[GRASS-SVN] r38415 - grass-addons/vector/v.krige
Tue Jul 14 10:16:00 EDT 2009
Author: martinl
Date: 2009-07-14 10:16:00 -0400 (Tue, 14 Jul 2009)
New Revision: 38415
Added:
   grass-addons/vector/v.krige/description.html
Removed:
   grass-addons/vector/v.krige/v.krige.html
follow grass6 rules
Copied: grass-addons/vector/v.krige/description.html (from rev 38414, grass-addons/vector/v.krige/v.krige.html)
--- grass-addons/vector/v.krige/description.html	                        (rev 0)
+++ grass-addons/vector/v.krige/description.html	2009-07-14 14:16:00 UTC (rev 38415)
@@ -0,0 +1,111 @@
+<h2>NAME</h2>
+<em><b>v.krige.py</b></em>  - Performs ordinary kriging.
+<h2>KEYWORDS</h2>
+kriging
+<h2>SYNOPSIS</h2>
+<b>v.krige.py</b><br>
+<b>v.krige.py help</b><br>
+<b>v.krige.py</b> [-<b>o</b>] <b>input</b>=<em>string</em> <b>column</b>=<em>string</em>  [<b>output</b>=<em>string</em>]   [<b>package</b>=<em>string</em>]   [<b>model</b>=<em>string</em>[,<i>string</i>,...]]   [<b>range</b>=<em>integer</em>]   [<b>nugget</b>=<em>integer</em>]   [<b>sill</b>=<em>integer</em>]   [--<b>verbose</b>]  [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>-o</b></DT>
+<DD>Overwrite output map with same name</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>input</b>=<em>string</em></DT>
+<DD>Name of point vector map containing sample data.</DD>
+<DT><b>column</b>=<em>string</em></DT>
+<DD>Column with numerical value to be interpolated</DD>
+<DT><b>output</b>=<em>string</em></DT>
+<DD>Name of output map. If omitted, will be &lt;input name&gt;_kriging</DD>
+<DT><b>package</b>=<em>string</em></DT>
+<DD>R package to use. Choices: gstat, geor</DD>
+<DD>Options: <em>gstat, geor</em></DD>
+<DD>Default: <em>gstat</em></DD>
+<DT><b>model</b>=<em>string[,<i>string</i>,...]</em></DT>
+<DD>Variogram model(s). Leave empty to</DD>
+<DD>Options: <em>Exp,Sph,Gau,Mat,Lin</em></DD>
+<DT><b>range</b>=<em>integer</em></DT>
+<DD>Range value. Automatically fixed if not set</DD>
+<DT><b>nugget</b>=<em>integer</em></DT>
+<DD>Nugget value. Automatically fixed if not set</DD>
+<DT><b>sill</b>=<em>integer</em></DT>
+<DD>Sill value. Automatically fixed if not set</DD>
+<h2>DESCRIPTION</h2>
+<i>v.krige</i> allows to perform kriging operations in GRASS environment,
+using R software functions in background.
+<h2>NOTES</h2>
+<i>v.krige</i> is just a front-end to R. The options and parameters are
+the same offered by packages <i>automap</i>, <i>gstat</i> and
+<i>geoR</i>.
+R users will therefore find in this GRASS module the same functionality of
+their preferred package, as far as kriging results are influenced by
+implementation.
+<h3>Dependencies</h3>
+<dl>
+<dt><b>GRASS with wxPython support</b></dt>
+<dd></dd>
+<dt><b>R software >= 2.x</b></dt>
+<dd></dd>
+<dt><b>rpy2</b></dt>
+<dd>Python binding to R. Note! rpy is not supported.</dd>
+<dt><b>R packages automap, gstat, geoR. </b></dt>
+<dd>Install at least one.</dd>
+</dl>
+<h2>EXAMPLES</h2>
+Run GUI:
+<br>
+<div class="code"><pre>
+   v.krige.py
+</pre></div>
+<p>
+Run CLI, minimum options required for ordinary kriging with automatic variogram fit (requires package automap):
+<br>
+   v.krige.py input=rs column=elev
+</pre></div>
+<p>
+Run CLI, more options:
+<br>
+   v.krige.py input=rs at PERMANENT column=elev model=Lin sill=2500 nugget=0 range=1000 output=rs_kriging
+</pre></div>
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Anne Ghisla, Google Summer of Code 2009
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass-addons/vector/v.krige/v.krige.html
--- grass-addons/vector/v.krige/v.krige.html	2009-07-14 14:05:28 UTC (rev 38414)
+++ grass-addons/vector/v.krige/v.krige.html	2009-07-14 14:16:00 UTC (rev 38415)
@@ -1,111 +0,0 @@
-<h2>NAME</h2>
-<em><b>v.krige.py</b></em>  - Performs ordinary kriging.
-<h2>KEYWORDS</h2>
-kriging
-<h2>SYNOPSIS</h2>
-<b>v.krige.py</b><br>
-<b>v.krige.py help</b><br>
-<b>v.krige.py</b> [-<b>o</b>] <b>input</b>=<em>string</em> <b>column</b>=<em>string</em>  [<b>output</b>=<em>string</em>]   [<b>package</b>=<em>string</em>]   [<b>model</b>=<em>string</em>[,<i>string</i>,...]]   [<b>range</b>=<em>integer</em>]   [<b>nugget</b>=<em>integer</em>]   [<b>sill</b>=<em>integer</em>]   [--<b>verbose</b>]  [--<b>quiet</b>]
-<h3>Flags:</h3>
-<DL>
-<DT><b>-o</b></DT>
-<DD>Overwrite output map with same name</DD>
-<DT><b>--verbose</b></DT>
-<DD>Verbose module output</DD>
-<DT><b>--quiet</b></DT>
-<DD>Quiet module output</DD>
-</DL>
-<h3>Parameters:</h3>
-<DL>
-<DT><b>input</b>=<em>string</em></DT>
-<DD>Name of point vector map containing sample data.</DD>
-<DT><b>column</b>=<em>string</em></DT>
-<DD>Column with numerical value to be interpolated</DD>
-<DT><b>output</b>=<em>string</em></DT>
-<DD>Name of output map. If omitted, will be &lt;input name&gt;_kriging</DD>
-<DT><b>package</b>=<em>string</em></DT>
-<DD>R package to use. Choices: gstat, geor</DD>
-<DD>Options: <em>gstat, geor</em></DD>
-<DD>Default: <em>gstat</em></DD>
-<DT><b>model</b>=<em>string[,<i>string</i>,...]</em></DT>
-<DD>Variogram model(s). Leave empty to</DD>
-<DD>Options: <em>Exp,Sph,Gau,Mat,Lin</em></DD>
-<DT><b>range</b>=<em>integer</em></DT>
-<DD>Range value. Automatically fixed if not set</DD>
-<DT><b>nugget</b>=<em>integer</em></DT>
-<DD>Nugget value. Automatically fixed if not set</DD>
-<DT><b>sill</b>=<em>integer</em></DT>
-<DD>Sill value. Automatically fixed if not set</DD>
-<h2>DESCRIPTION</h2>
-<i>v.krige</i> allows to perform kriging operations in GRASS environment,
-using R software functions in background.
-<h2>NOTES</h2>
-<i>v.krige</i> is just a front-end to R. The options and parameters are
-the same offered by packages <i>automap</i>, <i>gstat</i> and
-<i>geoR</i>.
-R users will therefore find in this GRASS module the same functionality of
-their preferred package, as far as kriging results are influenced by
-implementation.
-<h3>Dependencies</h3>
-<dl>
-<dt><b>GRASS with wxPython support</b></dt>
-<dd></dd>
-<dt><b>R software >= 2.x</b></dt>
-<dd></dd>
-<dt><b>rpy2</b></dt>
-<dd>Python binding to R. Note! rpy is not supported.</dd>
-<dt><b>R packages automap, gstat, geoR. </b></dt>
-<dd>Install at least one.</dd>
-</dl>
-<h2>EXAMPLES</h2>
-Run GUI:
-<br>
-<div class="code"><pre>
-   v.krige.py
-</pre></div>
-<p>
-Run CLI, minimum options required for ordinary kriging with automatic variogram fit (requires package automap):
-<br>
-   v.krige.py input=rs column=elev
-</pre></div>
-<p>
-Run CLI, more options:
-<br>
-   v.krige.py input=rs at PERMANENT column=elev model=Lin sill=2500 nugget=0 range=1000 output=rs_kriging
-</pre></div>
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Anne Ghisla, Google Summer of Code 2009
-<p>
-<i>Last changed: $Date$</i>
