[GRASS-SVN] r38257 - in grass-addons/grass7/general: . g.extension.add
Sun Jul 5 11:27:19 EDT 2009
Author: martinl
Date: 2009-07-05 11:27:18 -0400 (Sun, 05 Jul 2009)
New Revision: 38257
Added:
   grass-addons/grass7/general/g.extension.add/
   grass-addons/grass7/general/g.extension.add/Makefile
   grass-addons/grass7/general/g.extension.add/g.extension.add.html
   grass-addons/grass7/general/g.extension.add/g.extension.add.py
g.extension.add pythonized
Added: grass-addons/grass7/general/g.extension.add/Makefile
--- grass-addons/grass7/general/g.extension.add/Makefile	                        (rev 0)
+++ grass-addons/grass7/general/g.extension.add/Makefile	2009-07-05 15:27:18 UTC (rev 38257)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = g.extension.add
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/general/g.extension.add/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-sh
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass-addons/grass7/general/g.extension.add/g.extension.add.html
--- grass-addons/grass7/general/g.extension.add/g.extension.add.html	                        (rev 0)
+++ grass-addons/grass7/general/g.extension.add/g.extension.add.html	2009-07-05 15:27:18 UTC (rev 38257)
@@ -0,0 +1,22 @@
+<h2>DESCRIPTION</h2>
+<em>g.extension.add</em> downloads and installs extensions from
+GRASS Addons SVN repository into the local GRASS installation.
+<p>
+Re-running the script on an installed GRASS Addon re-installs
+the requested extension which may include updates.
+<h2>EXAMPLES</h2>
+Download and install i.landsat.toar into current GRASS installation:
+<div class="code"><pre>
+  g.extension.add extension=i.landsat.toar
+</pre></div>
+<h2>AUTHOR</h2>
+Markus Neteler<br>
+Upgraded for GRASS 7 by Martin Landa
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/general/g.extension.add/g.extension.add.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/general/g.extension.add/g.extension.add.py
--- grass-addons/grass7/general/g.extension.add/g.extension.add.py	                        (rev 0)
+++ grass-addons/grass7/general/g.extension.add/g.extension.add.py	2009-07-05 15:27:18 UTC (rev 38257)
@@ -0,0 +1,161 @@
+#!/usr/bin/env python
+# MODULE:       g.extension.add
+# AUTHOR(S):   	Markus Neteler
+#               Pythonized by Martin Landa
+# PURPOSE:      tool to download and install extensions from GRASS Addons SVN into
+#               local GRASS installation
+# COPYRIGHT:    (C) 2009 by the Markus Neteler, GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# TODO: add sudo support where needed (i.e. check first permission to write into
+#       $GISBASE directory)
+#%Module
+#%  description: Tool to download and install extensions from GRASS Addons SVN repository into local GRASS installation.
+#%  keywords: installation, extensions
+#%End
+#%option
+#% key: extension
+#% type: string
+#% key_desc : name
+#% description: Name of extension to install from GRASS Addons SVN repository
+#% required : no
+#%end
+#%flag
+#%  key: l
+#%  description: List available modules in the GRASS Addons SVN repository
+#%end
+import os
+import sys
+import re
+import atexit
+import urllib
+from grass.script import core as grass
+# definitions
+svnurl_addons = "https://svn.osgeo.org/grass/grass-addons/"
+# temp dir
+tmpdir = grass.tempfile()
+grass.try_remove(tmpdir)
+os.mkdir(tmpdir)
+def check():
+    # check if we have the svn client
+    if not grass.find_program('svn'):
+        grass.fatal('svn client required. Please install subversion first.')
+def expand_module_class_name(c):
+    name = { 'd'  : 'display',
+             'db' : 'database',
+             'g'  : 'general',
+             'i'  : 'imagery',
+             'm'  : 'misc',
+             'ps' : 'postscript',
+             'p'  : 'paint',
+             'r'  : 'raster',
+             'r3' : 'raster3D',
+             's'  : 'sites',
+             'v'  : 'vector' }
+    if name.has_key(c):
+        return name[c]
+    return c
+def list_available_modules():
+    global svnurl_addons
+    grass.message('Fetching list of modules from GRASS-Addons SVN (be patient)...')
+    pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
+    for d in ['d', 'db', 'g', 'i', 'ps',
+              'p', 'r', 'r3', 'v']:
+        modclass = expand_module_class_name(d)
+        url = svnurl_addons + modclass
+        f = urllib.urlopen(url)
+        if not f:
+            grass.warning("Unable to fetch '%s'" % url)
+            continue
+        for line in f.readlines():
+            sline = pattern.search(line)
+            if sline and sline.group(2).split('.', 1)[0] == d:
+                print sline.group(2).rstrip('/')
+def cleanup():
+    global tmpdir
+    grass.try_rmdir(tmpdir)
+def main():
+    # check dependecies
+    check()
+    # list available modules
+    if flags['l']:
+        list_available_modules()
+        return 0
+    else:
+        if not options['extension']:
+            grass.fatal('You need to define an extension name or use -l')
+    module = options['extension']
+    classchar = module.split('.', 1)[0]
+    moduleclass = expand_module_class_name(classchar)
+    url = svnurl_addons + moduleclass + '/' + module
+    global tmpdir
+    print tmpdir
+    grass.message("Fetching '%s' from GRASS-Addons SVN (be patient)..." % module)
+    os.chdir(tmpdir)
+    if grass.call(['svn', 'checkout',
+                   url]) != 0:
+        grass.fatal("GRASS Addons '%s' not found in repository" % module)
+    os.chdir(os.path.join(tmpdir, module))
+    grass.message("Compiling '%s'..." % module)
+    gisbase = os.getenv('GISBASE')
+    if grass.call(['make',
+                   'MODULE_TOPDIR=%s' % gisbase]) != 0:
+        cleanup()
+        grass.fatal('Compilation failed, sorry. Please check above error messages')
+    grass.message("Installing '%s'..." % module)
+    # can we write ?
+    try:
+        # replace with something better
+        file = os.path.join(gisbase, 'test')
+        f = open(file, "w")
+        f.close()
+        os.remove(file)
+        ret = grass.call(['make'
+                          'MODULE_TOPDIR=%s' % gisbase,
+                          'install'])
+    except IOError:
+        ret = grass.call(['sudo', 'make'
+                          'install'])
+    if ret != 0:
+        cleanup()
+        grass.fatal('Installation failed, sorry. Please check above error messages.')
+    grass.message("Installation of '%s' successfully finished." % module)
+    cleanup()
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/general/g.extension.add/g.extension.add.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
