[GRASS-SVN] r38336 - grass/trunk/gui/wxpython/gui_modules
Thu Jul 9 14:34:48 EDT 2009
Author: martinl
Date: 2009-07-09 14:34:48 -0400 (Thu, 09 Jul 2009)
New Revision: 38336
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
attempt to fix trac #483
       (merge from relbr64, r38334)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-07-09 18:25:06 UTC (rev 38335)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-07-09 18:34:48 UTC (rev 38336)
@@ -1362,7 +1362,7 @@
                 vectstr += "%s," % name
         # use display region settings instead of computation region settings
-        tmpreg = os.getenv("GRASS_REGION")
+        self.tmpreg = os.getenv("GRASS_REGION")
         os.environ["GRASS_REGION"] = self.Map.SetRegion(windres=False)
         # build query commands for any selected rasters and vectors
@@ -1398,19 +1398,33 @@
         if self._layerManager:
             if raststr:
                 self._layerManager.goutput.RunCmd(rcmd,
-                                                  compReg=False)
+                                                  compReg=False,
+                                                  onDone = self._QueryMapDone)
             if vectstr:
-                self._layerManager.goutput.RunCmd(vcmd)
+                self._layerManager.goutput.RunCmd(vcmd,
         else:
             if raststr:
                 gcmd.RunCommand(rcmd)
             if vectstr:
                 gcmd.RunCommand(vcmd)
+    def _QueryMapDone(self, returncode):
+        """!Restore settings after querying (restore GRASS_REGION)
-        # restore GRASS_REGION
-        if tmpreg:
-            os.environ["GRASS_REGION"] = tmpreg
+        @param returncode command return code
+        if hasattr(self, "tmpreg"):
+            if self.tmpreg:
+                os.environ["GRASS_REGION"] = self.tmpreg
+            elif os.environ.has_key('GRASS_REGION'):
+                del os.environ["GRASS_REGION"]
+            del self.tmpreg
     def QueryVector(self, x, y):
         Query vector map layer features
