[GRASS-SVN] r37714 - grass-addons/vector/v.autokrige2
Wed Jun 3 06:28:06 EDT 2009
Author: aghisla
Date: 2009-06-03 06:28:06 -0400 (Wed, 03 Jun 2009)
New Revision: 37714
   grass-addons/vector/v.autokrige2/v.autokrige2.py
in comments, proposed window structure. To be improved.
Modified: grass-addons/vector/v.autokrige2/v.autokrige2.py
--- grass-addons/vector/v.autokrige2/v.autokrige2.py	2009-06-03 10:26:00 UTC (rev 37713)
+++ grass-addons/vector/v.autokrige2/v.autokrige2.py	2009-06-03 10:28:06 UTC (rev 37714)
@@ -23,20 +23,8 @@
 import sys
 #import wx.lib.flatnotebook as FN # self.notebook attribute in Kriging Module's __init__
 #classes in alphabetical order
-class Log:
-    The log output is redirected to the status bar of the containing frame.
-    def __init__(self, parent):
-        self.parent = parent
-    def write(self, text_string):
-        """Update status bar"""
-        self.parent.SetStatusText(text_string.strip())
 class KrigingModule(wx.Frame):
     Kriging module for GRASS GIS.
@@ -45,27 +33,52 @@
         wx.Frame.__init__(self, parent, *args, **kwargs)
         # setting properties and all widgettery
         self.SetTitle("Kriging Module")
-        self.panel = wx.Panel(parent=self)
-        self.log = Log(self) # -> statusbar
+        self.log = Log(self) # writes on statusbar
         self.CreateStatusBar()
         # debug: remove before flight
         self.log.write("Are you reading this? This proves it is very beta version.")
+        # sizer stuff. Improvable.
+        vsizer1 = wx.BoxSizer(orient=wx.VERTICAL)
+        # uncommment this line when panels will be ready to be added
+#        vsizer1.Add(item=ITEM, proportion=1, flag=wx.EXPAND | wx.ALL, border=10)
+        self.SetSizerAndFit(vsizer1)
+#        self.SetAutoLayout(True)
+#        vsizer1.Fit(self)
+        #@TODO(anne): set minimum size around objects.
+#        global variables. don't know if it is a good place to store them, in case move them
+#        widgettery. They are all Panels into StaticBox Sizers.
+#        1. Combobox with all point layers of the mapset with xyz data: see how to call d.vect.
+#               whateverNameOfFunction(ltype='vector',
+#                                            lname=name,
+#                                            lchecked=True,
+#                                            lopacity=1.0,
+#                                            lcmd=['d.vect', 'map=%s' % name])
+#        2. Variogram.
+#            RadioButton (default choice): Auto-fit Variogram
+#            RadioButton: Choose variogram parameters -> Button that opens a dialog with the variogram plot and controls.
+#        3. Kriging.
+#            2 Notebook pages, one for R package gstat and other for geoR. Each page will have the available options, zB:
+#            RadioButton (default): Ordinary Kriging
+#            RadioButton: Block Kriging
+#            RadioButton: Cokriging
+#        n. OK - Cancel buttons
+class Log:
+    The log output is redirected to the status bar of the containing frame.
+    def __init__(self, parent):
+        self.parent = parent
-        #self.notebook = FN.FlatNotebook(parent=self.panel, id=wx.ID_ANY,
-        #                                style=FN.FNB_BOTTOM |
-        #                                FN.FNB_NO_NAV_BUTTONS |
-        #                                FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
+    def write(self, text_string):
+        """Update status bar"""
+        self.parent.SetStatusText(text_string.strip())
-        # use this block to add pages to the flat notebook widget
-        #dbmStyle = globalvar.FNPageStyle
-        ## start block
-        #self.browsePage = FN.FlatNotebook(self.panel, id=wx.ID_ANY,
-        #                                  style=dbmStyle)
-        #self.notebook.AddPage(self.browsePage, text=_("Browse data"))
-        #self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
-        ## end block
 #main
 def main(argv=None):
     if argv is None:
@@ -84,7 +97,8 @@
     ##some applications might require image handlers
     #wx.InitAllImageHandlers()
-    app = wx.PySimpleApp()
+#    app = wx.PySimpleApp() # deprecated?
+    app = wx.App()
     k = KrigingModule(parent=None, size=(600,300))
     k.Show()
     app.MainLoop()
@@ -92,3 +106,19 @@
 if __name__ == '__main__':
     main()
+## notebook stuff. If used, uncomment also import directive for flat notebook.
+#        self.notebook = FN.FlatNotebook(parent=self.panel, id=wx.ID_ANY,
+#                                        style=FN.FNB_BOTTOM |
+#                                        FN.FNB_NO_NAV_BUTTONS |
+#                                        FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
+#        # use this block to add pages to the flat notebook widget
+##        dbmStyle = globalvar.FNPageStyle
+#        ## start block
+#        self.collectDataPage = FN.FlatNotebook(self.panel, id=wx.ID_ANY)
+#        self.notebook.AddPage(self.collectDataPage, text=("Collect Data"))
+##        self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
+#        ## end block
+#    def __createCollectDataPage(self):
+#        pass
