[GRASS-SVN] r38020 - in grass/trunk: display/d.graph display/d.grid display/d.histogram display/d.labels display/d.path display/d.thematic.area display/d.title display/d.vect display/d.vect.chart general/g.mremove general/g.region general/manage/lister imagery/i.cca imagery/i.cluster imagery/i.gensig imagery/i.gensigset imagery/i.his.rgb imagery/i.maxlik imagery/i.rectify imagery/i.rgb.his imagery/i.smap ps/ps.map raster/r.buffer raster/r.carve raster/r.coin raster/r.colors raster/r.cost raster/r.cross raster/r.describe raster/r.distance raster/r.flow raster/r.in.gridatb raster/r.in.poly raster/r.in.xyz raster/r.info raster/r.kappa raster/r.le/r.le.patch raster/r.le/r.le.pixel raster/r.le/r.le.setup raster/r.le/r.le.trace raster/r.li/r.li.cwed raster/r.li/r.li.daemon raster/r.los raster/r.mapcalc raster/r.mfilter raster/r.mode raster/r.neighbors raster/r.out.gridatb raster/r.out.mpeg raster/r.out.vrml raster/r.out.vtk raster/r.param.scale raster/r.profile raster/r.proj raster/r.quant raster/r.random raster/r.random.cells raster/r.random.surface raster/r.reclass raster/r.recode raster/r.report raster/r.rescale raster/r.ros raster/r.spread raster/r.spreadpath raster/r.statistics raster/r.stats raster/r.sun2 raster/r.sunmask raster/r.support.stats raster/r.surf.contour raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw raster/r.surf.random raster/r.terraflow raster/r.texture raster/r.thin raster/r.to.vect raster/r.topidx raster/r.topmodel raster/r.univar raster/r.walk raster/r.water.outlet raster/r.watershed/ram raster/r.watershed/seg raster/r.watershed/shed raster3d/r3.gwflow raster3d/r3.mkdspf raster3d/r3.out.vtk vector/lidar/lidarlib vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection vector/lidar/v.lidar.growing vector/lidar/v.outlier vector/lidar/v.surf.bspline vector/v.convert vector/v.kernel vector/v.surf.idw vector/v.to.rast vector/v.vol.rst
Mon Jun 22 04:25:15 EDT 2009
Author: glynn
Date: 2009-06-22 04:25:13 -0400 (Mon, 22 Jun 2009)
New Revision: 38020
   grass/trunk/display/d.graph/graphics.c
   grass/trunk/display/d.grid/main.c
   grass/trunk/display/d.grid/plot.c
   grass/trunk/display/d.grid/plotborder.c
   grass/trunk/display/d.histogram/draw_slice.c
   grass/trunk/display/d.labels/do_labels.c
   grass/trunk/display/d.labels/main.c
   grass/trunk/display/d.path/select.c
   grass/trunk/display/d.thematic.area/area.c
   grass/trunk/display/d.title/fancy.c
   grass/trunk/display/d.title/normal.c
   grass/trunk/display/d.vect.chart/bar.c
   grass/trunk/display/d.vect.chart/pie.c
   grass/trunk/display/d.vect.chart/plot.c
   grass/trunk/display/d.vect/attr.c
   grass/trunk/display/d.vect/dir.c
   grass/trunk/display/d.vect/label.c
   grass/trunk/display/d.vect/topo.c
   grass/trunk/display/d.vect/utils.c
   grass/trunk/display/d.vect/zcoor.c
   grass/trunk/general/g.mremove/wc2regex.c
   grass/trunk/general/g.region/printwindow.c
   grass/trunk/general/manage/lister/vector.c
   grass/trunk/imagery/i.cca/matrix.c
   grass/trunk/imagery/i.cca/stats.c
   grass/trunk/imagery/i.cluster/checkpt.c
   grass/trunk/imagery/i.cluster/print1.c
   grass/trunk/imagery/i.cluster/print2.c
   grass/trunk/imagery/i.cluster/print3.c
   grass/trunk/imagery/i.cluster/print4.c
   grass/trunk/imagery/i.cluster/print5.c
   grass/trunk/imagery/i.cluster/print6.c
   grass/trunk/imagery/i.cluster/timer.c
   grass/trunk/imagery/i.gensig/alloc.c
   grass/trunk/imagery/i.gensig/can_invert.c
   grass/trunk/imagery/i.gensig/eigen.c
   grass/trunk/imagery/i.gensig/parse.c
   grass/trunk/imagery/i.gensigset/invert.c
   grass/trunk/imagery/i.gensigset/main.c
   grass/trunk/imagery/i.gensigset/parse.c
   grass/trunk/imagery/i.his.rgb/his2rgb.c
   grass/trunk/imagery/i.maxlik/invert.c
   grass/trunk/imagery/i.rectify/crs.c
   grass/trunk/imagery/i.rgb.his/rgb2his.c
   grass/trunk/imagery/i.smap/decimate.c
   grass/trunk/imagery/i.smap/interp.c
   grass/trunk/imagery/i.smap/invert.c
   grass/trunk/imagery/i.smap/multialloc.c
   grass/trunk/imagery/i.smap/parse.c
   grass/trunk/ps/ps.map/catval.c
   grass/trunk/ps/ps.map/distance.c
   grass/trunk/ps/ps.map/do_geogrid.c
   grass/trunk/ps/ps.map/do_masking.c
   grass/trunk/ps/ps.map/do_plt.c
   grass/trunk/ps/ps.map/do_psfiles.c
   grass/trunk/ps/ps.map/do_vectors.c
   grass/trunk/ps/ps.map/error.c
   grass/trunk/ps/ps.map/get_font.c
   grass/trunk/ps/ps.map/input.c
   grass/trunk/ps/ps.map/makeprocs.c
   grass/trunk/ps/ps.map/map_setup.c
   grass/trunk/ps/ps.map/parse_list.c
   grass/trunk/ps/ps.map/ps_info.h
   grass/trunk/ps/ps.map/r_labels.c
   grass/trunk/ps/ps.map/read_cfg.c
   grass/trunk/ps/ps.map/scale.c
   grass/trunk/ps/ps.map/scan_gis.c
   grass/trunk/ps/ps.map/session.c
   grass/trunk/ps/ps.map/vect.c
   grass/trunk/ps/ps.map/vector.c
   grass/trunk/raster/r.buffer/distance.h
   grass/trunk/raster/r.buffer/find_dist.c
   grass/trunk/raster/r.buffer/init.c
   grass/trunk/raster/r.carve/enforce.h
   grass/trunk/raster/r.carve/vect.c
   grass/trunk/raster/r.coin/coin.h
   grass/trunk/raster/r.colors/local_proto.h
   grass/trunk/raster/r.cost/btree.c
   grass/trunk/raster/r.cost/memory.c
   grass/trunk/raster/r.cross/glob.h
   grass/trunk/raster/r.describe/main.c
   grass/trunk/raster/r.describe/tree.c
   grass/trunk/raster/r.distance/defs.h
   grass/trunk/raster/r.distance/main.c
   grass/trunk/raster/r.distance/parse.c
   grass/trunk/raster/r.flow/aspect.c
   grass/trunk/raster/r.flow/aspect.h
   grass/trunk/raster/r.flow/io.h
   grass/trunk/raster/r.flow/mem.h
   grass/trunk/raster/r.flow/r.flow.h
   grass/trunk/raster/r.in.gridatb/local_proto.h
   grass/trunk/raster/r.in.gridatb/main.c
   grass/trunk/raster/r.in.poly/getformat.c
   grass/trunk/raster/r.in.poly/main.c
   grass/trunk/raster/r.in.xyz/local_proto.h
   grass/trunk/raster/r.info/reclas_txt.c
   grass/trunk/raster/r.kappa/calc_kappa.c
   grass/trunk/raster/r.kappa/kappa.h
   grass/trunk/raster/r.kappa/prt_mat.c
   grass/trunk/raster/r.kappa/stats.c
   grass/trunk/raster/r.le/r.le.patch/patch.h
   grass/trunk/raster/r.le/r.le.pixel/pixel.h
   grass/trunk/raster/r.le/r.le.setup/setup.h
   grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
   grass/trunk/raster/r.li/r.li.cwed/utility.c
   grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
   grass/trunk/raster/r.li/r.li.daemon/avl.c
   grass/trunk/raster/r.li/r.li.daemon/avlID.c
   grass/trunk/raster/r.li/r.li.daemon/daemon.h
   grass/trunk/raster/r.li/r.li.daemon/ipc.c
   grass/trunk/raster/r.li/r.li.daemon/list.c
   grass/trunk/raster/r.los/delete.c
   grass/trunk/raster/r.los/make_list.c
   grass/trunk/raster/r.los/make_point.c
   grass/trunk/raster/r.los/mark_pts.c
   grass/trunk/raster/r.los/radians.h
   grass/trunk/raster/r.mapcalc/column_shift.c
   grass/trunk/raster/r.mapcalc/expression.c
   grass/trunk/raster/r.mapcalc/mapcalc.h
   grass/trunk/raster/r.mapcalc/xabs.c
   grass/trunk/raster/r.mapcalc/xacos.c
   grass/trunk/raster/r.mapcalc/xadd.c
   grass/trunk/raster/r.mapcalc/xand.c
   grass/trunk/raster/r.mapcalc/xand2.c
   grass/trunk/raster/r.mapcalc/xasin.c
   grass/trunk/raster/r.mapcalc/xatan.c
   grass/trunk/raster/r.mapcalc/xbitand.c
   grass/trunk/raster/r.mapcalc/xbitnot.c
   grass/trunk/raster/r.mapcalc/xbitor.c
   grass/trunk/raster/r.mapcalc/xbitxor.c
   grass/trunk/raster/r.mapcalc/xcoor.c
   grass/trunk/raster/r.mapcalc/xcoor3.c
   grass/trunk/raster/r.mapcalc/xcos.c
   grass/trunk/raster/r.mapcalc/xdiv.c
   grass/trunk/raster/r.mapcalc/xdouble.c
   grass/trunk/raster/r.mapcalc/xeq.c
   grass/trunk/raster/r.mapcalc/xeval.c
   grass/trunk/raster/r.mapcalc/xexp.c
   grass/trunk/raster/r.mapcalc/xfloat.c
   grass/trunk/raster/r.mapcalc/xge.c
   grass/trunk/raster/r.mapcalc/xgraph.c
   grass/trunk/raster/r.mapcalc/xgt.c
   grass/trunk/raster/r.mapcalc/xif.c
   grass/trunk/raster/r.mapcalc/xint.c
   grass/trunk/raster/r.mapcalc/xisnull.c
   grass/trunk/raster/r.mapcalc/xle.c
   grass/trunk/raster/r.mapcalc/xlog.c
   grass/trunk/raster/r.mapcalc/xlt.c
   grass/trunk/raster/r.mapcalc/xmax.c
   grass/trunk/raster/r.mapcalc/xmin.c
   grass/trunk/raster/r.mapcalc/xmod.c
   grass/trunk/raster/r.mapcalc/xmode.c
   grass/trunk/raster/r.mapcalc/xmul.c
   grass/trunk/raster/r.mapcalc/xne.c
   grass/trunk/raster/r.mapcalc/xneg.c
   grass/trunk/raster/r.mapcalc/xnot.c
   grass/trunk/raster/r.mapcalc/xnull.c
   grass/trunk/raster/r.mapcalc/xor.c
   grass/trunk/raster/r.mapcalc/xor2.c
   grass/trunk/raster/r.mapcalc/xpow.c
   grass/trunk/raster/r.mapcalc/xrand.c
   grass/trunk/raster/r.mapcalc/xres.c
   grass/trunk/raster/r.mapcalc/xres3.c
   grass/trunk/raster/r.mapcalc/xround.c
   grass/trunk/raster/r.mapcalc/xrowcol.c
   grass/trunk/raster/r.mapcalc/xshiftl.c
   grass/trunk/raster/r.mapcalc/xshiftr.c
   grass/trunk/raster/r.mapcalc/xshiftru.c
   grass/trunk/raster/r.mapcalc/xsin.c
   grass/trunk/raster/r.mapcalc/xsqrt.c
   grass/trunk/raster/r.mapcalc/xsub.c
   grass/trunk/raster/r.mapcalc/xtan.c
   grass/trunk/raster/r.mfilter/filter.h
   grass/trunk/raster/r.mode/read_stats.c
   grass/trunk/raster/r.neighbors/readweights.c
   grass/trunk/raster/r.out.gridatb/local_proto.h
   grass/trunk/raster/r.out.gridatb/main.c
   grass/trunk/raster/r.out.mpeg/write.c
   grass/trunk/raster/r.out.vrml/pv.h
   grass/trunk/raster/r.out.vtk/parameters.c
   grass/trunk/raster/r.param.scale/interface.c
   grass/trunk/raster/r.param.scale/nrutil.c
   grass/trunk/raster/r.param.scale/param.h
   grass/trunk/raster/r.profile/local_proto.h
   grass/trunk/raster/r.proj/bordwalk.c
   grass/trunk/raster/r.quant/global.h
   grass/trunk/raster/r.random.cells/flag.c
   grass/trunk/raster/r.random.cells/main.c
   grass/trunk/raster/r.random.cells/random.c
   grass/trunk/raster/r.random.cells/ransurf.h
   grass/trunk/raster/r.random.surface/gennorm.c
   grass/trunk/raster/r.random.surface/random.c
   grass/trunk/raster/r.random.surface/ransurf.h
   grass/trunk/raster/r.random/main.c
   grass/trunk/raster/r.reclass/input.c
   grass/trunk/raster/r.reclass/rule.h
   grass/trunk/raster/r.recode/global.h
   grass/trunk/raster/r.recode/main.c
   grass/trunk/raster/r.report/global.h
   grass/trunk/raster/r.rescale/main.c
   grass/trunk/raster/r.ros/spot_dist.c
   grass/trunk/raster/r.spread/insert2Ha.c
   grass/trunk/raster/r.spread/replaceHa.c
   grass/trunk/raster/r.spread/select_linksB.c
   grass/trunk/raster/r.spread/spot.c
   grass/trunk/raster/r.spread/spread.c
   grass/trunk/raster/r.spreadpath/insert.c
   grass/trunk/raster/r.statistics/o_distrib.c
   grass/trunk/raster/r.statistics/read_stats.c
   grass/trunk/raster/r.stats/global.h
   grass/trunk/raster/r.sun2/rsunlib.c
   grass/trunk/raster/r.sunmask/g_solposition.c
   grass/trunk/raster/r.sunmask/solpos00.c
   grass/trunk/raster/r.support.stats/main.c
   grass/trunk/raster/r.surf.contour/contour.h
   grass/trunk/raster/r.surf.contour/flag_create.c
   grass/trunk/raster/r.surf.contour/flag_destroy.c
   grass/trunk/raster/r.surf.fractal/frac.h
   grass/trunk/raster/r.surf.fractal/spec_syn.c
   grass/trunk/raster/r.surf.gauss/main.c
   grass/trunk/raster/r.surf.idw/dist.c
   grass/trunk/raster/r.surf.idw/ll.c
   grass/trunk/raster/r.surf.idw/pi.h
   grass/trunk/raster/r.surf.random/main.c
   grass/trunk/raster/r.terraflow/common.h
   grass/trunk/raster/r.texture/h_measure.c
   grass/trunk/raster/r.thin/thin_lines.c
   grass/trunk/raster/r.to.vect/lines_io.c
   grass/trunk/raster/r.topidx/main.c
   grass/trunk/raster/r.topmodel/global.h
   grass/trunk/raster/r.univar/globals.h
   grass/trunk/raster/r.walk/btree.c
   grass/trunk/raster/r.walk/memory.c
   grass/trunk/raster/r.water.outlet/basin.h
   grass/trunk/raster/r.water.outlet/flag_create.c
   grass/trunk/raster/r.water.outlet/flag_destroy.c
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/flag_create.c
   grass/trunk/raster/r.watershed/ram/flag_destroy.c
   grass/trunk/raster/r.watershed/ram/main.c
   grass/trunk/raster/r.watershed/ram/usage.c
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/raster/r.watershed/seg/bseg_close.c
   grass/trunk/raster/r.watershed/seg/bseg_get.c
   grass/trunk/raster/r.watershed/seg/bseg_open.c
   grass/trunk/raster/r.watershed/seg/bseg_put.c
   grass/trunk/raster/r.watershed/seg/cseg_close.c
   grass/trunk/raster/r.watershed/seg/cseg_get.c
   grass/trunk/raster/r.watershed/seg/cseg_open.c
   grass/trunk/raster/r.watershed/seg/cseg_put.c
   grass/trunk/raster/r.watershed/seg/do_astar.c
   grass/trunk/raster/r.watershed/seg/dseg_close.c
   grass/trunk/raster/r.watershed/seg/dseg_get.c
   grass/trunk/raster/r.watershed/seg/dseg_open.c
   grass/trunk/raster/r.watershed/seg/dseg_put.c
   grass/trunk/raster/r.watershed/seg/main.c
   grass/trunk/raster/r.watershed/seg/sg_factor.c
   grass/trunk/raster/r.watershed/seg/sseg_close.c
   grass/trunk/raster/r.watershed/seg/sseg_get.c
   grass/trunk/raster/r.watershed/seg/sseg_open.c
   grass/trunk/raster/r.watershed/seg/sseg_put.c
   grass/trunk/raster/r.watershed/seg/usage.c
   grass/trunk/raster/r.watershed/shed/watershed.h
   grass/trunk/raster3d/r3.gwflow/main.c
   grass/trunk/raster3d/r3.mkdspf/calc_linefax.c
   grass/trunk/raster3d/r3.mkdspf/main.c
   grass/trunk/raster3d/r3.mkdspf/r3_find.c
   grass/trunk/raster3d/r3.out.vtk/parameters.c
   grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c
   grass/trunk/vector/lidar/lidarlib/TcholBand.c
   grass/trunk/vector/lidar/lidarlib/raster.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.c
   grass/trunk/vector/lidar/v.lidar.correction/main.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
   grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/lidar/v.outlier/outlier.c
   grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
   grass/trunk/vector/v.convert/dist.c
   grass/trunk/vector/v.convert/main.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.convert/read.c
   grass/trunk/vector/v.kernel/function.c
   grass/trunk/vector/v.surf.idw/read_sites.c
   grass/trunk/vector/v.to.rast/do_areas.c
   grass/trunk/vector/v.to.rast/do_lines.c
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.vol.rst/dataoct.c
   grass/trunk/vector/v.vol.rst/oct.c
   grass/trunk/vector/v.vol.rst/user2.c
   grass/trunk/vector/v.vol.rst/user4.c
   grass/trunk/vector/v.vol.rst/vector.c
Don't include <grass/raster.h> where not needed
Modified: grass/trunk/display/d.graph/graphics.c
--- grass/trunk/display/d.graph/graphics.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.graph/graphics.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <string.h>
 #include <grass/gis.h>
-#include <grass/raster.h>
 #include <grass/glocale.h>
 #include "local_proto.h"
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.grid/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -21,7 +21,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/display.h>
 #include <grass/gprojects.h>
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.grid/plot.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <string.h>
Modified: grass/trunk/display/d.grid/plotborder.c
--- grass/trunk/display/d.grid/plotborder.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.grid/plotborder.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 int plot_border(double grid_size, double east, double north)
Modified: grass/trunk/display/d.histogram/draw_slice.c
--- grass/trunk/display/d.histogram/draw_slice.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.histogram/draw_slice.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <math.h>
 char percent[] = "%";
Modified: grass/trunk/display/d.labels/do_labels.c
--- grass/trunk/display/d.labels/do_labels.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.labels/do_labels.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/display/d.labels/main.c
--- grass/trunk/display/d.labels/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.labels/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/display/d.path/select.c
--- grass/trunk/display/d.path/select.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.path/select.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <unistd.h>
 #include <math.h>
 #include <grass/Vect.h>
 #include <grass/colors.h>
Modified: grass/trunk/display/d.thematic.area/area.c
--- grass/trunk/display/d.thematic.area/area.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.thematic.area/area.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
 #include <string.h>
 #include <stdlib.h>
Modified: grass/trunk/display/d.title/fancy.c
--- grass/trunk/display/d.title/fancy.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.title/fancy.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "options.h"
 void fancy(struct Cell_head *window, struct Categories *cats, FILE * fp)
Modified: grass/trunk/display/d.title/normal.c
--- grass/trunk/display/d.title/normal.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.title/normal.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/attr.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <string.h>
 #include <grass/dbmi.h>
Modified: grass/trunk/display/d.vect/dir.c
--- grass/trunk/display/d.vect/dir.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/dir.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/label.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect/topo.c
--- grass/trunk/display/d.vect/topo.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/topo.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect/utils.c
--- grass/trunk/display/d.vect/utils.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/utils.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect/zcoor.c
--- grass/trunk/display/d.vect/zcoor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect/zcoor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 /* Print z coordinate value for each node */
Modified: grass/trunk/display/d.vect.chart/bar.c
--- grass/trunk/display/d.vect.chart/bar.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect.chart/bar.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/display/d.vect.chart/pie.c
--- grass/trunk/display/d.vect.chart/pie.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect.chart/pie.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
Modified: grass/trunk/display/d.vect.chart/plot.c
--- grass/trunk/display/d.vect.chart/plot.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/display/d.vect.chart/plot.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/general/g.mremove/wc2regex.c
--- grass/trunk/general/g.mremove/wc2regex.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/general/g.mremove/wc2regex.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 char *wc2regex(const char *wc)
Modified: grass/trunk/general/g.region/printwindow.c
--- grass/trunk/general/g.region/printwindow.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/general/g.region/printwindow.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include <projects.h>
Modified: grass/trunk/general/manage/lister/vector.c
--- grass/trunk/general/manage/lister/vector.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/general/manage/lister/vector.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <string.h>
 int main(int argc, char *argv[])
Modified: grass/trunk/imagery/i.cca/matrix.c
--- grass/trunk/imagery/i.cca/matrix.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cca/matrix.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 #include <grass/gmath.h>
Modified: grass/trunk/imagery/i.cca/stats.c
--- grass/trunk/imagery/i.cca/stats.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cca/stats.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/checkpt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "global.h"
Modified: grass/trunk/imagery/i.cluster/print1.c
--- grass/trunk/imagery/i.cluster/print1.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print1.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <grass/imagery.h>
 #include <grass/cluster.h>
Modified: grass/trunk/imagery/i.cluster/print2.c
--- grass/trunk/imagery/i.cluster/print2.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print2.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/print3.c
--- grass/trunk/imagery/i.cluster/print3.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print3.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/print4.c
--- grass/trunk/imagery/i.cluster/print4.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print4.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/print5.c
--- grass/trunk/imagery/i.cluster/print5.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print5.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/print6.c
--- grass/trunk/imagery/i.cluster/print6.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/print6.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
Modified: grass/trunk/imagery/i.cluster/timer.c
--- grass/trunk/imagery/i.cluster/timer.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.cluster/timer.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 #include "global.h"
Modified: grass/trunk/imagery/i.gensig/alloc.c
--- grass/trunk/imagery/i.gensig/alloc.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensig/alloc.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 double *vector(int nl, int nh)
Modified: grass/trunk/imagery/i.gensig/can_invert.c
--- grass/trunk/imagery/i.gensig/can_invert.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensig/can_invert.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 int can_invert(double **a, int n)
Modified: grass/trunk/imagery/i.gensig/eigen.c
--- grass/trunk/imagery/i.gensig/eigen.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensig/eigen.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <math.h>
 double **matrix(), *vector();
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensig/parse.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "parms.h"
Modified: grass/trunk/imagery/i.gensigset/invert.c
--- grass/trunk/imagery/i.gensigset/invert.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensigset/invert.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 int invert(
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensigset/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdlib.h>
 #include "files.h"
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.gensigset/parse.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "parms.h"
Modified: grass/trunk/imagery/i.his.rgb/his2rgb.c
--- grass/trunk/imagery/i.his.rgb/his2rgb.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.his.rgb/his2rgb.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -17,7 +17,6 @@
    each band is processed and written out.   CWU GIS Lab: DBS 8/90 */
 #include "globals.h"
 void his2rgb(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.maxlik/invert.c
--- grass/trunk/imagery/i.maxlik/invert.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.maxlik/invert.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <math.h>
 #include "global.h"
Modified: grass/trunk/imagery/i.rectify/crs.c
--- grass/trunk/imagery/i.rectify/crs.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.rectify/crs.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -32,7 +32,6 @@
 #include <math.h>
 #include <limits.h>
    #define MSDOS 1
Modified: grass/trunk/imagery/i.rgb.his/rgb2his.c
--- grass/trunk/imagery/i.rgb.his/rgb2his.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.rgb.his/rgb2his.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -17,7 +17,6 @@
 void rgb2his(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.smap/decimate.c
--- grass/trunk/imagery/i.smap/decimate.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.smap/decimate.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "bouman.h"
 #include "region.h"
Modified: grass/trunk/imagery/i.smap/interp.c
--- grass/trunk/imagery/i.smap/interp.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.smap/interp.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <math.h>
 #include "bouman.h"
 #include "region.h"
Modified: grass/trunk/imagery/i.smap/invert.c
--- grass/trunk/imagery/i.smap/invert.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.smap/invert.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 int invert(
Modified: grass/trunk/imagery/i.smap/multialloc.c
--- grass/trunk/imagery/i.smap/multialloc.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.smap/multialloc.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdio.h>
 #include <stdarg.h>
Modified: grass/trunk/imagery/i.smap/parse.c
--- grass/trunk/imagery/i.smap/parse.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/imagery/i.smap/parse.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "bouman.h"
Modified: grass/trunk/ps/ps.map/catval.c
--- grass/trunk/ps/ps.map/catval.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/catval.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
Modified: grass/trunk/ps/ps.map/distance.c
--- grass/trunk/ps/ps.map/distance.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/distance.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 double distance(double east, double west)
Modified: grass/trunk/ps/ps.map/do_geogrid.c
--- grass/trunk/ps/ps.map/do_geogrid.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/do_geogrid.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/ps/ps.map/do_masking.c
--- grass/trunk/ps/ps.map/do_masking.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/do_masking.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -6,7 +6,6 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "ps_info.h"
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/do_plt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -5,7 +5,6 @@
 #include <string.h>
 #include <grass/symbol.h>
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/do_psfiles.c
--- grass/trunk/ps/ps.map/do_psfiles.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/do_psfiles.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/do_vectors.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <string.h>
Modified: grass/trunk/ps/ps.map/error.c
--- grass/trunk/ps/ps.map/error.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/error.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdio.h>
 #include <unistd.h>
 extern FILE *tracefd;
Modified: grass/trunk/ps/ps.map/get_font.c
--- grass/trunk/ps/ps.map/get_font.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/get_font.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
 int get_font(char *data)
Modified: grass/trunk/ps/ps.map/input.c
--- grass/trunk/ps/ps.map/input.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/input.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <unistd.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/makeprocs.c
--- grass/trunk/ps/ps.map/makeprocs.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/makeprocs.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -6,7 +6,6 @@
Modified: grass/trunk/ps/ps.map/map_setup.c
--- grass/trunk/ps/ps.map/map_setup.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/map_setup.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
 #include "group.h"
Modified: grass/trunk/ps/ps.map/parse_list.c
--- grass/trunk/ps/ps.map/parse_list.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/parse_list.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
  * count will be negative if list is not valid
 int parse_val_list(char *buf, DCELL ** list)
Modified: grass/trunk/ps/ps.map/ps_info.h
--- grass/trunk/ps/ps.map/ps_info.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/ps_info.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 /* Font sizes */
 #define PS_FONT_MAX_SIZE      50
Modified: grass/trunk/ps/ps.map/r_labels.c
--- grass/trunk/ps/ps.map/r_labels.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/r_labels.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <string.h>
 #include "labels.h"
Modified: grass/trunk/ps/ps.map/read_cfg.c
--- grass/trunk/ps/ps.map/read_cfg.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/read_cfg.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -13,7 +13,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "paper.h"
Modified: grass/trunk/ps/ps.map/scale.c
--- grass/trunk/ps/ps.map/scale.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/scale.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/scan_gis.c
--- grass/trunk/ps/ps.map/scan_gis.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/scan_gis.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <unistd.h>
 #include <string.h>
 int scan_gis(char *element, char *desc, char *key, char *data,
Modified: grass/trunk/ps/ps.map/session.c
--- grass/trunk/ps/ps.map/session.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/session.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 static char cur[2000];
Modified: grass/trunk/ps/ps.map/vect.c
--- grass/trunk/ps/ps.map/vect.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/vect.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <math.h>
 #include "vector.h"
 #define LENGTH(DX, DY)  (  sqrt( (DX*DX)+(DY*DY) )  )
Modified: grass/trunk/ps/ps.map/vector.c
--- grass/trunk/ps/ps.map/vector.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/ps/ps.map/vector.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdio.h>
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/raster/r.buffer/distance.h
--- grass/trunk/raster/r.buffer/distance.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.buffer/distance.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -23,8 +23,6 @@
 #define __DISTANCE_H__
 struct Distance
Modified: grass/trunk/raster/r.buffer/find_dist.c
--- grass/trunk/raster/r.buffer/find_dist.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.buffer/find_dist.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include "distance.h"
Modified: grass/trunk/raster/r.buffer/init.c
--- grass/trunk/raster/r.buffer/init.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.buffer/init.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -21,7 +21,6 @@
 int init_grass(void)
Modified: grass/trunk/raster/r.carve/enforce.h
--- grass/trunk/raster/r.carve/enforce.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.carve/enforce.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -22,7 +22,6 @@
 #include <stdio.h>
 #include <grass/bitmap.h>
Modified: grass/trunk/raster/r.carve/vect.c
--- grass/trunk/raster/r.carve/vect.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.carve/vect.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdio.h>
 #include "enforce.h"
Modified: grass/trunk/raster/r.coin/coin.h
--- grass/trunk/raster/r.coin/coin.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.coin/coin.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,8 +20,6 @@
 #define __COIN_H__
 struct stats_table
Modified: grass/trunk/raster/r.colors/local_proto.h
--- grass/trunk/raster/r.colors/local_proto.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.colors/local_proto.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -21,7 +21,6 @@
 #define __LOCAL_PROTO_H__
 /* stats.c */
 int get_stats(const char *, const char *, struct Cell_stats *);
Modified: grass/trunk/raster/r.cost/btree.c
--- grass/trunk/raster/r.cost/btree.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.cost/btree.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -38,7 +38,6 @@
 #include "memory.h"
 #include <stdlib.h>
Modified: grass/trunk/raster/r.cost/memory.c
--- grass/trunk/raster/r.cost/memory.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.cost/memory.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -26,7 +26,6 @@
 #include <string.h>
 #include <errno.h>
 #include "memory.h"
 #define NUM_IN_BLOCK	1024*8
Modified: grass/trunk/raster/r.cross/glob.h
--- grass/trunk/raster/r.cross/glob.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.cross/glob.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,8 +20,6 @@
 #define __R_CROSS_GLOB_H__
 #define NFILES 30		/* maximum number of layers */
 #define SHIFT 6			/* 2^SHIFT cats per node */
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.describe/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.describe/tree.c
--- grass/trunk/raster/r.describe/tree.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.describe/tree.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -17,7 +17,6 @@
 #define INCR 10
Modified: grass/trunk/raster/r.distance/defs.h
--- grass/trunk/raster/r.distance/defs.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.distance/defs.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #define __R_DIST_DEFS_H__
 struct EdgeList			/* keep track of edge cells */
Modified: grass/trunk/raster/r.distance/main.c
--- grass/trunk/raster/r.distance/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.distance/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <stdio.h>
 #include "defs.h"
Modified: grass/trunk/raster/r.distance/parse.c
--- grass/trunk/raster/r.distance/parse.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.distance/parse.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <stdio.h>
 #include "defs.h"
 void parse(int argc, char *argv[], struct Parms *parms)
Modified: grass/trunk/raster/r.flow/aspect.c
--- grass/trunk/raster/r.flow/aspect.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.flow/aspect.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -26,7 +26,6 @@
 #include <math.h>
 #include "r.flow.h"
Modified: grass/trunk/raster/r.flow/aspect.h
--- grass/trunk/raster/r.flow/aspect.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.flow/aspect.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
  * aspect_fly: calculates aspect on the fly based on elevation map in z
Modified: grass/trunk/raster/r.flow/io.h
--- grass/trunk/raster/r.flow/io.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.flow/io.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 /********************************* I/O **********************************/
Modified: grass/trunk/raster/r.flow/mem.h
--- grass/trunk/raster/r.flow/mem.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.flow/mem.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 /************************** MEMORY MANAGEMENT ***************************/
 #define KB 1024
 #define MB (KB * KB)
 #define SEGSINMEM 9
Modified: grass/trunk/raster/r.flow/r.flow.h
--- grass/trunk/raster/r.flow/r.flow.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.flow/r.flow.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -32,7 +32,6 @@
 #include <math.h>
 #include <grass/segment.h>
Modified: grass/trunk/raster/r.in.gridatb/local_proto.h
--- grass/trunk/raster/r.in.gridatb/local_proto.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.in.gridatb/local_proto.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 int check_ready(void);
 int adjcellhd(struct Cell_head *cellhd);
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.in.gridatb/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 struct Cell_head cellhd;
Modified: grass/trunk/raster/r.in.poly/getformat.c
--- grass/trunk/raster/r.in.poly/getformat.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.in.poly/getformat.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "format.h"
 int getformat(FILE * fd)
Modified: grass/trunk/raster/r.in.poly/main.c
--- grass/trunk/raster/r.in.poly/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.in.poly/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -13,7 +13,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.in.xyz/local_proto.h
--- grass/trunk/raster/r.in.xyz/local_proto.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.in.xyz/local_proto.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #define BUFFSIZE 256
Modified: grass/trunk/raster/r.info/reclas_txt.c
--- grass/trunk/raster/r.info/reclas_txt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.info/reclas_txt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <string.h>
Modified: grass/trunk/raster/r.kappa/calc_kappa.c
--- grass/trunk/raster/r.kappa/calc_kappa.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.kappa/calc_kappa.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/kappa.h
--- grass/trunk/raster/r.kappa/kappa.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.kappa/kappa.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 struct _gstats_
Modified: grass/trunk/raster/r.kappa/prt_mat.c
--- grass/trunk/raster/r.kappa/prt_mat.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.kappa/prt_mat.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/stats.c
--- grass/trunk/raster/r.kappa/stats.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.kappa/stats.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <string.h>
 #include <unistd.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.le/r.le.patch/patch.h
--- grass/trunk/raster/r.le/r.le.patch/patch.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.le/r.le.patch/patch.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -32,7 +32,6 @@
 #include <stdlib.h>
 #include <string.h>
 #define  SML   0.5
 #define  MIN   2
Modified: grass/trunk/raster/r.le/r.le.pixel/pixel.h
--- grass/trunk/raster/r.le/r.le.pixel/pixel.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.le/r.le.pixel/pixel.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -26,7 +26,6 @@
 #include <stdlib.h>
 #include <string.h>
 #define  BIG   1000000000.0
 #define  MAX   800
Modified: grass/trunk/raster/r.le/r.le.setup/setup.h
--- grass/trunk/raster/r.le/r.le.setup/setup.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.le/r.le.setup/setup.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -28,7 +28,6 @@
 #include "stdlib.h"
 #include "string.h"
 #include "sys/types.h"
Modified: grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
--- grass/trunk/raster/r.le/r.le.trace/r.le.trace.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.le/r.le.trace/r.le.trace.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -26,7 +26,6 @@
 #include "stdlib.h"
 #include "string.h"
 #define EQ(a, b)    (a-b < 0.01 && a-b > -0.01 )
 #define BIG   500000000.0
Modified: grass/trunk/raster/r.li/r.li.cwed/utility.c
--- grass/trunk/raster/r.li/r.li.cwed/utility.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.cwed/utility.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -10,7 +10,6 @@
 #include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
--- grass/trunk/raster/r.li/r.li.daemon/GenericCell.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/GenericCell.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -9,7 +9,6 @@
 #ifndef GENERICCELL_H
Modified: grass/trunk/raster/r.li/r.li.daemon/avl.c
--- grass/trunk/raster/r.li/r.li.daemon/avl.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/avl.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
  *       \BUGS: please send bugs reports to pallecch at cli.di.unipi.it
 #include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/avlID.c
--- grass/trunk/raster/r.li/r.li.daemon/avlID.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/avlID.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -12,7 +12,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.h
--- grass/trunk/raster/r.li/r.li.daemon/daemon.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -18,7 +18,6 @@
 #include "list.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/ipc.c
--- grass/trunk/raster/r.li/r.li.daemon/ipc.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/ipc.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <unistd.h>
 #include "ipc.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/list.c
--- grass/trunk/raster/r.li/r.li.daemon/list.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.li/r.li.daemon/list.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include <stdlib.h>
 #include "daemon.h"
Modified: grass/trunk/raster/r.los/delete.c
--- grass/trunk/raster/r.los/delete.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.los/delete.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -11,7 +11,6 @@
 #include <stdlib.h>
 #include "point.h"
Modified: grass/trunk/raster/r.los/make_list.c
--- grass/trunk/raster/r.los/make_list.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.los/make_list.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -12,7 +12,6 @@
 #include <math.h>
 #include "point.h"
Modified: grass/trunk/raster/r.los/make_point.c
--- grass/trunk/raster/r.los/make_point.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.los/make_point.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -13,7 +13,6 @@
 #include "point.h"
 /* #define NULL 0  should be (char *0), or just let the compiler fix it. */
Modified: grass/trunk/raster/r.los/mark_pts.c
--- grass/trunk/raster/r.los/mark_pts.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.los/mark_pts.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -12,7 +12,6 @@
 #include "point.h"
 #define		PT_TO_MARK_X		PT_TO_MARK->x
 #define		PT_TO_MARK_Y		PT_TO_MARK->y
Modified: grass/trunk/raster/r.los/radians.h
--- grass/trunk/raster/r.los/radians.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.los/radians.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -10,7 +10,6 @@
 #define		PI		M_PI
 #define		PIBYFOUR 	M_PI_4
Modified: grass/trunk/raster/r.mapcalc/column_shift.c
--- grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "expression.h"
Modified: grass/trunk/raster/r.mapcalc/expression.c
--- grass/trunk/raster/r.mapcalc/expression.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/expression.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
 #include <string.h>
 #include "mapcalc.h"
Modified: grass/trunk/raster/r.mapcalc/mapcalc.h
--- grass/trunk/raster/r.mapcalc/mapcalc.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/mapcalc.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <grass/config.h>
Modified: grass/trunk/raster/r.mapcalc/xabs.c
--- grass/trunk/raster/r.mapcalc/xabs.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xabs.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
 #include "func_proto.h"
Modified: grass/trunk/raster/r.mapcalc/xacos.c
--- grass/trunk/raster/r.mapcalc/xacos.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xacos.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xadd.c
--- grass/trunk/raster/r.mapcalc/xadd.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xadd.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xand.c
--- grass/trunk/raster/r.mapcalc/xand.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xand.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xand2.c
--- grass/trunk/raster/r.mapcalc/xand2.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xand2.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xasin.c
--- grass/trunk/raster/r.mapcalc/xasin.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xasin.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xatan.c
--- grass/trunk/raster/r.mapcalc/xatan.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xatan.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xbitand.c
--- grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xbitnot.c
--- grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xbitor.c
--- grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xbitxor.c
--- grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xcoor.c
--- grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include "globals2.h"
Modified: grass/trunk/raster/r.mapcalc/xcoor3.c
--- grass/trunk/raster/r.mapcalc/xcoor3.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xcoor3.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <grass/G3d.h>
 #include "globals3.h"
Modified: grass/trunk/raster/r.mapcalc/xcos.c
--- grass/trunk/raster/r.mapcalc/xcos.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xcos.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xdiv.c
--- grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xdouble.c
--- grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xeq.c
--- grass/trunk/raster/r.mapcalc/xeq.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xeq.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xeval.c
--- grass/trunk/raster/r.mapcalc/xeval.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xeval.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xexp.c
--- grass/trunk/raster/r.mapcalc/xexp.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xexp.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xfloat.c
--- grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xge.c
--- grass/trunk/raster/r.mapcalc/xge.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xge.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xgraph.c
--- grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xgt.c
--- grass/trunk/raster/r.mapcalc/xgt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xgt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xif.c
--- grass/trunk/raster/r.mapcalc/xif.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xif.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xint.c
--- grass/trunk/raster/r.mapcalc/xint.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xint.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xisnull.c
--- grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xle.c
--- grass/trunk/raster/r.mapcalc/xle.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xle.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xlog.c
--- grass/trunk/raster/r.mapcalc/xlog.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xlog.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xlt.c
--- grass/trunk/raster/r.mapcalc/xlt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xlt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xmax.c
--- grass/trunk/raster/r.mapcalc/xmax.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xmax.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmin.c
--- grass/trunk/raster/r.mapcalc/xmin.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xmin.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmod.c
--- grass/trunk/raster/r.mapcalc/xmod.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xmod.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xmode.c
--- grass/trunk/raster/r.mapcalc/xmode.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xmode.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmul.c
--- grass/trunk/raster/r.mapcalc/xmul.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xmul.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xne.c
--- grass/trunk/raster/r.mapcalc/xne.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xne.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xneg.c
--- grass/trunk/raster/r.mapcalc/xneg.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xneg.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xnot.c
--- grass/trunk/raster/r.mapcalc/xnot.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xnot.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xnull.c
--- grass/trunk/raster/r.mapcalc/xnull.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xnull.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xor.c
--- grass/trunk/raster/r.mapcalc/xor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xor2.c
--- grass/trunk/raster/r.mapcalc/xor2.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xor2.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xpow.c
--- grass/trunk/raster/r.mapcalc/xpow.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xpow.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xrand.c
--- grass/trunk/raster/r.mapcalc/xrand.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xrand.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
Modified: grass/trunk/raster/r.mapcalc/xres.c
--- grass/trunk/raster/r.mapcalc/xres.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xres.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xres3.c
--- grass/trunk/raster/r.mapcalc/xres3.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xres3.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xround.c
--- grass/trunk/raster/r.mapcalc/xround.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xround.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <limits.h>
Modified: grass/trunk/raster/r.mapcalc/xrowcol.c
--- grass/trunk/raster/r.mapcalc/xrowcol.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xrowcol.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftl.c
--- grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftr.c
--- grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftru.c
--- grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xsin.c
--- grass/trunk/raster/r.mapcalc/xsin.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xsin.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsqrt.c
--- grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsub.c
--- grass/trunk/raster/r.mapcalc/xsub.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xsub.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
Modified: grass/trunk/raster/r.mapcalc/xtan.c
--- grass/trunk/raster/r.mapcalc/xtan.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mapcalc/xtan.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mfilter/filter.h
--- grass/trunk/raster/r.mfilter/filter.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mfilter/filter.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <grass/rowio.h>
 typedef struct
Modified: grass/trunk/raster/r.mode/read_stats.c
--- grass/trunk/raster/r.mode/read_stats.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.mode/read_stats.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <stdio.h>
 int read_stats(FILE * fd, long *cat1, long *cat2, double *value)
Modified: grass/trunk/raster/r.neighbors/readweights.c
--- grass/trunk/raster/r.neighbors/readweights.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.neighbors/readweights.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "ncb.h"
Modified: grass/trunk/raster/r.out.gridatb/local_proto.h
--- grass/trunk/raster/r.out.gridatb/local_proto.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.out.gridatb/local_proto.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 void check_ready(void);
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.out.gridatb/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -17,7 +17,6 @@
 #include <stdio.h>
Modified: grass/trunk/raster/r.out.mpeg/write.c
--- grass/trunk/raster/r.out.mpeg/write.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.out.mpeg/write.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -22,7 +22,6 @@
 #include <math.h>
 #include <unistd.h>
 #include "rom_proto.h"
Modified: grass/trunk/raster/r.out.vrml/pv.h
--- grass/trunk/raster/r.out.vrml/pv.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.out.vrml/pv.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 /*  VRML VERSION - only 1.0 currently supported
    #define VRML2
Modified: grass/trunk/raster/r.out.vtk/parameters.c
--- grass/trunk/raster/r.out.vtk/parameters.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.out.vtk/parameters.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include "parameters.h"
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.param.scale/interface.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -14,7 +14,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "param.h"
Modified: grass/trunk/raster/r.param.scale/nrutil.c
--- grass/trunk/raster/r.param.scale/nrutil.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.param.scale/nrutil.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stddef.h>
 #include <stdlib.h>
 #include "nrutil.h"
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.param.scale/param.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -9,7 +9,6 @@
 				/* programs. It sets up the necessary   */
 				/* prototypes for GRASS library calls.  */
 #include <math.h>
Modified: grass/trunk/raster/r.profile/local_proto.h
--- grass/trunk/raster/r.profile/local_proto.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.profile/local_proto.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <string.h>
 #include <math.h>
 /* main.c */
Modified: grass/trunk/raster/r.proj/bordwalk.c
--- grass/trunk/raster/r.proj/bordwalk.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.proj/bordwalk.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -28,7 +28,6 @@
 #include <math.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.quant/global.h
--- grass/trunk/raster/r.quant/global.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.quant/global.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 extern struct Quant quant_struct;
 extern CELL old_min, old_max;
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -22,7 +22,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.random.cells/flag.c
--- grass/trunk/raster/r.random.cells/flag.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.cells/flag.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "flag.h"
Modified: grass/trunk/raster/r.random.cells/main.c
--- grass/trunk/raster/r.random.cells/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.cells/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -18,7 +18,6 @@
 #include <stdlib.h>
 #include "ransurf.h"
Modified: grass/trunk/raster/r.random.cells/random.c
--- grass/trunk/raster/r.random.cells/random.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.cells/random.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 /* random.c                                                             */
Modified: grass/trunk/raster/r.random.cells/ransurf.h
--- grass/trunk/raster/r.random.cells/ransurf.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.cells/ransurf.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "flag.h"
 #define ODD(a)	((a) & 1)
Modified: grass/trunk/raster/r.random.surface/gennorm.c
--- grass/trunk/raster/r.random.surface/gennorm.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.surface/gennorm.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 /* gennorm.c                                                    */
 #include <math.h>
 void GenNorm(void)
Modified: grass/trunk/raster/r.random.surface/random.c
--- grass/trunk/raster/r.random.surface/random.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.surface/random.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 /* random.c                                                             */
 #define M1 259200
Modified: grass/trunk/raster/r.random.surface/ransurf.h
--- grass/trunk/raster/r.random.surface/ransurf.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.random.surface/ransurf.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -5,7 +5,6 @@
 #include <stdio.h>
 #include <math.h>
Modified: grass/trunk/raster/r.reclass/input.c
--- grass/trunk/raster/r.reclass/input.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.reclass/input.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <unistd.h>
 #include <string.h>
 int input(FILE * fp, int tty, char *buf)
Modified: grass/trunk/raster/r.reclass/rule.h
--- grass/trunk/raster/r.reclass/rule.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.reclass/rule.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 #define RULE struct _rule_
 RULE {
Modified: grass/trunk/raster/r.recode/global.h
--- grass/trunk/raster/r.recode/global.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.recode/global.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdio.h>
 extern RASTER_MAP_TYPE in_type;
 extern RASTER_MAP_TYPE out_type;
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.recode/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <string.h>
 #include <unistd.h>
 #include "global.h"
Modified: grass/trunk/raster/r.report/global.h
--- grass/trunk/raster/r.report/global.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.report/global.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -6,7 +6,6 @@
 #endif
 extern struct Cell_head window;
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.rescale/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include <stdio.h>
 #include <string.h>
Modified: grass/trunk/raster/r.ros/spot_dist.c
--- grass/trunk/raster/r.ros/spot_dist.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.ros/spot_dist.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -33,7 +33,6 @@
 #include <math.h>
Modified: grass/trunk/raster/r.spread/insert2Ha.c
--- grass/trunk/raster/r.spread/insert2Ha.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spread/insert2Ha.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -12,7 +12,6 @@
 #include "cell_ptrHa.h"
Modified: grass/trunk/raster/r.spread/replaceHa.c
--- grass/trunk/raster/r.spread/replaceHa.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spread/replaceHa.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -12,7 +12,6 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include "costHa.h"
Modified: grass/trunk/raster/r.spread/select_linksB.c
--- grass/trunk/raster/r.spread/select_linksB.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spread/select_linksB.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "costHa.h"
Modified: grass/trunk/raster/r.spread/spot.c
--- grass/trunk/raster/r.spread/spot.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spread/spot.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -44,7 +44,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "cmd_line.h"
 #include "costHa.h"
Modified: grass/trunk/raster/r.spread/spread.c
--- grass/trunk/raster/r.spread/spread.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spread/spread.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -33,7 +33,6 @@
 #include <stdlib.h>
 #include <math.h>
 #include "costHa.h"
Modified: grass/trunk/raster/r.spreadpath/insert.c
--- grass/trunk/raster/r.spreadpath/insert.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.spreadpath/insert.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "point.h"
Modified: grass/trunk/raster/r.statistics/o_distrib.c
--- grass/trunk/raster/r.statistics/o_distrib.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.statistics/o_distrib.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "method.h"
Modified: grass/trunk/raster/r.statistics/read_stats.c
--- grass/trunk/raster/r.statistics/read_stats.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.statistics/read_stats.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.stats/global.h
--- grass/trunk/raster/r.stats/global.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.stats/global.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 extern char *no_data_str;
 extern int nfiles;
Modified: grass/trunk/raster/r.sun2/rsunlib.c
--- grass/trunk/raster/r.sun2/rsunlib.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.sun2/rsunlib.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -32,7 +32,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "sunradstruct.h"
Modified: grass/trunk/raster/r.sunmask/g_solposition.c
--- grass/trunk/raster/r.sunmask/g_solposition.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.sunmask/g_solposition.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -31,7 +31,6 @@
 #include <string.h>
 #include <stdio.h>
 #include "solpos00.h"
Modified: grass/trunk/raster/r.sunmask/solpos00.c
--- grass/trunk/raster/r.sunmask/solpos00.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.sunmask/solpos00.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -96,7 +96,6 @@
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.support.stats/main.c
--- grass/trunk/raster/r.support.stats/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.support.stats/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -18,7 +18,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.contour/contour.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "flag.h"
 #define NODE		struct _n_o_d_e_
Modified: grass/trunk/raster/r.surf.contour/flag_create.c
--- grass/trunk/raster/r.surf.contour/flag_create.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.contour/flag_create.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "flag.h"
 FLAG *flag_create(int nrows, int ncols)
Modified: grass/trunk/raster/r.surf.contour/flag_destroy.c
--- grass/trunk/raster/r.surf.contour/flag_destroy.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.contour/flag_destroy.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "flag.h"
 int flag_destroy(FLAG * flags)
Modified: grass/trunk/raster/r.surf.fractal/frac.h
--- grass/trunk/raster/r.surf.fractal/frac.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.fractal/frac.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -13,7 +13,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/raster/r.surf.fractal/spec_syn.c
--- grass/trunk/raster/r.surf.fractal/spec_syn.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.fractal/spec_syn.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -23,7 +23,6 @@
 #include <unistd.h>
 #include <math.h>
 #include "frac.h"
Modified: grass/trunk/raster/r.surf.gauss/main.c
--- grass/trunk/raster/r.surf.gauss/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.gauss/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include <stdlib.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.surf.idw/dist.c
--- grass/trunk/raster/r.surf.idw/dist.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.idw/dist.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 #include "pi.h"
 /* distance from point to point along a geodesic
Modified: grass/trunk/raster/r.surf.idw/ll.c
--- grass/trunk/raster/r.surf.idw/ll.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.idw/ll.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include "main.h"
Modified: grass/trunk/raster/r.surf.idw/pi.h
--- grass/trunk/raster/r.surf.idw/pi.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.idw/pi.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 #define PI	M_PI
 #define Radians(x) ((x) * PI/180.0)
Modified: grass/trunk/raster/r.surf.random/main.c
--- grass/trunk/raster/r.surf.random/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.surf.random/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.terraflow/common.h
--- grass/trunk/raster/r.terraflow/common.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.terraflow/common.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -31,7 +31,6 @@
 #include "types.h" /* for dimension_type */
 extern "C" {
Modified: grass/trunk/raster/r.texture/h_measure.c
--- grass/trunk/raster/r.texture/h_measure.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.texture/h_measure.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -25,7 +25,6 @@
 #include <stdlib.h>
 #include <math.h>
 #define RADIX 2.0
Modified: grass/trunk/raster/r.thin/thin_lines.c
--- grass/trunk/raster/r.thin/thin_lines.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.thin/thin_lines.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
 #include <stdio.h>
 #include <unistd.h>
Modified: grass/trunk/raster/r.to.vect/lines_io.c
--- grass/trunk/raster/r.to.vect/lines_io.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.to.vect/lines_io.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -33,7 +33,6 @@
 #endif
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.topidx/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -21,7 +21,6 @@
 #define _MAIN_C_
 #include <stdlib.h>
 #include "global.h"
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.topmodel/global.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -5,7 +5,6 @@
 #include <math.h>
 #include <time.h>
 #define	FILL		0x1
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.univar/globals.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/raster/r.walk/btree.c
--- grass/trunk/raster/r.walk/btree.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.walk/btree.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -15,7 +15,6 @@
 #include "memory.h"
 #include <stdlib.h>
Modified: grass/trunk/raster/r.walk/memory.c
--- grass/trunk/raster/r.walk/memory.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.walk/memory.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -17,7 +17,6 @@
 #include <string.h>
 #include <errno.h>
 #include "memory.h"
Modified: grass/trunk/raster/r.water.outlet/basin.h
--- grass/trunk/raster/r.water.outlet/basin.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.water.outlet/basin.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 #include <grass/gis.h>
-#include <grass/raster.h>
 #include "ramseg.h"
 #include "flag.h"
Modified: grass/trunk/raster/r.water.outlet/flag_create.c
--- grass/trunk/raster/r.water.outlet/flag_create.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.water.outlet/flag_create.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "flag.h"
Modified: grass/trunk/raster/r.water.outlet/flag_destroy.c
--- grass/trunk/raster/r.water.outlet/flag_destroy.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.water.outlet/flag_destroy.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 /* last modified 03/26/91                       */
 #include <math.h>
 #include "ramseg.h"
 #include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include "Gwater.h"
 #include "do_astar.h"
 #include <grass/glocale.h>
 int do_astar(void)
Modified: grass/trunk/raster/r.watershed/ram/flag_create.c
--- grass/trunk/raster/r.watershed/ram/flag_create.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/flag_create.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/flag_destroy.c
--- grass/trunk/raster/r.watershed/ram/flag_destroy.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/flag_destroy.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <unistd.h>
 #include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/ram/usage.c
--- grass/trunk/raster/r.watershed/ram/usage.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/ram/usage.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -8,7 +8,6 @@
 #include <math.h>
 #include "cseg.h"
 #define AR_SIZE			16
Modified: grass/trunk/raster/r.watershed/seg/bseg_close.c
--- grass/trunk/raster/r.watershed/seg/bseg_close.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/bseg_close.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_get.c
--- grass/trunk/raster/r.watershed/seg/bseg_get.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/bseg_get.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_open.c
--- grass/trunk/raster/r.watershed/seg/bseg_open.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/bseg_open.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/bseg_put.c
--- grass/trunk/raster/r.watershed/seg/bseg_put.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/bseg_put.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_close.c
--- grass/trunk/raster/r.watershed/seg/cseg_close.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/cseg_close.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_get.c
--- grass/trunk/raster/r.watershed/seg/cseg_get.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/cseg_get.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include <fcntl.h>
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_put.c
--- grass/trunk/raster/r.watershed/seg/cseg_put.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/cseg_put.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_close.c
--- grass/trunk/raster/r.watershed/seg/dseg_close.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/dseg_close.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_get.c
--- grass/trunk/raster/r.watershed/seg/dseg_get.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/dseg_get.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/dseg_put.c
--- grass/trunk/raster/r.watershed/seg/dseg_put.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/dseg_put.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -21,7 +21,6 @@
 #include <unistd.h>
 #include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/sg_factor.c
--- grass/trunk/raster/r.watershed/seg/sg_factor.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/sg_factor.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_close.c
--- grass/trunk/raster/r.watershed/seg/sseg_close.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/sseg_close.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_get.c
--- grass/trunk/raster/r.watershed/seg/sseg_get.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/sseg_get.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include <unistd.h>
 #include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/sseg_put.c
--- grass/trunk/raster/r.watershed/seg/sseg_put.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/sseg_put.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,5 +1,4 @@
 #include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/usage.c
--- grass/trunk/raster/r.watershed/seg/usage.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/seg/usage.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,7 +1,6 @@
 #include <stdio.h>
 #include <stdlib.h>
Modified: grass/trunk/raster/r.watershed/shed/watershed.h
--- grass/trunk/raster/r.watershed/shed/watershed.h	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster/r.watershed/shed/watershed.h	2009-06-22 08:25:13 UTC (rev 38020)
@@ -4,7 +4,6 @@
 #include <stdio.h>
 #define RAM_NAME		"ram"
 #define SEG_NAME		"seg"
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.gwflow/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/N_pde.h>
Modified: grass/trunk/raster3d/r3.mkdspf/calc_linefax.c
--- grass/trunk/raster3d/r3.mkdspf/calc_linefax.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.mkdspf/calc_linefax.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "vizual.h"
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.mkdspf/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -44,7 +44,6 @@
 #include <math.h>
 #include "vizual.h"
 #include "local_proto.h"
Modified: grass/trunk/raster3d/r3.mkdspf/r3_find.c
--- grass/trunk/raster3d/r3.mkdspf/r3_find.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.mkdspf/r3_find.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -5,7 +5,6 @@
 #include <string.h>
Modified: grass/trunk/raster3d/r3.out.vtk/parameters.c
--- grass/trunk/raster3d/r3.out.vtk/parameters.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.out.vtk/parameters.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -16,7 +16,6 @@
Modified: grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c
--- grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -19,7 +19,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "globalDefs.h"
Modified: grass/trunk/vector/lidar/lidarlib/TcholBand.c
--- grass/trunk/vector/lidar/lidarlib/TcholBand.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/lidarlib/TcholBand.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdio.h>
 #include <math.h>
 #include <grass/PolimiFunct.h>
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/lidarlib/raster.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <string.h>
 #include <grass/Vect.h>
 #include <grass/dbmi.h>
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -22,7 +22,6 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -23,7 +23,6 @@
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -28,7 +28,6 @@
 #include <string.h>
 #include <math.h>
     /* #include <grass/PolimiFunct.h> */
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -27,7 +27,6 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
--- grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "growing.h"
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -23,7 +23,6 @@
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -3,7 +3,6 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -22,7 +22,6 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/v.convert/dist.c
--- grass/trunk/vector/v.convert/dist.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.convert/dist.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/main.c
--- grass/trunk/vector/v.convert/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.convert/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.convert/old2new.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/read.c
--- grass/trunk/vector/v.convert/read.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.convert/read.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.kernel/function.c
--- grass/trunk/vector/v.kernel/function.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.kernel/function.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
 #include "global.h"
Modified: grass/trunk/vector/v.surf.idw/read_sites.c
--- grass/trunk/vector/v.surf.idw/read_sites.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.surf.idw/read_sites.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -2,7 +2,6 @@
 #include <stdlib.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.to.rast/do_lines.c
--- grass/trunk/vector/v.to.rast/do_lines.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.to.rast/do_lines.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -1,6 +1,5 @@
 #include <math.h>
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.to.rast/main.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -20,7 +20,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/v.vol.rst/dataoct.c
--- grass/trunk/vector/v.vol.rst/dataoct.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.vol.rst/dataoct.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -29,7 +29,6 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include "dataoct.h"
 #include "externs.h"
 #include "user.h"
Modified: grass/trunk/vector/v.vol.rst/oct.c
--- grass/trunk/vector/v.vol.rst/oct.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.vol.rst/oct.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -30,7 +30,6 @@
 #include <stdlib.h>
 #include <math.h>
 #include "oct.h"
Modified: grass/trunk/vector/v.vol.rst/user2.c
--- grass/trunk/vector/v.vol.rst/user2.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.vol.rst/user2.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -30,7 +30,6 @@
 #include <math.h>
 #include <stdlib.h>
 #include "oct.h"
 #include "surf.h"
Modified: grass/trunk/vector/v.vol.rst/user4.c
--- grass/trunk/vector/v.vol.rst/user4.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.vol.rst/user4.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -31,7 +31,6 @@
 #include <math.h>
 #include <unistd.h>
 #include "oct.h"
 #include "surf.h"
Modified: grass/trunk/vector/v.vol.rst/vector.c
--- grass/trunk/vector/v.vol.rst/vector.c	2009-06-22 06:35:20 UTC (rev 38019)
+++ grass/trunk/vector/v.vol.rst/vector.c	2009-06-22 08:25:13 UTC (rev 38020)
@@ -32,7 +32,6 @@
 #include <unistd.h>
 #include <fcntl.h>
