[GRASS-SVN] r38265 - grass/trunk/scripts/g.extension
Sun Jul 5 14:46:46 EDT 2009
Author: martinl
Date: 2009-07-05 14:46:46 -0400 (Sun, 05 Jul 2009)
New Revision: 38265
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: print warning if module already installed
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2009-07-05 18:37:19 UTC (rev 38264)
+++ grass/trunk/scripts/g.extension/g.extension.py	2009-07-05 18:46:46 UTC (rev 38265)
@@ -115,6 +115,9 @@
     grass.try_rmdir(tmpdir)
 def install_extension(gisbase, module):
+    if grass.find_program(module):
+        grass.warning("Extension '%s' already installed. Will be updated..." % module)
     classchar = module.split('.', 1)[0]
     moduleclass = expand_module_class_name(classchar)
     global svnurl_addons
@@ -166,7 +169,7 @@
         if os.path.isfile(file):
             os.remove(file)
-    grass.message("'%s' successfully removed." % module)
+    grass.message("'%s' successfully uninstalled." % module)
 def main():
     # check dependecies
