[GRASS-SVN] r38363 - in grass/trunk: gui/wxpython/gui_modules scripts/v.db.join
Sat Jul 11 04:39:19 EDT 2009
Author: martinl
Date: 2009-07-11 04:39:18 -0400 (Sat, 11 Jul 2009)
New Revision: 38363
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/scripts/v.db.join/v.db.join.py
fix 'problem with gui wx with module v.db.join' - trac #490
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-07-11 08:02:10 UTC (rev 38362)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-07-11 08:39:18 UTC (rev 38363)
@@ -213,74 +213,68 @@
             win = self.parent.FindWindowById(uid)
             name = win.GetName()
-            if name == 'LayerSelect':
-                if not map and p.get('element', '') == 'vector':
-                    # standard way failed, try to track wxIds manually
+            map = layer = None
+            driver = db = table = None
+            if name in ('LayerSelect', 'ColumnSelect'):
+                if p.get('element', '') == 'vector': # -> vector
+                    # get map name
                     map = p.get('value', '')
-                if map:
-                    self.data[win.InsertLayers] = { 'vector' : map }
+                    # get layer
+                    for bid in p['wxId-bind']:
+                        p = self.task.get_param(bid, element = 'wxId', raiseError = False)
+                        if not p:
+                            continue
+                        if p.get('element', '') == 'layer':
+                            layer = p.get('value', '')
+                            if layer != '':
+                                layer = int(p.get('value', 1))
+                            else:
+                                layer = int(p.get('default', 1))
+                            break
+                elif p.get('element', '') == 'layer': # -> layer
+                    # get layer
+                    if layer != '':
+                    else:
+                    # get map name
+                    pMap = self.task.get_param(p['wxId'], element = 'wxId-bind', raiseError = False)
+                    if pMap:
+                        map = pMap.get('value', '')
-            elif name == 'TableSelect':
+            if name == 'TableSelect' or \
+                    (name == 'ColumnSelect' and not map):
                 pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
-                driver = db = None
                 if pDriver:
-                    driver = pDriver['value']
+                    driver = pDriver.get('value', '')
                 pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
                 if pDb:
-                    db = pDb['value']
+                    db = pDb.get('value', '')
+                if name == 'ColumnSelect':
+                    pTable = self.task.get_param('dbtable', element='element', raiseError=False)
+                    if pTable:
+                        table = pTable.get('value', '')
+            if name == 'LayerSelect':
+                self.data[win.InsertLayers] = { 'vector' : map }
+            elif name == 'TableSelect':
                 self.data[win.InsertTables] = { 'driver' : driver,
                                                 'database' : db }
             elif name == 'ColumnSelect':
-                if not map:
-                    if p.get('element', '') == 'vector':
-                        map = p.get('value', '')
-                        # get layer
-                        for bid in p['wxId-bind']:
-                            p = self.task.get_param(bid, element = 'wxId', raiseError = False)
-                            if not p:
-                                continue
-                            if p.get('element', '') == 'layer':
-                                pLayer = p
-                                break
-                    elif p.get('element', '') == 'layer':
-                        pLayer = p
-                        # get vector name
-                        pMap = self.task.get_param(p['wxId'], element = 'wxId-bind', raiseError = False)
-                        if pMap:
-                            map = pMap.get('value', '')
-                else:
-                    pLayer = self.task.get_param('layer', element='element', raiseError=False)
-                if pLayer:
-                    if pLayer.get('value', '') != '':
-                        layer = int(pLayer.get('value', 1))
-                    else:
-                        layer = int(pLayer.get('default', 1))
-                else:
-                    layer = 1
                 if map:
                     self.data[win.InsertColumns] = { 'vector' : map, 'layer' : layer }
                 else: # table
-                    pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
-                    if pDriver:
-                        driver = pDriver.get('value', None)
-                    pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
-                    if pDb:
-                        db = pDb.get('value', None)
-                    pTable = self.task.get_param('dbtable', element='element', raiseError=False)
-                    if pTable and \
-                            pTable.get('value', '') != '':
-                        if driver and db:
-                            self.data[win.InsertTableColumns] = { 'table' : pTable.get('value'),
-        'driver' : driver,
-        'database' : db }
-                        else:
-                            self.data[win.InsertTableColumns] = { 'table'  : pTable.get('value') }
+                    if driver and db:
+                        self.data[win.InsertTableColumns] = { 'table' : pTable.get('value'),
+                                                              'driver' : driver,
+                                                              'database' : db }
+                    else:
+                        self.data[win.InsertTableColumns] = { 'table'  : pTable.get('value') }
 def UpdateDialog(parent, event, eventId, task):
     return UpdateThread(parent, event, eventId, task)
@@ -1419,6 +1413,7 @@
                 continue
             guidep = p.get('guidependency', '')
             if guidep:
                 # fixed options dependency defined
                 options = guidep.split(',')
@@ -1428,6 +1423,7 @@
                         if not p.has_key('wxId-bind'):
                             p['wxId-bind'] = list()
                         p['wxId-bind'].append(pOpt['wxId'])
+                continue
             prompt = p.get('element', '')
             if prompt == 'vector':
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2009-07-11 08:02:10 UTC (rev 38362)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2009-07-11 08:39:18 UTC (rev 38363)
@@ -6,7 +6,7 @@
 # AUTHOR(S):    Markus Neteler
 #               Converted to Python by Glynn Clements
 # PURPOSE:      Join a table to a map table
-# COPYRIGHT:    (C) 2007 by Markus Neteler and the GRASS Development Team
+# COPYRIGHT:    (C) 2007-2009 by Markus Neteler and the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,6 +26,7 @@
 #% gisprompt: old,vector,vector
 #% description: Vector map to which to join other table
 #% required : yes
+#% guidependency: layer,column
 #%end
 #%option
@@ -35,6 +36,7 @@
 #% answer: 1
 #% required : no
 #% gisprompt: old_layer,layer,layer
+#% guidependency: column
 #%end
 #%option
@@ -51,6 +53,7 @@
 #% description: Other table name
 #% required : yes
 #% gisprompt: old_dbtable,dbtable,dbtable
+#% guidependency: ocolumn
 #%end
 #%option
