[GRASS-SVN] r35469 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jan 17 15:13:38 EST 2009
Author: martinl
Date: 2009-01-17 15:13:38 -0500 (Sat, 17 Jan 2009)
New Revision: 35469
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI: fix vector map querying
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-01-17 19:15:47 UTC (rev 35468)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-01-17 20:13:38 UTC (rev 35469)
@@ -3356,7 +3356,10 @@
if ret:
readAttrb = False
for item in ret.splitlines():
- key, value = item.split(':', 1)
+ try:
+ key, value = item.split(':', 1)
+ except ValueError:
+ continue
if key == 'Layer' and readAttrb:
readAttrb = False
@@ -3364,6 +3367,7 @@
if readAttrb:
name, value = item.split(':', 1)
name = name.strip()
+ value = value.strip()
# append value to the column
if len(value) < 1:
value = None
