[GRASS-SVN] r37816 - grass/trunk/scripts/v.colors
Wed Jun 10 22:53:54 EDT 2009
Author: glynn
Date: 2009-06-10 22:53:54 -0400 (Wed, 10 Jun 2009)
New Revision: 37816
Added:
   grass/trunk/scripts/v.colors/v.colors.py
Convert v.colors to Python (untested)
Added: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py	                        (rev 0)
+++ grass/trunk/scripts/v.colors/v.colors.py	2009-06-11 02:53:54 UTC (rev 37816)
@@ -0,0 +1,310 @@
+#!/usr/bin/env python
+# MODULE:       v.colors
+# AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+#                 New Zealand
+#               Converted to Python by Glynn Clements
+# PURPOSE:      Populate a GRASSRGB column with a color map and data column
+#		Helper script for thematic mapping tasks
+# COPYRIGHT:    (c) 2008 Hamish Bowman, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Set color rules for features in a vector using a numeric attribute column.
+#% keywords: vector, color table
+#%End
+#% option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of input vector map
+#% required: yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Name of column containg numeric data
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer number of data column
+#% gisprompt: old_layer,layer,layer
+#% answer: 1
+#% required: no
+#%end
+#%Option
+#% key: rgb_column
+#% type: string
+#% required: no
+#% description: Name of color column to populate
+#% answer: GRASSRGB
+#% guisection: Colors
+#%End
+#% option
+#% key: range
+#% type: double
+#% required: no
+#% multiple: no
+#% key_desc: min,max
+#% description: Manually set range (min,max)
+#%End
+#% option
+#% key: color
+#% type: string
+#% key_desc: style
+#% options: aspect,aspectcolr,bcyr,bgyr,byg,byr,celsius,curvature,differences,elevation,etopo2,evi,grey,grey1.0,grey255,gyr,ndvi,population,precipitation,rainbow,ramp,ryb,ryg,sepia,slope,srtm,terrain,wave,random
+#% description: Type of color table
+#% required: no
+#%end
+#%Option
+#% key: raster
+#% type: string
+#% required: no
+#% description: Raster map name from which to copy color table
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: rules
+#% type: string
+#% required: no
+#% description: Path to rules file
+#% gisprompt: old_file,file,input
+#%End
+#%Flag
+#% key: s
+#% description: Save placeholder raster map for use with d.legend
+#%End
+#%Flag
+#% key: n
+#% description: Invert colors
+#%End
+## TODO: implement -e (equalized) and -g (logarithmic) methods in r.colors
+##   'v.db.select column= | wc -l' to set region size (1xLength)
+##   then create r.in.ascii 1xLength matrix with data (WITHOUT uniq)
+##   and run r.colors on that raster map.
+##      or
+##   v.to.rast, r.colors -g, then parse colr/ file. But that's resolution dependent
+import sys
+import os
+import atexit
+import string
+import grass.script as grass
+def cleanup():
+    if tmp:
+	grass.try_remove(tmp)
+    if tmp_vcol:
+	grass.try_remove(tmp_vcol)
+    if tmp_colr:
+	grass.run_command('g.remove', rast = tmp_colr, quiet = True)
+def main():
+    color = options['color']
+    column = options['column']
+    layer = options['layer']
+    map = options['map']
+    range = options['range']
+    raster = options['raster']
+    rgb_column = options['rgb_column']
+    rules = options['rules']
+    flip = flags['n']
+    global tmp, tmp_colr, tmp_vcol
+    pid = os.getpid()
+    tmp = None
+    tmp_colr = None
+    tmp_vcol = None
+    os.environ['GRASS_VERBOSE'] = '0'
+    kv = grass.gisenv()
+    mapset = kv['MAPSET']
+    gisbase = os.getenv('GISBASE')
+    #### does map exist in CURRENT mapset?
+    kv = grass.find_file(map, element = 'vector', mapset = mapset)
+    map_split = map.split('@')
+    vect_mapset = map_split[1:]
+    if vect_mapset == []:
+	vect_mapset = mapset
+    else:
+	vect_mapset = vect_mapset[0]
+    if not kv['file'] or vect_mapset != mapset:
+	grass.fatal("Vector map <%s> not found in current mapset" % map)
+    vector = map_split[0]
+    # sanity check mutually exclusive color options
+    ctest = 0
+    for opt in ['color', 'raster', 'rules']:
+	if options[opt]:
+	    ctest += 1
+    if ctest != 1:
+	grass.fatal("Pick one of color, rules, or raster options")
+    if color:
+	#### check the color rule is valid
+	color_opts = os.listdir(os.path.join(gisbase,'etc','colors'))
+	color_opts += ['random', 'grey.eq', 'grey.log', 'rules']
+	if color not in color_opts:
+	    grass.fatal(("Invalid color rule <%s>\n" % color) +
+			("Valid options are: %s" % ' '.join(color_opts)))
+    elif raster:
+	if not grass.find_file(raster)['name']:
+	    grass.fatal("Unable to open raster map <%s>" % raster)
+    elif rules:
+	if not os.access(rules, os.R_OK):
+	    grass.fatal("Unable to read color rules file <%s>" % rules)
+    #### column checks
+    # check input data column
+    cols = grass.vector_columns(map, layer = layer)
+    if column not in cols:
+	grass.fatal("Column <%s> not found" % column)
+    ncolumn_type = cols[column]
+    if ncolumn_type not in ["INTEGER", "DOUBLE PRECISION"]:
+	grass.fatal("Column <%s> is not numeric" % column)
+    #g.message "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
+    # check if GRASSRGB column exists, make it if it doesn't
+    table = grass.vector_db(map)[layer]['table']
+    if rgb_column not in cols:
+        # RGB Column not found, create it
+	grass.message("Creating column <%s> ..." % rgb_column)
+	if 0 != grass.run_command('v.db.addcol', map = map, layer = layer, column = "%s varchar(11)" % rgb_column):
+	    grass.fatal("Creating color column")
+    else:
+	column_type = cols[rgb_column]
+	if column_type not in ["CHARACTER", "TEXT"]:
+	    grass.fatal("Column <%s> is not of compatible type (found %s)" % (rgb_column, column_type))
+	else:
+	    num_chars = dict([(v[0], int(v[2])) for v in grass.db_describe(table)['cols']])[rgb_column]
+	    if num_chars < 11:
+		grass.fatal("Color column <%s> is not wide enough (needs 11 characters)", rgb_column)
+    cvals = grass.vector_db_select(map, layer = layer, column = column)['values'].values()
+    # find data range
+    if range:
+	#order doesn't matter
+	vals = range.split(',')
+    else:
+	grass.message("Scanning values ...")
+	vals = [float(x[0]) for x in cvals]
+    minval = min(vals)
+    maxval = max(vals)
+    grass.message(" min=[%s]  max=[$%s]" % (minval, maxval))
+    if not minval or not maxval:
+	grass.fatal("Scanning data range")
+    # setup internal region
+    use_temp_region()
+    grass.run_command('g.region', rows = 2, cols = 2)
+    tmp_colr = "tmp_colr_%d" % pid
+    # create dummy raster map
+    if ncolumn_type == "INTEGER":
+	grass.mapcalc("$tmp_colr = if(row() == 1, $minval, $maxval)",
+		      tmp_colr = tmp_colr, minval = minval, maxval = maxval)
+    else:
+	grass.mapcalc("$tmp_colr = double(if(row() == 1, $minval, $maxval))",
+    if color:
+	color_cmd = {'color': color}
+    elif raster:
+	color_cmd = {'raster': raster}
+    elif rules:
+	color_cmd = {'rules': rules}
+    if flip:
+	flip_flag = 'n'
+    else:
+	flip_flag = ''
+    grass.run_command('r.colors', map = tmp_colr, flags = flip_flag, **color_cmd)
+    tmp = grass.tempfile()
+    # calculate colors and write SQL command file
+    grass.message("Looking up colors ...")
+    p = grass.start_command('r.what.color', flags = 'i', input = tmp_colr,
+			    stdin = grass.PIPE, stdout = grass.PIPE)
+    lastval = None
+    for v in sorted(cvals):
+	if v == lastval:
+	    continue
+	p.stdin.write('%f\n' % v)
+    p.stdin.close()
+    p.wait()
+    tmp_vcol = "%s_vcol.sql" % tmp
+    f = open(tmp_vcol, 'w')
+    t = string.Template("UPDATE $table SET $rgb_column = '$colr' WHERE $column = $value;\n")
+    found = 0
+    for line in p.stdout:
+	[value, colr] = line.split(':')
+	colr = colr.strip()
+	if len(colr.split(':')) != 3:
+	    continue
+	#g.message message="LINE=[$LINE]"
+	f.write(t.substitute(table = table, rgb_column = rgb_column, colr = colr, value = value))
+	found += 1
+    f.close()
+    if not found:
+	grass.fatal("No values found in color range")
+    # apply SQL commands to update the table with values
+    grass.message("Writing %s colors ..." % found)
+    # less "$TMP"
+    if 0 != grass.run_command('db.execute', input = tmp_vcol):
+	grass.fatal("Processing SQL transaction")
+    if flags['s']:
+	vcolors = "vcolors_%d" % pid
+	grass.run_command('g.rename', rast = (tmp_colr, vcolors))
+	grass.message("Raster map containing color rules saved to <%s>" % vcolors)
+	# TODO save full v.colors command line history
+	grass.run_command('r.support', map = vcolors,
+			  history = "",
+			  source1 = "vector map = %s" % map,
+			  source2 = "column = %s" % column,
+			  title = "Dummy raster to use as thematic vector legend",
+			  description = "generated by v.colors using r.mapcalc")
+			  history = "RGB saved into <%s> using <%s%s%s>" % (rgb_column, color, raster, rules))
+    else:
+	grass.run_command('g.remove', rast = tmp_colr)
+    #v.db.dropcol map=vcol_test col=GRASSRGB
+    #d.vect -a vcol_test icon=basic/circle color=none size=8
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
