[GRASS-SVN] r37915 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Tue Jun 16 16:16:52 EDT 2009
Author: martinl
Date: 2009-06-16 16:16:52 -0400 (Tue, 16 Jun 2009)
New Revision: 37915
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxgui_utils.py
No warning when querying grid layer (trac #650)
  (merge from trunk, r37913)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2009-06-16 20:11:16 UTC (rev 37914)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2009-06-16 20:16:52 UTC (rev 37915)
@@ -3477,31 +3477,39 @@
         self.MapWindow.SetCursor(self.cursors["cross"])
     def QueryMap(self, x, y):
-        Query map layer features
+        """!Query map layer features
-        Currently only raster and vector map layers are supported
+        Currently only raster and vector map layers are supported.
+        @param x,y coordinates
         #set query snap distance for v.what at mapunit equivalent of 10 pixels
         qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) / self.Map.width)
         east, north = self.MapWindow.Pixel2Cell((x, y))
-        if not self.tree.layer_selected:
+        num = 0
+        for layer in self.tree.GetSelections():
+            type = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
+            if type in ('raster', 'rgb', 'his',
+                        'vector', 'thememap', 'themechart'):
+                num += 1
+        if num < 1:
             dlg = wx.MessageDialog(parent=self,
-                                   message=_('No map layer selected for querying.'),
-                                   caption=_('Message'),
-                                   style=wx.OK | wx.ICON_INFORMATION)
+                                   message=_('No raster or vector map layer selected for querying.'),
+                                   caption=_('No map layer selected'),
+                                   style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
             dlg.ShowModal()
             dlg.Destroy()
             return
         mapname = None
         raststr = ''
         vectstr = ''
         rcmd = []
         vcmd = []
-            type = self.tree.GetPyData(layer)[0]['maplayer'].type
             dcmd = self.tree.GetPyData(layer)[0]['cmd']
             name = utils.GetLayerNameFromCmd(dcmd)
             if name == '':
@@ -3651,6 +3659,15 @@
                               kind=wx.ITEM_CHECK)
         toolsmenu.AppendItem(display)
         self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
+        numLayers = 0
+                numLayers += 1
+        if numLayers < 1:
+            display.Enable(False)
         if action == "displayAttrb":
             display.Check(True)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxgui_utils.py	2009-06-16 20:11:16 UTC (rev 37914)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxgui_utils.py	2009-06-16 20:16:52 UTC (rev 37915)
@@ -263,16 +263,17 @@
         # map layer items
         if ltype != "group" and \
-                ltype != "command": # properties
+                ltype != "command":
             self.popupMenu.AppendSeparator()
             self.popupMenu.Append(self.popupID8, text=_("Change opacity level"))
             self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID8)
             self.popupMenu.Append(self.popupID3, text=_("Properties"))
             self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
-            self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map(s)"))
-            self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
-            self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map(s)"))
-            self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
+            if ltype in ('raster', 'vector'):
+                self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map(s)"))
+                self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
+                self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map(s)"))
+                self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
             if numSelected > 1:
                 self.popupMenu.Enable(self.popupID8, False)
                 self.popupMenu.Enable(self.popupID3, False)
