[GRASS-SVN] r38321 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Jul 8 15:25:27 EDT 2009
Author: martinl
Date: 2009-07-08 15:25:26 -0400 (Wed, 08 Jul 2009)
New Revision: 38321
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI: save named region - clean up
       (merge from trunk, r38320)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2009-07-08 19:22:00 UTC (rev 38320)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2009-07-08 19:25:26 UTC (rev 38321)
@@ -211,66 +211,61 @@
     return (None, dlg.addbox.IsChecked())
 class SavedRegion(wx.Dialog):
-    def __init__(self, parent, id, title="", pos=wx.DefaultPosition, size=wx.DefaultSize,
-                 style=wx.DEFAULT_DIALOG_STYLE,
-                 loadsave='load'):
+    def __init__(self, parent, id = wx.ID_ANY, title="", loadsave='load',
+                 **kwargs):
+        """!Loading and saving of display extents to saved region file
+        @param loadsave load or save region?
-        Loading and saving of display extents to saved region file
-        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        wx.Dialog.__init__(self, parent, id, title, **kwargs)
         self.loadsave = loadsave
         self.wind = ''
         sizer = wx.BoxSizer(wx.VERTICAL)
         box = wx.BoxSizer(wx.HORIZONTAL)
+        label = wx.StaticText(parent=self, id=wx.ID_ANY)
+        box.Add(item=label, proportion=0, flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
         if loadsave == 'load':
-            label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Load region:"))
-            box.Add(item=label, proportion=0, flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
-            self.selection = gselect.Select(parent=self, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
-                                            type='windows')
-            self.selection.SetFocus()
-            box.Add(item=self.selection, proportion=0, flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
-            self.selection.Bind(wx.EVT_TEXT, self.OnSelection)
+            label.SetLabel(_("Load region:"))
+            selection = gselect.Select(parent=self, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
+                                       type='windows')
         elif loadsave == 'save':
-            label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Save region:"))
-            self.textentry = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="",
-                                         size=globalvar.DIALOG_TEXTCTRL_SIZE)
-            self.textentry.SetFocus()
-            box.Add(item=self.textentry, proportion=0, flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
-            self.textentry.Bind(wx.EVT_TEXT, self.OnText)
+            label.SetLabel(_("Save region:"))
+                                       type='windows', mapsets = [grass.gisenv()['MAPSET']])
+        box.Add(item=selection, proportion=0, flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
+        selection.SetFocus()
+        selection.Bind(wx.EVT_TEXT, self.OnRegion)
         sizer.Add(item=box, proportion=0, flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL,
                   border=5)
         line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20, -1), style=wx.LI_HORIZONTAL)
         sizer.Add(item=line, proportion=0,
                   flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=5)
         btnsizer = wx.StdDialogButtonSizer()
-        btn = wx.Button(self, wx.ID_OK)
+        btn = wx.Button(parent = self, id = wx.ID_OK)
         btn.SetDefault()
         btnsizer.AddButton(btn)
-        btn = wx.Button(self, wx.ID_CANCEL)
+        btn = wx.Button(parent = self, id = wx.ID_CANCEL)
         btnsizer.Realize()
         sizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
         self.SetSizer(sizer)
         sizer.Fit(self)
-    def OnSelection(self, event):
+        self.Layout()
+    def OnRegion(self, event):
         self.wind = event.GetString()
-    def OnText(self, event):
-        self.wind = event.GetString()
 class DecorationDialog(wx.Dialog):
     Controls setting options and displaying/hiding map overlay decorations
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-07-08 19:22:00 UTC (rev 38320)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-07-08 19:25:26 UTC (rev 38321)
@@ -2620,19 +2620,22 @@
         """!Set display geometry to match extents in
         saved region file
-        dlg = gdialogs.SavedRegion(parent = self, id = wx.ID_ANY,
+        dlg = gdialogs.SavedRegion(parent = self,
                                    title = _("Zoom to saved region extents"),
-                                   pos=wx.DefaultPosition, size=wx.DefaultSize,
                                    loadsave='load')
-        if dlg.ShowModal() == wx.ID_CANCEL:
+        if dlg.ShowModal() == wx.ID_CANCEL or not dlg.wind:
             dlg.Destroy()
             return
-        wind = dlg.wind
+        if not grass.find_file(name = dlg.wind, element = 'windows')['name']:
+            wx.MessageBox(parent = self,
+                          message = _("Region <%s> not found. Operation canceled.") % dlg.wind,
+                          caption = _("Error"), style = wx.ICON_ERROR | wx.OK | wx.CENTRE)
+            dlg.Destroy()
+            return
-        self.Map.GetRegion(regionName = wind,
+        self.Map.GetRegion(regionName = dlg.wind,
                            update = True)
         dlg.Destroy()
@@ -2649,50 +2652,34 @@
         Save display extents to named region file.
-        dlg = gdialogs.SavedRegion(self, wx.ID_ANY, "Save display extents to region file",
+                                   title = _("Save display extents to region file"),
                                    loadsave='save')
             dlg.Destroy()
             return
-        wind = dlg.wind
         # test to see if it already exists and ask permission to overwrite
-        windpath = os.path.join(self.Map.env["GISDBASE"], self.Map.env["LOCATION_NAME"],
-                                self.Map.env["MAPSET"],"windows",wind)
-        if windpath and not os.path.exists(windpath):
-            self.SaveRegion(wind)
-        elif windpath and os.path.exists(windpath):
-            overwrite = wx.MessageBox(_("Region file <%s> already exists. "
-                                        "Do you want to overwrite it?") % (wind),
-                                      _("Warning"), wx.YES_NO)
+        if grass.find_file(name = dlg.wind, element = 'windows')['name']:
+            overwrite = wx.MessageBox(parent = self,
+                                      message = _("Region file <%s> already exists. "
+                                                  "Do you want to overwrite it?") % (dlg.wind),
+                                      caption = _("Warning"), style = wx.YES_NO | wx.CENTRE)
             if (overwrite == wx.YES):
+                self.SaveRegion(dlg.wind)
         else:
-            pass
         dlg.Destroy()
     def SaveRegion(self, wind):
-        Save region settings
+        """!Save region settings
+        @param wind region name
-        new = self.Map.AlignResolution()
+        new = self.Map.GetCurrentRegion()
-        cmdRegion = ["g.region",
-                     "-u",
-                     "n=%f" % new['n'],
-                     "s=%f" % new['s'],
-                     "e=%f" % new['e'],
-                     "w=%f" % new['w'],
-                     "rows=%d" % new['rows'],
-                     "cols=%d" % new['cols'],
-                     "save=%s" % wind,
-                     "--o"]
         tmpreg = os.getenv("GRASS_REGION")
         if tmpreg:
             del os.environ["GRASS_REGION"]
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2009-07-08 19:22:00 UTC (rev 38320)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2009-07-08 19:25:26 UTC (rev 38321)
@@ -665,10 +665,7 @@
                               "Force quiting wxGUI. Please run manually g.region to "
                               "fix the problem.")
             e.Show()
-            if not rast and not vect:
-                sys.exit(1)
-            else:
-                return self.region
+            return self.region
         for reg in ret.splitlines():
             key, val = reg.split("=", 1)
