[GRASS-SVN] r38352 - grass-addons/vector/v.krige
Fri Jul 10 11:10:02 EDT 2009
Author: aghisla
Date: 2009-07-10 11:10:02 -0400 (Fri, 10 Jul 2009)
New Revision: 38352
   grass-addons/vector/v.krige/v.krige.py
cleanup, stripped comments
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py	2009-07-10 15:02:11 UTC (rev 38351)
+++ grass-addons/vector/v.krige/v.krige.py	2009-07-10 15:10:02 UTC (rev 38352)
@@ -444,14 +444,7 @@
         self.SetSizerAndFit(self.Sizer)
-def main(argv=None):
-    #@TODO(anne): check all dependencies and data here.
-    # grass - rpy2 - R - one of automap/gstat/geoR
-    # a nice splash screen like QGIS does can fit the purpose, with a log message on the bottom and
-    # popup windows for missing stuff messages.
-    # For the moment, deps are checked when creating the notebook pages for each package, and the
-    # data availability when clicking Run button. Quite late.
+def main(argv=None):
     #@FIXME: solve this double ifelse. the control should not be done twice.
     if argv is None:
         argv = sys.argv[1:] #stripping first item, the full name of this script
@@ -478,7 +471,7 @@
         # check for output map with same name. g.parser can't handle this, afaik.
         if grass.find_file(options['output'], element = 'cell')['fullname'] and not os.getenv("GRASS_OVERWRITE"):
             grass.fatal(_("option: <output>: Raster map already exists."))
         if options['model'] is '':
             try:
                 robjects.r.require("automap")
