[GRASS-SVN] r35601 - grass/trunk/raster/r.param.scale
Sat Jan 24 22:29:10 EST 2009
Author: hamish
Date: 2009-01-24 22:29:09 -0500 (Sat, 24 Jan 2009)
New Revision: 35601
   grass/trunk/raster/r.param.scale/close_down.c
   grass/trunk/raster/r.param.scale/main.c
   grass/trunk/raster/r.param.scale/param.c
   grass/trunk/raster/r.param.scale/param.h
more metadata (merge from devbr6)
Modified: grass/trunk/raster/r.param.scale/close_down.c
--- grass/trunk/raster/r.param.scale/close_down.c	2009-01-25 03:25:33 UTC (rev 35600)
+++ grass/trunk/raster/r.param.scale/close_down.c	2009-01-25 03:29:09 UTC (rev 35601)
@@ -1,24 +1,20 @@
 /***                             close_down()                              ***/
 /***   	   Closes all input and output raster maps and frees memory.	   ***/
 /***               Jo Wood, Project ASSIST, 7th February 1993              ***/
+#include <string.h>
 #include "param.h"
 void close_down(void)
     struct History history;
+    char map_title[RECORD_LEN], map_type[32];
     /* Close connection with existing input raster. */
     G_unopen_cell(fd_in);
@@ -26,8 +22,106 @@
     /* Write output raster map and close connection. */
     G_close_cell(fd_out);
+    /* write out map metadata */
     G_short_history(rast_out_name, "raster", &history);
+    strncpy(history.datsrc_1, rast_in_name, RECORD_LEN-1);
+    history.datsrc_1[RECORD_LEN-1] = '\0';
+    switch (mparam) {
+    case ELEV:
+	strcpy(map_type, "Generalised elevation value");
+	break;
+    case SLOPE:
+	strcpy(map_type, "Magnitude of maximum gradient");
+	G_write_raster_units(rast_out_name, "degrees");
+	strcpy(history.edhist[0],
+	    "Slope is given for steepest slope angle and measured in degrees.");
+	history.edlinecnt = 1;
+	break;
+    case ASPECT:
+	strcpy(map_type, "Direction of maximum gradient");
+	    "Flow direction (aspect): W=0, E=180, N=+90, S=-90 degrees");
+	break;
+    case PROFC:
+	strcpy(map_type, "Profile curvature");
+	    "Curvature intersecting with the plane defined by the Z axis and");
+	strcpy(history.edhist[1],
+	    "maximum gradient direction. Positive values describe convex profile");
+	strcpy(history.edhist[2], "curvature, negative values concave profile.");
+	history.edlinecnt = 3;
+	break;
+    case PLANC:
+	strcpy(map_type, "Plan curvature");
+	    "Plan curvature is the horizontal curvature, intersecting with");
+	    "the XY plane.");
+	history.edlinecnt = 2;
+	break;
+    case LONGC:
+	strcpy(map_type, "Longitudinal curvature");
+	    "Longitudinal curvature is the profile curvature intersecting with the");
+	    "plane defined by the surfacenormal and maximum gradient direction.");
+	break;
+    case CROSC:
+	strcpy(map_type, "Cross-sectional curvature");
+	    "Cross-sectional curvature is the tangential curvature intersecting");
+	    "with the plane defined by the surface normal and a tangent to the");
+	    "contour - perpendicular to maximum gradient direction.");
+	break;
+    case MINIC:
+	strcpy(map_type, "Minimum curvature");
+	    "Measured in direction perpendicular to the direction of of maximum curvature.");
+	break;
+    case MAXIC:
+	strcpy(map_type, "Maximum curvature");
+	    "The maximum curvature is measured in any direction");
+	break;
+    case FEATURE:
+	strcpy(map_type, "Morphometric features");
+	    "Morphometric features: peaks, ridges, passes, channels, pits and planes");
+	break;
+    default:
+	strcpy(map_type, "?");
+	break;
     G_command_history(&history);
     G_write_history(rast_out_name, &history);
+    sprintf(map_title, "DEM terrain parameter: %s", map_type);
+    G_put_cell_title(rast_out_name, map_title);
+    return;
Modified: grass/trunk/raster/r.param.scale/main.c
--- grass/trunk/raster/r.param.scale/main.c	2009-01-25 03:25:33 UTC (rev 35600)
+++ grass/trunk/raster/r.param.scale/main.c	2009-01-25 03:29:09 UTC (rev 35601)
@@ -39,7 +39,7 @@
     /* Make sure that the current projection is not lat/long */
     if ((G_projection() == PROJECTION_LL))
-	G_fatal_error(_("Lat/Long location is not supported"));
+	G_fatal_error(_("Lat/Long locations are not supported by this module"));
     open_files();
Modified: grass/trunk/raster/r.param.scale/param.c
--- grass/trunk/raster/r.param.scale/param.c	2009-01-25 03:25:33 UTC (rev 35600)
+++ grass/trunk/raster/r.param.scale/param.c	2009-01-25 03:29:09 UTC (rev 35601)
@@ -5,19 +5,12 @@
 /***                                param()                                ***/
 /***     Returns a terrain parameter based on the 6 quadratic coefficents  ***/
 /***	 that define a local trend surface. 			    	   ***/
 /***     Jo Wood, Department of Geography, V2.0 15th December, 1994        ***/
 #include "param.h"
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h	2009-01-25 03:25:33 UTC (rev 35600)
+++ grass/trunk/raster/r.param.scale/param.h	2009-01-25 03:29:09 UTC (rev 35601)
@@ -1,18 +1,11 @@
 /***				param.h				      ***/
 /***  Header file for use with r.param.scale			      ***/
 /***  Jo Wood, ASSIST, Dept of Geography, University of Leicester     ***/
 /***  V1.0  - 7th February, 1993				      ***/
 #include <grass/gis.h>
