[GRASS-SVN] r38323 - grass/branches/releasebranch_6_4/scripts/v.in.e00
Thu Jul 9 02:48:19 EDT 2009
Author: hamish
Date: 2009-07-09 02:48:19 -0400 (Thu, 09 Jul 2009)
New Revision: 38323
   grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00
correct quoting so it works with spaces in path names (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00
--- grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00	2009-07-09 06:45:15 UTC (rev 38322)
+++ grass/branches/releasebranch_6_4/scripts/v.in.e00/v.in.e00	2009-07-09 06:48:19 UTC (rev 38323)
@@ -111,11 +111,11 @@
 fi
 if [ -n "$GIS_OPT_FILE" ] ; then
-    E00NAME=`basename $GIS_OPT_FILE .e00`
+    E00NAME=`basename "$GIS_OPT_FILE" .e00`
     # to avoid CAPs problem:
-    E00NAME=`basename $E00NAME .E00`
+    E00NAME=`basename "$E00NAME" .E00`
     # avcimport only accepts 13 chars:
-    E00SHORTNAME="`echo $E00NAME | cut -b1-13`"
+    E00SHORTNAME="`echo "$E00NAME" | cut -b1-13`"
 fi
 #check if this is a split E00 file (.e01, .e02 ...):
@@ -155,7 +155,7 @@
 rm -f "$TMPDIR"
 mkdir "$TMPDIR"
-install -m 644 $E00NAME.e* $E00NAME.E* "$TMPDIR" 2>/dev/null
+install -m 644 "$E00NAME.e"* "$E00NAME.E"* "$TMPDIR" 2> /dev/null
 #change to temporary directory to later avoid removal problems (rm -r ...)
 cd "$TMPDIR"
@@ -218,13 +218,16 @@
 if [ "$GIS_OPT_TYPE" = "area" ] ; then
-        g.message "Importing areas..."
-        # we must reconstruct topology and cleanup polygons:
-        v.in.ogr -o dsn="$E00SHORTNAME" layer=LAB,ARC type=centroid,boundary output="$NAME"
-	if [ $? -eq 1 ] ; then
-   	g.message -e "An error occurred. Stop."
-   	rm -rf "$E00TMP.e00" "$E00SHORTNAME" info 2>&1 > /dev/null
-   	exit 1
+	g.message "Importing areas..."
+	# we must reconstruct topology and cleanup polygons:
+	v.in.ogr -o dsn="$E00SHORTNAME" layer=LAB,ARC \
+		type=centroid,boundary output="$NAME"
+	if [ $? -ne 0 ] ; then
+	   g.message -e "An error occurred. Halting."
+	   rm -rf "$E00TMP.e00" "$E00SHORTNAME" info 2>&1 > /dev/null
+	   exit 1
 	fi
 fi
