[GRASS-SVN] r35561 - in grass-addons/LandDyn: . r.levol.iterato.py
Fri Jan 23 15:28:36 EST 2009
Author: isaacullah
Date: 2009-01-23 15:28:36 -0500 (Fri, 23 Jan 2009)
New Revision: 35561
Added:
   grass-addons/LandDyn/r.levol.iterato.py/
   grass-addons/LandDyn/r.levol.iterato.py/r.levol.iterator.py
Removed:
   grass-addons/LandDyn/r.levol.iterator.py
moved script to own folder
Added: grass-addons/LandDyn/r.levol.iterato.py/r.levol.iterator.py
--- grass-addons/LandDyn/r.levol.iterato.py/r.levol.iterator.py	                        (rev 0)
+++ grass-addons/LandDyn/r.levol.iterato.py/r.levol.iterator.py	2009-01-23 20:28:36 UTC (rev 35561)
@@ -0,0 +1,368 @@
+#!/usr/bin/python
+# MODULE:       r.levol.it.cfct.py
+# AUTHOR(S):    iullah
+# COPYRIGHT:    (C) 2007 GRASS Development Team/iullah
+#  description: Create raster maps of net erosion/depostion, the modified terrain surface (DEM) after net erosion/deposition using the USPED equation, bedrock elevations after soil production, and soil depth maps. This module uses appropriate flow on different landforms by default; however, singular flow regimes can be chosen instead. THIS SCRIPT WILL PRODUCE MANY TEMPORARY MAPS AND REQUIRES A LOT OF FREE FILE SPACE! Note that all flags are disabled! Currently flags -z -b -n -f are hard coded to run by default.
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#% description: Create raster maps of net erosion/depostion, the modified terrain surface (DEM) after net erosion/deposition using the USPED equation, bedrock elevations after soil production, and soil depth maps. This module uses appropriate flow on different landforms by default; however, singular flow regimes can be chosen instead. THIS SCRIPT WILL PRODUCE MANY TEMPORARY MAPS AND REQUIRES A LOT OF FREE FILE SPACE! Note that all flags are disabled! Currently flags -z -b -n -f are hard coded to run by default.
+#%End
+#%Flag
+#% key: l
+#% description: -l Do not output maps of soil depths
+#% guisection: Input
+#%End
+#%Flag
+#% key: k
+#% description: -k Keep all intermediate files as well
+#%End
+#%Flag
+#% key: e
+#% description: -e Keep initial soil depths map
+#%End
+#%Flag
+#% key: z
+#% description: -z Keep region zoomed to output maps
+#% answer: 1
+#%End
+#%Flag
+#% key: b
+#% description: -b Use static bedrock elavations (do not create new soil)
+#% answer: 1
+#%End
+#%Flag
+#% key: y
+#% description: -y Don't smooth the map (faster, but spikes in erosion/deposition may result)
+#% guisection: Smoothing_Filter
+#%End
+#%Flag
+#% key: n
+#% description: -n Output maps of net erosion/deposition for ever year
+#% answer: 1
+#% guisection: Statistics
+#%End
+#%Flag
+#% key: c
+#% description: -c Output cumulative erosion/deposition map from data for all iterations
+#%End
+#%Flag
+#% key: m
+#% description: -m Output mean erosion/depostition map from data for all iterations (must check -n as well)
+#%End
+#%Flag
+#% key: t
+#% description: -t Output standard deviation of erosion/depostition map from data for all iterations (must check -n as well)
+#%End
+#%Flag
+#% key: s
+#% description: -s Output mean soil depths map from data for all iterations
+#%End
+#%Flag
+#% key: v
+#% description: -v Output standard deviation soil depths map from data for all iterations
+#%End
+#%Flag
+#% key: a
+#% description: -a Output maximum soil depths map from data for all iterations
+#%End
+#%Flag
+#% key: u
+#% description: -u Output minimum soil depths map from data for all iterations
+#%End
+#%Flag
+#% key: w
+#% description: -w Calcuate for only sheetwash across entire map
+#% guisection: Flow_type
+#%End
+#%Flag
+#% key: r
+#% description: -r Calcuate for only channelized flow across entire map
+#%End
+#%Flag
+#% key: d
+#% description: -d Calcuate for only diffusive flow (soil creep) across entire map
+#%End
+#%Flag
+#% key: f
+#% description: -f Use r.terrflow instead of r.flow to calculate flow accumulation (better for massive grids)
+#%End
+#%Option
+#% key: elev
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Input elevation map (DEM)
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: initbdrk
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Initial bedrock elevations map (for first iteration only)
+#% answer:
+#%End
+#%Option
+#% key: prefx
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Prefix for all output maps
+#% answer: usped_
+#%End
+#%Option
+#% key: outdem
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Name stem for output elevation map(s) (preceded by prefix and followed by numerical suffix if more than one iteration)
+#% answer: elevation
+#% gisprompt: string
+#%End
+#%Option
+#% key: outsoil
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Name stem for the output soil depth map(s) (preceded by prefix and followed by numerical suffix if more than one iteration)
+#% answer: soildepth
+#%End
+#%Option
+#% key: outbdrk
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Name stem for the output bedrock map(s) (required if the -b option is NOT checked; preceded by prefix and followed by numerical suffix if more than one iteration)
+#% answer: bedrock
+#%End
+#%Option
+#% key: statsout
+#% type: string
+#% description: Name for the statsout text file (optional, if none provided, a default name will be used)
+#% required: no
+#%end
+#%flag
+#% key: g
+#% description: -g do not put header on statsout text file and always append data, even if file already exists (useful if script is being run by an outside program)
+#%answer: 1
+#%end
+#%Option
+#% key: R
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Rainfall (R factor) constant (AVERAGE FOR WHOLE MAP AREA)
+#% answer: 5
+#% guisection: Variables
+#%End
+#%Option
+#% key: K
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Soil erodability index (K factor) map or constant
+#% answer: 0.32
+#%End
+#%option
+#% key: sdensity
+#% type: string
+#% description: Soil density constant (for conversion from mass to volume)
+#% answer: 1.2184
+#% required : yes
+#%end
+#%Option
+#% key: C
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Prefix for stack of landcover index (C factor) maps (leave off #'s)
+#% answer: 0.01
+#%End
+#%Option
+#% key: kappa
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Hillslope diffusion (Kappa) rate map or constant (meters per kiloyear)
+#% answer: 1
+#%End
+#%Option
+#% key: cutoff1
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Flow accumultion breakpoint value for shift from diffusion to overland flow (number of cells)
+#% answer: 4
+#%End
+#%Option
+#% key: cutoff2
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Flow accumultion breakpoint value for shift from overland flow to channelized flow (number of cells)
+#% answer: 50
+#%End
+#%Option
+#% key: number
+#% type: integer
+#% required: yes
+#% multiple: no
+#% description: number of iterations to run
+#% answer: 1
+#%End
+#%Option
+#% key: nbhood
+#% type: string
+#% required: yes
+#% multiple: no
+#% options: 1,3,5,7,9,11,13,15,17,19,21,23,25
+#% description: Band-pass filter neighborhood size
+#% answer: 7
+#%End
+#%Option
+#% key: method
+#% type: string
+#% required: yes
+#% multiple: no
+#% options: average,median,mode
+#% description: Neighborhood smoothing method
+#% answer: median
+#%End
+import sys
+import os
+import subprocess
+def grass_print(m):
+	subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
+	return
+def main(n, o, p, q):
+	initbdrk = os.getenv("GIS_OPT_initbdrk")
+	outbdrk = "%s_%s" % (os.getenv("GIS_OPT_outbdrk"), o)
+	outdem = "%s_%s" % (os.getenv("GIS_OPT_outdem"), o)
+	outsoil = "%s_%s" % (os.getenv("GIS_OPT_outsoil"), o)
+	R = os.getenv("GIS_OPT_R")
+	K = os.getenv("GIS_OPT_K")
+	sdensity = os.getenv("GIS_OPT_sdensity")
+	C = "%s_%s" % (os.getenv("GIS_OPT_C"), o)
+	kappa = os.getenv("GIS_OPT_kappa")
+	aplpha = os.getenv("GIS_OPT_method")
+	sigma = os.getenv("GIS_OPT_sigma")
+	nbhood = os.getenv("GIS_OPT_nbhood")
+	cutoff1 = os.getenv("GIS_OPT_cutoff1")
+	cutoff2 = os.getenv("GIS_OPT_cutoff2")
+	method = os.getenv("GIS_OPT_method")
+	years = os.getenv("GIS_OPT_number")
+	letters = list('lkezbyncmtsvauwrdfg')
+	flags = []
+	for letter in letters:
+		flag = "GIS_FLAG_%s" % (letter)
+		if ( os.getenv(flag) == "1" ):
+			flags.append("-" + letter)
+	conditions = ["elev=%s" % n, "initbdrk=%s" % initbdrk, "prefx=%s" % p, "outdem=%s" % outdem,\
+	 "outsoil=%s" % outsoil, "outbdrk=%s" % outbdrk, "statsout=%s" % q, "R=%s" % R, "K=%s" % K, "sdensity=%s" % sdensity, "C=%s" % C,\
+	  "kappa=%s" % kappa, "cutoff1=%s" % cutoff1, "cutoff2=%s" % cutoff2, "number=1", "nbhood=%s" % nbhood,\
+	   "method=%s" % method]
+	sep = ' '
+	flags_string = sep.join(flags)
+	variables_string = sep.join(conditions)
+	command_string = "r.landscape.evol.fast %s %s" % (flags_string, variables_string)
+	#command = ["r.landscape.evol"]
+	#command.extend(flags)
+	#command.extend(conditions)
+	#print command
+	subprocess.Popen(command_string, shell='bash').wait()
+	return	grass_print("Command for previous run: '"'%s'"'" % command_string)
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+	outdem = os.getenv("GIS_OPT_outdem")
+	prefx = os.getenv("GIS_OPT_prefx")
+	if os.getenv("GIS_OPT_statsout") == "":
+		p = subprocess.Popen("g.gisenv get=MAPSET", stdout=subprocess.PIPE, shell='bash')
+		out = p.stdout.read()
+		mapset = out.strip()
+		statsout = '%s_%s_lsevol_stats.txt' % (mapset, prefx)
+		f = file('%s_%s_lsevol_stats.txt' % (mapset, prefx), 'wt')
+	else:
+		statsout = os.getenv("GIS_OPT_statsout")
+		f = file(os.getenv("GIS_OPT_statsout"), 'wt')
+	grass_print("Total number of Python iterated iterations to be run is %s years" % years)
+	f.write('Year,,Mean Erosion,Max Erosion,Min Erosion,99th Percentile Erosion,,Mean Deposition,Min Deposition,Max Deposition,99th Percentile Deposition,,Mean Soil Depth,Min Soil Depth,Max Soil Depth,99th Percentile Soil Depth')
+	f.close()
+	for x in range(int(years)):
+		grass_print("REAL YEAR = %s" % (x + 1))
+		if ( x == 0 ):
+			elev_in = os.getenv("GIS_OPT_elev")
+		else:
+			elev_in = "%s%s_%s" % (prefx, outdem, x)
+		main(elev_in, (x + 1), prefx, statsout);
+grass_print("All Python iterated iterations complete! Have a nice day!")
Property changes on: grass-addons/LandDyn/r.levol.iterato.py/r.levol.iterator.py
___________________________________________________________________
Deleted: grass-addons/LandDyn/r.levol.iterator.py
--- grass-addons/LandDyn/r.levol.iterator.py	2009-01-23 20:26:29 UTC (rev 35560)
+++ grass-addons/LandDyn/r.levol.iterator.py	2009-01-23 20:28:36 UTC (rev 35561)
@@ -1,368 +0,0 @@
-#!/usr/bin/python
-# MODULE:       r.levol.it.cfct.py
-# AUTHOR(S):    iullah
-# COPYRIGHT:    (C) 2007 GRASS Development Team/iullah
-#  description: Create raster maps of net erosion/depostion, the modified terrain surface (DEM) after net erosion/deposition using the USPED equation, bedrock elevations after soil production, and soil depth maps. This module uses appropriate flow on different landforms by default; however, singular flow regimes can be chosen instead. THIS SCRIPT WILL PRODUCE MANY TEMPORARY MAPS AND REQUIRES A LOT OF FREE FILE SPACE! Note that all flags are disabled! Currently flags -z -b -n -f are hard coded to run by default.
-#  This program is free software; you can redistribute it and/or modify
-#  it under the terms of the GNU General Public License as published by
-#  the Free Software Foundation; either version 2 of the License, or
-#  (at your option) any later version.
-#  This program is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#  GNU General Public License for more details.
-#%Module
-#% description: Create raster maps of net erosion/depostion, the modified terrain surface (DEM) after net erosion/deposition using the USPED equation, bedrock elevations after soil production, and soil depth maps. This module uses appropriate flow on different landforms by default; however, singular flow regimes can be chosen instead. THIS SCRIPT WILL PRODUCE MANY TEMPORARY MAPS AND REQUIRES A LOT OF FREE FILE SPACE! Note that all flags are disabled! Currently flags -z -b -n -f are hard coded to run by default.
-#%End
-#%Flag
-#% key: l
-#% description: -l Do not output maps of soil depths
-#% guisection: Input
-#%End
-#%Flag
-#% key: k
-#% description: -k Keep all intermediate files as well
-#%End
-#%Flag
-#% key: e
-#% description: -e Keep initial soil depths map
-#%End
-#%Flag
-#% key: z
-#% description: -z Keep region zoomed to output maps
-#% answer: 1
-#%End
-#%Flag
-#% key: b
-#% description: -b Use static bedrock elavations (do not create new soil)
-#% answer: 1
-#%End
-#%Flag
-#% key: y
-#% description: -y Don't smooth the map (faster, but spikes in erosion/deposition may result)
-#% guisection: Smoothing_Filter
-#%End
-#%Flag
-#% key: n
-#% description: -n Output maps of net erosion/deposition for ever year
-#% answer: 1
-#% guisection: Statistics
-#%End
-#%Flag
-#% key: c
-#% description: -c Output cumulative erosion/deposition map from data for all iterations
-#%End
-#%Flag
-#% key: m
-#% description: -m Output mean erosion/depostition map from data for all iterations (must check -n as well)
-#%End
-#%Flag
-#% key: t
-#% description: -t Output standard deviation of erosion/depostition map from data for all iterations (must check -n as well)
-#%End
-#%Flag
-#% key: s
-#% description: -s Output mean soil depths map from data for all iterations
-#%End
-#%Flag
-#% key: v
-#% description: -v Output standard deviation soil depths map from data for all iterations
-#%End
-#%Flag
-#% key: a
-#% description: -a Output maximum soil depths map from data for all iterations
-#%End
-#%Flag
-#% key: u
-#% description: -u Output minimum soil depths map from data for all iterations
-#%End
-#%Flag
-#% key: w
-#% description: -w Calcuate for only sheetwash across entire map
-#% guisection: Flow_type
-#%End
-#%Flag
-#% key: r
-#% description: -r Calcuate for only channelized flow across entire map
-#%End
-#%Flag
-#% key: d
-#% description: -d Calcuate for only diffusive flow (soil creep) across entire map
-#%End
-#%Flag
-#% key: f
-#% description: -f Use r.terrflow instead of r.flow to calculate flow accumulation (better for massive grids)
-#%End
-#%Option
-#% key: elev
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Input elevation map (DEM)
-#% gisprompt: old,cell,raster
-#%End
-#%Option
-#% key: initbdrk
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Initial bedrock elevations map (for first iteration only)
-#% answer:
-#%End
-#%Option
-#% key: prefx
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Prefix for all output maps
-#% answer: usped_
-#%End
-#%Option
-#% key: outdem
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Name stem for output elevation map(s) (preceded by prefix and followed by numerical suffix if more than one iteration)
-#% answer: elevation
-#% gisprompt: string
-#%End
-#%Option
-#% key: outsoil
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Name stem for the output soil depth map(s) (preceded by prefix and followed by numerical suffix if more than one iteration)
-#% answer: soildepth
-#%End
-#%Option
-#% key: outbdrk
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name stem for the output bedrock map(s) (required if the -b option is NOT checked; preceded by prefix and followed by numerical suffix if more than one iteration)
-#% answer: bedrock
-#%End
-#%Option
-#% key: statsout
-#% type: string
-#% description: Name for the statsout text file (optional, if none provided, a default name will be used)
-#% required: no
-#%end
-#%flag
-#% key: g
-#% description: -g do not put header on statsout text file and always append data, even if file already exists (useful if script is being run by an outside program)
-#%answer: 1
-#%end
-#%Option
-#% key: R
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Rainfall (R factor) constant (AVERAGE FOR WHOLE MAP AREA)
-#% answer: 5
-#% guisection: Variables
-#%End
-#%Option
-#% key: K
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Soil erodability index (K factor) map or constant
-#% answer: 0.32
-#%End
-#%option
-#% key: sdensity
-#% type: string
-#% description: Soil density constant (for conversion from mass to volume)
-#% answer: 1.2184
-#% required : yes
-#%end
-#%Option
-#% key: C
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Prefix for stack of landcover index (C factor) maps (leave off #'s)
-#% answer: 0.01
-#%End
-#%Option
-#% key: kappa
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Hillslope diffusion (Kappa) rate map or constant (meters per kiloyear)
-#% answer: 1
-#%End
-#%Option
-#% key: cutoff1
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Flow accumultion breakpoint value for shift from diffusion to overland flow (number of cells)
-#% answer: 4
-#%End
-#%Option
-#% key: cutoff2
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Flow accumultion breakpoint value for shift from overland flow to channelized flow (number of cells)
-#% answer: 50
-#%End
-#%Option
-#% key: number
-#% type: integer
-#% required: yes
-#% multiple: no
-#% description: number of iterations to run
-#% answer: 1
-#%End
-#%Option
-#% key: nbhood
-#% type: string
-#% required: yes
-#% multiple: no
-#% options: 1,3,5,7,9,11,13,15,17,19,21,23,25
-#% description: Band-pass filter neighborhood size
-#% answer: 7
-#%End
-#%Option
-#% key: method
-#% type: string
-#% required: yes
-#% multiple: no
-#% options: average,median,mode
-#% description: Neighborhood smoothing method
-#% answer: median
-#%End
-import sys
-import os
-import subprocess
-def grass_print(m):
-	subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
-	return
-def main(n, o, p, q):
-	initbdrk = os.getenv("GIS_OPT_initbdrk")
-	outbdrk = "%s_%s" % (os.getenv("GIS_OPT_outbdrk"), o)
-	outdem = "%s_%s" % (os.getenv("GIS_OPT_outdem"), o)
-	outsoil = "%s_%s" % (os.getenv("GIS_OPT_outsoil"), o)
-	R = os.getenv("GIS_OPT_R")
-	K = os.getenv("GIS_OPT_K")
-	sdensity = os.getenv("GIS_OPT_sdensity")
-	C = "%s_%s" % (os.getenv("GIS_OPT_C"), o)
-	kappa = os.getenv("GIS_OPT_kappa")
-	aplpha = os.getenv("GIS_OPT_method")
-	sigma = os.getenv("GIS_OPT_sigma")
-	nbhood = os.getenv("GIS_OPT_nbhood")
-	cutoff1 = os.getenv("GIS_OPT_cutoff1")
-	cutoff2 = os.getenv("GIS_OPT_cutoff2")
-	method = os.getenv("GIS_OPT_method")
-	years = os.getenv("GIS_OPT_number")
-	letters = list('lkezbyncmtsvauwrdfg')
-	flags = []
-	for letter in letters:
-		flag = "GIS_FLAG_%s" % (letter)
-		if ( os.getenv(flag) == "1" ):
-			flags.append("-" + letter)
-	conditions = ["elev=%s" % n, "initbdrk=%s" % initbdrk, "prefx=%s" % p, "outdem=%s" % outdem,\
-	 "outsoil=%s" % outsoil, "outbdrk=%s" % outbdrk, "statsout=%s" % q, "R=%s" % R, "K=%s" % K, "sdensity=%s" % sdensity, "C=%s" % C,\
-	  "kappa=%s" % kappa, "cutoff1=%s" % cutoff1, "cutoff2=%s" % cutoff2, "number=1", "nbhood=%s" % nbhood,\
-	   "method=%s" % method]
-	sep = ' '
-	flags_string = sep.join(flags)
-	variables_string = sep.join(conditions)
-	command_string = "r.landscape.evol.fast %s %s" % (flags_string, variables_string)
-	#command = ["r.landscape.evol"]
-	#command.extend(flags)
-	#command.extend(conditions)
-	#print command
-	subprocess.Popen(command_string, shell='bash').wait()
-	return	grass_print("Command for previous run: '"'%s'"'" % command_string)
-if __name__ == "__main__":
-    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
-        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
-    else:
-	outdem = os.getenv("GIS_OPT_outdem")
-	prefx = os.getenv("GIS_OPT_prefx")
-	if os.getenv("GIS_OPT_statsout") == "":
-		p = subprocess.Popen("g.gisenv get=MAPSET", stdout=subprocess.PIPE, shell='bash')
-		out = p.stdout.read()
-		mapset = out.strip()
-		statsout = '%s_%s_lsevol_stats.txt' % (mapset, prefx)
-		f = file('%s_%s_lsevol_stats.txt' % (mapset, prefx), 'wt')
-	else:
-		statsout = os.getenv("GIS_OPT_statsout")
-		f = file(os.getenv("GIS_OPT_statsout"), 'wt')
-	grass_print("Total number of Python iterated iterations to be run is %s years" % years)
-	f.write('Year,,Mean Erosion,Max Erosion,Min Erosion,99th Percentile Erosion,,Mean Deposition,Min Deposition,Max Deposition,99th Percentile Deposition,,Mean Soil Depth,Min Soil Depth,Max Soil Depth,99th Percentile Soil Depth')
-	f.close()
-	for x in range(int(years)):
-		grass_print("REAL YEAR = %s" % (x + 1))
-		if ( x == 0 ):
-			elev_in = os.getenv("GIS_OPT_elev")
-		else:
-			elev_in = "%s%s_%s" % (prefx, outdem, x)
-		main(elev_in, (x + 1), prefx, statsout);
-grass_print("All Python iterated iterations complete! Have a nice day!")
