[GRASS-SVN] r38339 - in grass/trunk: gui/wxpython/gui_modules include lib/gis vector/v.distance
Fri Jul 10 04:22:52 EDT 2009
Author: martinl
Date: 2009-07-10 04:22:50 -0400 (Fri, 10 Jul 2009)
New Revision: 38339
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/include/gis.h
   grass/trunk/lib/gis/parser.c
   grass/trunk/vector/v.distance/main.c
attempt to fix trac #671 (wxgui: v.distance to_column option inaccessible)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-07-09 20:23:22 UTC (rev 38338)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-07-10 08:22:50 UTC (rev 38339)
@@ -50,6 +50,7 @@
 import textwrap
 import os
 import time
+import types
 import copy
 import locale
 from threading import Thread
@@ -228,7 +229,27 @@
                                                 'database' : db }
             elif name == 'ColumnSelect':
-                pLayer = self.task.get_param('layer', element='element', raiseError=False)
+                if not map:
+                    # standard way failed, try to track wxIds manually
+                    if p.get('element', '') == 'vector':
+                        map = p.get('value', '')
+                        # get layer
+                        for bid in p['wxId-bind']:
+                            p = self.task.get_param(bid, element = 'wxId', raiseError = False)
+                            if not p:
+                                continue
+                            if p.get('element', '') == 'layer':
+                                pLayer = p
+                                break
+                    elif p.get('element', '') == 'layer':
+                        pLayer = p
+                        # get vector name
+                        pMap = self.task.get_param(p['wxId'], element = 'wxId-bind', raiseError = False)
+                        if pMap:
+                            map = pMap.get('value', '')
+                else:
+                    pLayer = self.task.get_param('layer', element='element', raiseError=False)
                 if pLayer:
                     if pLayer.get('value', '') != '':
                         layer = int(pLayer.get('value', 1))
@@ -333,12 +354,21 @@
     def get_param(self, value, element='name', raiseError=True):
         """!Find and return a param by name."""
-        for p in self.params:
-            if p[element] == value:
-                return p
+        try:
+            for p in self.params:
+                val = p[element]
+                if type(val) in (types.ListType, types.TupleType):
+                    if value in val:
+                        return p
+                else:
+                    if p[element] == value:
+                        return p
+        except KeyError:
+            pass
         if raiseError:
-            raise ValueError, _("Parameter not found: %s") % \
-                value
+            raise ValueError, _("Parameter element '%s' not found: '%s'") % \
+                (element, value)
         else:
             return None
@@ -465,22 +495,23 @@
                     key_desc.append(ki.text)
             self.task.params.append( {
-                "name"        : p.get('name'),
-                "type"        : p.get('type'),
-                "required"    : p.get('required'),
-                "multiple"    : p.get('multiple'),
-                "label"       : self.__getNodeText(p, 'label'),
-                "description" : self.__getNodeText(p, 'description'),
-                'gisprompt'   : gisprompt,
-                'age'         : age,
-                'element'     : element,
-                'prompt'      : prompt,
-                "guisection"  : self.__getNodeText(p, 'guisection'),
-                "default"     : self.__getNodeText(p, 'default'),
-                "values"      : values,
-                "values_desc" : values_desc,
-                "value"       : '',
-                "key_desc"    : key_desc } )
+                "name"           : p.get('name'),
+                "type"           : p.get('type'),
+                "required"       : p.get('required'),
+                "multiple"       : p.get('multiple'),
+                "label"          : self.__getNodeText(p, 'label'),
+                "description"    : self.__getNodeText(p, 'description'),
+                'gisprompt'      : gisprompt,
+                'age'            : age,
+                'element'        : element,
+                'prompt'         : prompt,
+                "guisection"     : self.__getNodeText(p, 'guisection'),
+                "guidependency"  : self.__getNodeText(p, 'guidependency'),
+                "default"        : self.__getNodeText(p, 'default'),
+                "values"         : values,
+                "values_desc"    : values_desc,
+                "value"          : '',
+                "key_desc"       : key_desc } )
     def __processFlags(self):
         """!Process flags description"""
@@ -1383,8 +1414,18 @@
             if p.get('gisprompt', False) == False:
                 continue
+            guidep = p.get('guidependency', '')
+            if guidep:
+                # fixed options dependency defined
+                options = guidep.split(',')
+                for opt in options:
+                    pOpt = self.task.get_param(opt, element = 'name', raiseError = False)
+                    if id:
+                        if not p.has_key('wxId-bind'):
+                            p['wxId-bind'] = list()
+                        p['wxId-bind'].append(pOpt['wxId'])
             prompt = p.get('element', '')
             if prompt == 'vector':
                 name = p.get('name', '')
                 if name in ('map', 'input'):
@@ -1400,6 +1441,7 @@
             elif prompt == 'dbtable':
                 pTable = p
+        # collect ids
         pColumnIds = []
         for p in pColumn:
             pColumnIds.append(p['wxId'])
@@ -1407,13 +1449,15 @@
         for p in pLayer:
             pLayerIds.append(p['wxId'])
+        # set wxId-bindings
         if pMap:
             pMap['wxId-bind'] = copy.copy(pColumnIds)
             if pLayer:
                 pMap['wxId-bind'] += pLayerIds
-        for p in pLayer:
-            p['wxId-bind'] = copy.copy(pColumnIds)
+        if len(pLayer) == 1:
+            # TODO: fix modules with more 'layer' options
+            pLayer[0]['wxId-bind'] = copy.copy(pColumnIds)
         if pDriver and pTable:
             pDriver['wxId-bind'] = [pTable['wxId'], ]
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2009-07-09 20:23:22 UTC (rev 38338)
+++ grass/trunk/include/gis.h	2009-07-10 08:22:50 UTC (rev 38339)
@@ -319,6 +319,9 @@
     struct Option *next_opt;	/* Pointer to next option struct    */
     const char *gisprompt;	/* Interactive prompt guidance      */
     const char *guisection;	/* GUI Layout guidance: ';' delimited heirarchical tree position */
+    const char *guidependency;  /* GUI dependency, list of options
+				   (separated by commas) to be updated
+				   if the value is chanched */
     int (*checker) ();		/* Routine to check answer or NULL  */
     int count;
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2009-07-09 20:23:22 UTC (rev 38338)
+++ grass/trunk/lib/gis/parser.c	2009-07-10 08:22:50 UTC (rev 38339)
@@ -233,7 +233,7 @@
  * format: <i>key=value</i>. Options identified as REQUIRED must be
  * specified by user on command line. The option string can either
  * specify a range of values (e.g. "10-100") or a list of acceptable
- * values (e.g. "red,orange,yellow").  Unless the option string is
+ * values (e.g. "red,orange,yellow"). Unless the option string is
  * NULL, user provided input will be evaluated agaist this string.
  * \return pointer to an Option struct
@@ -269,7 +269,8 @@
     opt->description = NULL;
     opt->descriptions = NULL;
     opt->guisection = NULL;
+    opt->guidependency = NULL;
     st->current_option = opt;
     st->n_opts++;
@@ -1444,6 +1445,11 @@
 		print_escaped_for_xml(stdout, opt->guisection);
 		fprintf(stdout, "\n\t\t</guisection>\n");
+	    if (opt->guidependency) {
+		fprintf(stdout, "\t\t<guidependency>\n\t\t\t");
+		print_escaped_for_xml(stdout, opt->guidependency);
+		fprintf(stdout, "\n\t\t</guidependency>\n");
 	    /* TODO:
 	     * - key_desc?
 	     * - there surely are some more. which ones?
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2009-07-09 20:23:22 UTC (rev 38338)
+++ grass/trunk/vector/v.distance/main.c	2009-07-10 08:22:50 UTC (rev 38339)
@@ -145,12 +145,12 @@
     from_field_opt->key = "from_layer";
     from_field_opt->label = _("Layer number (from)");
     from_field_opt->guisection = _("From");
     to_field_opt = G_define_standard_option(G_OPT_V_FIELD);
     to_field_opt->key = "to_layer";
     to_field_opt->label = _("Layer number (to)");
     to_field_opt->guisection = _("To");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
     out_opt->key = "output";
     out_opt->required = NO;
@@ -206,7 +206,7 @@
     to_column_opt->description =
 	_("Column name of nearest feature (used with upload=to_attr)");
     to_column_opt->guisection = _("To");
     table_opt = G_define_standard_option(G_OPT_DB_TABLE);
     table_opt->gisprompt = "new_dbtable,dbtable,dbtable";
     table_opt->description =
@@ -225,6 +225,12 @@
 	_("Calculate distances to all features within the threshold");
     all_flag->description = _("The output is written to stdout but may be uploaded " "to a new table created by this module. " "From categories are may be multiple.");	/* huh? */
+    /* GUI dependency */
+    from_opt->guidependency = G_store(from_field_opt->key);
+    sprintf(buf1, "%s,%s", to_field_opt->key, to_column_opt->key);
+    to_opt->guidependency = G_store(buf1);
+    to_field_opt->guidependency = G_store(to_column_opt->key);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
