[GRASS-SVN] r37826 - in grass/trunk/gui/wxpython: . gui_modules xml
Thu Jun 11 12:19:44 EDT 2009
Author: martinl
Date: 2009-06-11 12:19:43 -0400 (Thu, 11 Jun 2009)
New Revision: 37826
   grass/trunk/gui/wxpython/gui_modules/gcmd.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/gui_modules/utils.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxGUI: use ElementTree for parsing workspace files
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py	2009-06-11 16:19:43 UTC (rev 37826)
@@ -64,14 +64,14 @@
 class GException(Exception):
     """!Generic exception"""
     def __init__(self, message, title=_("Error"), parent=None):
-        self.message = message
+        self.msg = message
         self.parent = parent
         self.title = title
     def Show(self):
         dlg = wx.MessageDialog(parent=self.parent,
                                caption=self.title,
-                               message=self.message,
+                               message=self.msg,
                                style=wx.ICON_ERROR | wx.CENTRE)
         dlg.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_error.ico'), wx.BITMAP_TYPE_ICO))
         if self.parent:
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-06-11 16:19:43 UTC (rev 37826)
@@ -142,11 +142,6 @@
             label = _('Select Color')
     return (rgb, label)
-def normalize_whitespace(text):
-    """!Remove redundant whitespace from a string"""
-    return string.join( string.split(text), ' ')
 def text_beautify( someString , width=70):
     Make really long texts shorter, clean up whitespace and
@@ -154,10 +149,10 @@
     if width > 0:
         return escape_ampersand( string.strip(
-                os.linesep.join( textwrap.wrap( normalize_whitespace(someString), width ) ),
+                os.linesep.join( textwrap.wrap( utils.normalize_whitespace(someString), width ) ),
     else:
-        return escape_ampersand( string.strip(normalize_whitespace(someString ), ".,;:" ))
+        return escape_ampersand( string.strip(utils.normalize_whitespace(someString ), ".,;:" ))
 def escape_ampersand(text):
     """!Escapes ampersands with additional ampersand for GUI"""
@@ -498,7 +493,7 @@
         """!Get node text"""
         p = node.find(tag)
         if p is not None:
-            return normalize_whitespace(p.text)
+            return utils.normalize_whitespace(p.text)
         return default
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py	2009-06-11 16:19:43 UTC (rev 37826)
@@ -17,6 +17,7 @@
 import os
 import sys
 import platform
+import string
 import globalvar
 grassPath = os.path.join(globalvar.ETCDIR, "python")
@@ -31,6 +32,10 @@
     sys.path.append(compatPath)
     import subprocess
+def normalize_whitespace(text):
+    """!Remove redundant whitespace from a string"""
+    return string.join( string.split(text), ' ')
 def GetTempfile(pref=None):
     Creates GRASS temporary file using defined prefix.
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2009-06-11 16:19:43 UTC (rev 37826)
@@ -1,4 +1,4 @@
 @package workspace.py
 @brief Open/save workspace definition file
@@ -25,322 +25,333 @@
 # from xml.parsers.xmlproc import xmlproc
 # from xml.parsers.xmlproc import xmlval
 # from xml.parsers.xmlproc import xmldtd
-import xml.sax
-import xml.sax.handler
-HandlerBase=xml.sax.handler.ContentHandler
-from xml.sax import make_parser
+try:
+    import xml.etree.ElementTree as etree
+except ImportError:
+    import elementtree.ElementTree as etree # Python <= 2.4
+import utils
 from preferences import globalSettings as UserSettings
-class ProcessWorkspaceFile(HandlerBase):
-    A SAX handler for the GXW XML file, as
-    defined in grass-gxw.dtd.
-    def __init__(self):
-        self.inTag = {}
-        for tag in ('gxw', 'layer', 'task', 'parameter',
-                    'flag', 'value', 'group', 'display',
-                    'layer_manager',
-                    'nviz',
-                    # surface
-                    'surface', 'attribute', 'draw', 'resolution',
-                    'wire_color', 'position', 'x', 'y', 'z',
-                    # vector lines
-                    'vlines', 'color', 'width', 'mode',
-                    'map', 'height',
-                    # vector points
-                    'vpoints', 'size'):
-            self.inTag[tag] = False
+class ProcessWorkspaceFile():
+    def __init__(self, tree):
+        """!A ElementTree handler for the GXW XML file, as defined in
+        grass-gxw.dtd.
+        self.tree = tree
+        self.root = self.tree.getroot()
         # layer manager properties
         self.layerManager = {}
-        self.layerManager['pos'] = None # window position
+        self.layerManager['pos']  = None # window position
         self.layerManager['size'] = None # window size
         # list of mapdisplays
         self.displays = []
         # list of map layers
         self.layers = []
-        self.cmd    = []
         self.displayIndex = -1 # first display has index '0'
+        self.__processFile()
     def __filterValue(self, value):
-        """!Translate value"""
+        """!Filter value
+        @param value
         value = value.replace('&lt;', '<')
         value = value.replace('&gt;', '>')
         return value
+    def __getNodeText(self, node, tag, default = ''):
+        """!Get node text"""
+        p = node.find(tag)
+        if p is not None:
+        return default
-    def startElement(self, name, attrs):
-        if name == 'display':
+    def __processFile(self):
+        """!Process workspace file"""
+        # layer manager
+        node_lm = self.root.find('layer_manager')
+        if node_lm is not None:
+            posAttr = node_lm.get('dim', '')
+            if posAttr:
+                posVal = map(int, posAttr.split(','))
+                try:
+                    self.layerManager['pos']  = (posVal[0], posVal[1])
+                    self.layerManager['size'] = (posVal[2], posVal[3])
+                except:
+                    pass
+        # displays
+        for display in self.root.findall('display'):
             self.displayIndex += 1
             # window position and size
-            posAttr = attrs.get('dim', '')
+            posAttr = display.get('dim', '')
             if posAttr:
                 try:
-                    pos = (posVal[0], posVal[1])
+                    pos  = (posVal[0], posVal[1])
                     size = (posVal[2], posVal[3])
                 except:
-                    pos = None
+                    pos  = None
                     size = None
             else:
-                pos = None
+                pos  = None
                 size = None
-            extentAttr = attrs.get('extent', '')
+            extentAttr = display.get('extent', '')
             if extentAttr:
                 # w, s, e, n
                 extent = map(float, extentAttr.split(','))
             else:
                 extent = None
-            self.displays.append({
-                "render"         : bool(int(attrs.get('render', "0"))),
-                "mode"           : int(attrs.get('mode', 0)),
-                "showCompExtent" : bool(int(attrs.get('showCompExtent', "0"))),
-                "pos"            : pos,
-                "size"           : size,
-                "extent"         : extent,
-                "constrainRes"   : bool(int(attrs.get('constrainRes', "0")))})
-        elif name == 'group':
-            self.groupName    = attrs.get('name', None)
-            self.groupChecked = attrs.get('checked', None)
-            self.layers.append({
-                "type"    : 'group',
-                "name"    : self.groupName,
-                "checked" : int(self.groupChecked),
-                "opacity" : None,
-                "cmd"     : None,
-                "group"   : self.inTag['group'],
-                "display" : self.displayIndex,
-                "nviz"    : None})
+            self.displays.append( {
+                    "render"         : bool(int(display.get('render', "0"))),
+                    "mode"           : int(display.get('mode', 0)),
+                    "showCompExtent" : bool(int(display.get('showCompExtent', "0"))),
+                    "pos"            : pos,
+                    "size"           : size,
+                    "extent"         : extent,
+                    "constrainRes"   : bool(int(display.get('constrainRes', "0"))) } )
+            self.__processLayers(display)
-        elif name == 'layer':
-            self.layerType     = attrs.get('type', None)
-            self.layerName     = attrs.get('name', None)
-            self.layerChecked  = attrs.get('checked', None)
-            self.layerOpacity  = attrs.get('opacity', None)
-            self.layerSelected = False
-            self.layerNviz     = None
-            self.cmd = []
+    def __processLayers(self, node):
+        """!Process layers/groups of selected display
-        elif name == 'task':
-            name = attrs.get('name', None)
-            self.cmd.append(name)
+        @param node display tree node
+        for item in node.getchildren():
+            if item.tag == 'group':
+                # -> group
+                self.layers.append( {
+                        "type"    : 'group',
+                        "name"    : item.get('name', ''),
+                        "checked" : bool(int(item.get('checked', "0"))),
+                        "opacity" : None,
+                        "cmd"     : None,
+                        "group"   : False, #### self.inTag['group'], # ???
+                        "display" : self.displayIndex,
+                        "nviz"    : None})
+            elif item.tag == 'layer':
+                cmd, selected, nviz = self.__processLayer(item)
+                        "type"     : item.get('type', None),
+                        "name"     : item.get('name', None),
+                        "opacity"  : float(item.get('opacity', '1.0')),
+                        "cmd"      : cmd,
+                        "selected" : selected,
+                        "nviz"     : nviz } )
+    def __processLayer(self, layer):
+        """!Process layer item
-        elif name == 'parameter':
-            self.parameterName = attrs.get('name', None)
+        @param layer tree node
+        cmd = list()
+        # layer attributes (task)
+        node_task = layer.find('task')
+        cmd.append(node_task.get('name', "unknown"))
+        # flags
+        flags = ''
+        for p in node_task.findall('flag'):
+            flags += p.get('name', '')
+        cmd.append('-' + flags)
+        # parameters
+        for p in node_task.findall('parameter'):
+            cmd.append('%s=%s' % (p.get('name', ''),
+                                  self.__filterValue(self.__getNodeText(p, 'value'))))
+        if layer.find('selected') is not None:
+            selected = True
+        else:
+            selected = False
-        elif name in ('value', 'x', 'y', 'z', 'map'):
-            self.value = ''
+        # Nviz (3D settings)
+        node_nviz = layer.find('nviz')
+        if node_nviz is not None:
+            nviz = self.__processLayerNviz(node_nviz)
+        else:
+            nviz = None
+        return (cmd, selected, nviz)
-        elif name == 'flag':
-            self.cmd.append('-' + name)
+    def __processLayerNviz(self, node_nviz):
+        """!Process 3D layer settings
-        elif name == 'selected':
-            if self.inTag['layer']:
-                self.layerSelected = True;
-        elif name == 'layer_manager':
-            if posAttr:
-                posVal = map(int, posAttr.split(','))
-                try:
-                    self.layerManager['pos'] = (posVal[0], posVal[1])
-                    self.layerManager['size'] = (posVal[2], posVal[3])
-                except:
-                    pass
-            else:
-                pass
-        # Nviz section
-        elif name == 'nviz':
-            # init nviz layer properties
-            self.layerNviz = {}
-            if self.layerType == 'raster':
-                self.layerNviz['surface'] = {}
-                for sec in ('attribute', 'draw', 'mask', 'position'):
-                    self.layerNviz['surface'][sec] = {}
-            elif self.layerType == 'vector':
-                self.layerNviz['vector'] = {}
+        @param node_nviz nviz node
+        # init nviz layer properties
+        nviz = {}
+        node = node_nviz.find('surface')
+        if node: # -> raster
+            nviz['surface'] = {}
+            for sec in ('attribute', 'draw', 'mask', 'position'):
+                nviz['surface'][sec] = {}
+        else:
+            node = node_nviz.find('vector')
+            if node: # -> vector
+                nviz['vector'] = {}
                 for sec in ('lines', 'points'):
-                    self.layerNviz['vector'][sec] = {}
-        elif name == 'attribute':
-            if self.inTag['nviz'] and self.inTag['surface']:
-                tagName = str(name)
-                attrbName = str(attrs.get('name', ''))
-                self.layerNviz['surface'][tagName][attrbName] = {}
-                if attrs.get('map', '0') == '0':
-                    self.layerNviz['surface'][tagName][attrbName]['map'] = False
+                    nviz['vector'][sec] = {}
+        if nviz.has_key('surface'):
+            # attributes
+            for attrb in node.find_all('attributes'):
+                tagName = str(attrb.tag)
+                attrbName = attrb.get('name', '')
+                self.nviz['surface'][tagName][attrbName] = {}
+                if attrb.get('map', '0') == '0':
+                    self.nviz['surface'][tagName][attrbName]['map'] = False
                 else:
-                    self.layerNviz['surface'][tagName][attrbName]['map'] = True
+                    self.nviz['surface'][tagName][attrbName]['map'] = True
+                self.refAttribute = self.nviz['surface'][tagName][attrbName]
-                self.refAttribute = self.layerNviz['surface'][tagName][attrbName]
-        elif name == 'draw':
-                self.layerNviz['surface'][tagName]['all'] = False
-                self.layerNviz['surface'][tagName]['mode'] = {}
-                self.layerNviz['surface'][tagName]['mode']['value'] = -1 # to be calculated
-                self.layerNviz['surface'][tagName]['mode']['desc'] = {}
-                self.layerNviz['surface'][tagName]['mode']['desc']['shading'] = \
+            # draw
+            node_draw = node.find('draw')
+            if node_draw is not None:
+                tagName = str(node_draw.tag)
+                nviz['surface'][tagName]['all'] = False
+                nviz['surface'][tagName]['mode'] = {}
+                nviz['surface'][tagName]['mode']['value'] = -1 # to be calculated
+                nviz['surface'][tagName]['mode']['desc'] = {}
+                nviz['surface'][tagName]['mode']['desc']['shading'] = \
                     str(attrs.get('shading', ''))
-                self.layerNviz['surface'][tagName]['mode']['desc']['style'] = \
+                nviz['surface'][tagName]['mode']['desc']['style'] = \
                     str(attrs.get('style', ''))
-                self.layerNviz['surface'][tagName]['mode']['desc']['mode'] = \
+                nviz['surface'][tagName]['mode']['desc']['mode'] = \
                     str(attrs.get('mode', ''))
-        elif name == 'resolution':
-                self.resolutionType = str(attrs.get('type', ''))
-                if not self.layerNviz['surface']['draw'].has_key(str(name)):
-                    self.layerNviz['surface']['draw'][str(name)] = {}
-        elif name == 'position':
-            if self.inTag['nviz'] and inTag['surface']:
-                self.layerNviz['surface']['position'] = {}
+                for node_pos in node_draw.findall('resolution'):
+                    self.resolutionType = str(node_pos.get('type', ''))
+                    if not nviz['surface']['draw'].has_key('reaolution'):
+                        nviz['surface']['draw']['resolution'] = {}
+            # position
+            node_pos = node.find('position')
+            if node_pos is not None:
+                self.nviz['surface']['position'] = {}
-        elif name == 'mode':
-            if self.inTag['nviz']:
-                if self.inTag['vlines']:
-                    self.layerNviz['vector']['lines']['mode'] = {}
-                    self.layerNviz['vector']['lines']['mode']['type'] = str(attrs.get('type', ''))
-                    self.layerNviz['vector']['lines']['mode']['surface'] = ''
-                elif self.inTag['vpoints']:
-                    self.layerNviz['vector']['points']['mode'] = {}
-                    self.layerNviz['vector']['points']['mode']['type'] = str(attrs.get('type', ''))
-                    self.layerNviz['vector']['points']['mode']['surface'] = ''
-        elif name == 'vpoints':
-                marker = str(attrs.get('marker', ''))
+        elif nviz.has_key('vector'):
+            # vpoints
+            node_vpoints = node.find('vpoints')
+            if node_vpoints is not None:
+                marker = str(node_vpoints.get('marker', ''))
                 markerId = list(UserSettings.Get(group='nviz', key='vector',
                                                  subkey=['points', 'marker'], internal=True)).index(marker)
-                self.layerNviz['vector']['points']['marker'] = markerId
-        self.inTag[name] = True
-    def endElement(self, name):
-        if name == 'group':
-            self.groupName = self.groupChecked = None
-                    "type"     : self.layerType,
-                    "name"     : self.layerName,
-                    "checked"  : int(self.layerChecked),
-                    "opacity"  : 1.0,
-                    "cmd"      : None,
-                    "selected" : self.layerSelected,
-                    "nviz"     : self.layerNviz})
+                nviz['vector']['points']['marker'] = markerId
+                node_mode = node.find('mode')
+                if node_mode is not None:
+                    nviz['vector']['points']['mode'] = {}
+                    nviz['vector']['points']['mode']['type'] = str(node_mode.get('type', ''))
+                    nviz['vector']['points']['mode']['surface'] = ''
-            if self.layerOpacity:
-                self.layers[-1]["opacity"] = float(self.layerOpacity)
-            if self.cmd:
-                self.layers[-1]["cmd"] = self.cmd
-            self.layerType = self.layerName = self.Checked = \
-                self.Opacity = self.cmd = None
+            # vlines
+            node_vlines = node.find('vlines')
+            if node_vlines is not None:
+                    nviz['vector']['lines']['mode'] = {}
+                    nviz['vector']['lines']['mode']['type'] = str(node_mode.get('type', ''))
+                    nviz['vector']['lines']['mode']['surface'] = ''
-            self.cmd.append('%s=%s' % (self.parameterName,
-                                       self.__filterValue(self.value)))
-            self.parameterName = self.value = None
+#         elif name == 'attribute':
+#             if self.inTag['nviz'] and self.inTag['surface']:
+#                 try:
+#                     self.refAttribute['value'] = int(self.value)
+#                 except ValueError:
+#                     try:
+#                         self.refAttribute['value'] = float(self.value)
+#                         self.refAttribute['value'] = str(self.value)
-        # Nviz section
-                try:
-                    self.refAttribute['value'] = int(self.value)
-                except ValueError:
-                    try:
-                        self.refAttribute['value'] = float(self.value)
-                        self.refAttribute['value'] = str(self.value)
+#         elif name == 'resolution':
+#                 self.layerNviz['surface']['draw']['resolution'][self.resolutionType] = int(self.value)
+#                 del self.resolutionType
-                self.layerNviz['surface']['draw']['resolution'][self.resolutionType] = int(self.value)
-                del self.resolutionType
+#         elif name == 'wire_color':
+#                 self.layerNviz['surface']['draw']['wire-color'] = {}
+#                 self.layerNviz['surface']['draw']['wire-color']['value'] = str(self.value)
-        elif name == 'wire_color':
-                self.layerNviz['surface']['draw']['wire-color'] = {}
-                self.layerNviz['surface']['draw']['wire-color']['value'] = str(self.value)
+#         elif name == 'x':
+#                 self.layerNviz['surface']['position']['x'] = int(self.value)
-        elif name == 'x':
-                self.layerNviz['surface']['position']['x'] = int(self.value)
+#         elif name == 'y':
+#                 self.layerNviz['surface']['position']['y'] = int(self.value)
-        elif name == 'y':
-                self.layerNviz['surface']['position']['y'] = int(self.value)
-        elif name == 'z':
-                self.layerNviz['surface']['position']['z'] = int(self.value)
+#         elif name == 'z':
+#                 self.layerNviz['surface']['position']['z'] = int(self.value)
-        elif name == 'color':
-                    self.layerNviz['vector']['lines']['color'] = str(self.value)
-                    self.layerNviz['vector']['points']['color'] = str(self.value)
+#         elif name == 'color':
+#             if self.inTag['nviz']:
+#                 if self.inTag['vlines']:
+#                     self.layerNviz['vector']['lines']['color'] = str(self.value)
+#                 elif self.inTag['vpoints']:
+#                     self.layerNviz['vector']['points']['color'] = str(self.value)
-        elif name == 'width':
-                    self.layerNviz['vector']['lines']['width'] = int(self.value)
-                    self.layerNviz['vector']['points']['width'] = int(self.value)
+#         elif name == 'width':
+#                     self.layerNviz['vector']['lines']['width'] = int(self.value)
+#                     self.layerNviz['vector']['points']['width'] = int(self.value)
-        elif name == 'height':
-                    self.layerNviz['vector']['lines']['height'] = int(self.value)
-                    self.layerNviz['vector']['points']['height'] = int(self.value)
+#         elif name == 'height':
+#                     self.layerNviz['vector']['lines']['height'] = int(self.value)
+#                     self.layerNviz['vector']['points']['height'] = int(self.value)
-        elif name == 'size':
-            if self.inTag['nviz'] and self.inTag['vpoints']:
-                self.layerNviz['vector']['points']['size'] = int(self.value)
+#         elif name == 'size':
+#             if self.inTag['nviz'] and self.inTag['vpoints']:
+#                 self.layerNviz['vector']['points']['size'] = int(self.value)
-        elif name == 'map':
-                    self.layerNviz['vector']['lines']['mode']['surface'] = str(self.value)
-                    self.layerNviz['vector']['points']['mode']['surface'] = str(self.value)
+#         elif name == 'map':
+#                     self.layerNviz['vector']['lines']['mode']['surface'] = str(self.value)
+#                     self.layerNviz['vector']['points']['mode']['surface'] = str(self.value)
-        self.inTag[name] = False
+        return nviz
-    def characters(self, ch):
-        self.my_characters(ch)
-    def my_characters(self, ch):
-        if self.inTag['value'] or \
-                self.inTag['x'] or \
-                self.inTag['y'] or \
-                self.inTag['z'] or \
-                self.inTag['map']:
-            self.value += ch
 class WriteWorkspaceFile(object):
     """!Generic class for writing workspace file"""
     def __init__(self, lmgr, file):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/wxgui.py	2009-06-11 16:19:43 UTC (rev 37826)
@@ -30,10 +30,10 @@
 import platform
 ### XML
-import xml.sax
+try:
 ### i18N
 import gettext
@@ -591,150 +591,104 @@
     def LoadWorkspaceFile(self, filename):
         """!Load layer tree definition stored in GRASS Workspace XML file (gxw)
-        Return True on success
-        Return False on error"""
+        @todo Validate against DTD
+        @return True on success
+        @return False on error
         # dtd
         dtdFilename = os.path.join(globalvar.ETCWXDIR, "xml", "grass-gxw.dtd")
-        # validate xml agains dtd
-        #         dtd = xmldtd.load_dtd(dtdFilename)
-        #         parser = xmlproc.XMLProcessor()
-        #         parser.set_application(xmlval.ValidatingApp(dtd, parser))
-        #         parser.dtd = dtd
-        #         parser.ent = dtd
-        #         try:
-        #             # TODO: set_error_handler(self,err)
-        #             parser.parse_resource(filename)
-        #         except:
-        #             dlg = wx.MessageDialog(self, _("Unable to open workspace file <%s>. "
-        #                                            "It is not valid GRASS Workspace File.") % filename,
-        #                                    _("Error"), wx.OK | wx.ICON_ERROR)
-        #             dlg.ShowModal()
-        #             dlg.Destroy()
-        #             return False
-        # read file and fix patch to dtd
+        # parse workspace file
         try:
-            file = open(filename, "r")
+            gxwXml = workspace.ProcessWorkspaceFile(etree.parse(filename))
+        except Exception, err:
+            raise gcmd.GStdError(_("Reading workspace file <%s> failed.\n"
+                                   "Invalid file, unable to parse XML document."
+                                   "\n\n%s") % (filename, err),
+                                 parent = self)
+        busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
+                           parent=self)
+        wx.Yield()
-            fileStream = ''.join(file.readlines())
-            p = re.compile('(grass-gxw.dtd)')
-            p.search(fileStream)
-            if platform.system() == 'Windows':
-                # FIXME mixing '\' and '/' causes error in p.sub
-                dtdFilename = dtdFilename.replace("\\", "/")
-            fileStream = p.sub(dtdFilename, fileStream)
-            # sax
-            gxwXml = workspace.ProcessWorkspaceFile()
+        # load layer manager window properties
+        if UserSettings.Get(group='workspace', key='posManager', subkey='enabled') is False:
+            if gxwXml.layerManager['pos']:
+                self.SetPosition(gxwXml.layerManager['pos'])
+            if gxwXml.layerManager['size']:
+                self.SetSize(gxwXml.layerManager['size'])
+        # start map displays first (list of layers can be empty)
+        displayId = 0
+        mapdisplay = []
+        for display in gxwXml.displays:
+            mapdisplay.append(self.NewDisplay(show=False))
+            maptree = self.gm_cb.GetPage(displayId).maptree
-            try:
-                xml.sax.parseString(fileStream, gxwXml)
-            except xml.sax.SAXParseException, err:
-                raise gcmd.GStdError(_("Reading workspace file <%s> failed. "
-                                       "Invalid file, unable to parse XML document.") % filename + \
-                                         "\n\n%s" % err,
-                                     parent=self)
-            except ValueError, err:
-                                         "\n\n%s" % err,
-                                     parent=self)
-            busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
-                               parent=self)
-            wx.Yield()
-            # load layer manager window properties
-            if UserSettings.Get(group='workspace', key='posManager', subkey='enabled') is False:
-                if gxwXml.layerManager['pos']:
-                    self.SetPosition(gxwXml.layerManager['pos'])
-                if gxwXml.layerManager['size']:
-                    self.SetSize(gxwXml.layerManager['size'])
-            # start map displays first (list of layers can be empty)
-            displayId = 0
-            mapdisplay = []
-            for display in gxwXml.displays:
-                mapdisplay.append(self.NewDisplay(show=False))
-                maptree = self.gm_cb.GetPage(displayId).maptree
-                # set windows properties
-                mapdisplay[-1].SetProperties(render=display['render'],
-                                             mode=display['mode'],
-                                             showCompExtent=display['showCompExtent'],
-                                             constrainRes=display['constrainRes'])
-                # set position and size of map display
-                if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
-                    if display['pos']:
-                        mapdisplay[-1].SetPosition(display['pos'])
-                    if display['size']:
-                        mapdisplay[-1].SetSize(display['size'])
-                # set extent if defined
-                if display['extent']:
-                    w, s, e, n = display['extent']
-                    maptree.Map.region = maptree.Map.GetRegion(w=w, s=s, e=e, n=n)
+            # set windows properties
+            mapdisplay[-1].SetProperties(render=display['render'],
+                                         mode=display['mode'],
+                                         showCompExtent=display['showCompExtent'],
+                                         constrainRes=display['constrainRes'])
+            # set position and size of map display
+            if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
+                if display['pos']:
+                    mapdisplay[-1].SetPosition(display['pos'])
+                if display['size']:
+                    mapdisplay[-1].SetSize(display['size'])
-                mapdisplay[-1].Show()
-                displayId += 1
+            # set extent if defined
+            if display['extent']:
+                w, s, e, n = display['extent']
+                maptree.Map.region = maptree.Map.GetRegion(w=w, s=s, e=e, n=n)
+            mapdisplay[-1].Show()
+            displayId += 1
-            maptree = None
-            selected = [] # list of selected layers
-            # load list of map layers
-            for layer in gxwXml.layers:
-                display = layer['display']
-                maptree = self.gm_cb.GetPage(display).maptree
-                newItem = maptree.AddLayer(ltype=layer['type'],
-                                           lname=layer['name'],
-                                           lchecked=layer['checked'],
-                                           lopacity=layer['opacity'],
-                                           lcmd=layer['cmd'],
-                                           lgroup=layer['group'],
-                                           lnviz=layer['nviz'])
+        maptree = None
+        selected = [] # list of selected layers
+        # load list of map layers
+        for layer in gxwXml.layers:
+            display = layer['display']
+            maptree = self.gm_cb.GetPage(display).maptree
+            newItem = maptree.AddLayer(ltype=layer['type'],
+                                       lname=layer['name'],
+                                       lchecked=layer['checked'],
+                                       lopacity=layer['opacity'],
+                                       lcmd=layer['cmd'],
+                                       lgroup=layer['group'],
+                                       lnviz=layer['nviz'])
+            if layer.has_key('selected'):
+                if layer['selected']:
+                    selected.append((maptree, newItem))
+                else:
+                    maptree.SelectItem(newItem, select=False)
+        for maptree, layer in selected:
+            if not maptree.IsSelected(layer):
+                maptree.SelectItem(layer, select=True)
+                maptree.layer_selected = layer
-                # tag 'selected' added 2008/04
-                if layer.has_key('selected'):
-                    if layer['selected']:
-                        selected.append((maptree, newItem))
-                    else:
-                        maptree.SelectItem(newItem, select=False)
-            for maptree, layer in selected:
-                if not maptree.IsSelected(layer):
-                    maptree.SelectItem(layer, select=True)
-                    maptree.layer_selected = layer
+        busy.Destroy()
+        if maptree:
+            # reverse list of map layers
+            maptree.Map.ReverseListOfLayers()
-            busy.Destroy()
-            if maptree:
-                # reverse list of map layers
-                maptree.Map.ReverseListOfLayers()
+        for mdisp in mapdisplay:
+            mdisp.MapWindow2D.UpdateMap()
-            for mdisp in mapdisplay:
-                mdisp.MapWindow2D.UpdateMap()
-            file.close()
-        except IOError, err:
-            wx.MessageBox(parent=self,
-                          message="%s <%s>. %s%s" % (_("Unable to read workspace file"),
-                                                     filename, os.linesep, err),
-                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-            return False
-        except gcmd.GStdError, e:
-            print e
-            return False
         return True
     def OnWorkspaceLoad(self, event=None):
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2009-06-11 15:57:00 UTC (rev 37825)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2009-06-11 16:19:43 UTC (rev 37826)
@@ -34,8 +34,10 @@
 <!ATTLIST display  render	   (0 | 1) #IMPLIED>
 <!ATTLIST display  mode            (0 | 1 | 2 | 3 | 4 | 5 | 6) #IMPLIED>
 <!ATTLIST display  showCompExtent  (0 | 1) #IMPLIED>
+<!ATTLIST display  constrainRes    (0 | 1) #IMPLIED>
 <!-- window dimenstion (x, y (ur), width, heigth -->
 <!ATTLIST display  dim             CDATA   #IMPLIED>
+<!ATTLIST display  extent          CDATA   #IMPLIED>
 <!--    group of map layers
