[GRASS-SVN] r37837 - grass/trunk/ps/ps.map
Fri Jun 12 05:43:42 EDT 2009
Author: hamish
Date: 2009-06-12 05:43:42 -0400 (Fri, 12 Jun 2009)
New Revision: 37837
   grass/trunk/ps/ps.map/ps.map.html
   grass/trunk/ps/ps.map/ps_header.c
take title from raster map (#641), add simple example (merge from devbr6)
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html	2009-06-12 09:38:03 UTC (rev 37836)
+++ grass/trunk/ps/ps.map/ps.map.html	2009-06-12 09:43:42 UTC (rev 37837)
@@ -881,7 +881,9 @@
 <EM>rgb</EM> option, count as a raster map layer for the
 purposes of the preceding paragraph.
 <P>
+The PostScript file's internal title will be set to the raster map's
+title, which in turn may be set with the <em>r.suppport</em> module.
+<P>
 This example would paint a map of the raster map layer <EM>soils</EM>.
 <PRE>
@@ -1566,14 +1568,36 @@
 <P>
+<H2>EXAMPLES</H2>
-<H2>EXAMPLE ps.map INPUT FILE</H2>
-The following is an example of a <EM>ps.map</EM> script file. The file has been
-named <EM>spear.soils</EM>:
+The following are examples of <EM>ps.map</EM> script files.
+<P>
+<h4>Simple example</h4>
+The file has been named <EM>spear.basic</EM>:
 <PRE>
 # this ps.map example draws a map of Spearfish, SD
+<B>raster</B> elevation.dem
+<B>header</B>
+  <B>end</B>
+<B>vlines</B> roads
+  <B>color</B> brown
+  <B>end</B>
+<B>end</B>
+</PRE>
+Generate map as Postsript file:
+<PRE>
+ ps.map input=spear.basic output=spear_basic.ps
+</PRE>
+<h4>More complicated example</h4>
+The file has been named <EM>spear.soils</EM>:
+<PRE>
+# this ps.map example draws a map of Spearfish, SD
 <B>raster</B> soils
 <B>outline</B>
    <B>color</B> black
Modified: grass/trunk/ps/ps.map/ps_header.c
--- grass/trunk/ps/ps.map/ps_header.c	2009-06-12 09:38:03 UTC (rev 37836)
+++ grass/trunk/ps/ps.map/ps_header.c	2009-06-12 09:43:42 UTC (rev 37837)
@@ -5,6 +5,7 @@
 #include <stdio.h>
 #include <unistd.h>
+#include <grass/gis.h>
 #include "ps_info.h"
 static long bb_offset;
@@ -13,6 +14,12 @@
 int write_PS_header(void)
+    struct Categories cats;
+    int cats_ok;
+    if (PS.do_raster)
+	cats_ok = G_read_cats(PS.cell_name, PS.cell_mapset, &cats) >= 0;
     /* write PostScript header */
     /*fprintf(PS.fp, "%%!PS-Adobe-2.0 EPSF-1.2\n"); */
     if (eps_output)
@@ -24,9 +31,10 @@
     fprintf(PS.fp, "                                       ");
     fprintf(PS.fp, "                                       \n");
     fprintf(PS.fp, "%%%%Title: ");
-    if (PS.do_raster)
-	fprintf(PS.fp, "Map layer = %s  ", PS.cell_name);
-    fprintf(PS.fp, "Mapset = %s\n", PS.cell_mapset);
+    if (PS.do_raster && cats_ok)
+	fprintf(PS.fp, "%s\n", cats.title);
+    else
+	fprintf(PS.fp, "Mapset = %s\n", PS.cell_mapset);
     fprintf(PS.fp, "%%%%EndComments\n");
     return 0;
