[GRASS-SVN] r38381 - in grass-addons/vector: . v.in.gama
Mon Jul 13 05:50:49 EDT 2009
Author: martinl
Date: 2009-07-13 05:50:47 -0400 (Mon, 13 Jul 2009)
New Revision: 38381
Added:
   grass-addons/vector/v.in.gama/
   grass-addons/vector/v.in.gama/Makefile
   grass-addons/vector/v.in.gama/ToDo
   grass-addons/vector/v.in.gama/description.html
   grass-addons/vector/v.in.gama/gama-local-adjustment.dtd
   grass-addons/vector/v.in.gama/global.h
   grass-addons/vector/v.in.gama/head.c
   grass-addons/vector/v.in.gama/main.c
   grass-addons/vector/v.in.gama/parse.c
   grass-addons/vector/v.in.gama/table.c
   grass-addons/vector/v.in.gama/tables.xml
   grass-addons/vector/v.in.gama/tree.c
   grass-addons/vector/v.in.gama/vect.c
v.in.gama (2006) moved to GRASS Add-ons
Property changes on: grass-addons/vector/v.in.gama
___________________________________________________________________
Added: svn:ignore
   + *.tmp.html
OBJ.*
Added: grass-addons/vector/v.in.gama/Makefile
--- grass-addons/vector/v.in.gama/Makefile	                        (rev 0)
+++ grass-addons/vector/v.in.gama/Makefile	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,18 @@
+# MODULE_TOPDIR = ../..
+MODULE_TOPDIR = /home/landa/src/grass6_devel
+PGM = v.in.gama
+LIBES = $(VECTLIB) $(GISLIB) `xml2-config --libs`
+DEPENDENCIES= $(VECTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS) `xml2-config --cflags`
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd xml
+xml:
+	if [ ! -d $(GISBASE)/etc ]; then $(MKDIR) $(GISBASE)/etc; fi
+	if [ ! -d $(GISBASE)/etc/v.in.gama ]; then $(MKDIR) $(GISBASE)/etc/v.in.gama; fi
+	$(INSTALL) -m 644 tables.xml $(GISBASE)/etc/v.in.gama/
Property changes on: grass-addons/vector/v.in.gama/Makefile
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/vector/v.in.gama/ToDo
--- grass-addons/vector/v.in.gama/ToDo	                        (rev 0)
+++ grass-addons/vector/v.in.gama/ToDo	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,8 @@
+ToDo
+* SQL X C types ?
+* use DTD
+* G_debug ()
+* patch d.what.vect
+* patch v.info
\ No newline at end of file
Added: grass-addons/vector/v.in.gama/description.html
--- grass-addons/vector/v.in.gama/description.html	                        (rev 0)
+++ grass-addons/vector/v.in.gama/description.html	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,61 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.gama</em> creates a GRASS vector map layer based on GNU GaMa
+XML output file. This file (which contains adjustment results of
+geodetic network) can be created by <em>gama-local</em> tool.
+<h2>EXAMPLE</h2>
+First, we adjust geodetic network by <em>gama-local</em> tool. The
+adjustment results are saved also in XML data format.
+<div class="code"><pre>
+gama-local --xmlout network.xml network.gkf
+</pre></div>
+Afterwards we create a map layer <i>network</i> by the
+module <em>v.in.gama</em>:
+v.in.gama input=network.xml output=network
+</pre></div>
+This map layer contains two different layers. Layer 1 is connected
+with attribute table 'network_point', layer 2 with 'network_obs'. In the first
+layer are stored points of geodetic network. Layer 2 contains
+observation data (in geometry way lines and points).
+<h2>NOTES</h2>
+<b>GNU Gama</b> is a project dedicated to adjustment of geodetic
+networks. GNU Gama is released under GNU General Public Licence. For
+parsing XML documents GNU Gama calls <em>expat</em> parser written by James
+Clark.
+<p>
+GNU Gama currently contains two main development branches. Stable
+branch of the project is limited to network adjustment in a local
+coordinate system (program <em>gama-local</em>). In the unstable development
+branch the adjustment model is based on geocentric coordinate system
+(program <em>gama-g3</em>).
+<p>
+The development version of the program <em>gama-local</em> enables
+to save adjustment results besides of the standard text format also in
+newly designed XML output data format. This feature is fundamental for
+GRASS module <em>v.in.gama</em>. Currently it is possible to
+use <em>v.in.gama</em> only in connection with
+<em>gama-local</em> from unstable development branch.
+<h2>REFERENCES</h2>
+<ul>
+  <li><a href="http://www.gnu.org/software/gama/">GNU Gama</a> &nbsp; adjustment of geodetic networks</li>
+</ul>
+<h2>AUTHOR</h2>
+Martin Landa, CTU in Prague, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/vector/v.in.gama/description.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/vector/v.in.gama/gama-local-adjustment.dtd
--- grass-addons/vector/v.in.gama/gama-local-adjustment.dtd	                        (rev 0)
+++ grass-addons/vector/v.in.gama/gama-local-adjustment.dtd	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,217 @@
+        gama-local-adjustment.dtd          version 0.4a  2006-02-19
+        http://www.gnu.org/software/gama/gama-local-adjustment.dtd
+<!ELEMENT gama-local-adjustment (
+        description,
+        network-general-parameters,
+        network-processing-summary,
+        coordinates,
+        observations ) >
+<!ATTLIST gama-local-adjustment version NMTOKEN #REQUIRED >
+<!ELEMENT description ( #PCDATA ) >
+<!ELEMENT network-general-parameters EMPTY >
+<!ATTLIST network-general-parameters
+        axes-xy (ne | sw | es | wn |
+                 en | nw | se | ws )          "ne"
+        angles  (right-handed | left-handed)  "right-handed"
+        epoch    NMTOKEN                      "0.0" >
+<!ELEMENT network-processing-summary (
+        coordinates-summary,
+        observations-summary,
+        project-equations,
+        standard-deviation ) >
+<!ELEMENT coordinates-summary (
+        coordinates-summary-adjusted,
+        coordinates-summary-constrained,
+        coordinates-summary-fixed ) >
+<!ELEMENT observations-summary (
+        distances,
+        directions,
+        angles,
+        xyz-coords,
+        h-diffs,
+        z-angles,
+        s-dists,
+        vectors ) >
+<!ELEMENT project-equations (
+        equations,
+        unknowns,
+        degrees-of-freedom,
+        defect,
+        sum-of-squares,
+        ( connected-network | disconnected-network ) ) >
+<!ELEMENT standard-deviation (
+        apriori,
+        aposteriori,
+        used,
+        probability,
+        ratio,
+        lower,
+        upper,
+        ( failed | passed ),
+        confidence-scale ) >
+<!ELEMENT coordinates (
+        fixed,
+        approximate,
+        adjusted,
+        orientation-shifts,
+        cov-mat ) >
+<!ELEMENT orientation-shifts ( orientation* ) >
+<!ELEMENT cov-mat ( dim, band, flt+ ) >
+<!ELEMENT observations (
+        distance |
+        direction |
+        angle |
+        height-diff |
+        slope-distance |
+        zenith-angle |
+        dx |
+        dy |
+        dz |
+        coordinate-x |
+        coordinate-y |
+        coordinate-z )* >
+<!ELEMENT adjusted    ( point* ) >
+<!ELEMENT constrained ( point* ) >
+<!ELEMENT fixed       ( point* ) >
+<!ELEMENT connected-network    EMPTY >
+<!ELEMENT disconnected-network EMPTY >
+<!ELEMENT failed EMPTY >
+<!ELEMENT passed EMPTY >
+<!ELEMENT coordinates-summary-adjusted    ( count-xyz, count-xy, count-z ) >
+<!ELEMENT coordinates-summary-constrained ( count-xyz, count-xy, count-z ) >
+<!ELEMENT coordinates-summary-fixed       ( count-xyz, count-xy, count-z ) >
+<!ELEMENT count-xyz ( #PCDATA ) >
+<!ELEMENT count-xy  ( #PCDATA ) >
+<!ELEMENT count-z   ( #PCDATA ) >
+<!ELEMENT point ( id, ((X | x), (Y | y))?, (Z | z)? ) >
+<!ELEMENT orientation ( id, approx, adj ) >
+<!ENTITY  % observation-elements
+        "(obs, adj, stdev, f,  (std-residual, (err-obs, err-adj)? )?)" >
+<!ELEMENT distance       ( from, to,          %observation-elements; ) >
+<!ELEMENT direction      ( from, to,          %observation-elements; ) >
+<!ELEMENT angle          ( from, left, right, %observation-elements; ) >
+<!ELEMENT slope-distance ( from, to,          %observation-elements; ) >
+<!ELEMENT zenith-angle   ( from, to,          %observation-elements; ) >
+<!ELEMENT dx             ( from, to,          %observation-elements; ) >
+<!ELEMENT dy             ( from, to,          %observation-elements; ) >
+<!ELEMENT dz             ( from, to,          %observation-elements; ) >
+<!ELEMENT height-diff    ( from, to,          %observation-elements; ) >
+<!ELEMENT coordinate-x   ( id,                %observation-elements; ) >
+<!ELEMENT coordinate-y   ( id,                %observation-elements; ) >
+<!ELEMENT coordinate-z   ( id,                %observation-elements; ) >
+<!ELEMENT id    ( #PCDATA ) >
+<!ELEMENT from  ( #PCDATA ) >
+<!ELEMENT left  ( #PCDATA ) >
+<!ELEMENT right ( #PCDATA ) >
+<!ELEMENT X ( #PCDATA ) >
+<!ELEMENT x ( #PCDATA ) >
+<!ELEMENT Y ( #PCDATA ) >
+<!ELEMENT y ( #PCDATA ) >
+<!ELEMENT Z ( #PCDATA ) >
+<!ELEMENT z ( #PCDATA ) >
+<!ELEMENT adj ( #PCDATA ) >
+<!ELEMENT angles ( #PCDATA ) >
+<!ELEMENT aposteriori ( #PCDATA ) >
+<!ELEMENT approx ( #PCDATA ) >
+<!ELEMENT approximate ( point+ ) >
+<!ELEMENT apriori ( #PCDATA ) >
+<!ELEMENT axes-xy ( #PCDATA ) >
+<!ELEMENT band ( #PCDATA ) >
+<!ELEMENT confidence-scale ( #PCDATA ) >
+<!ELEMENT defect ( #PCDATA ) >
+<!ELEMENT degrees-of-freedom ( #PCDATA ) >
+<!ELEMENT dim ( #PCDATA ) >
+<!ELEMENT directions ( #PCDATA ) >
+<!ELEMENT distances ( #PCDATA ) >
+<!ELEMENT epoch ( #PCDATA ) >
+<!ELEMENT equations ( #PCDATA ) >
+<!ELEMENT err-adj ( #PCDATA ) >
+<!ELEMENT err-obs ( #PCDATA ) >
+<!ELEMENT f ( #PCDATA ) >
+<!ELEMENT flt ( #PCDATA ) >
+<!ELEMENT h-diffs ( #PCDATA ) >
+<!ELEMENT lower ( #PCDATA ) >
+<!ELEMENT obs ( #PCDATA ) >
+<!ELEMENT probability ( #PCDATA ) >
+<!ELEMENT ratio ( #PCDATA ) >
+<!ELEMENT s-dists ( #PCDATA ) >
+<!ELEMENT std-residual ( #PCDATA ) >
+<!ELEMENT stdev ( #PCDATA ) >
+<!ELEMENT sum-of-squares ( #PCDATA ) >
+<!ELEMENT to ( #PCDATA ) >
+<!ELEMENT unknowns ( #PCDATA ) >
+<!ELEMENT upper ( #PCDATA ) >
+<!ELEMENT used ( #PCDATA ) >
+<!ELEMENT vectors ( #PCDATA ) >
+<!ELEMENT xy ( #PCDATA ) >
+<!ELEMENT xyz ( #PCDATA ) >
+<!ELEMENT xyz-coords ( #PCDATA ) >
+<!ELEMENT z-angles ( #PCDATA ) >
Added: grass-addons/vector/v.in.gama/global.h
--- grass-addons/vector/v.in.gama/global.h	                        (rev 0)
+++ grass-addons/vector/v.in.gama/global.h	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,103 @@
+#ifndef MAIN
+# define EXT extern
+#else
+# define EXT
+#endif
+#ifndef GLOBAL___H
+#define GLOBAL___H
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#include <libxml/parser.h>
+#include <libxml/tree.h>
+#define FIX 0
+#define ADJ 1
+#define APP 2
+#define FIELD_POINT 1
+#define FIELD_OBS   2
+#define DIM   3                   /* coordinates */
+#define ID_LENGTH 128             /* varchar (ID_LENGTH) */
+#define OPTIONS struct _options_
+EXT OPTIONS
+    char* input;
+    char* output;
+    int   dotable;
+} options;
+struct coor
+  double val [3];        /* x_fix, x_adj, x_app */
+  short  is_null [3];
+  short  is_constrained;
+typedef struct _point_
+  int         cat; /* -1 -> not writen to the map due missing x|y */
+  dbString    id;
+  struct coor xyz [3];
+} Point;
+struct list_points
+  Point* point;
+  struct list_points* next;
+struct list_nodes
+  xmlNode* node;
+  struct list_nodes* next;
+/* head.c */
+int write_head (struct Map_info*, xmlDoc*);
+int find_substring (dbString*, const char*, dbString*);
+/* parser.c */
+int parse_command_line(int, char**);
+/* vect.c */
+int create_map (struct Map_info*, xmlDoc*, int);
+int create_points (struct Map_info*, xmlDoc*, int, struct list_points**);
+void point_init (Point*);
+void point_set (Point*, xmlNode*, int, xmlNode*, xmlNode*, xmlNode*);
+void write_points (struct Map_info*, xmlNode*, struct list_points*, int);
+void list_points_free (struct list_points**);
+int list_points_push_back (struct list_points**, Point*);
+Point* find_point (struct list_points*, dbString* id);
+void point_update (Point*, int, xmlNode*, xmlNode*, xmlNode*);
+int point_get_xyz (Point*, char*, double*);
+int point_exists (struct list_points*, dbString*);
+int create_obs (struct Map_info*, xmlDoc*, int, struct list_points*);
+int write_line (struct Map_info*, int, int, int, int);
+/* table.c */
+int create_tables (struct Map_info*, xmlDoc*);
+void insert_point (struct field_info*, dbDriver*, dbTable*, Point*, int);
+void insert_obs   (struct field_info*, dbDriver*, dbTable*, xmlNode*, int);
+/* tree.c */
+int find_node (xmlNode*, const char*, xmlNode**);
+int find_nodes (xmlNode*, const char*, struct list_nodes**);
+void find__nodes (xmlNode*, xmlNode*, const char*, struct list_nodes**, int*, int*);
+void list_init (void**);
+void list_nodes_free (struct list_nodes**);
+void list_nodes_push_back (struct list_nodes** lnodes, xmlNode* node);
+int is_3d_map (xmlDoc*);
+int node_get_value_int (xmlNode*, int*);
+int node_get_value_double (xmlNode*, double*);
+int node_get_value_string (xmlNode*, char*, dbString*);
+int axes_xy_str2type (char *);
+#endif
Property changes on: grass-addons/vector/v.in.gama/global.h
   + text/x-chdr
   + native
Added: grass-addons/vector/v.in.gama/head.c
--- grass-addons/vector/v.in.gama/head.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/head.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,122 @@
+#include "global.h"
+int write_head(struct Map_info *Map, xmlDoc * doc)
+    xmlNode *root;
+    struct list_nodes *desc;
+    dbString val, value;
+    int scale;
+    root = xmlDocGetRootElement(doc);
+    list_init((void **)&desc);
+    db_init_string(&val);
+    db_init_string(&value);
+    if (!root) {
+	G_fatal_error(_("Unable to get the root element"));
+    else {
+	find_nodes(root, "description", &desc);
+	if (desc) {
+	    if (node_get_value_string(desc->node, NULL, &val)) {
+		if (find_substring(&val, "scale", &value)) {
+		    scale = atoi(db_get_string(&value));
+		    if (scale > 0) {
+			Vect_set_scale(Map, scale);
+		else {
+		    Vect_set_scale(Map, 1000);	/* default scale 1000 */
+		if (find_substring(&val, "date", &value)) {
+		    Vect_set_map_date(Map, db_get_string(&value));
+		else {
+		    Vect_set_map_date(Map, G_date());	/* default map date = date */
+		if (find_substring(&val, "name", &value)) {
+		    Vect_set_map_name(Map, db_get_string(&value));
+		else {
+		    Vect_set_map_name(Map, "GNU GaMa network");
+		if (find_substring(&val, "organization", &value)) {
+		    Vect_set_organization(Map, db_get_string(&value));
+		else {
+		    char *organization;
+		    if ((organization =
+			 (char *)G_getenv("GRASS_ORGANIZATION"))) {
+			Vect_set_organization(Map, organization);
+		    else {
+			Vect_set_organization(Map, "GRASS Development Team");
+		if (find_substring(&val, "person", &value)) {
+		    Vect_set_person(Map, db_get_string(&value));
+		else {
+		    Vect_set_person(Map, G_whoami());
+		if (find_substring(&val, "other info", &value)) {
+		    const short int odim = 65;
+		    char other_info[odim];
+		    G_warning(_("Other info is too long, "
+				"only first %d chars will be stored"), odim);
+		    strncpy(other_info, db_get_string(&value), odim);
+		    Vect_set_comment(Map, other_info);
+		else {
+		    Vect_set_comment(Map, "created by v.in.gama");
+	    Vect_set_date(Map, G_date());
+    list_nodes_free(&desc);
+    return 0;
+int find_substring(dbString * str, const char *pattern, dbString * substring)
+    char *c, *s, z[2];
+    dbString buf;
+    db_init_string(&buf);
+    c = strstr(db_get_string(str), pattern);
+    if (c) {
+	s = c + strlen(pattern);
+	if (*(s++) == ':') {
+	    while (*s != '\n' && *s != '\0') {
+		z[0] = *(s++);
+		z[1] = '\0';
+		db_append_string(&buf, z);
+	    db_copy_string(substring, &buf);
+	    return 1;
+	/* maybe a bit confusing
+	   else
+	   G_warning (_("Cannot recognize substring '%s'."),
+	   db_get_string (str));
+    return 0;
Property changes on: grass-addons/vector/v.in.gama/head.c
   + text/x-csrc
   + native
Added: grass-addons/vector/v.in.gama/main.c
--- grass-addons/vector/v.in.gama/main.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/main.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,143 @@
+/* v.in.gama - convert GNU GaMa XML output file to                      */
+/*             a GRASS vector map layer                                 */
+/* Martin Landa, 5/2006                                                 */
+/* This file is part of GRASS GIS. It is free software. You can         */
+/* redistribute it and/or modify it under the terms of                  */
+/* the GNU General Public License as published by the Free Software     */
+/* Foundation; either version 2 of the License, or (at your option)     */
+/* any later version.                                                   */
+#define MAIN
+#include <unistd.h>
+int main(int argc, char *argv[])
+    FILE *input_xml_file, *tables_xml_file;
+    struct Map_info Map;
+    struct GModule *module;
+    xmlDoc *doc, *tables_doc;
+    dbString path_tables_xml;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->description = _("Converts GNU GaMa XML output file "
+			    "to a GRASS vector map layer.");
+    /* parse command line */
+    parse_command_line(argc, argv);
+    /* open temporary file - needed? */
+    char *tmp;
+    FILE *tmpfile;
+    tmp = G_tempfile();
+    tmpfile = fopen(tmp, "w+");
+    if (tmpfile == NULL) {
+	G_fatal_error(_("Unable to open temp file '%s'"), tmp);
+    unlink(tmp);
+    fclose(tmpfile);
+       this initialize the library and check potential ABI mismatches
+       between the version it was compiled for and the actual shared
+       library used.
+    LIBXML_TEST_VERSION;
+    /* read input file
+       open the XML file and get the DOM */
+    if (options.input) {
+	input_xml_file = fopen(options.input, "r");
+	if (!input_xml_file) {
+	    G_fatal_error(_("Unable to open input file '%s'"),
+			  options.input);
+	doc = xmlReadFile(options.input, NULL, 0);
+    else {
+	/* doc = xmlReadFile ("-", NULL, 0); */
+	doc = xmlReadFd(0, NULL, NULL, 0);
+    if (doc == NULL) {
+	G_fatal_error("Parsing file '%s' failed", options.input);
+    G_debug(1, "input XML file opened");
+    /* open the output vector map */
+    Vect_open_new(&Map, options.output, is_3d_map(doc));
+    /* metadata */
+    write_head(&Map, doc);
+    Vect_hist_command(&Map);
+    /* create empty attribute table */
+    if (options.dotable) {
+	db_init_string(&path_tables_xml);
+	db_set_string(&path_tables_xml, G_gisbase());
+	db_append_string(&path_tables_xml, "/etc/");
+	db_append_string(&path_tables_xml, G_program_name());
+	db_append_string(&path_tables_xml, "/tables.xml");
+	tables_xml_file = fopen(db_get_string(&path_tables_xml), "r");
+	if (!tables_xml_file) {
+	    G_fatal_error(_("Unable to open file '%s'"),
+			  db_get_string(&path_tables_xml));
+	tables_doc = xmlReadFile(db_get_string(&path_tables_xml), NULL, 0);
+	if (!tables_doc) {
+	    G_fatal_error(_("Unable to parse parse file '%s'"),
+	create_tables(&Map, tables_doc);
+	xmlFreeDoc(tables_doc);
+	if (tables_xml_file) {
+	    fclose(tables_xml_file);
+    /* point data
+       -> insert attribute data (layer 1) and create vector points
+       observation data
+       -> insert attribute data (layer 2) and create vector lines */
+    create_map(&Map, doc, options.dotable);
+    xmlFreeDoc(doc);
+    xmlCleanupParser();
+	fclose(input_xml_file);
+    Vect_build_partial(&Map, GV_BUILD_NONE);
+    Vect_build(&Map);
+    Vect_close(&Map);
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/vector/v.in.gama/main.c
   + text/x-csrc
   + native
Added: grass-addons/vector/v.in.gama/parse.c
--- grass-addons/vector/v.in.gama/parse.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/parse.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,36 @@
+int parse_command_line(int argc, char *argv[])
+    struct
+	struct Option *input;
+	struct Option *output;
+    } parms;
+    struct
+	struct Flag *t;
+    } flags;
+    parms.input = G_define_standard_option(G_OPT_F_INPUT);
+    parms.input->description =
+	_("GNU GaMa XML output file to be converted to "
+	  "binary vector file, if not given reads from standard input");
+    parms.output = G_define_standard_option(G_OPT_V_OUTPUT);
+    flags.t = G_define_flag();
+    flags.t->key = 't';
+    flags.t->description = _("Do not create attribute table");
+    if (G_parser(argc, argv)) {
+	exit(EXIT_FAILURE);
+    options.input = parms.input->answer;
+    options.output = parms.output->answer;
+    options.dotable = flags.t->answer ? 0 : 1;
+    return 0;
Property changes on: grass-addons/vector/v.in.gama/parse.c
   + text/x-csrc
   + native
Added: grass-addons/vector/v.in.gama/table.c
--- grass-addons/vector/v.in.gama/table.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/table.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,315 @@
+int create_tables(struct Map_info *Map, xmlDoc * doc)
+    int i, num_of_cols, col_type, num_of_tables;
+    struct field_info *fi;
+    int field;
+    dbDriver *driver;
+    dbTable *dbtable;
+    dbColumn *dbcolumn;
+    dbString table_name, col_name, suffix;
+    xmlNode *root, *table, *column, *name, *datatype;
+    struct list_nodes *tables, *columns, *tmp_col, *tmp_tab;
+    num_of_tables = 0;
+    field = 1;
+    dbtable = NULL;
+    db_init_string(&table_name);
+    db_init_string(&col_name);
+    db_init_string(&suffix);
+    list_init((void **)&tables);
+    list_init((void **)&columns);
+    if (!root) {
+    if (!find_nodes(root, "table", &tables)) {
+	G_fatal_error(_("Invalid table structure"));
+    else {
+	for (tmp_tab = tables; tmp_tab; tmp_tab = tmp_tab->next) {
+	    table = tmp_tab->node;
+	    fi = Vect_default_field_info(Map, field, NULL, GV_1TABLE);
+	    if (!fi) {
+		G_fatal_error(_("Unable to get default vector layer"));
+	    driver = db_start_driver_open_database(fi->driver, fi->database);
+	    if (!driver) {
+		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+			      fi->database, fi->driver);
+	    db_begin_transaction(driver);
+	    num_of_cols = find_nodes(table, "column", &columns);
+	    if (num_of_cols < 1) {
+	    else {
+		dbtable = db_alloc_table(num_of_cols);
+		for (tmp_col = columns, i = 0; tmp_col;
+		     i++, tmp_col = tmp_col->next) {
+		    column = tmp_col->node;
+		    dbcolumn = db_get_table_column(dbtable, i);
+		    if (!find_node(column, "name", &name) ||
+			!find_node(column, "datatype", &datatype) ||
+			!node_get_value_string(name, NULL, &col_name) ||
+			!node_get_value_int(datatype, &col_type)) {
+		    db_set_column_name(dbcolumn, db_get_string(&col_name));
+		    db_set_column_sqltype(dbcolumn, col_type);
+		    if (db_get_column_sqltype(dbcolumn) ==
+			DB_SQL_TYPE_CHARACTER) {
+			db_set_column_length(dbcolumn, ID_LENGTH);
+		db_set_string(&table_name, fi->table);
+		if (!node_get_value_string(table, "type", &suffix)) {
+		else {
+		    db_append_string(&table_name, "_");
+		    db_append_string(&table_name, db_get_string(&suffix));
+		fi->table = G_store(db_get_string(&table_name));	/* nasty */
+		db_set_table_name(dbtable, fi->table);
+		if (db_create_table(driver, dbtable) != DB_OK) {
+		    G_fatal_error(_("Unable to create table"));
+		if (driver) {
+		    db_commit_transaction(driver);
+		    db_close_database_shutdown_driver(driver);
+		Vect_map_add_dblink(Map, field++, NULL, fi->table,
+				    fi->key, fi->database, fi->driver);
+		num_of_tables++;
+    list_nodes_free(&tables);
+    list_nodes_free(&columns);
+    return num_of_tables;
+void insert_point(struct field_info *fi, dbDriver * driver, dbTable * table,
+		  Point * point, int cat)
+    int i, ret;
+    double coor_val;
+    char *name;
+    char buff[1024];
+    dbColumn *column;
+    dbString sql;
+    db_init_string(&sql);
+    sprintf(buff, "INSERT INTO %s (", fi->table);
+    db_set_string(&sql, buff);
+    for (i = 0; i < db_get_table_number_of_columns(table); i++) {
+	column = db_get_table_column(table, i);
+	if (i > 0) {
+	    db_append_string(&sql, ",");
+	db_append_string(&sql, db_get_column_name(column));
+    db_append_string(&sql, ") VALUES (");
+	name = (char *)db_get_column_name(column);
+	if (i > 0) {
+	/* category number */
+	if (!G_strcasecmp(name, "cat")) {
+	    sprintf(buff, "%d", cat);
+	    db_append_string(&sql, buff);
+	    continue;
+	/* id */
+	if (!G_strcasecmp(name, "id")) {
+	    if (db_sizeof_string(&(point->id)) > 1) {
+		if (db_sizeof_string(&(point->id)) > ID_LENGTH) {
+		    G_warning
+			("Only first %d characters of point id [%s] will be stored.",
+			 ID_LENGTH, db_get_string(&(point->id)));
+		db_append_string(&sql, "'");
+		db_append_string(&sql, db_get_string(&(point->id)));
+	    else {
+		db_append_string(&sql, "NULL");
+	    continue;
+	/* coordinates */
+	ret = point_get_xyz(point, name, &coor_val);
+	if (ret) {
+	    if (ret == 1)
+		sprintf(buff, "%f", coor_val);
+	    else		/* constrained */
+		sprintf(buff, "%d", (int)coor_val);
+	else {
+    db_append_string(&sql, ")");
+    G_debug(3, "SQL: %s", db_get_string(&sql));
+    if (db_execute_immediate(driver, &sql) != DB_OK) {
+	G_fatal_error(_("Unable to insert new row: '%s'"), db_get_string(&sql));
+    return;
+void insert_obs(struct field_info *fi, dbDriver * driver, dbTable * table,
+		xmlNode * node, int cat)
+       column name | xml
+       from_id     | from
+       to_id       | to
+       left_id     | left
+       right_id    | right
+       _           | -
+    int i;
+    double val;
+    char *c, *cnxml, *cnxml_tmp;
+    char buf[512];
+    dbColumn *column;
+    dbString sql, sval, col_name_xml;
+    xmlNode *obs_val;
+    db_init_string(&sval);
+    db_init_string(&col_name_xml);
+    db_set_string(&sql, "INSERT INTO ");
+    db_append_string(&sql, fi->table);
+    db_append_string(&sql, " (");
+	if (i > 0) {
+    sprintf(buf, "%d", cat);
+    db_append_string(&sql, buf);
+    for (i = 1; i < db_get_table_number_of_columns(table); i++) {
+	db_set_string(&col_name_xml, db_get_column_name(column));
+	cnxml = db_get_string(&col_name_xml);
+	if (!G_strcasecmp(cnxml, "obs_type")) {
+	    db_append_string(&sql, ",'");
+	    db_append_string(&sql, (char *)node->name);
+	    continue;
+	/* remove "_id" from original (xml) column name */
+	if (!G_strcasecmp(cnxml, "from_id") ||
+	    !G_strcasecmp(cnxml, "to_id") ||
+	    !G_strcasecmp(cnxml, "left_id") ||
+	    !G_strcasecmp(cnxml, "right_id")) {
+	    cnxml_tmp = G_str_replace(cnxml, "_id", "");
+	    db_set_string(&col_name_xml, cnxml_tmp);
+	/* replace '_' -> '-' */
+	c = strstr(cnxml, "_");
+	if (c) {
+	    cnxml_tmp = G_str_replace(cnxml, "_", "-");
+	if (find_node(node, cnxml, &obs_val)) {
+	    switch (db_get_column_sqltype(column)) {
+	    case DB_SQL_TYPE_CHARACTER:
+		    if (node_get_value_string(obs_val, NULL, &sval)) {
+			sprintf(buf, "'%s'", db_get_string(&sval));
+		    else {
+			db_append_string(&sql, ",NULL");
+		    break;
+	    case DB_SQL_TYPE_DOUBLE_PRECISION:
+		    if (node_get_value_double(obs_val, &val)) {
+			sprintf(buf, "%f", val);
+		    else {
+		    break;
+	    default:
+		    G_fatal_error(_("Unable to determine data type of the column <%s>"),
+				  db_get_column_name(column));
+		    break;
+	else {
+    return;
Property changes on: grass-addons/vector/v.in.gama/table.c
   + text/x-csrc
   + native
Added: grass-addons/vector/v.in.gama/tables.xml
--- grass-addons/vector/v.in.gama/tables.xml	                        (rev 0)
+++ grass-addons/vector/v.in.gama/tables.xml	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,128 @@
+<?xml version="1.0" ?>
+DB_SQL_TYPE_CHARACTER        1
+DB_SQL_TYPE_SMALLINT         2
+DB_SQL_TYPE_INTEGER          3
+DB_SQL_TYPE_DOUBLE_PRECISION 6
+<tables>
+  <table type="point">
+    <column>
+      <name>cat</name>
+      <datatype>3</datatype>
+      <required/>
+    </column>
+    <column>
+      <name>id</name>
+      <datatype>1</datatype>
+    </column>
+    <column>
+      <name>x_fix</name>
+    <datatype>6</datatype>
+    </column>
+    <column>
+      <name>y_fix</name>
+    </column>
+    <column>
+      <name>z_fix</name>
+    </column>
+    <column>
+      <name>x_adj</name>
+    </column>
+    <column>
+      <name>y_adj</name>
+    </column>
+    <column>
+      <name>z_adj</name>
+    </column>
+    <column>
+      <name>x_app</name>
+    </column>
+    <column>
+      <name>y_app</name>
+    </column>
+    <column>
+      <name>z_app</name>
+    </column>
+    <column>
+      <name>x_con</name>
+    </column>
+    <column>
+      <name>y_con</name>
+    </column>
+    <column>
+      <name>z_con</name>
+    </column>
+  </table>
+  <table type="obs">
+    <column>
+      <name>cat</name>
+    </column>
+    <column>
+      <name>obs_type</name>
+    </column>
+    <column>
+      <name>from_id</name>
+    </column>
+    <column>
+      <name>to_id</name>
+    </column>
+    <column>
+      <name>left_id</name>
+    </column>
+    <column>
+      <name>right_id</name>
+    </column>
+    <column>
+      <name>id</name>
+    </column>
+    <column>
+      <name>obs</name>
+    </column>
+    <column>
+      <name>adj</name>
+    </column>
+    <column>
+      <name>stdev</name>
+    </column>
+    <column>
+      <name>f</name>
+    </column>
+    <column>
+      <name>std_residual</name>
+    </column>
+    <column>
+      <name>err_obs</name>
+    </column>
+    <column>
+      <name>err_adj</name>
+    </column>
+  </table>
+</tables>
Added: grass-addons/vector/v.in.gama/tree.c
--- grass-addons/vector/v.in.gama/tree.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/tree.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,259 @@
+int find_node(xmlNode * root, const char *name, xmlNode ** fnode)
+    int found = 0;
+    struct list_nodes *fnodes;
+    list_init((void **)&fnodes);
+    found = find_nodes(root, name, &fnodes);
+    if (fnodes) {
+	*fnode = fnodes->node;
+    else {
+	*fnode = NULL;
+    list_nodes_free(&fnodes);
+    return found;
+int find_nodes(xmlNode * root, const char *name, struct list_nodes **fnodes)
+    int fcount, stop;
+    xmlNode *last;
+    fcount = stop = 0;
+    if (root->next) {
+	last = root->next;
+    else {			/* root element */
+	last = root->last;
+    list_nodes_free(fnodes);
+    find__nodes(root, last, name, fnodes, &fcount, &stop);
+    return fcount;
+void find__nodes(xmlNode * root, xmlNode * last, const char *name,
+		 struct list_nodes **fnodes, int *fcount, int *stop)
+    xmlNode *node = NULL;
+    for (node = root; node && !(*stop); node = node->next) {
+	if (node == last) {
+	    *stop = 1;
+	    break;
+	if (node->type == XML_ELEMENT_NODE &&
+	    !G_strcasecmp((char *)node->name, name)) {
+	    list_nodes_push_back(fnodes, node);
+	    (*fcount)++;
+	find__nodes(node->children, last, name, fnodes, fcount, stop);
+    return;
+void list_init(void **lnodes)
+    *lnodes = NULL;
+    return;
+void list_nodes_free(struct list_nodes **lnodes)
+    struct list_nodes *tmp, *next;
+    tmp = *lnodes;
+    while (tmp) {
+	next = tmp->next;
+	G_free((struct list_nodes *)tmp);
+	tmp = next;
+    if (*lnodes)
+	*lnodes = NULL;
+    return;
+void list_nodes_push_back(struct list_nodes **lnodes, xmlNode * node)
+    struct list_nodes *ln, *tmp;
+    tmp = *lnodes;
+    ln = (struct list_nodes *)G_malloc((unsigned int)
+				       sizeof(struct list_nodes));
+    ln->node = node;
+    ln->next = NULL;
+    if (tmp) {
+	while (tmp->next)
+	    tmp = tmp->next;
+	tmp->next = ln;
+    else {
+	*lnodes = ln;
+    return;
+int is_3d_map(xmlDoc * doc)
+    int count;
+    xmlNode *root;
+    struct list_nodes *summary, *count_xyz, *count_z;
+    list_init((void **)&summary);
+    list_init((void **)&count_xyz);
+    list_init((void **)&count_z);
+    if (!root) {
+    find_nodes(root, "coordinates-summary", &summary);
+    if (summary) {
+	struct list_nodes *tmp;
+	find_nodes(summary->node, "count-xyz", &count_xyz);
+	if (count_xyz) {
+	    for (tmp = count_xyz; tmp; tmp = tmp->next) {
+		if (node_get_value_int(tmp->node, &count))
+		    if (count > 0)
+			return WITH_Z;
+	find_nodes(summary->node, "count-z", &count_z);
+	if (count_z) {
+	    for (tmp = count_z; tmp; tmp = tmp->next) {
+		    if (count > 0)
+			return WITH_Z;
+    list_nodes_free(&summary);
+    list_nodes_free(&count_xyz);
+    list_nodes_free(&count_z);
+    return WITHOUT_Z;
+int node_get_value_int(xmlNode * node, int *value)
+    xmlNode *node_value;
+    if (node) {
+	node_value = node->children;
+	if (node_value && node_value->type == XML_TEXT_NODE) {
+	    *value = (long)atoi((char *)node_value->content);
+	    return 1;
+    return 0;
+int node_get_value_double(xmlNode * node, double *value)
+    if (node) {
+	    *value = (double)atof((char *)node_value->content);
+	    return 1;
+    return 0;
+int node_get_value_string(xmlNode * node, char *attr, dbString * value)
+    if (node) {
+	if (!attr) {
+		db_set_string(value, (char *)node_value->content);
+		return 1;
+	else {			/* attribute */
+	    xmlAttr *attr_value;
+	    attr_value = node->properties;
+	    while (attr_value) {
+		if (attr_value->type == XML_ATTRIBUTE_NODE &&
+		    !G_strcasecmp((char *)attr_value->name, attr)) {
+		    if (attr_value->children) {
+				      (char *)attr_value->children->content);
+			if (db_sizeof_string(value) > 0) {
+			    return 1;
+		attr_value = attr_value->next;
+    return 0;
+int axes_xy_str2type(char *attr)
+    if (attr) {
+	/* right-handed */
+	if (!G_strcasecmp(attr, "ne"))
+	    return 0;
+	if (!G_strcasecmp(attr, "sw"))
+	    return 1;
+	if (!G_strcasecmp(attr, "es"))
+	    return 2;
+	if (!G_strcasecmp(attr, "wn"))
+	    return 3;
+	/* left-handed */
+	if (!G_strcasecmp(attr, "en"))
+	    return 4;
+	if (!G_strcasecmp(attr, "ws"))
+	    return 5;
+	if (!G_strcasecmp(attr, "se"))
+	    return 6;
+	if (!G_strcasecmp(attr, "nw"))
+	    return 7;
+    return -1;
Property changes on: grass-addons/vector/v.in.gama/tree.c
   + text/x-csrc
   + native
Added: grass-addons/vector/v.in.gama/vect.c
--- grass-addons/vector/v.in.gama/vect.c	                        (rev 0)
+++ grass-addons/vector/v.in.gama/vect.c	2009-07-13 09:50:47 UTC (rev 38381)
@@ -0,0 +1,798 @@
+int create_map(struct Map_info *Map, xmlDoc * doc, int dotable)
+    struct list_points *vpoints;
+    list_init((void **)&vpoints);
+    create_points(Map, doc, dotable, &vpoints);
+    create_obs(Map, doc, options.dotable, vpoints);
+    list_points_free(&vpoints);
+    return 0;
+int create_points(struct Map_info *Map, xmlDoc * doc, int dotable,
+		  struct list_points **vpoints)
+    unsigned int i;
+    xmlNode *root_element = NULL;
+    xmlNode *points;
+    struct list_nodes *point;
+    xmlNode *id, *coor_x, *coor_y, *coor_z;
+    Point *vpoint;
+    const char *coor_type[] = { "fixed", "adjusted", "approximate" };
+    dbString sid;
+    db_init_string(&sid);
+    list_init((void **)&point);
+    root_element = xmlDocGetRootElement(doc);
+    if (root_element == NULL) {
+    for (i = 0; i < sizeof(coor_type) / sizeof(char *); i++) {
+	find_node(root_element, coor_type[i], &points);
+	if (points) {
+	    find_nodes(points, "point", &point);
+	    if (point) {
+		struct list_nodes *tp = point;
+		while (tp) {
+		    find_node(tp->node, "id", &id);
+		    find_node(tp->node, "x", &coor_x);
+		    find_node(tp->node, "y", &coor_y);
+		    find_node(tp->node, "z", &coor_z);
+		    if ((node_get_value_string(id, NULL, &sid)) &&
+			(vpoint = find_point(*vpoints, &sid))) {
+			point_update(vpoint, i, coor_x, coor_y, coor_z);
+		    else {
+			/* G_free () in function list_points_free () */
+			vpoint = (Point *)
+			    G_malloc((unsigned int)sizeof(Point));
+			point_init(vpoint);
+			point_set(vpoint, id, i, coor_x, coor_y, coor_z);
+			list_points_push_back(vpoints, vpoint);
+		    tp = tp->next;
+    /* write new vector element && insert records into table */
+    write_points(Map, root_element, *vpoints, dotable);
+    list_nodes_free(&point);
+    return 0;
+void point_init(Point * point)
+    int i, j;
+    point->cat = -1;
+    db_init_string(&(point->id));
+    for (i = 0; i < DIM; i++) {	/* x | y | z */
+	for (j = 0; j < DIM; j++) {	/* fix | adj | app */
+	    point->xyz[i].is_null[j] = 1;
+	point->xyz[i].is_constrained = 0;
+    return;
+void point_set(Point * point, xmlNode * id, int type,
+	       xmlNode * x, xmlNode * y, xmlNode * z)
+    unsigned int i;
+    dbString idvalue;
+    double dvalue;
+    const char *XYZ[] = { "X", "Y", "Z" };
+    xmlNode *nodes[] = { x, y, z };
+    db_init_string(&idvalue);
+    if (id && node_get_value_string(id, NULL, &idvalue)) {
+	db_copy_string(&(point->id), &idvalue);
+    else {
+	G_warning("Missing point id");
+    for (i = 0; i < sizeof(nodes) / sizeof(struct list_nodes *); i++) {
+	if (nodes[i]) {
+	    if (node_get_value_double(nodes[i], &dvalue)) {
+		point->xyz[i].val[type] = dvalue;
+		point->xyz[i].is_null[type] = 0;
+		if (!strcmp((char *)nodes[i]->name, XYZ[i])) {	/* cannot be G_strcasecmp */
+		    point->xyz[i].is_constrained = 1;
+    return;
+void write_points(struct Map_info *Map, xmlNode * root,
+		  struct list_points *points, int dotable)
+    int i, j, cat;
+    double xyz[DIM];
+    short xyz_null[DIM];
+    struct list_points *lp;
+    Point *p;
+    struct line_pnts *ps;
+    struct line_cats *cs;
+    dbDriver *driver;
+    dbTable *table;
+    dbString axes_xy, table_name;
+    struct list_nodes *network_param;
+    enum axes_xy_type
+	NE, SW, ES, WN,		/* right-handed */
+	EN, WS, SE, NW		/* left-handed */
+    int xy_type;
+    cat = 1;
+    lp = points;
+    list_init((void **)&network_param);
+    db_init_string(&axes_xy);
+    ps = Vect_new_line_struct();
+    cs = Vect_new_cats_struct();
+    if (dotable) {
+	fi = Vect_get_dblink(Map, FIELD_POINT - 1);
+	if (!fi) {
+	    G_fatal_error(_("Database connection not defined for layer %d"), FIELD_POINT - 1);
+	if (!driver) {
+	if (db_describe_table(driver, &table_name, &table) != DB_OK) {
+	    G_fatal_error(_("Unable to describe table <%s>"), fi->table);
+    xy_type = -1;
+    find_nodes(root, "network-general-parameters", &network_param);
+    if (network_param) {
+	if (node_get_value_string(network_param->node, "axes-xy", &axes_xy)) {
+	    if (db_sizeof_string(&axes_xy) > 0) {
+		xy_type = axes_xy_str2type(db_get_string(&axes_xy));
+    if (xy_type == -1) {
+	G_warning("Unable to recognize 'axes-xy' attribute, "
+		  "switching to the default value 'en'");
+	xy_type = NE;
+    while (lp) {
+	p = lp->point;		/* should not be NULL */
+	if (p) {
+		xyz_null[i] = 1;
+		    if (xyz_null[i] && !(p->xyz[i].is_null[j])) {
+			xyz[i] = p->xyz[i].val[j];
+			xyz_null[i] = 0;
+	    if (xyz_null[2] && Vect_is_3d(Map)) {
+		G_warning(_("Point id '%s': cannot set coordinate z"),
+			  db_get_string(&(p->id)));
+		xyz[2] = 0.0;
+	    if (xyz_null[0] || xyz_null[1]) {
+		G_warning(_("Point id '%s': missing coordinate x|y!"),
+	    else {
+		/* acceptable values
+		   right-handed:
+		   * ne
+		   * sw
+		   * es
+		   * wn
+		   left-handed:
+		   * en
+		   * ws
+		   * se
+		   * nw
+		switch (xy_type) {
+		case NE:
+			Vect_append_point(ps, xyz[1], xyz[0], xyz[2]);
+			break;
+		case SW:
+			Vect_append_point(ps, -1.0 * xyz[1], -1.0 * xyz[0],
+					  xyz[2]);
+			break;
+		case ES:
+			Vect_append_point(ps, xyz[0], -1.0 * xyz[1], xyz[2]);
+			break;
+		case WN:
+			Vect_append_point(ps, -1.0 * xyz[0], xyz[1], xyz[2]);
+			break;
+		case EN:
+			Vect_append_point(ps, xyz[0], xyz[1], xyz[2]);
+			break;
+		case WS:
+			Vect_append_point(ps, -1.0 * xyz[0], -1.0 * xyz[1],
+					  xyz[2]);
+			break;
+		case SE:
+			Vect_append_point(ps, xyz[1], -1.0 * xyz[0], xyz[2]);
+			break;
+		case NW:
+			Vect_append_point(ps, -1.0 * xyz[1], xyz[0], xyz[2]);
+			break;
+		default:
+		    break;
+		Vect_cat_set(cs, FIELD_POINT, cat);
+		Vect_write_line(Map, GV_POINT, ps, cs);
+		p->cat = cat;
+	    if (dotable) {
+		/* insert record into table */
+		insert_point(fi, driver, table, p, cat);
+	    cat++;
+	lp = lp->next;
+	Vect_reset_line(ps);
+	Vect_reset_cats(cs);
+    if (dotable && driver) {
+    Vect_destroy_line_struct(ps);
+    Vect_destroy_cats_struct(cs);
+    list_nodes_free(&network_param);
+    return;
+void list_points_free(struct list_points **lpoints)
+    struct list_points *tmp, *next;
+    tmp = *lpoints;
+    while (tmp) {
+	next = tmp->next;
+	G_free((Point *) tmp->point);
+	G_free((struct list_point *)tmp);
+	tmp = next;
+    if (*lpoints)
+	*lpoints = NULL;
+    return;
+int list_points_push_back(struct list_points **lpoints, Point * np)
+    struct list_points *lp, *tmp;
+    tmp = *lpoints;
+    lp = (struct list_points *)G_malloc((unsigned int)
+					sizeof(struct list_points));
+    lp->point = np;
+    lp->next = NULL;
+    if (tmp) {
+	while (tmp->next)
+	    tmp = tmp->next;
+	tmp->next = lp;
+    else {
+	*lpoints = lp;
+    return 1;
+Point *find_point(struct list_points * lp, dbString * id)
+    struct list_points *tmp;
+    for (tmp = lp; tmp; tmp = tmp->next) {
+	if (!G_strcasecmp
+	    (db_get_string(&(tmp->point->id)), db_get_string(id))) {
+	    return tmp->point;
+    return NULL;
+void point_update(Point * point, int type,
+    int i;
+    double val;
+    xmlNode *xyz[] = { x, y, z };
+	if (xyz[i]) {
+	    if (node_get_value_double(xyz[i], &val)) {
+		point->xyz[i].val[type] = val;
+    return;
+   0 ... error
+   1 ... coordinate
+   2 ... is constrained ?
+int point_get_xyz(Point * point, char *name, double *val)
+    int index_xyz, index_type;
+    char *typesubstr;
+    index_xyz = index_type = -1;
+    /* name -> x_fix */
+    typesubstr = &name[2];
+    switch (name[0]) {
+    case 'x':
+	    index_xyz = 0;
+	    break;
+    case 'y':
+	    index_xyz = 1;
+	    break;
+    case 'z':
+	    index_xyz = 2;
+	    break;
+    default:
+	    G_fatal_error(_("Unable to determine coordinate x|y|z!"));
+	    break;
+    if (!G_strcasecmp(typesubstr, "fix")) {
+	index_type = FIX;
+    else {
+	if (!G_strcasecmp(typesubstr, "adj")) {
+	    index_type = ADJ;
+	else {
+	    if (!G_strcasecmp(typesubstr, "app")) {
+		index_type = APP;
+	    else {
+		if (!G_strcasecmp(typesubstr, "con")) {
+		    *val = point->xyz[index_xyz].is_constrained;
+		    return 2;
+		else {
+    if (index_type == -1 || index_xyz == -1 ||
+	point->xyz[index_xyz].is_null[index_type]) {
+	return 0;
+    *val = point->xyz[index_xyz].val[index_type];
+    return 1;
+int create_obs(struct Map_info *Map, xmlDoc * doc, int dotable,
+	       struct list_points *vpoints)
+    unsigned int i;
+    int write;
+    int cat, cat1, cat2, cat3;
+    const int field = 1;	/* layer 2 */
+    dbDriver *driver;
+    dbTable *table;
+    dbString table_name, id1, id2, id3;
+    xmlNode *root, *obss, *obs_id;
+    struct list_nodes *obs, *tmp;
+    /* should be determined from DTD ... */
+    const char *obs_tag[] = {
+	"distance", "direction", "angle",
+	"height-diff", "slope-distance", "zenith-angle",
+	"dx", "dy", "dz",
+	"coordinate-x", "coordinate-y", "coordinate-z"
+    cat = 1;
+    db_init_string(&id1);
+    db_init_string(&id2);
+    db_init_string(&id3);
+    list_init((void **)&obs);
+    if (dotable) {
+	fi = Vect_get_dblink(Map, field);
+	if (!fi) {
+	    G_fatal_error(_("Database connection not defined for layer %d"), field);
+	if (!driver) {
+    if (!root) {
+    find_node(root, "observations", &obss);
+    if (!obss) {
+	G_warning(_("No observations found"));
+    else {
+	for (i = 0; i < sizeof(obs_tag) / sizeof(char *); i++) {
+	    if (find_nodes(obss, obs_tag[i], &obs)) {
+		tmp = obs;
+		while (tmp) {
+		    write = 0;
+		    if (dotable) {
+			insert_obs(fi, driver, table, tmp->node, cat);
+		    if (!G_strcasecmp(obs_tag[i], "coordinate-x") ||
+			!G_strcasecmp(obs_tag[i], "coordinate-y") ||
+			!G_strcasecmp(obs_tag[i], "coordinate-z")) {
+			if (find_node(tmp->node, "id", &obs_id)) {
+			    node_get_value_string(obs_id, NULL, &id1);
+			cat1 = point_exists(vpoints, &id1);
+			cat2 = cat3 = -1;
+			if (cat1 != -1) {
+			    write = 1;
+		    else {
+			if (!G_strcasecmp(obs_tag[i], "angle")) {
+			    if (find_node(tmp->node, "from", &obs_id)) {
+			    if (find_node(tmp->node, "left", &obs_id)) {
+				node_get_value_string(obs_id, NULL, &id2);
+			    if (find_node(tmp->node, "right", &obs_id)) {
+				node_get_value_string(obs_id, NULL, &id3);
+			    cat2 = point_exists(vpoints, &id2);
+			    cat3 = point_exists(vpoints, &id3);
+			    if (cat1 != -1 && cat2 != -1 && cat3 != -1) {
+				write = 1;
+			else {
+			    if (find_node(tmp->node, "to", &obs_id)) {
+			    cat3 = -1;
+			    if (cat1 != -1 && cat2 != -1) {
+				write = 1;
+		    if (write) {
+			write_line(Map, cat1, cat2, cat3, cat++);
+		    else {
+			char buf[1024];
+			dbString err;
+			db_init_string(&err);
+			sprintf(buf,
+				"Line number %d: unable write vector line, "
+				" missing point id ", tmp->node->line);
+			db_set_string(&err, buf);
+			if (db_sizeof_string(&id1) > 0) {
+			    sprintf(buf, "[%s]", db_get_string(&id1));
+			    db_append_string(&err, buf);
+			if (db_sizeof_string(&id2) > 0) {
+			    sprintf(buf, " or [%s]", db_get_string(&id2));
+			if (db_sizeof_string(&id3) > 0) {
+			    sprintf(buf, " or [%s]", db_get_string(&id3));
+			db_append_string(&err, ".");
+			G_warning(_(db_get_string(&err)));
+		    tmp = tmp->next;
+    list_nodes_free(&obs);
+    return 0;
+int point_exists(struct list_points *vpoints, dbString * from_id)
+    Point *fp;
+    fp = find_point(vpoints, from_id);
+    if (fp) {
+	return fp->cat;
+    return -1;
+int write_line(struct Map_info *Map, int cat_id1, int cat_id2, int cat_id3,
+	       int cat)
+    int line, nlines, i, j, k;
+    int pcat, cat_line, fcat;
+    int points[3];
+    struct line_pnts *ps_line, *ps[3];
+    struct line_cats *cs_line, *cs[3];
+    int cats[] = { cat_id1, cat_id2, cat_id3 };
+    const short dim = sizeof(cats) / sizeof(int);
+    for (i = 0; i < dim; i++) {
+	points[i] = 0;
+	ps[i] = Vect_new_line_struct();
+	cs[i] = Vect_new_cats_struct();
+    ps_line = Vect_new_line_struct();
+    cs_line = Vect_new_cats_struct();
+    Vect_build_partial(Map, GV_BUILD_BASE);
+    nlines = Vect_get_num_lines(Map);
+    for (line = 1; line <= nlines; line++) {
+	if (!Vect_line_alive(Map, line) ||
+	    Vect_read_line(Map, ps_line, cs_line, line) != GV_POINT)
+	    continue;
+	pcat = Vect_get_line_cat(Map, line, FIELD_POINT);
+	    if (cats[i] != -1 && pcat == cats[i]) {
+		points[i] = line;
+	if (points[i] > 0) {
+	    /* add category number to the point */
+	    Vect_read_line(Map, ps[i], cs[i], points[i]);
+	    Vect_cat_set(cs[i], FIELD_OBS, cat);
+	    Vect_rewrite_line(Map, points[i], GV_POINT, ps[i], cs[i]);
+    if (cats[0] != -1) {
+	for (i = 1; cats[i] != -1 && i < dim; i++) {
+	    cat_line = -1;
+	    Vect_reset_line(ps_line);
+	    Vect_reset_cats(cs_line);
+	    for (j = 0; cat_line == -1 && j < cs[0]->n_cats; j++) {
+		if (cs[0]->field[j] != FIELD_OBS)
+		    continue;
+		for (k = 0; cat_line == -1 && k < cs[i]->n_cats; k++) {
+		    if (cs[i]->field[k] == FIELD_OBS &&
+			cs[i]->cat[k] != cat &&
+			cs[0]->cat[j] == cs[i]->cat[k]) {
+			cat_line = cs[i]->cat[k];
+	    if (cat_line == -1) {
+		/* write new line with category number 'cat' */
+		Vect_cat_set(cs_line, FIELD_OBS, cat);
+		Vect_append_points(ps_line, ps[0], GV_FORWARD);
+		Vect_append_points(ps_line, ps[i], GV_FORWARD);
+		Vect_write_line(Map, GV_LINE, ps_line, cs_line);
+	    else {
+		/* add category number to the existing vector line */
+				       line) != GV_LINE)
+			continue;
+		    Vect_cat_get(cs_line, FIELD_OBS, &fcat);
+		    if (fcat == cat_line) {
+			/* works only if fcat is the first category number in given field
+			   -> it should be (?)
+			Vect_rewrite_line(Map, line, GV_LINE, ps_line,
+					  cs_line);
+			break;
+    Vect_destroy_line_struct(ps_line);
+    Vect_destroy_cats_struct(cs_line);
+	Vect_destroy_line_struct(ps[i]);
+	Vect_destroy_cats_struct(cs[i]);
+    return 0;
Property changes on: grass-addons/vector/v.in.gama/vect.c
   + text/x-csrc
   + native
