[GRASS-SVN] r38550 - grass/trunk/lib/db/dbmi_base
Fri Jul 31 07:41:31 EDT 2009
Author: martinl
Date: 2009-07-31 07:41:29 -0400 (Fri, 31 Jul 2009)
New Revision: 38550
   grass/trunk/lib/db/dbmi_base/string.c
doxygen update
Modified: grass/trunk/lib/db/dbmi_base/string.c
--- grass/trunk/lib/db/dbmi_base/string.c	2009-07-31 11:32:25 UTC (rev 38549)
+++ grass/trunk/lib/db/dbmi_base/string.c	2009-07-31 11:41:29 UTC (rev 38550)
@@ -1,12 +1,26 @@
+  \file db/dbmi_base/string.c
+  \brief DBMI Library (base) - string management
+  (C) 1999-2009 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Joel Jones (CERL/UIUC)
+  \author Upgraded to GRASS 5.7 by Radim Blazek
 #include <string.h>
 #include <stdlib.h>
+#include <grass/gis.h>
 #include <grass/dbmi.h>
-   \fn
-   \brief
-   \return
-   \param
+   \brief Initialize dbString
+   \param[in,out] x pointer to dbString
 void db_init_string(dbString * x)
@@ -14,32 +28,30 @@
     x->nalloc = 0;
+static int set_string(dbString * x, char *s, int copy);
+  \brief Inserts string to dbString (enlarge string)
+  \param s string to be inserted
-   \fn
-   \brief
-   \return
-   \param
+  \return DB_OK on success
+  \return DB_MEMORY_ERR on error
-/* db_set_string(dbString *x, char *s, int copy)
- *  inserts 's' into 'x'
- *   if 'copy' is true, then memory is allocated to copy into
- *   else 'x' is made to point to 's'
- * returns DB_OK or DB_MEMORY_ERR
-static int set_string(dbString * x, char *s, int copy);
 int db_set_string(dbString * x, const char *s)
     return set_string(x, (char *)s, 1);
-   \fn
-   \brief
-   \return
-   \param
+  \brief Inserts string to dbString (overwrite current value)
 int db_set_string_no_copy(dbString * x, char *s)
@@ -47,12 +59,13 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Get string size
+  \param x pointer to dbString
+  \return string size
-unsigned int db_sizeof_string(dbString * x)
+unsigned int db_sizeof_string(const dbString * x)
     if (x->nalloc < 0)
 	return 0;
@@ -60,22 +73,15 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Zero string
 void db_zero_string(dbString * x)
     db_zero((void *)db_get_string(x), db_sizeof_string(x));
-   \fn
-   \brief
-   \return
-   \param
     int len;
@@ -103,10 +109,13 @@
-   \fn
-   \brief
-   \return
-   \param
+   \brief Enlarge dbString
+   \param len requested string size
 int db_enlarge_string(dbString * x, int len)
@@ -122,53 +131,53 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Get string
-char *db_get_string(dbString * x)
+  \return pointer to buffer containg string
+char *db_get_string(const dbString * x)
     return x->string;
-   \fn
-   \brief
-   \return
-   \param
+  \brief Free allocated space
+  \param x poiter to dbString
 void db_free_string(dbString * x)
     if (x->nalloc > 0)
-	free(x->string);
+	G_free(x->string);
     db_init_string(x);
-   \fn
-   \brief
-   \return
-   \param
+  \brief Free allocated dbString array
+  \param a pointer to 1st dbString in the array
+  \param n number of items in array
-void db_free_string_array(dbString * a, int n)
+void db_free_string_array(dbString *a, int n)
     int i;
     if (a) {
 	for (i = 0; i < n; i++)
 	    db_free_string(&a[i]);
-	free(a);
+	G_free(a);
-   \fn
-   \brief
-   \return
-   \param
+  \brief Allocate dbString array
+  \param count number of items to be allocated
+  \return pointer to 1st dbString in the array
 dbString *db_alloc_string_array(int count)
     int i;
@@ -185,10 +194,13 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Append string to dbString
+  \param s string to be appended
+  \return otherwise error code is returned
 int db_append_string(dbString * x, const char *s)
@@ -204,22 +216,24 @@
-   \fn
-   \brief
-   \return
-   \param
+  \brief Copy dbString
+  \param dst destination dbString
+  \param src source dbString
+  \return DB_ERR code on error
-int db_copy_string(dbString * dst, dbString * src)
+int db_copy_string(dbString * dst, const dbString * src)
     return db_set_string(dst, db_get_string(src));
-   \fn
-   \brief each ' is replaced by ''
-   \return
-   \param
+  \brief Replace each ' is replaced by ''
+  \param src pointer to dbString
 void db_double_quote_string(dbString * src)
     char *ptra, *ptrb, buf[2];
