[GRASS-SVN] r37921 - grass-addons/vector/v.krige
Wed Jun 17 08:34:07 EDT 2009
Author: aghisla
Date: 2009-06-17 08:34:07 -0400 (Wed, 17 Jun 2009)
New Revision: 37921
   grass-addons/vector/v.krige/v.krige.html
started populationg doc page
Modified: grass-addons/vector/v.krige/v.krige.html
--- grass-addons/vector/v.krige/v.krige.html	2009-06-17 10:27:08 UTC (rev 37920)
+++ grass-addons/vector/v.krige/v.krige.html	2009-06-17 12:34:07 UTC (rev 37921)
@@ -1,12 +1,55 @@
+<h2>NAME</h2>
+<i><b>v.krige</b></i>  - Performs kriging via R software.
+<h2>KEYWORDS</h2>
+TODO
+<h2>SYNOPSIS</h2>
+<b>v.krige</b><br>
+<b>v.krige help</b><br>
+<b>v.krige</b> <b>map</b>=<em>string</em>  [<b>layer</b>=<em>integer</em>]  <b>column</b>=<em>string</em>  [<b>value</b>=<em>string</em>]   [<b>qcolumn</b>=<em>string</em>]   [<b>where</b>=<em>string</em>]   [--<b>verbose</b>]  [--<b>quiet</b>]
 <h2>DESCRIPTION</h2>
+<i>v.krige</i> allows to perform kriging operations in GRASS environment,
+using R software functions in background.
+<h2>NOTES</h2>
+<i>v.krige</i> is just a front-end to R. The options and parameters are
+the same offered by packages <i>automap</i>, <i>gstat</i> and
+<i>geoR</i>.
+R users will therefore find in this GRASS module the same functionality of
+their preferred package, as far as kriging results are influenced by
+implementation.
+<h3>Dependencies</h3>
+<dl>
+<dt><b>GRASS with wxPython support</b></dt>
+<dd></dd>
+<dt><b>R software >= 2.x</b></dt>
+<dd></dd>
+<dt><b>rpy2</b></dt>
+<dd>Python binding to R. Note! rpy is not supported.</dd>
+<dt><b>R packages automap, gstat, geoR. </b></dt>
+<dd>Install at least one.</dd>
+</dl>
+<h2>EXAMPLES</h2>
 TODO
 <h2>SEE ALSO</h2>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
 Anne Ghisla, Google Summer of Code 2009
 <p>
-<i>Last changed: $Date$</i>
+<i>Last changed: $Date$</i>
\ No newline at end of file
