[GRASS-SVN] r35534 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Jan 21 12:57:15 EST 2009
Author: martinl
Date: 2009-01-21 12:57:15 -0500 (Wed, 21 Jan 2009)
New Revision: 35534
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: fix layer > 1
       (merge from trunk, r35533)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2009-01-21 17:54:08 UTC (rev 35533)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2009-01-21 17:57:15 UTC (rev 35534)
@@ -1327,8 +1327,7 @@
         # set widget relations for OnUpdateSelection
         pMap = None
-        pLayer = None
-        pLayerList = []
+        pLayer = []
         pDriver = None
         pDatabase = None
         pTable = None
@@ -1344,11 +1343,9 @@
                 if name in ('map', 'input'):
                     pMap = p
             elif prompt == 'layer':
-                pLayerList.append(p['wxId'])
-                if not pLayer: # TODO: check all 'layer' options
-                    pLayer = p
+                pLayer.append(p)
             elif prompt == 'dbcolumn':
-                pColumn.append(p['wxId'])
+                pColumn.append(p)
             elif prompt == 'dbdriver':
                 pDriver = p
             elif prompt == 'dbname':
@@ -1356,13 +1353,20 @@
             elif prompt == 'dbtable':
                 pTable = p
+        pColumnIds = []
+        for p in pColumn:
+            pColumnIds.append(p['wxId'])
+        pLayerIds = []
+        for p in pLayer:
+            pLayerIds.append(p['wxId'])
         if pMap:
-            pMap['wxId-bind'] = copy.copy(pColumn)
+            pMap['wxId-bind'] = copy.copy(pColumnIds)
             if pLayer:
-                pMap['wxId-bind'] += pLayerList
+                pMap['wxId-bind'] += pLayerIds
-        if pLayer:
-            p['wxId-bind'] = pColumn
+        for p in pLayer:
+            p['wxId-bind'] = copy.copy(pColumnIds)
         if pDriver and pTable:
             pDriver['wxId-bind'] = [pTable['wxId'], ]
@@ -1537,6 +1541,7 @@
             id = event.GetId()
         p = self.task.get_param(id, element='wxId', raiseError=False)
         if not p or \
                 not p.has_key('wxId-bind'):
             return
