[GRASS-SVN] r35648 - grass-addons/vector/v.in.gshhs
Mon Jan 26 13:04:20 EST 2009
Author: mmetz
Date: 2009-01-26 13:04:20 -0500 (Mon, 26 Jan 2009)
New Revision: 35648
   grass-addons/vector/v.in.gshhs/Makefile
   grass-addons/vector/v.in.gshhs/README
   grass-addons/vector/v.in.gshhs/description.html
   grass-addons/vector/v.in.gshhs/gshhs.h
   grass-addons/vector/v.in.gshhs/gshhs_datum.txt
   grass-addons/vector/v.in.gshhs/main.c
longitudes with 180 deg limit
Modified: grass-addons/vector/v.in.gshhs/Makefile
--- grass-addons/vector/v.in.gshhs/Makefile	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/Makefile	2009-01-26 18:04:20 UTC (rev 35648)
@@ -4,7 +4,6 @@
 LIBES = $(VECTLIB) $(GPROJLIB) $(DBMILIB) $(GISLIB)
 DEPENDENCIES = $(VECTDEP) $(GPROJDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC) $(PROJINC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass-addons/vector/v.in.gshhs/README
--- grass-addons/vector/v.in.gshhs/README	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/README	2009-01-26 18:04:20 UTC (rev 35648)
@@ -1,5 +1,4 @@
 v.in.gshhs
 Program to extract and import binned shoreline data
Modified: grass-addons/vector/v.in.gshhs/description.html
--- grass-addons/vector/v.in.gshhs/description.html	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/description.html	2009-01-26 18:04:20 UTC (rev 35648)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
 <em>v.in.gshhs</em> imports GSHHS shorelines as available on
-<a href="ftp://ftp.soest.hawaii.edu/pwessel/gshhs/">ftp://ftp.soest.hawaii.edu/pwessel/gshhs/</a>
+<a href="http://www.soest.hawaii.edu/wessel/gshhs/">http://www.soest.hawaii.edu/wessel/gshhs/</a>
 <p>
 GSHHS shorelines are in latlon but can be imported to any location with
 any projection apart from unreferenced XY projection. Reprojection is
Modified: grass-addons/vector/v.in.gshhs/gshhs.h
--- grass-addons/vector/v.in.gshhs/gshhs.h	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/gshhs.h	2009-01-26 18:04:20 UTC (rev 35648)
@@ -27,6 +27,8 @@
  *	28-AUG-2007.  PW: Version 1.6.  no format change
  *			  For use with version 1.6 of GSHHS which now has WDBII
  *			  borders and rivers.
+ * may need updating for new GSHHS versions
 #ifndef _GSHHS
Modified: grass-addons/vector/v.in.gshhs/gshhs_datum.txt
--- grass-addons/vector/v.in.gshhs/gshhs_datum.txt	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/gshhs_datum.txt	2009-01-26 18:04:20 UTC (rev 35648)
@@ -93,5 +93,5 @@
 University of Hawaii at Manoa
 1680 East-West Road,
 Honolulu, HI 96822
-(808) 956-4778/5154 (voice/fax)
+(808) 956-4778/5154 (voice/fax)
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c	2009-01-26 17:56:00 UTC (rev 35647)
+++ grass-addons/vector/v.in.gshhs/main.c	2009-01-26 18:04:20 UTC (rev 35648)
@@ -1,3 +1,4 @@
  * MODULE:       v.in.gshhs (based on gshhstograss.c)
@@ -19,414 +20,726 @@
  *               Read the file COPYING that comes with GRASS
  *               for details.
 #include <stdlib.h>
 #include <unistd.h>
 #include <string.h>
 #include <time.h>
 #include <grass/gis.h>
 #include <grass/dbmi.h>
 #include <grass/Vect.h>
 #include <grass/gprojects.h>
 #include <grass/glocale.h>
-/* updating to a newer GSHHS version can be as easy as replacing gshhs.h
- * if not too many changes were introduced */
+    /* updating to a newer GSHHS version can be as easy as replacing gshhs.h
+     * if not too many changes were introduced */
 #include "gshhs.h"
+int main(int argc, char **argv)
+double w, e, s, n, area, lon, lat;
+double minx = -180., maxx = 180., miny = -90., maxy = 90.;
+char *dataname, *outname;
+char buf[2000], source;
+static char *slevel[] =
+	{ "shore", "land", "lake", "island in lake",
+"pond in island in lake" };
+int shore_levels = 5;
+FILE * fp;
+int k, i, n_read, flip, level, version, greenwich, src;
+int max_east = 180000000;	/* max_east = 270000000: confuses GRASS */
+int cnt = 1;
+struct GSHHS_POINT p;	/* renamed to avoid conflict */
+struct GSHHS h;
+struct pj_info info_in;
+struct pj_info info_out;
+struct Key_Value *out_proj_keys, *out_unit_keys;
+int type, zone;
+struct Cell_head region;
+struct Map_info VectMap;
+struct line_pnts *Points;
+struct line_cats *Cats;
+double lat_nw, lon_nw, lat_ne, lon_ne;
+double lat_sw, lon_sw, lat_se, lon_se;
+struct
+struct Option *input, *output, *n, *s, *e, *w;
+} parm;
+struct
+struct Flag *g, *topo, *a;
+} flag;
+struct GModule *module;
-int main(int argc, char **argv)
-    double w, e, s, n, area, lon, lat;
-    double minx = -180., maxx = 180., miny = -90., maxy = 90.;
-    char *dataname, *outname;
-    char buf[2000], source;
-    static char *slevel[] =
-	{ "shore", "land", "lake", "island in lake", "pond in island in lake" };
-    int shore_levels = 5;
-    FILE *fp;
-    int k, i, max_east = 270000000, n_read, flip, level, version, greenwich, src;
-    int cnt = 1;
-    struct GSHHS_POINT p; /* renamed to avoid conflict */
-    struct GSHHS h;
-    struct pj_info info_in;
-    struct pj_info info_out;
-    struct Key_Value *out_proj_keys, *out_unit_keys;
-    int type, zone;
-    struct Cell_head region;
-    struct Map_info VectMap;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
-    double lat_nw, lon_nw, lat_ne, lon_ne;
-    double lat_sw, lon_sw, lat_se, lon_se;
-    struct
-	struct Option *input, *output, *n, *s, *e, *w;
-    } parm;
-    struct
-	struct Flag *g, *topo, *a;
-    } flag;
-    struct GModule *module;
+	/* attribute table */
+    struct field_info *Fi;
+dbDriver * driver;
+dbString sql, strval;
+char *cat_col_name = "cat";
+G_gisinit(argv[0]);
-    /* attribute table */
-    struct field_info *Fi;
-    dbDriver *driver;
-    dbString sql, strval;
-    char *cat_col_name = "cat";
+	/* Set description */
+	module = G_define_module();
+module->description = ""
+	"Imports Global Self-consistent Hierarchical High-resolution Shoreline (GSHHS) vector data";
+parm.input = G_define_option();
+parm.input->key = "input";
+parm.input->type = TYPE_STRING;
+parm.input->required = YES;
+parm.input->gisprompt = "old_file,file,gshhs";
+parm.input->description =
+	"Name of GSHHS shoreline file: gshhs_[f|h|i|l|c].b";
+parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
+parm.n = G_define_option();
+parm.n->key = "n";
+parm.n->type = TYPE_DOUBLE;
+parm.n->required = NO;
+parm.n->description = "North limit in units of location projection";
+parm.s = G_define_option();
+parm.s->key = "s";
+parm.s->type = TYPE_DOUBLE;
+parm.s->required = NO;
+parm.s->description = "South limit in units of location projection";
+parm.e = G_define_option();
+parm.e->key = "e";
+parm.e->type = TYPE_DOUBLE;
+parm.e->required = NO;
+parm.e->description = "East limit in units of location projection";
+parm.w = G_define_option();
+parm.w->key = "w";
+parm.w->type = TYPE_DOUBLE;
+parm.w->required = NO;
+parm.w->description = "West limit in units of location projection";
+flag.g = G_define_flag();
+flag.g->key = 'g';
+flag.g->description = "Get coordinates from current GRASS region";
+flag.topo = G_define_flag();
+flag.topo->key = 't';
+flag.topo->description =
+"Do not build topology for output vector";
-    G_gisinit(argv[0]);
+	/* Importing as boundary causes problems with subregions, incorrect boundaries */
+	/*    flag.a = G_define_flag();
+	   flag.a->key = 'a';
+	   flag.a->description =
+	   "Import shoreline as type line (default = boundary)";
+if (G_parser(argc, argv))
+exit(1);
-    /* Set description */
-    module = G_define_module();
-    module->description = ""
-	"Imports Global Self-consistent Hierarchical High-resolution Shoreline (GSHHS) vector data";
+	/* get parameters */
+	dataname = parm.input->answer;
+outname = parm.output->answer;
+G_get_window(&region);
+zone = region.zone;
-    parm.input = G_define_option();
-    parm.input->key = "input";
-    parm.input->type = TYPE_STRING;
-    parm.input->required = YES;
-    parm.input->gisprompt = "old_file,file,gshhs";
-    parm.input->description = "Name of GSHHS shoreline file: gshhs_[f|h|i|l|c].b";
+	/* Out Info */
+	out_proj_keys = G_get_projinfo();
+out_unit_keys = G_get_projunits();
+if (pj_get_kv(&info_out, out_proj_keys, out_unit_keys) < 0) {
+exit(0);
+G_free_key_value(out_proj_keys);
+G_free_key_value(out_unit_keys);
-    parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
-    parm.n = G_define_option();
-    parm.n->key = "n";
-    parm.n->type = TYPE_DOUBLE;
-    parm.n->required = NO;
-    parm.n->description = "North limit in units of location projection";
-    parm.s = G_define_option();
-    parm.s->key = "s";
-    parm.s->type = TYPE_DOUBLE;
-    parm.s->required = NO;
-    parm.s->description = "South limit in units of location projection";
-    parm.e = G_define_option();
-    parm.e->key = "e";
-    parm.e->type = TYPE_DOUBLE;
-    parm.e->required = NO;
-    parm.e->description = "East limit in units of location projection";
-    parm.w = G_define_option();
-    parm.w->key = "w";
-    parm.w->type = TYPE_DOUBLE;
-    parm.w->required = NO;
-    parm.w->description = "West limit in units of location projection";
-    flag.g = G_define_flag();
-    flag.g->key = 'g';
-    flag.g->description = "Get coordinates from current GRASS region";
-    flag.topo = G_define_flag();
-    flag.topo->key = 't';
-    flag.topo->description =
-	"Do not build topology for output vector";
-/* Importing as boundary causes problems with subregions, incorrect boundaries */
-/*    flag.a = G_define_flag();
-    flag.a->key = 'a';
-    flag.a->description =
-	"Import shoreline as type line (default = boundary)";
-    if (G_parser(argc, argv))
-	exit(1);
-/* get parameters */
-    dataname = parm.input->answer;
-    outname = parm.output->answer;
-    G_get_window(&region);
-    zone = region.zone;
-/* Out Info */
-    out_proj_keys = G_get_projinfo();
-    out_unit_keys = G_get_projunits();
-    if (pj_get_kv(&info_out, out_proj_keys, out_unit_keys) < 0) {
-	exit(0);
-    G_free_key_value(out_proj_keys);
-    G_free_key_value(out_unit_keys);
-/* In Info */
-/* N.B. GSHHS data is not referenced to any ellipsoid or datum. This
- * limits its precision to several hundred metres. Hence it does not
- * matter which ellipsoid we use in the input projection keys as the
- * precision of the data is less than the maximum error that could be
- * caused by projecting using the 'wrong' ellipsoid.
- * Anyone who understands this better than me feel free to change it.
- * PK March 2003 */
-/* GSHHS spatial reference
- * GSHHS is a combination of WVS and WDBII
- * The WVS dataset uses WGS84 according to
- * http://shoreline.noaa.gov/data/datasheets/wvs.html
- * The WDBII dataset may have used wgs72 but is inaccurate anyway
- * Safest would be to always use wgs84
- * MM Jan 2009 */
-/* set input projection to lat/long w/ same ellipsoid as output */
-/* TODO: use wgs84 datum and ellipsoid */
-    info_in.zone = 0;
-    info_in.meters = 1.;
-    sprintf(info_in.proj, "ll");
-    if ((info_in.pj = pj_latlong_from_proj(info_out.pj)) == NULL)
-	G_fatal_error("Unable to set up lat/long projection parameters");
-    if (flag.g->answer) {
-    /* get coordinates from current region */
-	minx = region.west;
-	maxx = region.east;
-	miny = region.south;
-	maxy = region.north;
-    else {
-    /* get coordinates from command line */
-	if (!parm.w->answer || !parm.e->answer || !parm.s->answer
-	    || !parm.n->answer) {
-	    G_fatal_error("Missing region parameters: you must supply n, s, e, w values or use '-g' flag");
-	sscanf(parm.w->answer, "%lf", &minx);
-	sscanf(parm.e->answer, "%lf", &maxx);
-	sscanf(parm.s->answer, "%lf", &miny);
-	sscanf(parm.n->answer, "%lf", &maxy);
+	/* In Info */
+	/* N.B. GSHHS data is not referenced to any ellipsoid or datum. This
+	 * limits its precision to several hundred metres. Hence it does not
+	 * matter which ellipsoid we use in the input projection keys as the
+	 * precision of the data is less than the maximum error that could be
+	 * caused by projecting using the 'wrong' ellipsoid.
+	 * Anyone who understands this better than me feel free to change it.
+	 * PK March 2003 */
-	if (maxx < minx)
-		G_fatal_error("East must be east of West");
-	if (maxy < miny)
-		G_fatal_error("North must be north of South");
-    if (G_projection() != PROJECTION_LL) {
-    /* convert to latlon and print bounds */
-    /* NW */
-	lon_nw = minx;
-	lat_nw = maxy;
-	if (pj_do_proj(&lon_nw, &lat_nw, &info_out, &info_in) < 0) {
-	    G_fatal_error("Error in coordinate transformation for north west corner");
-    /* NE */
-	lon_ne = maxx;
-	lat_ne = maxy;
-	if (pj_do_proj(&lon_ne, &lat_ne, &info_out, &info_in) < 0) {
-	    G_fatal_error("Error in coordinate transformation for north east corner");
-    /* SE */
-	lon_se = maxx;
-	lat_se = miny;
-	if (pj_do_proj(&lon_se, &lat_se, &info_out, &info_in) < 0) {
-	    G_fatal_error("Error in coordinate transformation for south eest corner");
-    /* SW */
-	lon_sw = minx;
-	lat_sw = miny;
-	if (pj_do_proj(&lon_sw, &lat_sw, &info_out, &info_in) < 0) {
-	    G_fatal_error("Error in coordinate transformation for south west corner");
-        /* get north max */
-        maxy = lat_nw > lat_ne ? lat_nw : lat_ne;
-        /* get south min*/
-        miny = lat_sw < lat_se ? lat_sw : lat_se;
-        /* get east max*/
-        maxx = lon_ne > lon_se ? lon_ne : lon_se;
-        /* get west min*/
-        minx = lon_nw < lon_sw ? lon_nw : lon_sw;
-    /* check coordinate accuracy */
-    if (maxx < minx) {
-	G_fatal_error(_("maxx %f < minx %f."), maxx, minx);
-    if (maxy < miny) {
-	G_fatal_error(_("maxy %f < miny %f."), maxy, miny);
-    G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny, maxx,
-	    minx);
-    /* open GSHHS shoreline for reading */
-    if ((fp = fopen(dataname, "rb")) == NULL) {
-	G_fatal_error(_("Could not find file %s."), dataname);
-    /* Open new vector */
-    if (0 > Vect_open_new(&VectMap, outname, 0)) {
-	G_fatal_error(_("Cannot open new vector %s"), outname);
+	/* GSHHS spatial reference
+	 * GSHHS is a combination of WVS and WDBII
+	 * The WVS dataset uses WGS84 according to
+	 * http://shoreline.noaa.gov/data/datasheets/wvs.html
+	 * The WDBII dataset may have used wgs72 but is inaccurate anyway
+	 * Safest would be to always use wgs84
+	 * MM Jan 2009 */
+	/* set input projection to lat/long w/ same ellipsoid as output */
+	/* TODO: use wgs84 datum and ellipsoid */
+	info_in.zone = 0;
+info_in.meters = 1.;
+sprintf(info_in.proj, "ll");
+if ((info_in.pj = pj_latlong_from_proj(info_out.pj)) == NULL)
+G_fatal_error("Unable to set up lat/long projection parameters");
+if (flag.g->answer) {
+	    /* get coordinates from current region */
+	    minx = region.west;
+maxx = region.east;
+miny = region.south;
+maxy = region.north;
-    /* set vector line type to GV_LINE, boundaries can cause problems */
-    type = GV_LINE;
+    else {
+	    /* get coordinates from command line */
+	    if (!parm.w->answer || !parm.e->answer || !parm.s->answer
+		||!parm.n->answer) {
+G_fatal_error
+		("Missing region parameters: you must supply n, s, e, w values or use '-g' flag");
+sscanf(parm.w->answer, "%lf", &minx);
+sscanf(parm.e->answer, "%lf", &maxx);
+sscanf(parm.s->answer, "%lf", &miny);
+sscanf(parm.n->answer, "%lf", &maxy);
+if (maxx < minx)
+G_fatal_error("East must be east of West");
+if (maxy < miny)
+G_fatal_error("North must be north of South");
+if (G_projection() != PROJECTION_LL) {
+	    /* convert to latlon and print bounds */
+	    /* NW */
+	    lon_nw = minx;
+lat_nw = maxy;
+if (pj_do_proj(&lon_nw, &lat_nw, &info_out, &info_in) < 0) {
+G_fatal_error
+		("Error in coordinate transformation for north west corner");
+	    /* NE */
+	    lon_ne = maxx;
+lat_ne = maxy;
+if (pj_do_proj(&lon_ne, &lat_ne, &info_out, &info_in) < 0) {
+G_fatal_error
+		("Error in coordinate transformation for north east corner");
+	    /* SE */
+	    lon_se = maxx;
+lat_se = miny;
+if (pj_do_proj(&lon_se, &lat_se, &info_out, &info_in) < 0) {
+G_fatal_error
+		("Error in coordinate transformation for south eest corner");
+	    /* SW */
+	    lon_sw = minx;
+lat_sw = miny;
+if (pj_do_proj(&lon_sw, &lat_sw, &info_out, &info_in) < 0) {
+G_fatal_error
+		("Error in coordinate transformation for south west corner");
-    /* Initialize vector line struct */
-    Points = Vect_new_line_struct();
+	    /* get north max */
+	    maxy = lat_nw > lat_ne ? lat_nw : lat_ne;
+	    /* get south min */
+	    miny = lat_sw < lat_se ? lat_sw : lat_se;
+	    /* get east max */
+	    maxx = lon_ne > lon_se ? lon_ne : lon_se;
+	    /* get west min */
+	    minx = lon_nw < lon_sw ? lon_nw : lon_sw;
-    /* Initialize vector category struct */
-    Cats = Vect_new_cats_struct();
+	/* check coordinate accuracy */
+	if (maxx < minx) {
+G_fatal_error(_("maxx %f < minx %f."), maxx, minx);
+if (maxy < miny) {
+G_fatal_error(_("maxy %f < miny %f."), maxy, miny);
+G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny,
+		maxx,
+minx);
-    /* read header from GSHHS database */
-    n_read = fread ((void *)&h, (size_t)sizeof (struct GSHHS), (size_t)1, fp);
-    version = (h.flag >> 8) & 255;
-    flip = (version < 6);	/* Take as sign that byte-swapping is needed */
-    if (flip) {
-	version = swabi4 ((unsigned int)h.flag);
-	version = (version >> 8) & 255;
+	/* open GSHHS shoreline for reading */
+	if ((fp = fopen(dataname, "rb")) == NULL) {
+G_fatal_error(_("Could not find file %s."), dataname);
-    /* read lines from GSHHS database */
-    while (n_read == 1) {
-	if (flip) {
-	    h.id = swabi4 ((unsigned int)h.id);
-	    h.n  = swabi4 ((unsigned int)h.n);
-	    h.west  = swabi4 ((unsigned int)h.west);
-	    h.east  = swabi4 ((unsigned int)h.east);
-	    h.south = swabi4 ((unsigned int)h.south);
-	    h.north = swabi4 ((unsigned int)h.north);
-	    h.area  = swabi4 ((unsigned int)h.area);
-	    h.flag  = swabi4 ((unsigned int)h.flag);
-	level = h.flag & 255;
-	/* version = (h.flag >> 8) & 255; */
-	greenwich = (h.flag >> 16) & 255;
-	src = (h.flag >> 24) & 255;
-	w = h.west  * GSHHS_SCL;	/* Convert from microdegrees to degrees */
-	e = h.east  * GSHHS_SCL;
-	s = h.south * GSHHS_SCL;
-	n = h.north * GSHHS_SCL;
-	/* skip WDBII data because they are too inacurate? */
-	source = (src == 1) ? 'W' : 'C';	/* Either WVS or CIA (WDBII) pedigree */
-	area = 0.1 * h.area;			/* Now im km^2 */
+	/* Open new vector */
+	if (0 > Vect_open_new(&VectMap, outname, 0)) {
+G_fatal_error(_("Cannot open new vector %s"), outname);
-	if (h.west > max_east) w -= 360.0;
-	if (h.east > max_east) e -= 360.0;
+	/* set vector line type to GV_LINE, boundaries can cause problems */
+	type = GV_LINE;
-	/* got line header now read in points if line box overlaps with region */
-	if( ( w <= maxx && e >= minx ) && ( s <= maxy && n >= miny ) ){
-	    Vect_reset_line(Points);
-	    Vect_reset_cats(Cats);
+	/* Initialize vector line struct */
+	Points = Vect_new_line_struct();
-	    for (k = 0; k < h.n; k++) {
-		if (fread
-		((void *)&p, (size_t)sizeof(struct GSHHS_POINT), (size_t)1,
-		 fp) != 1)
-		G_fatal_error("Error reading data.");
+	/* Initialize vector category struct */
+	Cats = Vect_new_cats_struct();
-		if (flip) {
-		    p.x = swabi4((unsigned int) p.x);
-		    p.y = swabi4((unsigned int) p.y);
-		lon = p.x * GSHHS_SCL;
-		if (p.x > max_east) lon -= 360.0;
-		lat = p.y * GSHHS_SCL;
+	/* read header from GSHHS database */
+	n_read =
+	fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
+version = (h.flag >> 8) & 255;
+flip = (version < 6);	/* Take as sign that byte-swapping is needed */
+if (flip) {
+version = swabi4((unsigned int)h.flag);
+version = (version >> 8) & 255;
-			if (pj_do_proj(&lon, &lat, &info_in, &info_out) < 0) {
-			G_fatal_error("Error in coordinate transformation");
-		Vect_append_point(Points, lon, lat, 0.);
-	    }			/* done with line */
-	    if (k) {
-		/* simple table and cats for layer 1: not unique, just per slevel */
-		Vect_cat_set(Cats, 1, level);
-		/* cats for layer 2 are unique ID, same like GSHHS ID */
-		Vect_cat_set(Cats, 2, h.id);
-		Vect_write_line(&VectMap, type, Points, Cats);
-		cnt++;
-	else {
-	    G_debug(1, "skipped line box west: %f, east: %f, north: %f, south: %f", w, e, n, s);
-	    fseek (fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
-	max_east = 180000000; /* Only Eurasiafrica needs 270 */
+	/* read lines from GSHHS database */
+	while (n_read == 1) {
+if (flip) {
+h.id = swabi4((unsigned int)h.id);
+h.n = swabi4((unsigned int)h.n);
+h.west = swabi4((unsigned int)h.west);
+h.east = swabi4((unsigned int)h.east);
+h.south = swabi4((unsigned int)h.south);
+h.north = swabi4((unsigned int)h.north);
+h.area = swabi4((unsigned int)h.area);
+h.flag = swabi4((unsigned int)h.flag);
+level = h.flag & 255;
-	n_read = fread((void *)&h, (size_t)sizeof (struct GSHHS), (size_t)1, fp);
-    /* done with gshhs file */
-    fclose(fp);
+	    /* version = (h.flag >> 8) & 255; */
+	    greenwich = (h.flag >> 16) & 255;
+src = (h.flag >> 24) & 255;
+w = h.west * GSHHS_SCL;	/* Convert from microdegrees to degrees */
+e = h.east * GSHHS_SCL;
+s = h.south * GSHHS_SCL;
+n = h.north * GSHHS_SCL;
+	    /* skip WDBII data because they are too inacurate? */
+	    source = (src == 1) ? 'W' : 'C';	/* Either WVS or CIA (WDBII) pedigree */
+area = 0.1 * h.area;	/* Now im km^2 */
+if (h.west > max_east)
+	    w -= 360.0;
+if (h.east > max_east)
+	    e -= 360.0;
-    Vect_destroy_line_struct(Points);
-    Vect_destroy_cats_struct(Cats);
+	    /* got line header now read in points if line box overlaps with region */
+	    if ((w <= maxx && e >= minx) && (s <= maxy && n >= miny)) {
+Vect_reset_line(Points);
+Vect_reset_cats(Cats);
+for (k = 0; k < h.n; k++) {
+if (fread
+		     ((void *)&p, (size_t) sizeof(struct GSHHS_POINT),
+		      (size_t) 1,
+fp) != 1)
+G_fatal_error("Error reading data.");
+if (flip) {
+p.x = swabi4((unsigned int)p.x);
+p.y = swabi4((unsigned int)p.y);
+lon = p.x * GSHHS_SCL;
+if (p.x > max_east)
+		    lon -= 360.0;
+lat = p.y * GSHHS_SCL;
+if (pj_do_proj(&lon, &lat, &info_in, &info_out) < 0) {
+G_fatal_error("Error in coordinate transformation");
+Vect_append_point(Points, lon, lat, 0.);
+}			/* done with line */
+if (k) {
+		    /* simple table and cats for layer 1: not unique, just per slevel */
+		    Vect_cat_set(Cats, 1, level);
+		    /* cats for layer 2 are unique ID, same like GSHHS ID */
+		    Vect_cat_set(Cats, 2, h.id);
+Vect_write_line(&VectMap, type, Points, Cats);
+cnt++;
+	else {
+G_debug(1,
+		     "skipped line box west: %f, east: %f, north: %f, south: %f",
+		     w, e, n, s);
+fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
+	    /* max_east = 180000000; *//* Only Eurasiafrica needs 270 */
+n_read =
+	/* done with gshhs file */
+	fclose(fp);
+Vect_destroy_line_struct(Points);
+Vect_destroy_cats_struct(Cats);
-    /* write out vect header info */
-    Vect_set_scale(&VectMap, 100000);
-    sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs", version);
-    Vect_set_comment(&VectMap, buf);
+	/* write out vect header info */
+	Vect_set_scale(&VectMap, 100000);
+sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs",
+	     version);
+Vect_set_comment(&VectMap, buf);
-    /* create table and link new vector to table, code taken from v.in.ogr */
-    db_init_string(&sql);
-    db_init_string(&strval);
-    Fi = Vect_default_field_info(&VectMap, 1, NULL, GV_1TABLE);
-    Vect_map_add_dblink(&VectMap, 1, NULL, Fi->table,
-			    cat_col_name, Fi->database, Fi->driver);
-    sprintf(buf, "create table %s (%s integer, type varchar(25))", Fi->table,
-	    cat_col_name);
-    db_set_string(&sql, buf);
+	/* create table and link new vector to table, code taken from v.in.ogr */
+db_init_string(&sql);
+db_init_string(&strval);
+Fi = Vect_default_field_info(&VectMap, 1, NULL, GV_1TABLE);
+Vect_map_add_dblink(&VectMap, 1, NULL, Fi->table,
+cat_col_name,
+			  Fi->database, Fi->driver);
+sprintf(buf, "create table %s (%s integer, type varchar(25))",
+	      Fi->table,
+cat_col_name);
+db_set_string(&sql, buf);
+driver =
+	db_start_driver_open_database(Fi->driver,
+Vect_subst_var(Fi->database,
+						      &VectMap));
+if (driver == NULL) {
+G_fatal_error(_("Cannot open database %s by driver %s"),
+Vect_subst_var(Fi->database, &VectMap), Fi->driver);
+G_debug(1, "table: %s", Fi->table);
+G_debug(1, "driver: %s", Fi->driver);
+G_debug(1, "database: %s", Fi->database);
+if (db_execute_immediate(driver, &sql) != DB_OK) {
+db_close_database(driver);
+db_shutdown_driver(driver);
+G_fatal_error(_("Cannot create table: %s"),
+db_get_string(&sql));
+if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
+G_warning(_("Cannot create index"));
+if (db_grant_on_table
+	  (driver, Fi->table, DB_PRIV_SELECT,
+DB_GROUP | DB_PUBLIC) != DB_OK)
+G_fatal_error(_("Cannot grant privileges on table %s"), Fi->table);
+db_begin_transaction(driver);
+for (i = 0; i < shore_levels; i++) {
+sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1,
+		 slevel[i]);
+G_fatal_error(_("Cannot insert new row: %s"),
+db_commit_transaction(driver);
+db_close_database_shutdown_driver(driver);
+if (flag.topo->answer) {
+G_message(_("Run \"v.build map=%s option=build\" to build topology"),
+		   outname);
-    driver = db_start_driver_open_database(Fi->driver,
-					  Vect_subst_var(Fi->database, &VectMap));
+    else {
+Vect_build(&VectMap);
+Vect_close(&VectMap);
+G_message(_("GSHHS shoreline version %d import complete"), version);
+exit(EXIT_SUCCESS);
-    if (driver == NULL) {
-	G_fatal_error(_("Cannot open database %s by driver %s"),
-		      Vect_subst_var(Fi->database, &VectMap), Fi->driver);
-    G_debug(1, "table: %s", Fi->table);
-    G_debug(1, "driver: %s", Fi->driver);
-    G_debug(1, "database: %s", Fi->database);
-    if (db_execute_immediate(driver, &sql) != DB_OK) {
-	db_close_database(driver);
-	db_shutdown_driver(driver);
-	G_fatal_error(_("Cannot create table: %s"),
-		      db_get_string(&sql));
-    if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-	G_warning(_("Cannot create index"));
-    if (db_grant_on_table(driver, Fi->table, DB_PRIV_SELECT,
-     DB_GROUP | DB_PUBLIC) != DB_OK)
-	G_fatal_error(_("Cannot grant privileges on table %s"), Fi->table);
-    db_begin_transaction(driver);
-    for (i = 0; i < shore_levels; i++) {
-	sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1, slevel[i]);
-	    G_fatal_error(_("Cannot insert new row: %s"),
-    db_commit_transaction(driver);
-    db_close_database_shutdown_driver(driver);
-    if (flag.topo->answer) {
-	G_message(_("Run \"v.build map=%s option=build\" to build topology"), outname);
-    else {
-    Vect_build(&VectMap);
-    Vect_close(&VectMap);
-    G_message(_("GSHHS shoreline version %d import complete"), version);
-    exit(EXIT_SUCCESS);
