[GRASS-SVN] r38184 - grass/trunk/raster/r.sun2
Fri Jul 3 04:31:43 EDT 2009
Author: hamish
Date: 2009-07-03 04:31:43 -0400 (Fri, 03 Jul 2009)
New Revision: 38184
   grass/trunk/raster/r.sun2/main.c
(Thomas Huld) Fixed problem with incidence angle being 0 when the sun isn't there. Now the value is null. Note that this is also the case if the pixel is in shadow. (merge from devbr6)
Modified: grass/trunk/raster/r.sun2/main.c
--- grass/trunk/raster/r.sun2/main.c	2009-07-03 08:29:10 UTC (rev 38183)
+++ grass/trunk/raster/r.sun2/main.c	2009-07-03 08:31:43 UTC (rev 38184)
@@ -1922,9 +1922,13 @@
 		    lum =
 			lumcline2(&sunGeom, &sunVarGeom, &sunSlopeGeom,
 				  &gridGeom, horizonarray + shadowoffset);
-		    lum = rad2deg * asin(lum);
-		    lumcl[j][i] = (float)lum;
+		    if (lum > 0.) {
+			lum = rad2deg * asin(lum);
+			lumcl[j][i] = (float)lum;
+		    else lumcl[j][i] = UNDEFZ;
 		if (someRadiation) {
 		    joules2(&sunGeom, &sunVarGeom, &sunSlopeGeom, &sunRadVar,
 			    &gridGeom, horizonarray + shadowoffset, latitude,
@@ -1946,7 +1950,6 @@
 	    shadowoffset += arrayNumInt;
 	arrayOffset++;
     /* re-use &hist, but try all to initiate it for any case */
