[GRASS-SVN] r35578 - in grass/branches/releasebranch_6_4: . include/Make
Sat Jan 24 11:11:49 EST 2009
Author: neteler
Date: 2009-01-24 11:11:49 -0500 (Sat, 24 Jan 2009)
New Revision: 35578
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
   grass/branches/releasebranch_6_4/include/Make/Platform.make.in
save TCL version number in include/Make/Platform.make[.in] for Tcl86 check (not for GRASS 7 since TclTk eliminated there)
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2009-01-24 16:11:29 UTC (rev 35577)
+++ grass/branches/releasebranch_6_4/configure	2009-01-24 16:11:49 UTC (rev 35578)
@@ -8801,9 +8801,8 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8807: checking Tcl version" >&5
+echo "configure:8806: checking Tcl version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8811,7 +8810,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
   cat > conftest.$ac_ext <<EOF
-#line 8815 "configure"
+#line 8814 "configure"
 #include "confdefs.h"
 #include <stdio.h>
@@ -8823,7 +8822,7 @@
 EOF
-if { (eval echo configure:8827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8841,7 +8840,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8845: checking Tk version" >&5
+echo "configure:8844: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8849,7 +8848,7 @@
 else
-#line 8853 "configure"
+#line 8852 "configure"
 #include <stdio.h>
@@ -8861,7 +8860,7 @@
 EOF
-if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8883,6 +8882,8 @@
     { echo "configure: error: *** Tcl/Tk version mismatch." 1>&2; exit 1; }
 fi
+TCL_VERSION="$tcl_ver"
 # FreeBSD and CygWin don't have a "dot" between major/minor version number
 tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
@@ -8890,7 +8891,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8894: checking for location of Tcl/Tk library" >&5
+echo "configure:8895: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8920,13 +8921,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8924: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8925: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8930 "configure"
+#line 8931 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -8937,7 +8938,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8956,13 +8957,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:8960: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8961: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8966 "configure"
+#line 8967 "configure"
@@ -8973,7 +8974,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9000,13 +9001,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9004: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9005: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 9010 "configure"
+#line 9011 "configure"
@@ -9017,7 +9018,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9036,13 +9037,13 @@
-echo "configure:9040: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9041: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 9046 "configure"
+#line 9047 "configure"
@@ -9053,7 +9054,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9080,13 +9081,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9084: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9085: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 9090 "configure"
+#line 9091 "configure"
@@ -9097,7 +9098,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9116,13 +9117,13 @@
-echo "configure:9120: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9121: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9126 "configure"
+#line 9127 "configure"
@@ -9133,7 +9134,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9211,13 +9212,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9215: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9216: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9221 "configure"
+#line 9222 "configure"
@@ -9228,7 +9229,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9247,13 +9248,13 @@
-echo "configure:9251: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9252: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9257 "configure"
+#line 9258 "configure"
@@ -9264,7 +9265,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9291,13 +9292,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9295: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9296: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9301 "configure"
+#line 9302 "configure"
@@ -9308,7 +9309,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9327,13 +9328,13 @@
-echo "configure:9331: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9332: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9337 "configure"
+#line 9338 "configure"
@@ -9344,7 +9345,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9371,13 +9372,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9375: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9376: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9381 "configure"
+#line 9382 "configure"
@@ -9388,7 +9389,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9407,13 +9408,13 @@
-echo "configure:9411: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9412: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9417 "configure"
+#line 9418 "configure"
@@ -9424,7 +9425,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9516,7 +9517,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9520: checking whether to use PostgreSQL" >&5
+echo "configure:9521: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9543,7 +9544,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9547: checking for location of PostgreSQL includes" >&5
+echo "configure:9548: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9569,15 +9570,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9573: checking for $ac_hdr" >&5
+echo "configure:9574: checking for $ac_hdr" >&5
-#line 9576 "configure"
+#line 9577 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:9581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -9615,7 +9616,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9619: checking for location of PostgreSQL library" >&5
+echo "configure:9620: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9644,13 +9645,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9648: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9649: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9654 "configure"
+#line 9655 "configure"
@@ -9661,7 +9662,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9680,13 +9681,13 @@
-echo "configure:9684: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9685: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9690 "configure"
+#line 9691 "configure"
@@ -9697,7 +9698,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9716,13 +9717,13 @@
-echo "configure:9720: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9721: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9726 "configure"
+#line 9727 "configure"
@@ -9733,7 +9734,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9752,13 +9753,13 @@
-echo "configure:9756: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9757: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9762 "configure"
+#line 9763 "configure"
@@ -9769,7 +9770,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9826,13 +9827,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9830: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9831: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9836 "configure"
+#line 9837 "configure"
@@ -9843,7 +9844,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9865,13 +9866,13 @@
-echo "configure:9869: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9870: checking for PQcmdTuples in -lpq" >&5
-#line 9875 "configure"
+#line 9876 "configure"
@@ -9882,7 +9883,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9925,7 +9926,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9929: checking whether to use MySQL" >&5
+echo "configure:9930: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9945,7 +9946,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9949: checking for location of MySQL includes" >&5
+echo "configure:9950: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9971,15 +9972,15 @@
 do
-echo "configure:9975: checking for $ac_hdr" >&5
+echo "configure:9976: checking for $ac_hdr" >&5
-#line 9978 "configure"
+#line 9979 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10016,7 +10017,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:10020: checking for location of MySQL library" >&5
+echo "configure:10021: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -10047,13 +10048,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:10051: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10052: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 10057 "configure"
+#line 10058 "configure"
@@ -10064,7 +10065,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10083,13 +10084,13 @@
-echo "configure:10087: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10088: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10093 "configure"
+#line 10094 "configure"
@@ -10100,7 +10101,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10119,13 +10120,13 @@
-echo "configure:10123: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10124: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10129 "configure"
+#line 10130 "configure"
@@ -10136,7 +10137,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10155,13 +10156,13 @@
-echo "configure:10159: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10160: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10165 "configure"
+#line 10166 "configure"
@@ -10172,7 +10173,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10191,13 +10192,13 @@
-echo "configure:10195: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10196: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10201 "configure"
+#line 10202 "configure"
@@ -10208,7 +10209,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10227,13 +10228,13 @@
-echo "configure:10231: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10232: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10237 "configure"
+#line 10238 "configure"
@@ -10244,7 +10245,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10263,13 +10264,13 @@
-echo "configure:10267: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10268: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10273 "configure"
+#line 10274 "configure"
@@ -10280,7 +10281,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10299,13 +10300,13 @@
-echo "configure:10303: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10304: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10309 "configure"
+#line 10310 "configure"
@@ -10316,7 +10317,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10406,7 +10407,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10410: checking for $ac_word" >&5
+echo "configure:10411: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10447,10 +10448,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10451: checking for mysql_server_init" >&5
+echo "configure:10452: checking for mysql_server_init" >&5
-#line 10454 "configure"
+#line 10455 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10473,7 +10474,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10511,7 +10512,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10515: checking whether to use SQLite" >&5
+echo "configure:10516: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10531,7 +10532,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10535: checking for location of SQLite includes" >&5
+echo "configure:10536: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10557,15 +10558,15 @@
 do
-echo "configure:10561: checking for $ac_hdr" >&5
+echo "configure:10562: checking for $ac_hdr" >&5
-#line 10564 "configure"
+#line 10565 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10608,7 +10609,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10612: checking for location of SQLite library" >&5
+echo "configure:10613: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10635,13 +10636,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10639: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10640: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10645 "configure"
+#line 10646 "configure"
@@ -10652,7 +10653,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10671,13 +10672,13 @@
-echo "configure:10675: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10676: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10681 "configure"
+#line 10682 "configure"
@@ -10688,7 +10689,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10741,7 +10742,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10745: checking whether to use FFMPEG" >&5
+echo "configure:10746: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10761,7 +10762,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10765: checking for location of FFMPEG includes" >&5
+echo "configure:10766: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10787,15 +10788,15 @@
 do
-echo "configure:10791: checking for $ac_hdr" >&5
+echo "configure:10792: checking for $ac_hdr" >&5
-#line 10794 "configure"
+#line 10795 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10831,15 +10832,15 @@
 do
-echo "configure:10835: checking for $ac_hdr" >&5
+echo "configure:10836: checking for $ac_hdr" >&5
-#line 10838 "configure"
+#line 10839 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10875,15 +10876,15 @@
 do
-echo "configure:10879: checking for $ac_hdr" >&5
+echo "configure:10880: checking for $ac_hdr" >&5
-#line 10882 "configure"
+#line 10883 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10926,7 +10927,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10930: checking for location of FFMPEG library" >&5
+echo "configure:10931: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10953,13 +10954,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10957: checking for av_free in -lavutil" >&5
+echo "configure:10958: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10963 "configure"
+#line 10964 "configure"
@@ -10970,7 +10971,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10989,13 +10990,13 @@
-echo "configure:10993: checking for av_free in -lavutil" >&5
+echo "configure:10994: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10999 "configure"
+#line 11000 "configure"
@@ -11006,7 +11007,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11051,13 +11052,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:11055: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11056: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 11061 "configure"
+#line 11062 "configure"
@@ -11068,7 +11069,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11087,13 +11088,13 @@
-echo "configure:11091: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11092: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11097 "configure"
+#line 11098 "configure"
@@ -11104,7 +11105,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11149,13 +11150,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11153: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11154: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11159 "configure"
+#line 11160 "configure"
@@ -11166,7 +11167,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11185,13 +11186,13 @@
-echo "configure:11189: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11190: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11195 "configure"
+#line 11196 "configure"
@@ -11202,7 +11203,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11262,7 +11263,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11266: checking whether to use OpenGL" >&5
+echo "configure:11267: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11296,7 +11297,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11300: checking for location of OpenGL includes" >&5
+echo "configure:11301: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11322,15 +11323,15 @@
 do
-echo "configure:11326: checking for $ac_hdr" >&5
+echo "configure:11327: checking for $ac_hdr" >&5
-#line 11329 "configure"
+#line 11330 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11364,7 +11365,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11368: checking for location of OpenGL library" >&5
+echo "configure:11369: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11393,13 +11394,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11397: checking for glBegin in -lGL" >&5
+echo "configure:11398: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11403 "configure"
+#line 11404 "configure"
@@ -11410,7 +11411,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11429,13 +11430,13 @@
-echo "configure:11433: checking for glBegin in -lGL" >&5
+echo "configure:11434: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11439 "configure"
+#line 11440 "configure"
@@ -11446,7 +11447,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11465,13 +11466,13 @@
-echo "configure:11469: checking for glBegin in -lGL" >&5
+echo "configure:11470: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11475 "configure"
+#line 11476 "configure"
@@ -11482,7 +11483,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11501,13 +11502,13 @@
-echo "configure:11505: checking for glBegin in -lGL" >&5
+echo "configure:11506: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11511 "configure"
+#line 11512 "configure"
@@ -11518,7 +11519,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11580,13 +11581,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11584: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11585: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11590 "configure"
+#line 11591 "configure"
@@ -11597,7 +11598,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11616,13 +11617,13 @@
-echo "configure:11620: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11621: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11626 "configure"
+#line 11627 "configure"
@@ -11633,7 +11634,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11677,10 +11678,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11681: checking for glXCreatePbuffer" >&5
+echo "configure:11682: checking for glXCreatePbuffer" >&5
-#line 11684 "configure"
+#line 11685 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11703,7 +11704,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11725,10 +11726,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11729: checking for glXCreateGLXPixmap" >&5
+echo "configure:11730: checking for glXCreateGLXPixmap" >&5
-#line 11732 "configure"
+#line 11733 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11751,7 +11752,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11790,7 +11791,7 @@
-echo "configure:11794: checking for location of OpenGL includes" >&5
+echo "configure:11795: checking for location of OpenGL includes" >&5
@@ -11816,15 +11817,15 @@
 do
-echo "configure:11820: checking for $ac_hdr" >&5
+echo "configure:11821: checking for $ac_hdr" >&5
-#line 11823 "configure"
+#line 11824 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11829: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11859,10 +11860,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11863: checking for glBegin" >&5
+echo "configure:11864: checking for glBegin" >&5
-#line 11866 "configure"
+#line 11867 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11885,7 +11886,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11900,10 +11901,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11904: checking for gluBeginCurve" >&5
+echo "configure:11905: checking for gluBeginCurve" >&5
-#line 11907 "configure"
+#line 11908 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11926,7 +11927,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11970,7 +11971,7 @@
-echo "configure:11974: checking for location of OpenGL includes" >&5
+echo "configure:11975: checking for location of OpenGL includes" >&5
@@ -11996,15 +11997,15 @@
 do
-echo "configure:12000: checking for $ac_hdr" >&5
+echo "configure:12001: checking for $ac_hdr" >&5
-#line 12003 "configure"
+#line 12004 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12038,7 +12039,7 @@
-echo "configure:12042: checking for location of OpenGL library" >&5
+echo "configure:12043: checking for location of OpenGL library" >&5
@@ -12063,18 +12064,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12067: checking for OpenGL library" >&5
+echo "configure:12068: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 12071 "configure"
+#line 12072 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -12098,18 +12099,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12102: checking for GLU library" >&5
+echo "configure:12103: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 12106 "configure"
+#line 12107 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12158,7 +12159,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12162: checking whether to use ODBC" >&5
+echo "configure:12163: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12177,7 +12178,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12181: checking for location of ODBC includes" >&5
+echo "configure:12182: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12203,15 +12204,15 @@
 do
-echo "configure:12207: checking for $ac_hdr" >&5
+echo "configure:12208: checking for $ac_hdr" >&5
-#line 12210 "configure"
+#line 12211 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12245,7 +12246,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12249: checking for location of ODBC library" >&5
+echo "configure:12250: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12270,13 +12271,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12274: checking for SQLConnect in -lodbc" >&5
+echo "configure:12275: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12280 "configure"
+#line 12281 "configure"
@@ -12287,7 +12288,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12312,13 +12313,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12316: checking for SQLConnect in -liodbc" >&5
+echo "configure:12317: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12322 "configure"
+#line 12323 "configure"
@@ -12329,7 +12330,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12354,11 +12355,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12358: checking for ODBC library" >&5
+echo "configure:12359: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12362 "configure"
+#line 12363 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12366,7 +12367,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12415,7 +12416,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12419: checking whether to use FFTW" >&5
+echo "configure:12420: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12434,7 +12435,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12438: checking for location of FFTW includes" >&5
+echo "configure:12439: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12460,15 +12461,15 @@
 do
-echo "configure:12464: checking for $ac_hdr" >&5
+echo "configure:12465: checking for $ac_hdr" >&5
-#line 12467 "configure"
+#line 12468 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12473: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12496,15 +12497,15 @@
 do
-echo "configure:12500: checking for $ac_hdr" >&5
+echo "configure:12501: checking for $ac_hdr" >&5
-#line 12503 "configure"
+#line 12504 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12532,15 +12533,15 @@
 do
-echo "configure:12536: checking for $ac_hdr" >&5
+echo "configure:12537: checking for $ac_hdr" >&5
-#line 12539 "configure"
+#line 12540 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12586,7 +12587,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12590: checking for location of FFTW library" >&5
+echo "configure:12591: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12611,13 +12612,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12615: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12616: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12621 "configure"
+#line 12622 "configure"
@@ -12628,7 +12629,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12653,13 +12654,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12657: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12658: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12663 "configure"
+#line 12664 "configure"
@@ -12670,7 +12671,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12695,13 +12696,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12699: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12700: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12705 "configure"
+#line 12706 "configure"
@@ -12712,7 +12713,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12769,7 +12770,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12773: checking whether to use BLAS" >&5
+echo "configure:12774: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12790,7 +12791,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12794: checking for location of BLAS includes" >&5
+echo "configure:12795: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12810,7 +12811,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12814: checking for location of BLAS library" >&5
+echo "configure:12815: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12836,15 +12837,15 @@
 do
-echo "configure:12840: checking for $ac_hdr" >&5
+echo "configure:12841: checking for $ac_hdr" >&5
-#line 12843 "configure"
+#line 12844 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12848: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12879,13 +12880,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12883: checking for dnrm2_ in -lblas" >&5
+echo "configure:12884: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12889 "configure"
+#line 12890 "configure"
@@ -12896,7 +12897,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12915,13 +12916,13 @@
-echo "configure:12919: checking for dnrm2_ in -lblas" >&5
+echo "configure:12920: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12925 "configure"
+#line 12926 "configure"
@@ -12932,7 +12933,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12976,13 +12977,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12980: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12981: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12986 "configure"
+#line 12987 "configure"
@@ -12993,7 +12994,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13008,13 +13009,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13012: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13013: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13018 "configure"
+#line 13019 "configure"
@@ -13025,7 +13026,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13040,13 +13041,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13044: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13045: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13050 "configure"
+#line 13051 "configure"
@@ -13057,7 +13058,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13102,16 +13103,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13106: checking for sgemm in $vlib_flags" >&5
+echo "configure:13107: checking for sgemm in $vlib_flags" >&5
-#line 13108 "configure"
+#line 13109 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13129,13 +13130,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13133: checking for sgemm_ in -lblas" >&5
+echo "configure:13134: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13139 "configure"
+#line 13140 "configure"
@@ -13146,7 +13147,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13161,13 +13162,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13165: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13166: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13171 "configure"
+#line 13172 "configure"
@@ -13178,7 +13179,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13193,13 +13194,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13197: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13198: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13203 "configure"
+#line 13204 "configure"
@@ -13210,7 +13211,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13244,13 +13245,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13248: checking for acosp in -lsunmath" >&5
+echo "configure:13249: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13254 "configure"
+#line 13255 "configure"
@@ -13261,7 +13262,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13276,13 +13277,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13280: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13281: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13286 "configure"
+#line 13287 "configure"
@@ -13293,7 +13294,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13323,13 +13324,13 @@
 # Generic BLAS library
-echo "configure:13327: checking for sgemm_ in -lblas" >&5
+echo "configure:13328: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13333 "configure"
+#line 13334 "configure"
@@ -13340,7 +13341,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13379,7 +13380,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13383: checking whether to use LAPACK" >&5
+echo "configure:13384: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13404,7 +13405,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13408: checking for location of LAPACK includes" >&5
+echo "configure:13409: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13424,7 +13425,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13428: checking for location of LAPACK library" >&5
+echo "configure:13429: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13450,15 +13451,15 @@
 do
-echo "configure:13454: checking for $ac_hdr" >&5
+echo "configure:13455: checking for $ac_hdr" >&5
-#line 13457 "configure"
+#line 13458 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13490,10 +13491,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13494: checking for dsegv_" >&5
+echo "configure:13495: checking for dsegv_" >&5
-#line 13497 "configure"
+#line 13498 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13516,7 +13517,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13543,13 +13544,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13547: checking for desgv_ in -llapack" >&5
+echo "configure:13548: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13553 "configure"
+#line 13554 "configure"
@@ -13560,7 +13561,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13592,13 +13593,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13596: checking for dgesv_ in -llapack" >&5
+echo "configure:13597: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13602 "configure"
+#line 13603 "configure"
@@ -13609,7 +13610,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13628,13 +13629,13 @@
-echo "configure:13632: checking for dgesv_ in -llapack" >&5
+echo "configure:13633: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 13638 "configure"
+#line 13639 "configure"
 #include "confdefs.h"
@@ -13645,7 +13646,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13701,7 +13702,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13705: checking whether to use Motif" >&5
+echo "configure:13706: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13720,7 +13721,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13724: checking for location of Motif includes" >&5
+echo "configure:13725: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13746,15 +13747,15 @@
 do
-echo "configure:13750: checking for $ac_hdr" >&5
+echo "configure:13751: checking for $ac_hdr" >&5
-#line 13753 "configure"
+#line 13754 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13788,7 +13789,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13792: checking for location of Motif library" >&5
+echo "configure:13793: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13813,13 +13814,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13817: checking for XmStringCreate in -lXm" >&5
+echo "configure:13818: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13823 "configure"
+#line 13824 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13830,7 +13831,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13871,7 +13872,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13875: checking whether to use Cairo" >&5
+echo "configure:13876: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13897,15 +13898,15 @@
 do
-echo "configure:13901: checking for $ac_hdr" >&5
+echo "configure:13902: checking for $ac_hdr" >&5
-#line 13904 "configure"
+#line 13905 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13942,10 +13943,10 @@
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13946: checking for cairo_create" >&5
+echo "configure:13947: checking for cairo_create" >&5
-#line 13949 "configure"
+#line 13950 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13968,7 +13969,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14003,7 +14004,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14007: checking whether to use GLw" >&5
+echo "configure:14008: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14022,7 +14023,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14026: checking for location of GLw includes" >&5
+echo "configure:14027: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14048,15 +14049,15 @@
 do
-echo "configure:14052: checking for $ac_hdr" >&5
+echo "configure:14053: checking for $ac_hdr" >&5
-#line 14055 "configure"
+#line 14056 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14084,15 +14085,15 @@
 do
-echo "configure:14088: checking for $ac_hdr" >&5
+echo "configure:14089: checking for $ac_hdr" >&5
-#line 14091 "configure"
+#line 14092 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14132,7 +14133,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14136: checking for location of GLw library" >&5
+echo "configure:14137: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14157,13 +14158,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14161: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14162: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14167 "configure"
+#line 14168 "configure"
@@ -14174,7 +14175,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14199,13 +14200,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14203: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14204: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14209 "configure"
+#line 14210 "configure"
@@ -14216,7 +14217,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14241,13 +14242,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14245: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14246: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14251 "configure"
+#line 14252 "configure"
@@ -14258,7 +14259,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14283,13 +14284,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14287: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14288: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14293 "configure"
+#line 14294 "configure"
@@ -14300,7 +14301,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14325,13 +14326,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14329: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14330: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14335 "configure"
+#line 14336 "configure"
@@ -14342,7 +14343,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14367,13 +14368,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14371: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14372: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14377 "configure"
+#line 14378 "configure"
@@ -14384,7 +14385,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14411,13 +14412,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14415: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14416: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14421 "configure"
+#line 14422 "configure"
@@ -14428,7 +14429,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14447,13 +14448,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:14451: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14452: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14457 "configure"
+#line 14458 "configure"
@@ -14464,7 +14465,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14491,13 +14492,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14495: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14496: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14501 "configure"
+#line 14502 "configure"
@@ -14508,7 +14509,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14527,13 +14528,13 @@
-echo "configure:14531: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14532: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14537 "configure"
+#line 14538 "configure"
@@ -14544,7 +14545,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14657,7 +14658,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14661: checking whether to use FreeType" >&5
+echo "configure:14662: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14676,7 +14677,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14680: checking for location of FreeType includes" >&5
+echo "configure:14681: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14702,15 +14703,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14706: checking for $ac_hdr" >&5
+echo "configure:14707: checking for $ac_hdr" >&5
-#line 14709 "configure"
+#line 14710 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14714: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -14744,7 +14745,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14748: checking for location of FreeType library" >&5
+echo "configure:14749: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14769,13 +14770,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14773: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14774: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14779 "configure"
+#line 14780 "configure"
@@ -14786,7 +14787,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14827,7 +14828,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14831: checking whether to use NLS" >&5
+echo "configure:14832: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14847,10 +14848,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14851: checking for gettext" >&5
+echo "configure:14852: checking for gettext" >&5
-#line 14854 "configure"
+#line 14855 "configure"
     which can conflict with char gettext(); below.  */
@@ -14873,7 +14874,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14891,13 +14892,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14895: checking for gettext in -lintl" >&5
+echo "configure:14896: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14901 "configure"
+#line 14902 "configure"
@@ -14908,7 +14909,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14943,7 +14944,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14947: checking whether to use C++" >&5
+echo "configure:14948: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14959,7 +14960,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:14963: checking for $ac_word" >&5
+echo "configure:14964: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14988,7 +14989,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14992: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14993: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14999,12 +15000,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15003 "configure"
+#line 15004 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15030,19 +15031,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15034: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15035: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15039: checking whether we are using GNU C++" >&5
+echo "configure:15040: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15060,7 +15061,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15064: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15065: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15101,7 +15102,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15105: checking whether to use openDWG" >&5
+echo "configure:15106: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15121,7 +15122,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15125: checking for location of openDGW includes" >&5
+echo "configure:15126: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15147,15 +15148,15 @@
 do
-echo "configure:15151: checking for $ac_hdr" >&5
+echo "configure:15152: checking for $ac_hdr" >&5
-#line 15154 "configure"
+#line 15155 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15160: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15189,7 +15190,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15193: checking for location of openDWG library" >&5
+echo "configure:15194: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15236,7 +15237,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15240: checking for special C compiler options needed for large files" >&5
+echo "configure:15241: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15244,7 +15245,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15248 "configure"
+#line 15249 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15260,7 +15261,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15264: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15269,7 +15270,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15273 "configure"
+#line 15274 "configure"
@@ -15285,7 +15286,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15289: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15290: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15305,11 +15306,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15309: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15310: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15313 "configure"
+#line 15314 "configure"
@@ -15325,14 +15326,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15329: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15336 "configure"
+#line 15337 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15350,7 +15351,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15354: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15369,11 +15370,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15373: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15374: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15377 "configure"
+#line 15378 "configure"
@@ -15389,14 +15390,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15393: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15400 "configure"
+#line 15401 "configure"
 #define _LARGE_FILES 1
@@ -15414,7 +15415,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15418: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15419: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15433,25 +15434,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15437: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15438: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15441 "configure"
+#line 15442 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15448: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15455 "configure"
+#line 15456 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15460,7 +15461,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15464: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15465: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15481,10 +15482,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15485: checking if system supports Large Files at all" >&5
+echo "configure:15486: checking if system supports Large Files at all" >&5
-#line 15488 "configure"
+#line 15489 "configure"
 #include <stdio.h>
@@ -15516,7 +15517,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15520: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15521: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15545,7 +15546,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15549: checking whether to use Python" >&5
+echo "configure:15550: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15565,7 +15566,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15569: checking for $ac_word" >&5
+echo "configure:15570: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15610,15 +15611,15 @@
 do
-echo "configure:15614: checking for $ac_hdr" >&5
+echo "configure:15615: checking for $ac_hdr" >&5
-#line 15617 "configure"
+#line 15618 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15623: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15658,7 +15659,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15662: checking for $ac_word" >&5
+echo "configure:15663: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15704,7 +15705,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15708: checking whether to use wxWidgets" >&5
+echo "configure:15709: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15724,7 +15725,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15728: checking for $ac_word" >&5
+echo "configure:15729: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15772,7 +15773,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15776: checking wxWidgets version" >&5
+echo "configure:15777: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15795,15 +15796,15 @@
 do
-echo "configure:15799: checking for $ac_hdr" >&5
+echo "configure:15800: checking for $ac_hdr" >&5
-#line 15802 "configure"
+#line 15803 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15839,15 +15840,15 @@
 do
-echo "configure:15843: checking for $ac_hdr" >&5
+echo "configure:15844: checking for $ac_hdr" >&5
-#line 15846 "configure"
+#line 15847 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16103,6 +16104,7 @@
 s%@TKINCDIR@%$TKINCDIR%g
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
 s%@TCLTKLIBS@%$TCLTKLIBS%g
+s%@TCL_VERSION@%$TCL_VERSION%g
 s%@USE_POSTGRES@%$USE_POSTGRES%g
 s%@PQINCPATH@%$PQINCPATH%g
 s%@PQLIBPATH@%$PQLIBPATH%g
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2009-01-24 16:11:29 UTC (rev 35577)
+++ grass/branches/releasebranch_6_4/configure.in	2009-01-24 16:11:49 UTC (rev 35578)
@@ -846,7 +846,6 @@
 LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR $X_CFLAGS)
 # Tcl/Tk version checks
 LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
 LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
@@ -857,6 +856,8 @@
     AC_MSG_ERROR([*** Tcl/Tk version mismatch.])
 fi
+TCL_VERSION="$tcl_ver"
 # FreeBSD and CygWin don't have a "dot" between major/minor version number
 tcltk_ver2=`echo $tcltk_ver | sed 's/\.//g'`
@@ -893,7 +894,7 @@
 AC_SUBST(TKINCDIR)
 AC_SUBST(TCLTKLIBPATH)
 AC_SUBST(TCLTKLIBS)
+AC_SUBST(TCL_VERSION)
 # Done checking Tcl/Tk
 # Enable PostgreSQL option
Modified: grass/branches/releasebranch_6_4/include/Make/Platform.make.in
--- grass/branches/releasebranch_6_4/include/Make/Platform.make.in	2009-01-24 16:11:29 UTC (rev 35577)
+++ grass/branches/releasebranch_6_4/include/Make/Platform.make.in	2009-01-24 16:11:49 UTC (rev 35578)
@@ -170,6 +170,7 @@
 TKINCDIR            = @TKINCDIR@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
+TCLVERSION          = @TCL_VERSION@
 #FFTW:
 FFTWINC             = @FFTWINC@
