[GRASS-SVN] r38401 - in grass/trunk/doc: raster/r.example vector/v.example
Mon Jul 13 13:26:11 EDT 2009
Author: martinl
Date: 2009-07-13 13:26:11 -0400 (Mon, 13 Jul 2009)
New Revision: 38401
   grass/trunk/doc/raster/r.example/
   grass/trunk/doc/raster/r.example/Makefile
   grass/trunk/doc/raster/r.example/main.c
   grass/trunk/doc/vector/v.example/
   grass/trunk/doc/vector/v.example/main.c
fix example modules (rasterlib)
Property changes on: grass/trunk/doc/raster/r.example
___________________________________________________________________
Added: svn:ignore
   + OBJ.*
Modified: grass/trunk/doc/raster/r.example/Makefile
--- grass/trunk/doc/raster/r.example/Makefile	2009-07-13 17:04:09 UTC (rev 38400)
+++ grass/trunk/doc/raster/r.example/Makefile	2009-07-13 17:26:11 UTC (rev 38401)
@@ -4,8 +4,8 @@
 PGM = r.example
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/doc/raster/r.example/main.c
--- grass/trunk/doc/raster/r.example/main.c	2009-07-13 17:04:09 UTC (rev 38400)
+++ grass/trunk/doc/raster/r.example/main.c	2009-07-13 17:26:11 UTC (rev 38401)
@@ -7,7 +7,7 @@
  * PURPOSE:      Just copies a raster map, preserving the raster map type
  *               Intended to explain GRASS raster programming
- * COPYRIGHT:    (C) 2002,2005 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002, 2005-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
@@ -15,11 +15,11 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
+#include <grass/raster.h>
 #include <grass/glocale.h>
@@ -68,14 +68,12 @@
     int nrows, ncols;
     int row, col;
     int infd, outfd;		/* file descriptor */
-    int verbose;
     RASTER_MAP_TYPE data_type;	/* type of the map (CELL/DCELL/...) */
     struct History history;	/* holds meta-data (title, comments,..) */
     struct GModule *module;	/* GRASS module for parsing arguments */
     struct Option *input, *output;	/* options */
-    struct Flag *flag1;		/* flags */
     /* initialize GIS environment */
     G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
@@ -92,11 +90,6 @@
     output = G_define_standard_option(G_OPT_R_OUTPUT);
-    /* Define the different flags */
-    flag1 = G_define_flag();
-    flag1->key = 'q';
-    flag1->description = _("Quiet");
     /* options and flags parser */
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -104,11 +97,10 @@
     /* stores options and flags to variables */
     name = input->answer;
     result = output->answer;
-    verbose = (!flag1->answer);
     /* returns NULL if the map was not found in any mapset,
      * mapset name otherwise */
-    mapset = G_find_cell2(name, "");
+    mapset = (char *) G_find_cell2(name, "");
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
@@ -144,8 +136,7 @@
 	FCELL f;
 	DCELL d;
-	if (verbose)
-	    G_percent(row, nrows, 2);
+	G_percent(row, nrows, 2);
 	/* read input map */
 	if (Rast_get_row(infd, inrast, row, data_type) < 0)
Property changes on: grass/trunk/doc/vector/v.example
Added: svn:ignore
   + OBJ.*
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c	2009-07-13 17:04:09 UTC (rev 38400)
+++ grass/trunk/doc/vector/v.example/main.c	2009-07-13 17:26:11 UTC (rev 38401)
@@ -8,7 +8,7 @@
  * PURPOSE:    copies vector data from source map to destination map
  *             prints out all point coordinates and atributes
- * COPYRIGHT:  (C) 2002-2008 by the GRASS Development Team
+ * COPYRIGHT:  (C) 2002-2009 by the GRASS Development Team
  *             GNU General Public License (>=v2).
@@ -71,7 +71,7 @@
     Vect_check_input_output_name(old->answer, new->answer, GV_FATAL_EXIT);
-    if ((mapset = G_find_vector2(old->answer, "")) == NULL)
+    if ((mapset = (char *)G_find_vector2(old->answer, "")) == NULL)
 	G_fatal_error(_("Vector map <%s> not found"), old->answer);
     /* Predetermine level at which a map will be opened for reading
