[GRASS-SVN] r37720 - grass-addons/vector/v.autokrige
Wed Jun 3 13:17:44 EDT 2009
Author: mathieug
Date: 2009-06-03 13:17:44 -0400 (Wed, 03 Jun 2009)
New Revision: 37720
Added:
   grass-addons/vector/v.autokrige/v.autokrige.py
v.autokrige.py : a port of v.autokrige to python (working beta version)
Added: grass-addons/vector/v.autokrige/v.autokrige.py
--- grass-addons/vector/v.autokrige/v.autokrige.py	                        (rev 0)
+++ grass-addons/vector/v.autokrige/v.autokrige.py	2009-06-03 17:17:44 UTC (rev 37720)
@@ -0,0 +1,356 @@
+#!/usr/bin/python
+#-*- coding: utf-8 -*-
+# MODULE:       v.autokrige.py
+# AUTHOR(S):	Mathieu Grelier (greliermathieu at gmail.com)
+# PURPOSE:	automatic kriging interpolation from vector point data
+# REQUIREMENTS:
+# - unix utility : bc
+# - statistical software : R (http://www.r-project.org/) with spgrass6 (http://cran.r-project.org/web/packages/spgrass6/index.html)
+#	and automap (http://intamap.geo.uu.nl/~paul/Downloads.html) packages
+# - imagemagick : convert program
+# COPYRIGHT:	(C) 2009 Mathieu Grelier
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: automatic kriging interpolation from vector point data
+#%  keywords: kriging, autokrige, RGrass
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of the vector containing sites data (values to interpolate) and geometry. Must not contain any null values.
+#% required : yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Attribute column to interpolate (must be numeric).
+#% required : yes
+#%end
+#%option
+#% key: nbcell
+#% type: integer
+#% answer: 100
+#% description: number of cell of the created grid. If set, GRASS region is affected.
+#% required : no
+#%end
+#%option
+#% key: models
+#% type: string
+#% options: Exp,Sph,Gau,Mat
+#% multiple : yes
+#% answer:
+#% description: List of variogram models to be automatically tested. Select only one to fix the model.
+#% required : no
+#%end
+#%option
+#% key: range
+#% type: integer
+#% description: Range value. Automatically fixed if not set.
+#% required : no
+#%end
+#%option
+#% key: nugget
+#% type: double
+#% description: Nugget value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: sill
+#% type: double
+#% description: Sill value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: output
+#% type: string
+#% answer: autokrige
+#% description: Name of the raster to produce
+#% required : yes
+#%end
+#%option
+#% key: colormap
+#% type: string
+#% answer: bcyor
+#% description: Colormap file to use to colorize the raster
+#% required : no
+#%end
+#%flag
+#% key: v
+#% description: Create variance raster also
+#%end
+#%flag
+#% key: r
+#% description: Don't set region from sites extent. Region would have been previously set in grass.
+#%end
+import sys
+import os
+import re
+from subprocess import Popen, PIPE
+import traceback
+from grass import core as grass
+from dbgp.client import brk
+class AutoKrige():
+    def __init__(self, options, flags):
+        ##options
+        self.input = options['input']
+        self.column = options['column']
+        self.nbcell = options['nbcell'] if options['nbcell'].strip() != '' else None
+        self.models = options['models'] if options['models'].strip() != '' else None
+        self.range = options['range'] if options['range'].strip() != '' else None
+        self.nugget = options['nugget'] if options['nugget'].strip() != '' else None
+        self.sill = options['sill'] if options['sill'].strip() != '' else None
+        self.output = options['output']
+        self.colormap = options['colormap'] if options['colormap'].strip() != '' else 'bcyor'
+        ##flags
+        self.varianceFlag = True if flags['v'] is True else False
+        self.regionFlag = True if flags['r'] is True else False
+        #others
+        self.RscriptFile = None
+        self.logfile='v.autokrige.log'
+    def __checkLayers(self, input, output):
+        ##Test for input vector map.
+        testInput = grass.find_file(input, element = 'vector')
+        if testInput['fullname'] == '':
+            raise AutoKrigeError("vector map " + input + " not found in mapset search path.")
+        ##Test if output raster map already exists.
+        testOutput = grass.find_file(output, element = 'cell')
+        if testOutput['fullname'] != '':
+            if not grass.overwrite is True:
+                raise AutoKrigeError("raster map " + output + " already exists in mapset search path. \n \
+Use the --o flag to overwrite.")
+            else:
+                print "Warning: raster map " + output + " will be overwritten."
+        ##Test also variance raster.
+        if self.varianceFlag is True:
+            testVarOutput = grass.find_file(output + '_var', element = 'cell')
+            if testVarOutput['fullname'] != '':
+                else:
+                    print "Warning: raster map " + output + '_var' + " will be overwritten."
+    def __getGridCellSize(self, input, nbcell):
+        """Define kriged grid cell size : we take region resolution as cell size.
+        Only one value is needed because the R script use square cells."""
+        if self.regionFlag is not True:
+            grass.run_command("g.region", vect = input)
+        if nbcell is not None:
+            self.__fixRegionResFromNumberOfCells(nbcell)
+        regionParams = grass.region()
+        cellsize = float(regionParams['nsres']) if float(regionParams['nsres']) > float(regionParams['ewres']) \
+        else float(regionParams['ewres'])
+        return cellsize
+    def __fixRegionResFromNumberOfCells(self, nbcell=100):
+        """to explain"""
+        nsResForGivenNbCell = (float(regionParams['n'])- float(regionParams['s'])) / float(nbcell)
+        ewResForGivenNbCell = (float(regionParams['e'])- float(regionParams['w'])) / float(nbcell)
+        tmpRegionRes = nsResForGivenNbCell if nsResForGivenNbCell > ewResForGivenNbCell else ewResForGivenNbCell
+        grass.use_temp_region
+        grass.run_command("g.region", res = tmpRegionRes)
+    def __prepareRScriptArguments(self, cellsize, models=None, range=None, nugget=None, sill=None):
+        ##1)Models
+        ##The script will try to create the R argument as expected in the R script,
+        ##to avoid string manipulations with R.
+        RargumentsDict = {}
+        if models is None:
+            #it is important not to have any space between commas and following slashes
+            RargumentsDict['models']='c(\"Sph\",\"Exp\",\"Gau\",\"Mat\")'
+        else:
+            #conversion to R arguments in the expected format, starting from model1,model2...
+            #add c(" at the beginning and add ") at the end
+            RargumentsDict['models'] = 'c(\\"' + models + '\\")'
+            #replace commas by \",\"
+            p = re.compile(',')
+            RargumentsDict['models'] = p.sub('\\",\\"',RargumentsDict['models'])
+        ##2)Range, nugget, sill
+        RargumentsDict['range'] = range if range is not None else 'NA'
+        RargumentsDict['nugget'] = nugget if nugget is not None else 'NA'
+        RargumentsDict['sill'] = sill if sill is not None else 'NA'
+        return RargumentsDict
+    def __writeRScript(self):
+        RscriptFile = grass.tempfile()
+        fileHandle = open(RscriptFile, 'a')
+        script = """
+        options(echo = FALSE)
+        args <- commandArgs()
+        ##start at index 5 because first arguments are R options
+        sitesG <- args[5]
+        column <- args[6]
+        rastername <- args[7]
+        cellsize <- as.numeric(args[8])
+        models <- args[9]
+        modelslist <- eval(parse(text = models))
+        range <- as.numeric(args[10])
+        if(args[10] == "NA") {nugget = NA} else {nugget <- as.numeric(args[11])}
+        if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
+        writevarrast <- as.logical(args[13])
+        tryCatch({
+            ##libraries
+            library(spgrass6)
+            library(automap)
+            ##retrieve sites in a SpatialPointsDataFrame object
+            cat("retrieve sites from GRASS","\n")
+            sitesR <- readVECT6(sitesG, ignore.stderr = F)
+            ##uncomment to check sites
+            #sitesR
+            cat("retrieve metadata","\n")
+            G <- gmeta6()
+            cat("GridTopology creation","\n")
+            grd <- gmeta2grd()
+            ##this is necessary to ensure that we have square cells
+            ##the more this number is small, the more the kriged map resolution is high
+            slot(grd, "cellsize") <- c(cellsize, cellsize)
+            ##creation of another grid object: SpatialGridDataFrame
+            ##this is a matrix whose values receive spatial coordinates associated to interpolated values
+            ##matrix size must be equal to the number of GridTopology cells
+            ##we create first a classical data.frame
+            data <- data.frame(list(k=rep(1,(floor(G$cols)*floor(G$rows)))))
+            cat("SpatialGridDataFrame creation","\n")
+            mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
+            ##add coordinates system
+            attr(sitesR, "proj4string") <-CRS(G$proj4)
+            cat("ordinary kriging","\n")
+            #[note : rajouter une option pour gérer le krigeage universel]
+            kriging_result = autoKrige(as.formula(paste(column,"~",1)), sitesR[column], mask_SG, model = modelslist, fix.values = c(nugget,range,sill), debug.level=-1, verbose=TRUE)
+            cat("send raster to GRASS","\n")
+            writeRAST6(kriging_result$krige_output,rastername,zcol=1,NODATA=0)
+            cat("Generated",rastername," "); cat("", sep="\n")
+            if(writevarrast == T) {
+                varrastername = paste(rastername, "_var", sep = "")
+                writeRASTt6(kriging_result$krige_output,varrastername,zcol=2,NODATA=0)
+                cat("Generated",varrastername," "); cat("", sep="\n")
+            ##plot experimental and model variogram
+            cat("plot kriging results","\n")
+            options(device="pdf")
+            try(automap:::plot.autoKrige(kriging_result))
+            cat("R script done","\n")
+            quit(status = 0)
+        }, interrupt = function(ex) {
+            cat("An interrupt was detected.\n");
+            quit(status = 4)
+            error = function(ex) {
+            cat("Error while executing R script.\n");
+            quit(status = 5)
+        fileHandle.write(script)
+        fileHandle.close()
+        return RscriptFile
+    def __finalize(self, output, colormap):
+        try:
+            ##convert plot to png
+            self.__execShellCommand('convert -alpha off Rplots.pdf Rplots.png')
+            ##apply colormap
+            grass.run_command("r.colors", map = output, rules = colormap, quiet = True)
+        except:
+            ##we don't want to stop execution if an error occurs here
+            pass
+    def __execShellCommand(self, command, stderrRedirection=False, writeToLog=False):
+        """general purpose function, maybe should be added in some way to core.py """
+        if stderrRedirection is True:
+            command = command + " 2>&1"
+        p = Popen(command, shell=True, stdout=PIPE)
+        retcode = p.wait()
+        com = p.communicate()
+        if writeToLog is True:
+            fileHandle = open(self.logfile, 'w')
+            fileHandle.write(com[0])
+        if retcode == 0:
+            return com[0]
+        else:
+            errorMessage = ''
+            for elem in com:
+                errorMessage += str(elem) + "\n"
+            raise AutoKrigeError(errorMessage)
+    def runAutoKrige(self):
+        """Autokrige class public method"""
+        ##1)Necessary checks
+        self.__checkLayers(self.input, self.output)
+        ##2)Adjust interpolation resolution
+        cellsize = self.__getGridCellSize(self.input, self.nbcell)
+        ##3)Put all R arguments in a dict
+        RargsDict = self.__prepareRScriptArguments(cellsize, self.models, self.range, \
+        self.nugget, self.sill)
+        ##4)Execute R from GRASS
+        self.RscriptFile = self.__writeRScript()
+        ##spgrass6 cause : column name in R has only the 10 first characters of the original column name
+        Rcolumnname = self.column[0:9]
+        writeVarRast = 'T' if self.varianceFlag is True else 'F'
+        print "RGrass is working..."
+        autoKrigeCommand = 'R --vanilla --slave --args ' + self.input + ' ' + Rcolumnname + ' ' + \
+                        self.output + ' ' + str(cellsize) + ' "' + RargsDict['models'] + '" ' + \
+                        RargsDict['range'] + ' ' +  RargsDict['nugget'] + ' ' + RargsDict['sill'] \
+                        + ' ' + writeVarRast + ' < "' + self.RscriptFile + '"'
+        self.__execShellCommand(autoKrigeCommand, stderrRedirection=True, writeToLog=True)
+        ##5)Finalize output
+        self.__finalize(self.output, self.colormap)
+class AutoKrigeError(Exception):
+    """Errors specific to Autokrige class"""
+    def __init__(self, message):
+        self.details = '\nDetails:\n'
+        exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
+        self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+        self.message = message + "\n" + self.details
+def main():
+    try:
+        autoKrige = AutoKrige(options, flags)
+        autoKrige.runAutoKrige()
+    except AutoKrigeError, e1:
+        print >> sys.stderr, "Error:", e1.message
+    except:
+        print >> sys.stderr, "Unexpected error:"
+        traceback.print_exc()
+    else:
+        print "Done"
+        sys.exit(0)
+    finally:
+        grass.try_remove(autoKrige.RscriptFile)
+if __name__ == "__main__":
+    ### DEBUG : uncomment to start local debugging session
+    #brk(host="localhost", port=9000)
+    if grass.find_program('R'):
+        options, flags = grass.parser()
+        main()
+    else:
+        print "R required, please install R first"
Property changes on: grass-addons/vector/v.autokrige/v.autokrige.py
___________________________________________________________________
