box.N - Box.S) + (Box.N - cb->y);
+    if (ma < mb)
+	return -1;
+    if (ma > mb)
+	return 1;
+    return 0;
+int main(int argc, char **argv)
+    int i;
+    int **cats, *ncats, nfields, *fields;
+    struct Flag *line_flag;
+    /* struct Flag *all_flag; */
+    struct Option *in_opt, *out_opt;
+    struct Flag *table_flag;
+    struct GModule *module;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    int node, nnodes;
+    COOR *coor;
+    int ncoor, acoor;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("vector");
+    module->description = _("Creates a Voronoi diagram from an input vector "
+			    "map containing points or centroids.");
+    in_opt = G_define_standard_option(G_OPT_V_INPUT);
+    out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+       all_flag = G_define_flag ();
+       all_flag->key = 'a';
+       all_flag->description = _("Use all points (do not limit to current region)");
+    line_flag = G_define_flag();
+    line_flag->key = 'l';
+    line_flag->description =
+	_("Output tessellation as a graph (lines), not areas");
+    table_flag = G_define_flag();
+    table_flag->key = 't';
+    table_flag->description = _("Do not create attribute table");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    if (line_flag->answer)
+	Type = GV_LINE;
+    else
+	Type = GV_BOUNDARY;
+    All = 0;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    /* open files */
+    Vect_set_open_level(2);
+    Vect_open_old(&In, in_opt->answer, "");
+    if (Vect_open_new(&Out, out_opt->answer, 0) < 0)
+	G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
+    Vect_hist_copy(&In, &Out);
+    Vect_hist_command(&Out);
+    /* initialize working region */
+    G_get_window(&Window);
+    Vect_region_box(&Window, &Box);
+    freeinit(&sfl, sizeof *sites);
+    readsites();
+    siteidx = 0;
+    geominit();
+    triangulate = 0;
+    plot = 0;
+    debug = 0;
+    voronoi(triangulate, nextone);
+    /* Close free ends by cyrrent region */
+    Vect_build_partial(&Out, GV_BUILD_BASE);
+    ncoor = 0;
+    acoor = 100;
+    coor = (COOR *) G_malloc(sizeof(COOR) * acoor);
+    nnodes = Vect_get_num_nodes(&Out);
+    for (node = 1; node <= nnodes; node++) {
+	double x, y;
+	if (Vect_get_node_n_lines(&Out, node) < 2) {	/* add coordinates */
+	    Vect_get_node_coor(&Out, node, &x, &y, NULL);
+	    if (ncoor == acoor - 5) {	/* always space for 5 region corners */
+		acoor += 100;
+		coor = (COOR *) G_realloc(coor, sizeof(COOR) * acoor);
+	    coor[ncoor].x = x;
+	    coor[ncoor].y = y;
+	    ncoor++;
+    /* Add region corners */
+    coor[ncoor].x = Box.W;
+    coor[ncoor].y = Box.S;
+    ncoor++;
+    coor[ncoor].x = Box.E;
+    ncoor++;
+    coor[ncoor].y = Box.N;
+    ncoor++;
+    ncoor++;
+    /* Sort */
+    qsort(coor, ncoor, sizeof(COOR), (void *)cmp);
+    /* add last (first corner) */
+    ncoor++;
+    for (i = 1; i < ncoor; i++) {
+	if (coor[i].x == coor[i - 1].x && coor[i].y == coor[i - 1].y)
+	    continue;		/* duplicate */
+	Vect_reset_line(Points);
+	Vect_append_point(Points, coor[i].x, coor[i].y, 0.0);
+	Vect_append_point(Points, coor[i - 1].x, coor[i - 1].y, 0.0);
+	Vect_write_line(&Out, Type, Points, Cats);
+    G_free(coor);
+    /* Copy input points as centroids */
+    nfields = Vect_cidx_get_num_fields(&In);
+    cats = (int **)G_malloc(nfields * sizeof(int *));
+    ncats = (int *)G_malloc(nfields * sizeof(int));
+    fields = (int *)G_malloc(nfields * sizeof(int));
+    for (i = 0; i < nfields; i++) {
+	ncats[i] = 0;
+	cats[i] =
+	    (int *)G_malloc(Vect_cidx_get_num_cats_by_index(&In, i) *
+			    sizeof(int));
+	fields[i] = Vect_cidx_get_field_number(&In, i);
+    if (1) {
+	int line, nlines, type;
+	nlines = Vect_get_num_lines(&In);
+	for (line = 1; line <= nlines; line++) {
+	    type = Vect_read_line(&In, Points, Cats, line);
+	    if (!(type & GV_POINTS))
+		continue;
+	    if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &Box))
+		continue;
+	    Vect_write_line(&Out, GV_CENTROID, Points, Cats);
+	    for (i = 0; i < Cats->n_cats; i++) {
+		int f, j;
+		for (j = 0; j < nfields; j++) {	/* find field */
+		    if (fields[j] == Cats->field[i]) {
+			f = j;
+			break;
+		cats[f][ncats[f]] = Cats->cat[i];
+		ncats[f]++;
+    /* Copy tables */
+    if (!(table_flag->answer)) {
+	int ttype, ntabs = 0;
+	struct field_info *IFi, *OFi;
+	/* Number of output tabs */
+	for (i = 0; i < Vect_get_num_dblinks(&In); i++) {
+	    int f, j;
+	    IFi = Vect_get_dblink(&In, i);
+		if (fields[j] == IFi->number) {
+		    f = j;
+		    break;
+	    if (ncats[f] > 0)
+		ntabs++;
+	if (ntabs > 1)
+	    ttype = GV_MTABLE;
+	else
+	    ttype = GV_1TABLE;
+	    int ret;
+	    if (fields[i] == 0)
+		continue;
+	    G_message(_("Layer %d"), fields[i]);
+	    /* Make a list of categories */
+	    IFi = Vect_get_field(&In, fields[i]);
+	    if (!IFi) {		/* no table */
+		G_message(_("No table"));
+		continue;
+	    OFi =
+		Vect_default_field_info(&Out, IFi->number, IFi->name, ttype);
+	    ret =
+		db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
+				      OFi->driver,
+				      Vect_subst_var(OFi->database, &Out),
+				      OFi->table, IFi->key, cats[i],
+				      ncats[i]);
+	    if (ret == DB_FAILED) {
+		G_warning(_("Cannot copy table"));
+	    else {
+		Vect_map_add_dblink(&Out, OFi->number, OFi->name, OFi->table,
+				    IFi->key, OFi->database, OFi->driver);
+	    G_done_msg(" ");
+    Vect_close(&In);
+    Vect_build_partial(&Out, GV_BUILD_NONE);
+    Vect_build(&Out);
+    Vect_close(&Out);
+    exit(EXIT_SUCCESS);
Property changes on: grass/trunk/vector/v.voronoi/main.c
___________________________________________________________________
   + text/x-csrc
   + Author Date Id
   + native
Deleted: grass/trunk/vector/v.voronoi/v.delaunay.html
--- grass/trunk/vector/v.voronoi/v.delaunay.html	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/v.delaunay.html	2009-01-17 15:06:01 UTC (rev 35461)
@@ -1,65 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>v.delaunay</EM> uses an existing vector points map (<B>input</B>)
-to create a Delaunay triangulation vector map (<B>output</B>).
-<P>
-<BR>
-Delaunay triangulation and Voronoi diagram example:
-<center>
-<img src=v_voronoi_delaunay.png border=1><BR>
-<table border=0 width=590>
-<tr><td><center>
-<i>Delaunay Triangulation (left pane), Voronoi diagram (center pane),
-and both (right pane)</i>
-</center></td></tr>
-</table>
-</center>
-<H2>EXAMPLE</H2>
-Commands used with the Spearfish dataset to create the above figure.
-<div class="code"><pre>
-  g.region n=4927250 s=4919400 w=588650 e=594850
-  d.frame -c fr=one at=0,100,0,33.3333
-  d.frame -c fr=two at=0,100,33.3333,66.6667
-  d.frame -c fr=three at=0,100,66.6667,100
-  v.delaunay -lr in=archsites out=arch_delaunay
-  d.frame -s one
-  d.vect arch_delaunay
-  d.vect archsites color=red fcolor=red size=5 icon=basic/circle
-  v.voronoi -l in=archsites out=arch_voronoi
-  d.frame -s two
-  d.vect arch_voronoi type=line
-  d.frame -s three
-  d.vect arch_delaunay color=blue
-</pre></div>
-<H2>REFERENCES</H2>
-<EM>Steve J. Fortune,  (1987).  A Sweepline Algorithm for
-    Voronoi Diagrams, Algorithmica 2, 153-174.</EM>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="v.voronoi.html">v.voronoi</A>,
-<A HREF="v.hull.html">v.hull</A>
-</EM>
-<H2>AUTHORS</H2>
-James Darrell McCauley, Purdue University<br>
-GRASS 5 update, improvements: <a href="mailto:aaime at libero.it">Andrea Aime</a>,
- Modena, Italy<br>
-GRASS 5.7 update: Radim Blazek
-<p>
-<i>Last changed: $Date$</i></p>
Deleted: grass/trunk/vector/v.voronoi/vo_main.c
--- grass/trunk/vector/v.voronoi/vo_main.c	2009-01-17 14:55:30 UTC (rev 35460)
+++ grass/trunk/vector/v.voronoi/vo_main.c	2009-01-17 15:06:01 UTC (rev 35461)
@@ -1,354 +0,0 @@
- * MODULE:       v.voronoi
- * AUTHOR(S):    James McCauley <mccauley ecn.purdue.edu>, s.voronoi, based
- *                     on netlib code (see README) (original contributor)
- *               Andrea Aime <aaime libero.it>
- *               Radim Blazek <radim.blazek gmail.com> (GRASS 5.1 v.voronoi)
- *               Glynn Clements <glynn gclements.plus.com>,
- *               Markus Neteler <neteler itc.it>
- * PURPOSE:      produce a Voronoi diagram using vector points
- * COPYRIGHT:    (C) 1993-2006 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-/*-s.voronoi
-**         USDA Fellow
-#include <stdio.h>
-#include <math.h>
-#include <grass/dbmi.h>
-#include "defs.h"
-typedef struct
-    double x, y;
-} COOR;
-int cmp(void *a, void *b)
-    COOR *ca = (COOR *) a;
-    COOR *cb = (COOR *) b;
-    double thresh = 1e-10;
-    double ma, mb;
-    /* calculate measure */
-    ma = mb = 0.0;
-    if (fabs(ca->y - Box.S) < thresh) {	/* bottom */
-	ma = ca->x - Box.W;
-    else if (fabs(ca->x - Box.E) < thresh) {	/* right */
-	ma = (Box.E - Box.W) + (ca->y - Box.S);
-    else if (fabs(ca->y - Box.N) < thresh) {	/* top */
-	ma = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - ca->x);
-    else {			/* left */
-	ma = 2 * (Box.E - Box.W) + (Box.N - Box.S) + (Box.N - ca->y);
-    if (fabs(cb->y - Box.S) < thresh) {	/* bottom */
-	mb = cb->x - Box.W;
-    else if (fabs(cb->x - Box.E) < thresh) {	/* right */
-	mb = (Box.E - Box.W) + (cb->y - Box.S);
-    else if (fabs(cb->y - Box.N) < thresh) {	/* top */
-	mb = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - cb->x);
-    else {			/* left */
-	mb = 2 * (Box.E - Box.W) + (Box.N - Box.S) + (Box.N - cb->y);
-    if (ma < mb)
-	return -1;
-    if (ma > mb)
-	return 1;
-    return 0;
-    int i;
-    int **cats, *ncats, nfields, *fields;
-    struct Flag *line_flag;
-    /* struct Flag *all_flag; */
-    struct Flag *table_flag;
-    int node, nnodes;
-    COOR *coor;
-    int ncoor, acoor;
-    module->description = _("Creates a Voronoi diagram from an input vector "
-			    "map containing points or centroids.");
-       all_flag = G_define_flag ();
-       all_flag->key = 'a';
-       all_flag->description = _("Use all points (do not limit to current region)");
-	_("Output tessellation as a graph (lines), not areas");
-    table_flag = G_define_flag();
-    table_flag->key = 't';
-    table_flag->description = _("Do not create attribute table");
-	Type = GV_LINE;
-    else
-    All = 0;
-    /* open files */
-    if (Vect_open_new(&Out, out_opt->answer, 0) < 0)
-	G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
-    readsites();
-    siteidx = 0;
-    geominit();
-    triangulate = 0;
-    plot = 0;
-    debug = 0;
-    /* Close free ends by cyrrent region */
-    ncoor = 0;
-    acoor = 100;
-    coor = (COOR *) G_malloc(sizeof(COOR) * acoor);
-    nnodes = Vect_get_num_nodes(&Out);
-    for (node = 1; node <= nnodes; node++) {
-	double x, y;
-	if (Vect_get_node_n_lines(&Out, node) < 2) {	/* add coordinates */
-	    Vect_get_node_coor(&Out, node, &x, &y, NULL);
-	    if (ncoor == acoor - 5) {	/* always space for 5 region corners */
-		acoor += 100;
-		coor = (COOR *) G_realloc(coor, sizeof(COOR) * acoor);
-	    coor[ncoor].x = x;
-	    coor[ncoor].y = y;
-	    ncoor++;
-    /* Add region corners */
-    coor[ncoor].x = Box.W;
-    coor[ncoor].y = Box.S;
-    ncoor++;
-    coor[ncoor].x = Box.E;
-    ncoor++;
-    coor[ncoor].y = Box.N;
-    ncoor++;
-    ncoor++;
-    /* Sort */
-    qsort(coor, ncoor, sizeof(COOR), (void *)cmp);
-    /* add last (first corner) */
-    ncoor++;
-    for (i = 1; i < ncoor; i++) {
-	if (coor[i].x == coor[i - 1].x && coor[i].y == coor[i - 1].y)
-	    continue;		/* duplicate */
-	Vect_append_point(Points, coor[i].x, coor[i].y, 0.0);
-	Vect_append_point(Points, coor[i - 1].x, coor[i - 1].y, 0.0);
-	Vect_write_line(&Out, Type, Points, Cats);
-    G_free(coor);
-    /* Copy input points as centroids */
-    nfields = Vect_cidx_get_num_fields(&In);
-    cats = (int **)G_malloc(nfields * sizeof(int *));
-    ncats = (int *)G_malloc(nfields * sizeof(int));
-    fields = (int *)G_malloc(nfields * sizeof(int));
-    for (i = 0; i < nfields; i++) {
-	ncats[i] = 0;
-	cats[i] =
-	    (int *)G_malloc(Vect_cidx_get_num_cats_by_index(&In, i) *
-			    sizeof(int));
-	fields[i] = Vect_cidx_get_field_number(&In, i);
-    if (1) {
-	int line, nlines, type;
-	nlines = Vect_get_num_lines(&In);
-	for (line = 1; line <= nlines; line++) {
-	    type = Vect_read_line(&In, Points, Cats, line);
-	    if (!(type & GV_POINTS))
-		continue;
-	    if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &Box))
-		continue;
-	    for (i = 0; i < Cats->n_cats; i++) {
-		int f, j;
-		for (j = 0; j < nfields; j++) {	/* find field */
-		    if (fields[j] == Cats->field[i]) {
-			f = j;
-			break;
-		cats[f][ncats[f]] = Cats->cat[i];
-		ncats[f]++;
-    /* Copy tables */
-    if (!(table_flag->answer)) {
-	int ttype, ntabs = 0;
-	struct field_info *IFi, *OFi;
-	/* Number of output tabs */
-	for (i = 0; i < Vect_get_num_dblinks(&In); i++) {
-	    int f, j;
-	    IFi = Vect_get_dblink(&In, i);
-		if (fields[j] == IFi->number) {
-		    f = j;
-		    break;
-	    if (ncats[f] > 0)
-		ntabs++;
-	if (ntabs > 1)
-	    ttype = GV_MTABLE;
-	else
-	    ttype = GV_1TABLE;
-	    int ret;
-	    if (fields[i] == 0)
-		continue;
-	    G_message(_("Layer %d"), fields[i]);
-	    /* Make a list of categories */
-	    IFi = Vect_get_field(&In, fields[i]);
-	    if (!IFi) {		/* no table */
-		G_message(_("No table"));
-		continue;
-	    OFi =
-		Vect_default_field_info(&Out, IFi->number, IFi->name, ttype);
-	    ret =
-		db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
-				      OFi->driver,
-				      Vect_subst_var(OFi->database, &Out),
-				      OFi->table, IFi->key, cats[i],
-				      ncats[i]);
-	    if (ret == DB_FAILED) {
-		G_warning(_("Cannot copy table"));
-	    else {
-		Vect_map_add_dblink(&Out, OFi->number, OFi->name, OFi->table,
-				    IFi->key, OFi->database, OFi->driver);
-	    G_done_msg(" ");
-    Vect_close(&In);
-    Vect_build(&Out);
-    Vect_close(&Out);
