[GRASS-SVN] r37702 - grass/trunk/scripts/r.colors.stddev
Tue Jun 2 06:22:05 EDT 2009
Author: glynn
Date: 2009-06-02 06:22:04 -0400 (Tue, 02 Jun 2009)
New Revision: 37702
Added:
   grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
Removed:
Convert r.colors.stddev to Python
Deleted: grass/trunk/scripts/r.colors.stddev/r.colors.stddev
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev	2009-06-02 10:11:55 UTC (rev 37701)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev	2009-06-02 10:22:04 UTC (rev 37702)
@@ -1,145 +0,0 @@
-#!/bin/sh
-# MODULE:       r.colors.stddev
-# AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
-#                 New Zealand
-# PURPOSE:      Set color rules based on stddev from a map's mean value.
-# COPYRIGHT:    (c) 2007 Hamish Bowman, and the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%Module
-#% description: Set color rules based on stddev from a map's mean value.
-#% keywords: raster, color table
-#%End
-#% option
-#% key: input
-#% type: string
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of input raster map
-#% required: yes
-#%end
-#%flag
-#% key: b
-#% description: Color using standard deviation bands
-#%end
-#%flag
-#% key: z
-#% description: Force center at zero
-#%end
-if  [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." 1>&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-eval `r.univar -g "$GIS_OPT_INPUT"`
-# $? is result of the eval not r.univar (???)
-#if [ $? -ne 0 ] ; then
-#   g.region -e "Problem running r.univar"
-#   exit 1
-#fi
-if [ $GIS_FLAG_Z -eq 0 ] ; then
-   MEAN_MINUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 - 2*$2}'`
-   MEAN_PLUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 + 2*$2}'`
-   if [ $GIS_FLAG_B -eq 0 ] ; then
-     # smooth free floating blue/white/red
-     r.colors "$GIS_OPT_INPUT" color=rules << EOF
-       0% blue
-       $MEAN_MINUS_2STDEV blue
-       $mean white
-       $MEAN_PLUS_2STDEV red
-       100% red
-EOF
-   else
-     # banded free floating  black/red/yellow/green/yellow/red/black
-     MEAN_MINUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 - $2}'`
-     MEAN_MINUS_3STDEV=`echo "$mean $stddev" | awk '{print $1 - 3*$2}'`
-     MEAN_PLUS_1STDEV=`echo "$mean $stddev" | awk '{print $1 + $2}'`
-     MEAN_PLUS_3STDEV=`echo "$mean $stddev" | awk '{print $1 + 3*$2}'`
-     # reclass with labels only works for category (integer) based maps
-     #r.reclass input="$GIS_OPT_INPUT" output="${GIS_OPT_INPUT}.stdevs" << EOF
-     # >3 S.D. outliers colored black so they show up in d.histogram w/ white background
-       0% black
-       $MEAN_MINUS_3STDEV black
-       $MEAN_MINUS_3STDEV red
-       $MEAN_MINUS_2STDEV red
-       $MEAN_MINUS_2STDEV yellow
-       $MEAN_MINUS_1STDEV yellow
-       $MEAN_MINUS_1STDEV green
-       $MEAN_PLUS_1STDEV green
-       $MEAN_PLUS_1STDEV yellow
-       $MEAN_PLUS_2STDEV yellow
-       $MEAN_PLUS_3STDEV red
-       $MEAN_PLUS_3STDEV black
-       100% black
-EOF
-   fi
-else
-   # data centered on 0  (e.g. map of deviations)
-   r.mapcalc "r_col_stdev_abs_$$ = abs($GIS_OPT_INPUT)"
-   eval `r.info -r "r_col_stdev_abs_$$"`
-   # current r.univar truncates percentage to the base integer
-   STDDEV2=`r.univar -eg "r_col_stdev_abs_$$" perc=95.4500 | grep ^percentile | cut -f2 -d=`
-     # zero centered smooth blue/white/red
-       -$max blue
-       -$STDDEV2 blue
-       0 white
-       $STDDEV2 red
-       $max red
-EOF
-   else
-     # zero centered banded  black/red/yellow/green/yellow/red/black
-     STDDEV1=`r.univar -eg "r_col_stdev_abs_$$" perc=68.2689 | grep ^percentile | cut -f2 -d=`
-     STDDEV3=`r.univar -eg "r_col_stdev_abs_$$" perc=99.7300 | grep ^percentile | cut -f2 -d=`
-       -$max black
-       -$STDDEV3 black
-       -$STDDEV3 red
-       -$STDDEV2 red
-       -$STDDEV2 yellow
-       -$STDDEV1 yellow
-       -$STDDEV1 green
-       $STDDEV1 green
-       $STDDEV1 yellow
-       $STDDEV2 yellow
-       $STDDEV2 red
-       $STDDEV3 red
-       $STDDEV3 black
-       $max black
-EOF
-   fi
-   g.remove rast="r_col_stdev_abs_$$" --quiet
-fi
Added: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	                        (rev 0)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2009-06-02 10:22:04 UTC (rev 37702)
@@ -0,0 +1,145 @@
+#!/usr/bin/env python
+# MODULE:       r.colors.stddev
+# AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+#                 New Zealand
+#               Converted to Python by Glynn Clements
+# PURPOSE:      Set color rules based on stddev from a map's mean value.
+# COPYRIGHT:    (c) 2007,2009 Hamish Bowman, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Set color rules based on stddev from a map's mean value.
+#% keywords: raster, color table
+#%End
+#% option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of input raster map
+#% required: yes
+#%end
+#%flag
+#% key: b
+#% description: Color using standard deviation bands
+#%end
+#%flag
+#% key: z
+#% description: Force center at zero
+#%end
+import sys
+import os
+import atexit
+import grass.script as grass
+def z(n):
+    return mean + n * stddev
+def cleanup():
+    if tmpmap:
+	grass.run_command('g.remove', rast = tmpmap, quiet = True)
+def main():
+    global tmpmap
+    tmpmap = None
+    input = options['input']
+    zero = flags['z']
+    bands = flags['b']
+    if not zero:
+	s = grass.read_command('r.univar', flags = 'g', map = input)
+	kv = grass.parse_key_val(s)
+	global mean, stddev
+	mean = float(kv['mean'])
+	stddev = float(kv['stddev'])
+	if not bands:
+	    # smooth free floating blue/white/red
+	    rules = '\n'.join([
+		"0% blue",
+		"%f blue"  % z(-2),
+		"%f white" % mean,
+		"%f red"   % z(+2),
+		"100% red"])
+	else:
+	    # banded free floating  black/red/yellow/green/yellow/red/black
+	    # reclass with labels only works for category (integer) based maps
+            #r.reclass input="$GIS_OPT_INPUT" output="${GIS_OPT_INPUT}.stdevs" << EOF
+	    # >3 S.D. outliers colored black so they show up in d.histogram w/ white background
+		"0% black",
+		"%f black"  % z(-3),
+		"%f red"    % z(-3),
+		"%f red"    % z(-2),
+		"%f yellow" % z(-2),
+		"%f yellow" % z(-1),
+		"%f green"  % z(-1),
+		"%f green"  % z(+1),
+		"%f yellow" % z(+1),
+		"%f yellow" % z(+2),
+		"%f red"    % z(+2),
+		"%f red"    % z(+3),
+		"%f black"  % z(+3),
+		"100% black"])
+    else:
+	tmpmap = "r_col_stdev_abs_%d" % os.getpid()
+	grass.mapcalc("$tmp = abs($input)", tmp = tmpmap, input = input)
+	# data centered on 0  (e.g. map of deviations)
+	info = grass.raster_info(tmpmap)
+	maxv = info['max']
+	# current r.univar truncates percentage to the base integer
+	s = grass.read_command('r.univar', flags = 'eg', map = input, percentile = [95.45,68.2689,99.7300])
+	stddev1 = float(kv['percentile_68'])
+	stddev2 = float(kv['percentile_95'])
+	stddev3 = float(kv['percentile_99'])
+	if not bands:
+	    # zero centered smooth blue/white/red
+		"%f blue" % -maxv,
+		"%f blue" % -stddev2,
+		"0 white",
+		"%f red"  % stddev2,
+		"%f red"  % maxv])
+	else:
+	    # zero centered banded  black/red/yellow/green/yellow/red/black
+		"%f black" % -maxv,
+		"%f black" % -stddev3,
+		"%f red" % -stddev3,
+		"%f red" % -stddev2,
+		"%f yellow" % -stddev2,
+		"%f yellow" % -stddev1,
+		"%f green" % -stddev1,
+		"%f green" % stddev1,
+		"%f yellow" % stddev1,
+		"%f yellow" % stddev2,
+		"%f red" % stddev3,
+		"%f black" % stddev3,
+		"%f black" % maxv,
+    grass.write_command('r.colors', map = input, rules = '-', stdin = rules)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
___________________________________________________________________
