[GRASS-SVN] r37691 - in grass-addons/raster: . r.prominence
Mon Jun 1 05:18:31 EDT 2009
Author: neteler
Date: 2009-06-01 05:18:31 -0400 (Mon, 01 Jun 2009)
New Revision: 37691
Added:
   grass-addons/raster/r.prominence/
   grass-addons/raster/r.prominence/Makefile
   grass-addons/raster/r.prominence/description.html
   grass-addons/raster/r.prominence/main.c
benducke: terrain prominence tool
Added: grass-addons/raster/r.prominence/Makefile
--- grass-addons/raster/r.prominence/Makefile	                        (rev 0)
+++ grass-addons/raster/r.prominence/Makefile	2009-06-01 09:18:31 UTC (rev 37691)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = r.prominence
+GTLIB = -lgt
+LIBES = $(GISLIB) $(DATETIMELIB)
+EXTRA_CFLAGS = -I../dst/include \
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/raster/r.prominence/Makefile
___________________________________________________________________
   + native
Added: grass-addons/raster/r.prominence/description.html
--- grass-addons/raster/r.prominence/description.html	                        (rev 0)
+++ grass-addons/raster/r.prominence/description.html	2009-06-01 09:18:31 UTC (rev 37691)
@@ -0,0 +1,31 @@
+<h2>DESCRIPTION</h2>
+<em>r.prominence</em> calculates the average difference between a
+central cell and its neighbors. It approximated the terrain 'ruggedness'
+by looking at average differences in elevation within a given neighborhood
+The <em>radius</em> is specified in number of map rows/columns.
+<h2>EXAMPLE</h2>
+Spearfish region:
+<div class="code"><pre>
+g.region rast=elevation.10m
+# get region rows/columns
+g.region -g
+# calculate prominence (radius of 500 map rows)
+r.prominence in=elevation.10m out=prominence radius=500
+# visualize over shaded DEM
+r.shaded.relief elevation.10m
+d.mon x0
+d.his i=elevation.10m.shade h=prominence
+</pre></div>
+<h2>AUTHOR</h2>
+Benjamin Ducke (benjamin.ducke - oxfordarch.co.uk)
+<p><i>Last changed: $Date: 2008-05-20 20:26:19 +0200 (Tue, 20 May 2008) $</i>
Added: grass-addons/raster/r.prominence/main.c
--- grass-addons/raster/r.prominence/main.c	                        (rev 0)
+++ grass-addons/raster/r.prominence/main.c	2009-06-01 09:18:31 UTC (rev 37691)
@@ -0,0 +1,540 @@
+ * MODULE:       r.prominence
+ * AUTHOR(S):    Benjamin Ducke, UK
+ * PURPOSE:      calculates terain prominence in a DEM
+ * COPYRIGHT:    (C) 2009 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the COPYING file that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <unistd.h>
+#include <math.h>
+#include <grass/gis.h>
+#define PROGVERSION 1.0
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct
+	struct Option *input;
+	struct Option *output;
+	struct Option *radius;
+    } parm;
+    struct
+	struct Flag *localnorm;
+	struct Flag *globalnorm;
+	struct Flag *rect;
+	struct Flag *absolute;
+	struct Flag *quiet;
+    } flag;
+    char *sysstr;
+    char *mapset;
+    int i, j, radius, n, x, y;
+    int a, b, dist;
+    int firstrun;
+    int nullvalue;
+    double centerval;
+    double sum, prominence;
+    double min, max;
+    double from, to;
+    int nrows, ncols;
+    int fd, fd_out;
+    struct Cell_head region;
+    struct Colors colors;
+    DCELL *diskrow = NULL;
+    DCELL *outrow = NULL;
+    sysstr = G_calloc(512, sizeof(char));
+    module = G_define_module();
+    module->description = "Calculates Llobera's prominence index";
+    /* setup some basic GIS stuff */
+    G_gisinit(argv[0]);
+    /* do not pause after a warning message was displayed */
+    G_sleep_on_error(0);
+    parm.input = G_define_standard_option(G_OPT_R_INPUT);
+    parm.input->key = "input";
+    parm.input->type = TYPE_STRING;
+    parm.input->required = YES;
+    parm.input->gisprompt = "old,fcell";
+    parm.input->description = "FP raster map for which to calculate index";
+    parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.output->key = "output";
+    parm.output->type = TYPE_STRING;
+    parm.output->required = YES;
+    parm.output->gisprompt = "fcell";
+    parm.output->description = "FP raster to store output";
+    parm.radius = G_define_option();
+    parm.radius->key = "radius";
+    parm.radius->type = TYPE_INTEGER;
+    parm.radius->required = YES;
+    parm.radius->description = "Radius of neighbourhood in map cells";
+    flag.absolute = G_define_flag();
+    flag.absolute->key = 'a';
+    flag.absolute->description = "Calculate absolute differences";
+    flag.localnorm = G_define_flag();
+    flag.localnorm->key = 'l';
+    flag.localnorm->description = "Local data normalisation";
+    flag.globalnorm = G_define_flag();
+    flag.globalnorm->key = 'g';
+    flag.globalnorm->description = "Global data normalisation";
+    flag.rect = G_define_flag();
+    flag.rect->key = 'r';
+    flag.rect->description = "Use quadratic neighbourhood";
+    flag.quiet = G_define_flag();
+    flag.quiet->key = 'q';
+    flag.quiet->description = "Disable on-screen progress display";
+    /* parse command line */
+    if (G_parser(argc, argv)) {
+	exit(-1);
+    G_get_window(&region);
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    /* check parameters for validity */
+    radius = atoi(parm.radius->answer);
+    if ((radius < 1) || (radius > nrows / 2) || (radius > ncols / 2)) {
+	G_fatal_error
+	    ("Radius in rows/columns must be > 1 and smaller than half the map's extent in both directions.");
+    if ((flag.localnorm->answer) && (flag.globalnorm->answer)) {
+	G_fatal_error("Please choose either local OR global normalisation.");
+    mapset = G_calloc(512, sizeof(char));
+    mapset = G_find_cell(parm.input->answer, "");
+    if (mapset == NULL) {
+	G_fatal_error("Input map does not exist in the current location.");
+    if (!G_raster_map_is_fp(parm.input->answer, mapset)) {
+	G_fatal_error
+	    ("Input map is not a floating point map.\nOnly integer maps are allowed as input maps.");
+    fd = G_open_cell_old(parm.input->answer, mapset);
+    if (fd < 0) {
+	G_fatal_error("Could not open input map for reading!\n");
+    if (!G_legal_filename(parm.output->answer)) {
+	G_fatal_error("%s is not a legal filename for an output map.\n",
+		      parm.output->answer);
+    fd_out = G_open_raster_new(parm.output->answer, DCELL_TYPE);
+    if (fd_out < 0) {
+	G_fatal_error("Could not open output map for writing!\n");
+    diskrow = G_allocate_d_raster_buf();
+    outrow = G_allocate_d_raster_buf();
+    /* initialize statistics */
+    n = 0;
+    firstrun = 1;
+    min = 0;
+    max = 0;
+    sum = 0.0;
+    if (!flag.quiet->answer) {
+	fprintf(stdout, "Calculating prominence index:\n");
+	fflush(stdout);
+    /* main loop: read raster row from disk, add to values in neighbourhood */
+    i = 0;
+    j = 0;
+    nullvalue = 0;
+    for (y = 0; y < nrows; y++) {
+	for (x = 0; x < ncols; x++) {
+	    G_get_d_raster_row(fd, diskrow, y);
+	    centerval = diskrow[x];
+	    if (G_is_d_null_value(&diskrow[x])) {
+		nullvalue = 1;
+	    else {
+		nullvalue = 0;
+		for (j = y - radius; j <= y + radius; j++) {
+		    if ((j > 0) && (j < nrows)) {
+			G_get_d_raster_row(fd, diskrow, j);
+			nullvalue = 0;
+			for (i = x - radius; i <= x + radius; i++) {
+			    if (((i != x) || (j != y)) && (i > 0) &&
+				(i < ncols)) {
+				if (!G_is_d_null_value(&diskrow[i])) {
+				    if (flag.rect->answer) {
+					/* use rectangular neighbourhood */
+					n = n + 1;
+					if (flag.absolute->answer) {
+					    sum =
+						sum + fabs(centerval -
+							   diskrow[i]);
+					else {
+					    sum =
+						sum + (centerval -
+						       diskrow[i]);
+				    else {
+					/* use circular neighbourhood */
+					a = abs(x - i);
+					b = abs(y - j);
+					dist =
+					    (int)sqrt((double)(a * a) +
+						      (b * b));
+					if (dist <= radius) {
+					    n = n + 1;
+						sum =
+							       diskrow[i]);
+					    else {
+						sum =
+							   diskrow[i]);
+	    /* write one cell to output map */
+	    prominence = sum / n;
+	    if (!nullvalue) {
+		outrow[x] = prominence;
+	    else {
+		G_set_d_null_value(&outrow[x], 1);
+	    if (firstrun) {
+		min = prominence;
+		max = prominence;
+		firstrun = 0;
+	    else {
+		if (prominence < min)
+		    min = prominence;
+		if (prominence > max)
+		    max = prominence;
+	    n = 0;
+	    sum = 0.0;
+	/* write one row to output map on disk */
+	G_put_raster_row(fd_out, outrow, DCELL_TYPE);
+	    G_percent(y, nrows - 1, 1);
+	    fflush(stdout);
+    G_close_cell(fd);
+    G_close_cell(fd_out);
+    if (flag.localnorm->answer) {
+	    fprintf(stdout, "\nNormalising data by neighbourhood maximum:\n");
+	    fflush(stdout);
+	/* re-open output map for reading */
+	fd = G_open_cell_old(parm.output->answer, G_mapset());
+	if (fd < 0) {
+	    G_fatal_error
+		("Could not open output map for normalisation pass!\n");
+	G_strcpy(sysstr, parm.output->answer);
+	G_strcat(sysstr, ".localnorm");
+	fd_out = G_open_raster_new(sysstr, DCELL_TYPE);
+	if (fd_out < 0) {
+	    G_fatal_error
+		("Could not open temporary map for normalisation pass (write access)!\n");
+	i = 0;
+	j = 0;
+		min = diskrow[x];
+		max = diskrow[x];
+		    nullvalue = 1;
+		else {
+		    nullvalue = 0;
+			    nullvalue = 0;
+				    (i < ncols)) {
+					    if (diskrow[i] > max) {
+						max = diskrow[i];
+					    if (diskrow[i] < min) {
+						min = diskrow[i];
+					else {
+					    a = abs(x - i);
+					    b = abs(y - j);
+					    dist =
+							  (b * b));
+						    max = diskrow[i];
+						    min = diskrow[i];
+		if (!nullvalue) {
+			outrow[x] = (centerval - min) / (max - min);
+		    else {
+			if (min < 0) {
+			    if (centerval < 0) {
+				outrow[x] = centerval / fabs(min);
+			    if (centerval > 0) {
+				outrow[x] = centerval / max;
+			    if (centerval == 0) {
+				outrow[x] = 0;
+			else {
+		else {
+		fflush(stdout);
+	G_close_cell(fd);
+    if (flag.globalnorm->answer) {
+	/* normalise evidence over total map */
+	    fprintf(stdout, "\nNormalising data by map maximum:\n");
+	    fflush(stdout);
+	if (fd < 0) {
+	    G_fatal_error
+	G_strcat(sysstr, ".globalnorm");
+	if (fd_out < 0) {
+	    G_fatal_error
+	/* normalise evidence within map */
+		if (!G_is_d_null_value(&diskrow[x])) {
+			outrow[x] = (diskrow[x] - min) / (max - min);
+		    else {
+			if (min < 0) {
+			    if (diskrow[x] < 0) {
+				outrow[x] = diskrow[x] / fabs(min);
+			    if (diskrow[x] > 0) {
+				outrow[x] = diskrow[x] / max;
+			    if (diskrow[x] == 0) {
+				outrow[x] = 0;
+			else {
+		else {
+		fflush(stdout);
+	G_close_cell(fd);
+    /* if normalisation was done, we delete the original map, and rename the normalised one */
+    if ((flag.localnorm->answer) || (flag.globalnorm->answer)) {
+	G_remove("cats", parm.output->answer);
+	G_remove("cell", parm.output->answer);
+	G_remove("cell_hd", parm.output->answer);
+	G_remove("cell_misc", parm.output->answer);
+	G_remove("colr", parm.output->answer);
+	G_remove("colr2", parm.output->answer);
+	G_remove("fcell", parm.output->answer);
+	G_remove("hist", parm.output->answer);
+	G_rename("cats", sysstr, parm.output->answer);
+	G_rename("cell", sysstr, parm.output->answer);
+	G_rename("cell_hd", sysstr, parm.output->answer);
+	G_rename("cell_misc", sysstr, parm.output->answer);
+	G_rename("colr", sysstr, parm.output->answer);
+	G_rename("colr2", sysstr, parm.output->answer);
+	G_rename("fcell", sysstr, parm.output->answer);
+	G_rename("hist", sysstr, parm.output->answer);
+    /* if the data was normalised, we need to rescale to get a good grey range */
+	    min = 0;
+	    max = 1.0;
+	else {
+	    if (min < 0) {
+		min = -1.0;
+	    else {
+		min = 0.0;
+	    max = 1.0;
+    /* write a colormap in grey shades: lowest prominence gets black, highest white */
+    G_init_colors(&colors);
+    if ((flag.absolute->answer)) {
+	from = min;
+	to = max / 2;
+	G_add_d_raster_color_rule(&from, 0, 0, 0, &to, 127, 127, 127,
+				  &colors);
+	from = max / 2;
+	to = max;
+	G_add_d_raster_color_rule(&from, 128, 128, 128, &to, 255, 255, 255,
+				  &colors);
+    else {
+	if (min < 0) {
+	    from = min;
+	    to = min / 2;
+	    G_add_d_raster_color_rule(&from, 255, 0, 0, &to, 127, 0, 0,
+				      &colors);
+	    from = min / 2;
+	    to = 0;
+	    G_add_d_raster_color_rule(&from, 127, 0, 0, &to, 0, 0, 0,
+				      &colors);
+	    from = 0;
+	else {
+	    from = min;
+	to = max / 2;
+				  &colors);
+	from = max / 2;
+	to = max;
+				  &colors);
+    G_write_colors(parm.output->answer, G_mapset(), &colors);
+    G_free_colors(&colors);
+    G_free(diskrow);
+    G_free(outrow);
+    free(mapset);
+	fprintf(stdout, "\nDone.\n");
+	fflush(stdout);
+    return (0);
Property changes on: grass-addons/raster/r.prominence/main.c
   + native
