[GRASS-SVN] r38168 - grass-addons/vector/v.in.postgis
svn_grass at osgeo.org
Thu Jul 2 12:06:52 EDT 2009
Author: mathieug
Date: 2009-07-02 12:06:51 -0400 (Thu, 02 Jul 2009)
New Revision: 38168
grass-addons/vector/v.in.postgis/v.in.postgis.sh
renamed old shell script
Modified: grass-addons/vector/v.in.postgis/v.in.postgis.sh
--- grass-addons/vector/v.in.postgis/v.in.postgis.sh 2009-07-02 15:56:10 UTC (rev 38167)
+++ grass-addons/vector/v.in.postgis/v.in.postgis.sh 2009-07-02 16:06:51 UTC (rev 38168)
@@ -28,27 +28,27 @@
#% key: geometryfield
#% type: string
#% answer: the_geom
-#% description: Name of the source geometry field. Usually defaults to the_geom but needed if a geometry function was used (for example, centroid), or if the table has many geometry columns.
+#% description: Name of the source geometry field (usually defaults to the_geom)
#% required : yes
#%end
#%option
#% key: output
#% type: string
#% answer: v_in_postgis
-#% description: Name of the geographic postgis table where to place the query results. Will be the name of the imported grass layer. If -d flag is set, this table is deleted and replaced by a dbf attribute table. Use a different name than the original. Do not use capital letters
+#% description: Name of the imported grass layer (do not use capital letters)
#% required : no
#%end
#%flag
#% key: d
-#% description: import result in grass dbf format (no new table in postgis). If not set, the grass layer will be directly connected to the postgis new table
+#% description: Import result in grass dbf format (no new table in postgis - if not set, new grass layer attributes will be connected to the result table)
#%end
#%flag
#% key: r
-#% description: use -o for v.in.ogr (override dataset projection)
+#% description: Use -o for v.in.ogr (override dataset projection)
#%end
#%flag
#% key: g
-#% description: add a gist index to the imported table in postgis (useless with the d flag)
+#% description: Add a gist index to the imported result table in postgis (useless with the d flag)
#%end
if [ -z "$GISBASE" ] ; then
