[GRASS-SVN] r38210 - grass/branches/releasebranch_6_4/db/base
Sat Jul 4 12:47:31 EDT 2009
Author: martinl
Date: 2009-07-04 12:47:31 -0400 (Sat, 04 Jul 2009)
New Revision: 38210
   grass/branches/releasebranch_6_4/db/base/execute.c
do not ignore default schema - fix trac #673
   (merge from devbr6, r38209)
Modified: grass/branches/releasebranch_6_4/db/base/execute.c
--- grass/branches/releasebranch_6_4/db/base/execute.c	2009-07-04 16:33:25 UTC (rev 38209)
+++ grass/branches/releasebranch_6_4/db/base/execute.c	2009-07-04 16:47:31 UTC (rev 38210)
@@ -41,6 +41,7 @@
     dbHandle handle;
     int ret;
     FILE *fd;
+    const char *schema;
     int error = 0;
     parse_command_line(argc, argv);
@@ -61,7 +62,8 @@
     db_init_handle(&handle);
-    db_set_handle(&handle, parms.database, NULL);
+    schema = db_get_default_schema_name();
+    db_set_handle(&handle, parms.database, schema);
     if (db_open_database(driver, &handle) != DB_OK)
 	G_fatal_error(_("Unable to open database <%s>"), parms.database);
