[GRASS-SVN] r37971 - in grass/trunk/gui/wxpython: gui_modules xml
Fri Jun 19 14:48:38 EDT 2009
Author: martinl
Date: 2009-06-19 14:48:38 -0400 (Fri, 19 Jun 2009)
New Revision: 37971
Added:
   grass/trunk/gui/wxpython/gui_modules/units.py
   grass/trunk/gui/wxpython/gui_modules/__init__.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/prompt.py
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxGUI/vdigit: units for geometry attributes
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py	2009-06-19 18:44:24 UTC (rev 37970)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py	2009-06-19 18:48:38 UTC (rev 37971)
@@ -28,6 +28,7 @@
     "rules.py",
     "sqlbuilder.py",
     "toolbars.py",
+    "units.py",
     "utils.py",
     "vdigit.py",
     "workspace.py",
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-19 18:44:24 UTC (rev 37970)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-19 18:48:38 UTC (rev 37971)
@@ -32,6 +32,7 @@
 import globalvar
 from debug import Debug
 from preferences import globalSettings as UserSettings
+from units import ConvertValue as UnitsConvertValue
 from vdigit import GV_LINES as VDigit_Lines_Type
 from vdigit import VDigitCategoryDialog
 from vdigit import VDigitZBulkDialog
@@ -1180,14 +1181,18 @@
             val = -1
             if attrb == 'length':
                 val = digit.GetLineLength(fid)
+                type = attrb
             elif attrb == 'area':
                 val = digit.GetAreaSize(fid)
+                type = attrb
             elif attrb == 'perimeter':
                 val = digit.GetAreaPerimeter(fid)
+                type = 'length'
             if val > 0:
                 layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
-                column =  vdigit['geomAttr'][attrb]
+                column = vdigit['geomAttr'][attrb]['column']
+                val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
                 dialog.SetColumnValue(layer, column, val)
                 dialog.OnReset()
Property changes on: grass/trunk/gui/wxpython/gui_modules/prompt.py
___________________________________________________________________
   + text/x-python
   + Author Date Id
   + native
Added: grass/trunk/gui/wxpython/gui_modules/units.py
--- grass/trunk/gui/wxpython/gui_modules/units.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/units.py	2009-06-19 18:48:38 UTC (rev 37971)
@@ -0,0 +1,118 @@
+ at package units
+ at brief Units management
+Probably will be replaced by Python SWIG fns in the near future(?)
+Usage:
+ at code
+from units import Units
+ at endcode
+Classes:
+ - BaseUnits
+(C) 2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+class BaseUnits:
+    def __init__(self):
+        self._units = dict()
+        self._units['length'] = { 0 : { 'key' : 'mu', 'label' : _('map units') },
+                             1 : { 'key' : 'me', 'label' : _('meters') },
+                             2 : { 'key' : 'km', 'label' : _('kilometers') },
+                             3 : { 'key' : 'mi', 'label' : _('miles') },
+                             4 : { 'key' : 'ft', 'label' : _('feet') } }
+        self._units['area']   = { 0 : { 'key' : 'mu', 'label' : _('sq map units') },
+                             1 : { 'key' : 'me', 'label' : _('sq meters') },
+                             2 : { 'key' : 'km', 'label' : _('sq kilometers') },
+                             3 : { 'key' : 'ar', 'label' : _('acres') },
+                             4 : { 'key' : 'ht', 'label' : _('hectares') } }
+    def GetUnitsList(self, type):
+        """!Get list of units (their labels)
+        @param type units type ('length' or 'area')
+        @return list of units labels
+        result = list()
+        try:
+            keys = self._units[type].keys()
+            keys.sort()
+            for idx in keys:
+                result.append(self._units[type][idx]['label'])
+        except KeyError:
+            pass
+        return result
+    def GetUnitsKey(self, type, index):
+        """!Get units key based on index
+        @param index units index
+        return self._units[type][index]['key']
+    def GetUnitsIndex(self, type, key):
+        """!Get units index based on key
+        @param key units key, e.g. 'me' for meters
+        @return index
+        for k, u in self._units[type].iteritems():
+            if u['key'] == key:
+                return k
+        return 0
+Units = BaseUnits()
+def ConvertValue(value, type, units):
+    """!Convert value from map units to given units
+    Inspired by vector/v.to.db/units.c
+    @param value value to be converted
+    @param type units type ('length', 'area')
+    @param unit  destination units
+    # get map units
+    # TODO
+    f = 1
+    if type == 'length':
+        if units == 'me':
+            f = 1.0
+        elif units == 'km':
+            f = 1.0e-3
+        elif units == 'mi':
+            f = 6.21371192237334e-4
+        elif units == 'ft':
+            f = 3.28083989501312
+    else: # -> area
+        if units == 'me':
+            f = 1.0
+            f = 1.0e-6
+            f = 3.86102158542446e-7
+            f = 10.7639104167097
+        elif units == 'ar':
+            f = 2.47105381467165e-4
+        elif units == 'ht':
+            f = 1.0e-4
+    return f * value
Property changes on: grass/trunk/gui/wxpython/gui_modules/units.py
   + text/x-python
   + Author Date Id
   + native
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-06-19 18:44:24 UTC (rev 37970)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-06-19 18:48:38 UTC (rev 37971)
@@ -46,6 +46,7 @@
 from debug import Debug as Debug
 import gselect
 import globalvar
 try:
     digitPath = os.path.join(globalvar.ETCWXDIR, "vdigit")
@@ -1542,19 +1543,28 @@
                                  layer = layer, excludeKey = True,
                                  type = ['integer', 'double precision'])
             # units
-            ### TODO: more units
-            units = wx.Choice(parent = panel, id = wx.ID_ANY,
-                              choices = [_("map units")])
+            if attrb == 'area':
+                choices = Units.GetUnitsList('area')
+            else:
+                choices = Units.GetUnitsList('length')
+            win_units = wx.Choice(parent = panel, id = wx.ID_ANY,
+                                  choices = choices, size=(120, -1))
             # default values
             check.SetValue(False)
             if item and tree.GetPyData(item)[0]['vdigit'] and \
                     tree.GetPyData(item)[0]['vdigit'].has_key('geomAttr') and \
                     tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(attrb):
                 check.SetValue(True)
-                column.SetStringSelection(tree.GetPyData(item)[0]['vdigit']['geomAttr'][attrb])
+                column.SetStringSelection(tree.GetPyData(item)[0]['vdigit']['geomAttr'][attrb]['column'])
+                    type = 'area'
+                else:
+                    type = 'length'
+                unitsIdx = Units.GetUnitsIndex(type,
+                                                tree.GetPyData(item)[0]['vdigit']['geomAttr'][attrb]['units'])
+                win_units.SetSelection(unitsIdx)
             if not vectorName:
                 check.Enable(False)
                 column.Enable(False)
@@ -1564,14 +1574,14 @@
             self.geomAttrb[attrb]['check']  = check.GetId()
             self.geomAttrb[attrb]['column'] = column.GetId()
-            self.geomAttrb[attrb]['units']  = units.GetId()
+            self.geomAttrb[attrb]['units']  = win_units.GetId()
             gridSizer.Add(item = check,
                           flag = wx.ALIGN_CENTER_VERTICAL,
                           pos = (row, 0))
             gridSizer.Add(item = column,
                           pos = (row, 1))
-            gridSizer.Add(item = units,
+            gridSizer.Add(item = win_units,
                           pos = (row, 2))
             row += 1
@@ -1810,13 +1820,21 @@
         for key, val in self.geomAttrb.iteritems():
             checked = self.FindWindowById(val['check']).IsChecked()
             column  = self.FindWindowById(val['column']).GetValue()
-            if not tree.GetPyData(item)[0]['vdigit']:
+            unitsIdx = self.FindWindowById(val['units']).GetSelection()
+            if item and not tree.GetPyData(item)[0]['vdigit']:
                 tree.GetPyData(item)[0]['vdigit'] = { 'geomAttr' : dict() }
             if checked: # enable
-                tree.GetPyData(item)[0]['vdigit']['geomAttr'][key] = column
+                if key == 'area':
+                    type = key
+                else:
+                    type = 'length'
+                unitsKey = Units.GetUnitsKey(type, unitsIdx)
+                tree.GetPyData(item)[0]['vdigit']['geomAttr'][key] = { 'column' : column,
+        'units' : unitsKey }
             else:
-                if tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(key):
+                if item and tree.GetPyData(item)[0]['vdigit'] and \
+                        tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(key):
                     del tree.GetPyData(item)[0]['vdigit']['geomAttr'][key]
         # snapping threshold
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2009-06-19 18:44:24 UTC (rev 37970)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2009-06-19 18:48:38 UTC (rev 37971)
@@ -240,7 +240,11 @@
         for node in node_vdigit.findall('geometryAttribute'):
             if not vdigit.has_key('geomAttr'):
                 vdigit['geomAttr'] = dict()
-            vdigit['geomAttr'][node.get('type')] = node.get('column')
+            type = node.get('type')
+            vdigit['geomAttr'][type] = dict()
+            vdigit['geomAttr'][type]['column'] = node.get('column') # required
+            # default map units
+            vdigit['geomAttr'][type]['units'] = node.get('units', 'mu')
         return vdigit
@@ -771,9 +775,12 @@
                     self.file.write('%s<vdigit>\n' % (' ' * self.indent))
                     if vdigit.has_key('geomAttr'):
                         self.indent += 4
-                        for type, column in vdigit['geomAttr'].iteritems():
-                            self.file.write('%s<geometryAttribute type="%s" column="%s" />\n' % \
-                                                (' ' * self.indent, type, column))
+                        for type, val in vdigit['geomAttr'].iteritems():
+                            units = ''
+                            if val['units'] != 'mu':
+                                units = ' units="%s"' % val['units']
+                            self.file.write('%s<geometryAttribute type="%s" column="%s"%s />\n' % \
+                                                (' ' * self.indent, type, val['column'], units))
                         self.indent -= 4
                     self.file.write('%s</vdigit>\n' % (' ' * self.indent))
                 # nviz
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2009-06-19 18:44:24 UTC (rev 37970)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2009-06-19 18:48:38 UTC (rev 37971)
@@ -88,6 +88,7 @@
 <!ELEMENT geometryAttribute EMPTY>
 <!ATTLIST parameter	type	(length | area | perimeter) #REQUIRED>
 <!ATTLIST parameter	column	CDATA                       #REQUIRED>
+<!ATTLIST parameter	units	CDATA                       #IMPLIED>
 <!-- *********************** Nviz *********************** -->
