[GRASS-SVN] r38158 - grass-addons/vector/v.krige
Thu Jul 2 06:37:01 EDT 2009
Author: aghisla
Date: 2009-07-02 06:37:00 -0400 (Thu, 02 Jul 2009)
New Revision: 38158
   grass-addons/vector/v.krige/v.krige.py
gstat options bound to the code
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py	2009-07-02 09:06:11 UTC (rev 38157)
+++ grass-addons/vector/v.krige/v.krige.py	2009-07-02 10:37:00 UTC (rev 38158)
@@ -179,7 +179,7 @@
         #2. collect options
         Column = self.InputDataColumn.GetValue()
         #@TODO(anne): pick up parameters if user chooses to set variogram parameters.
-        #3. Fit variogram. For the moment in batch mode, no interactive window. Stay tuned!
+        #3. Fit variogram. For the moment in blind mode, no interactive window. Stay tuned!
         self.parent.log.write(_("Variogram fitting"))
         Formula = robjects.r['as.formula'](robjects.r.paste(Column, "~ 1"))
         Variogram = SelectedPanel.FitVariogram(Formula, InputData)
@@ -299,16 +299,22 @@
         RBookPanel.__init__(self, parent, *args, **kwargs)
         ModelFactor = robjects.r.vgm().r['long']
-        ModelList = robjects.r.levels(ModelFactor[0])
+        ModelList = robjects.r.levels(ModelFactor[0]) # no other way to let the Python pick it up..
         self.ParametersSizer.Insert(before=0, item=wx.StaticText(self, id= wx.ID_ANY, label = _("Variogram model")))
-        self.ParametersSizer.Insert(before=1, item=wx.Choice(self, id=wx.ID_ANY, choices=ModelList))
+        self.ModelChoicebox = wx.Choice(self, id=wx.ID_ANY, choices=ModelList)
+        self.ParametersSizer.Insert(before=1, item= self.ModelChoicebox)
         self.SetSizerAndFit(self.Sizer)
     def FitVariogram(self, formula, data):
         DataVariogram = robjects.r.variogram(formula, data)
-        VariogramModel = robjects.r['fit.variogram'](DataVariogram, model = robjects.r.vgm(1, "Lin"))
-        #@TODO: hardcoded on rs dataset. There is a trend indeed.
+        ModelShortName = self.ModelChoicebox.GetStringSelection().split()[0]
+        print ModelShortName
+        VariogramModel = robjects.r['fit.variogram'](DataVariogram,
+                                                     model = robjects.r.vgm(psill = self.SillCtrl.GetValue(),
+        model = ModelShortName,
+        nugget = self.NuggetCtrl.GetValue(),
+        range = self.RangeCtrl.GetValue()))
         return VariogramModel
     def DoKriging(self, formula, data, grid,  model):
