[GRASS-SVN] r38386 - in grass/trunk/include: . vect
Mon Jul 13 08:29:00 EDT 2009
Author: mmetz
Date: 2009-07-13 08:29:00 -0400 (Mon, 13 Jul 2009)
New Revision: 38386
   grass/trunk/include/vect/dig_externs.h
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/include/vector.h
updated vector includes
Modified: grass/trunk/include/vect/dig_externs.h
--- grass/trunk/include/vect/dig_externs.h	2009-07-13 12:27:16 UTC (rev 38385)
+++ grass/trunk/include/vect/dig_externs.h	2009-07-13 12:29:00 UTC (rev 38386)
@@ -176,10 +176,16 @@
 void dig_spidx_free_areas(struct Plus_head *);
 void dig_spidx_free_isles(struct Plus_head *);
 void dig_spidx_free(struct Plus_head *);
-int dig_write_spidx(struct gvfile *, struct Plus_head *);
+int dig_Rd_spidx_head(struct gvfile  *, struct Plus_head *);
+int dig_Wr_spidx_head(struct gvfile  *, struct Plus_head *);
+int dig_Wr_spidx(struct gvfile *, struct Plus_head *);
+int dig_Rd_spidx(struct gvfile *, struct Plus_head *);
 int dig_dump_spidx(FILE *, const struct Plus_head *);
-int dig_read_spidx(struct gvfile *, struct Plus_head *);
+int rtree_search(struct RTree *, struct Rect *, SearchHitCallback ,
+		void *, struct Plus_head *);
 /* category index */
 int dig_cidx_init(struct Plus_head *);
 void dig_cidx_free(struct Plus_head *);
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2009-07-13 12:27:16 UTC (rev 38385)
+++ grass/trunk/include/vect/dig_structs.h	2009-07-13 12:29:00 UTC (rev 38386)
@@ -100,6 +100,7 @@
     /* portability stuff, set in V1_open_new/old() */
     /* file byte order */
     int byte_order;
+    int off_t_size;
     /* conversion matrices between file and native byte order */
     unsigned char dbl_cnvrt[PORT_DOUBLE];
@@ -281,14 +282,16 @@
     P_LINE **Line;		/* P_LINE array of pointers *//* all these (not 0) */
     P_AREA **Area;
     P_ISLE **Isle;
+    /* add here P_FACE, P_VOLUME, P_HOLE */
-    plus_t n_nodes;		/* Current Number of nodes */
-    plus_t n_edges;		/* Current Number of edges */
-    plus_t n_lines;		/* Current Number of lines */
-    plus_t n_areas;		/* Current Number of areas */
-    plus_t n_isles;
-    plus_t n_volumes;		/* Current Number of volumes */
-    plus_t n_holes;		/* Current Number of holes */
+    plus_t n_nodes;		/* current Number of nodes */
+    plus_t n_edges;		/* current Number of edges */
+    plus_t n_lines;		/* current Number of lines */
+    plus_t n_areas;		/* current Number of areas */
+    plus_t n_isles;		/* current Number of isles */
+    plus_t n_faces;		/* current Number of faces */
+    plus_t n_volumes;	/* current Number of volumes */
+    plus_t n_holes;		/* current Number of holes */
     plus_t n_plines;		/* Current Number of point    lines */
     plus_t n_llines;		/* Current Number of line     lines */
@@ -296,6 +299,8 @@
     plus_t n_clines;		/* Current Number of centroid lines */
     plus_t n_flines;		/* Current Number of face lines */
     plus_t n_klines;		/* Current Number of kernel lines */
+    plus_t n_vfaces;		/* Current Number of volume faces */
+    plus_t n_hfaces;		/* Current Number of hole faces */
     plus_t alloc_nodes;		/* # of nodes we have alloc'ed space for
 				   i.e. array size - 1 */
@@ -303,8 +308,9 @@
     plus_t alloc_lines;		/* # of lines we have alloc'ed space for */
     plus_t alloc_areas;		/* # of areas we have alloc'ed space for */
     plus_t alloc_isles;		/* # of isles we have alloc'ed space for */
-    plus_t alloc_volumes;
-    plus_t alloc_holes;
+    plus_t alloc_faces;		/* # of faces we have alloc'ed space for */
+    plus_t alloc_volumes;	/* # of volumes we have alloc'ed space for */
+    plus_t alloc_holes;		/* # of holes we have alloc'ed space for */
     off_t Node_offset;		/* offset of array of nodes in topo file */
     off_t Edge_offset;
@@ -314,25 +320,30 @@
     off_t Volume_offset;
     off_t Hole_offset;
-    /* Spatial index */
-    /* Spatial index is never saved, it is built automaticaly for new and updated vectors.
-     * It is not built for old vectors until it is needed, i.e. until Vect_select is called.
-     * or until Vect_build is called */
+    /* Spatial index is always saved */
-    int Spidx_built;		/* set to 1 if spatial index is available and to 0 if it is not */
+    int Spidx_built;		/* set to 1 if spatial index is available */
+    int Spidx_new;          /* set to 1 if new spatial index will be generated */
-    off_t Node_spidx_offset;	/* offset of spindex */
-    off_t Edge_spidx_offset;
+    GVFILE spidx_fp;		    /* spatial index file pointer */
+    char *spidx_node_fname;     /* node spatial index file name */
+    off_t Node_spidx_offset;	/* offset of spatial index in sidx file */
     off_t Line_spidx_offset;
     off_t Area_spidx_offset;
     off_t Isle_spidx_offset;
+    off_t Face_spidx_offset;
     off_t Volume_spidx_offset;
     off_t Hole_spidx_offset;
-    struct Node *Node_spidx;
-    struct Node *Line_spidx;
-    struct Node *Area_spidx;
-    struct Node *Isle_spidx;
+    struct RTree *Node_spidx;     /* node spatial index */
+    struct RTree *Line_spidx;     /* line spatial index */
+    struct RTree *Area_spidx;     /* area spatial index */
+    struct RTree *Isle_spidx;     /* isle spatial index */
+    struct RTree *Face_spidx;     /* face spatial index */
+    struct RTree *Volume_spidx;   /* volume spatial index */
+    struct RTree *Hole_spidx;     /* hole spatial index */
     /* Category index */
     /* By default, category index is not updated */
@@ -547,7 +558,8 @@
 /* Spatial index for use in modules. */
 struct spatial_index
-    struct Node *root;
+    struct RTree *si_tree;
+    char *name;
 typedef struct spatial_index SPATIAL_INDEX;
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h	2009-07-13 12:27:16 UTC (rev 38385)
+++ grass/trunk/include/vector.h	2009-07-13 12:29:00 UTC (rev 38386)
@@ -126,13 +126,6 @@
 int Vect_box_clip(double *, double *, double *, double *, const BOUND_BOX *);
 int Vect_region_box(const struct Cell_head *, BOUND_BOX *);
-/* Spatial index */
-void Vect_spatial_index_init(SPATIAL_INDEX *);
-void Vect_spatial_index_destroy(SPATIAL_INDEX *);
-void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
-void Vect_spatial_index_del_item(SPATIAL_INDEX *, int);
-int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
 int Vect_cidx_get_num_fields(const struct Map_info *);
 int Vect_cidx_get_field_number(const struct Map_info *, int);
@@ -393,6 +386,13 @@
 				struct line_pnts *, int);
 char *Vect_subst_var(const char *, const struct Map_info *);
+/* Custom spatial index */
+void Vect_spatial_index_init(SPATIAL_INDEX *, int);
+void Vect_spatial_index_destroy(SPATIAL_INDEX *);
+void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
+void Vect_spatial_index_del_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
+int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
  * Internal functions, MUST NOT be used in modules
@@ -404,11 +404,11 @@
 const char *Vect_maptype_info(const struct Map_info *);
 int Vect_open_topo(struct Map_info *, int);
 int Vect_save_topo(struct Map_info *);
-int Vect_open_spatial_index(struct Map_info *);
-int Vect_save_spatial_index(struct Map_info *);
-int Vect_spatial_index_dump(struct Map_info *, FILE *);
+int Vect_open_sidx(struct Map_info *, int);
+int Vect_save_sidx(struct Map_info *);
+int Vect_sidx_dump(struct Map_info *, FILE *);
 int Vect_build_sidx_from_topo(struct Map_info *);
-int Vect_build_spatial_index(struct Map_info *);
+int Vect_build_sidx(struct Map_info *);
 int Vect__write_head(const struct Map_info *);
 int Vect__read_head(struct Map_info *);
@@ -460,7 +460,7 @@
 			 struct line_pnts *, struct line_cats *);
 #endif
-    /* Miscellaneous */
+    /* Build topology */
 int Vect_build_nat(struct Map_info *, int);
 int Vect_build_ogr(struct Map_info *, int);
 int Vect_build_line_area(struct Map_info *, int, int);
