[GRASS-SVN] r38026 - in grass/trunk: display/d.extract display/d.path display/d.thematic.area display/d.vect display/d.vect.chart display/d.what.vect display/d.zoom doc/vector/v.example general/g.region general/manage/lister gui/wxpython/vdigit imagery/i.vpoints include include/Make lib/manage lib/ogsf lib/rst/interp_float lib/sites lib/vector/Vlib lib/vector/diglib ps/ps.map raster/r.carve raster/r.contour raster/r.drain raster/r.flow raster/r.le/r.le.setup raster/r.random raster/r.region raster/r.to.vect raster/simwe/r.sim.sediment raster/simwe/r.sim.water swig/include swig/python vector/lidar/lidarlib vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection vector/lidar/v.lidar.growing vector/lidar/v.outlier vector/lidar/v.surf.bspline vector/v.buffer vector/v.build vector/v.build.polylines vector/v.category vector/v.class vector/v.clean vector/v.clean/test vector/v.convert vector/v.db.connect vector/v.db.select vector/v.delaunay vector/v.distance vector/v.drape vector/v.edit vector/v.external vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.in.ascii vector/v.in.db vector/v.in.dwg vector/v.in.dxf vector/v.in.ogr vector/v.in.region vector/v.in.sites vector/v.info vector/v.kcv vector/v.kernel vector/v.label vector/v.label.sa vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.mkgrid vector/v.neighbors vector/v.net vector/v.net.alloc vector/v.net.iso vector/v.net.path vector/v.net.salesman vector/v.net.steiner vector/v.net.visibility vector/v.normal vector/v.out.ascii vector/v.out.dxf vector/v.out.ogr vector/v.out.pov vector/v.out.svg vector/v.out.vtk vector/v.overlay vector/v.parallel vector/v.patch vector/v.perturb vector/v.proj vector/v.qcount vector/v.random vector/v.reclass vector/v.sample vector/v.segment vector/v.select vector/v.split vector/v.support vector/v.surf.idw vector/v.surf.rst vector/v.to.3d vector/v.to.db vector/v.to.points vector/v.to.rast vector/v.to.rast3 vector/v.transform vector/v.type vector/v.univar vector/v.vol.rst vector/v.voronoi vector/v.what vector/v.what.rast visualization/nviz/src
Mon Jun 22 07:56:35 EDT 2009
Author: martinl
Date: 2009-06-22 07:56:33 -0400 (Mon, 22 Jun 2009)
New Revision: 38026
Added:
   grass/trunk/include/vector.h
Removed:
   grass/trunk/include/Vect.h
   grass/trunk/display/d.extract/extract.c
   grass/trunk/display/d.extract/main.c
   grass/trunk/display/d.path/main.c
   grass/trunk/display/d.path/select.c
   grass/trunk/display/d.thematic.area/area.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.thematic.area/plot1.c
   grass/trunk/display/d.vect.chart/bar.c
   grass/trunk/display/d.vect.chart/main.c
   grass/trunk/display/d.vect.chart/pie.c
   grass/trunk/display/d.vect.chart/plot.c
   grass/trunk/display/d.vect/area.c
   grass/trunk/display/d.vect/attr.c
   grass/trunk/display/d.vect/dir.c
   grass/trunk/display/d.vect/label.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/display/d.vect/plot1.c
   grass/trunk/display/d.vect/topo.c
   grass/trunk/display/d.vect/utils.c
   grass/trunk/display/d.vect/zcoor.c
   grass/trunk/display/d.what.vect/main.c
   grass/trunk/display/d.what.vect/what.c
   grass/trunk/display/d.zoom/main.c
   grass/trunk/doc/vector/v.example/main.c
   grass/trunk/general/g.region/main.c
   grass/trunk/general/manage/lister/vector.c
   grass/trunk/gui/wxpython/vdigit/digit.i
   grass/trunk/gui/wxpython/vdigit/driver.h
   grass/trunk/gui/wxpython/vdigit/setup.py
   grass/trunk/imagery/i.vpoints/drawvect.c
   grass/trunk/imagery/i.vpoints/plot.c
   grass/trunk/imagery/i.vpoints/vectpoints.h
   grass/trunk/include/Make/Grass.make
   grass/trunk/include/V_.h
   grass/trunk/include/vedit.h
   grass/trunk/lib/manage/do_copy.c
   grass/trunk/lib/manage/do_remove.c
   grass/trunk/lib/manage/do_rename.c
   grass/trunk/lib/ogsf/Gp3.c
   grass/trunk/lib/ogsf/Gv3.c
   grass/trunk/lib/rst/interp_float/interpf.h
   grass/trunk/lib/rst/interp_float/point2d.c
   grass/trunk/lib/rst/interp_float/vinput2d.c
   grass/trunk/lib/sites/sites.c
   grass/trunk/lib/vector/Vlib/Makefile
   grass/trunk/lib/vector/Vlib/area.c
   grass/trunk/lib/vector/Vlib/array.c
   grass/trunk/lib/vector/Vlib/box.c
   grass/trunk/lib/vector/Vlib/break_lines.c
   grass/trunk/lib/vector/Vlib/break_polygons.c
   grass/trunk/lib/vector/Vlib/bridges.c
   grass/trunk/lib/vector/Vlib/buffer.c
   grass/trunk/lib/vector/Vlib/buffer2.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/build_nat.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/cats.c
   grass/trunk/lib/vector/Vlib/cindex.c
   grass/trunk/lib/vector/Vlib/clean_nodes.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_nat.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/constraint.c
   grass/trunk/lib/vector/Vlib/dangles.c
   grass/trunk/lib/vector/Vlib/dbcolumns.c
   grass/trunk/lib/vector/Vlib/dgraph.c
   grass/trunk/lib/vector/Vlib/error.c
   grass/trunk/lib/vector/Vlib/field.c
   grass/trunk/lib/vector/Vlib/find.c
   grass/trunk/lib/vector/Vlib/geos.c
   grass/trunk/lib/vector/Vlib/graph.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/Vlib/hist.c
   grass/trunk/lib/vector/Vlib/init_head.c
   grass/trunk/lib/vector/Vlib/intersect.c
   grass/trunk/lib/vector/Vlib/legal_vname.c
   grass/trunk/lib/vector/Vlib/level.c
   grass/trunk/lib/vector/Vlib/level_two.c
   grass/trunk/lib/vector/Vlib/line.c
   grass/trunk/lib/vector/Vlib/list.c
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/merge_lines.c
   grass/trunk/lib/vector/Vlib/net.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/overlap.c
   grass/trunk/lib/vector/Vlib/overlay.c
   grass/trunk/lib/vector/Vlib/poly.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_nat.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/remove_areas.c
   grass/trunk/lib/vector/Vlib/remove_duplicates.c
   grass/trunk/lib/vector/Vlib/rewind.c
   grass/trunk/lib/vector/Vlib/rewind_nat.c
   grass/trunk/lib/vector/Vlib/rewind_ogr.c
   grass/trunk/lib/vector/Vlib/select.c
   grass/trunk/lib/vector/Vlib/sindex.c
   grass/trunk/lib/vector/Vlib/snap.c
   grass/trunk/lib/vector/Vlib/tin.c
   grass/trunk/lib/vector/Vlib/type.c
   grass/trunk/lib/vector/Vlib/window.c
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/diglib/allocation.c
   grass/trunk/lib/vector/diglib/angle.c
   grass/trunk/lib/vector/diglib/box.c
   grass/trunk/lib/vector/diglib/cindex.c
   grass/trunk/lib/vector/diglib/cindex_rw.c
   grass/trunk/lib/vector/diglib/file.c
   grass/trunk/lib/vector/diglib/frmt.c
   grass/trunk/lib/vector/diglib/head.c
   grass/trunk/lib/vector/diglib/inside.c
   grass/trunk/lib/vector/diglib/list.c
   grass/trunk/lib/vector/diglib/plus.c
   grass/trunk/lib/vector/diglib/plus_area.c
   grass/trunk/lib/vector/diglib/plus_line.c
   grass/trunk/lib/vector/diglib/plus_node.c
   grass/trunk/lib/vector/diglib/plus_struct.c
   grass/trunk/lib/vector/diglib/poly.c
   grass/trunk/lib/vector/diglib/port_init.c
   grass/trunk/lib/vector/diglib/port_test.c
   grass/trunk/lib/vector/diglib/portable.c
   grass/trunk/lib/vector/diglib/prune.c
   grass/trunk/lib/vector/diglib/spindex.c
   grass/trunk/lib/vector/diglib/spindex_rw.c
   grass/trunk/lib/vector/diglib/struct_alloc.c
   grass/trunk/lib/vector/diglib/test.c
   grass/trunk/lib/vector/diglib/type.c
   grass/trunk/lib/vector/diglib/update.c
   grass/trunk/ps/ps.map/catval.c
   grass/trunk/ps/ps.map/do_vectors.c
   grass/trunk/ps/ps.map/ps_vareas.c
   grass/trunk/ps/ps.map/ps_vlines.c
   grass/trunk/ps/ps.map/ps_vpoints.c
   grass/trunk/ps/ps.map/r_vareas.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_vpoints.c
   grass/trunk/ps/ps.map/symbol.c
   grass/trunk/ps/ps.map/vect.c
   grass/trunk/raster/r.carve/enforce.h
   grass/trunk/raster/r.contour/cont.c
   grass/trunk/raster/r.contour/main.c
   grass/trunk/raster/r.drain/main.c
   grass/trunk/raster/r.flow/r.flow.h
   grass/trunk/raster/r.le/r.le.setup/sample.c
   grass/trunk/raster/r.random/random.c
   grass/trunk/raster/r.random/support.c
   grass/trunk/raster/r.region/main.c
   grass/trunk/raster/r.to.vect/areas_io.c
   grass/trunk/raster/r.to.vect/lines_io.c
   grass/trunk/raster/r.to.vect/main.c
   grass/trunk/raster/r.to.vect/points.c
   grass/trunk/raster/r.to.vect/util.c
   grass/trunk/raster/simwe/r.sim.sediment/main.c
   grass/trunk/raster/simwe/r.sim.water/main.c
   grass/trunk/swig/include/vector.i
   grass/trunk/swig/python/Makefile
   grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
   grass/trunk/vector/lidar/lidarlib/raster.c
   grass/trunk/vector/lidar/lidarlib/zones.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.h
   grass/trunk/vector/lidar/v.lidar.correction/main.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
   grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
   grass/trunk/vector/lidar/v.lidar.growing/growing.c
   grass/trunk/vector/lidar/v.lidar.growing/growing.h
   grass/trunk/vector/lidar/v.lidar.growing/main.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/lidar/v.outlier/outlier.c
   grass/trunk/vector/lidar/v.outlier/outlier.h
   grass/trunk/vector/lidar/v.surf.bspline/bspline.h
   grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
   grass/trunk/vector/lidar/v.surf.bspline/main.c
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.build.polylines/main.c
   grass/trunk/vector/v.build.polylines/walk.c
   grass/trunk/vector/v.build/main.c
   grass/trunk/vector/v.category/main.c
   grass/trunk/vector/v.class/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.clean/prune.c
   grass/trunk/vector/v.clean/rmdac.c
   grass/trunk/vector/v.clean/rmline.c
   grass/trunk/vector/v.clean/test/topocheck.c
   grass/trunk/vector/v.convert/att.c
   grass/trunk/vector/v.convert/dist.c
   grass/trunk/vector/v.convert/main.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.convert/read.c
   grass/trunk/vector/v.convert/type.c
   grass/trunk/vector/v.db.connect/main.c
   grass/trunk/vector/v.db.select/main.c
   grass/trunk/vector/v.delaunay/defs.h
   grass/trunk/vector/v.delaunay/in_out.c
   grass/trunk/vector/v.delaunay/main.c
   grass/trunk/vector/v.delaunay/memory.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.edit/global.h
   grass/trunk/vector/v.external/main.c
   grass/trunk/vector/v.extract/extract.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/displacement.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.generalize/matrix.h
   grass/trunk/vector/v.generalize/misc.c
   grass/trunk/vector/v.generalize/misc.h
   grass/trunk/vector/v.generalize/network.c
   grass/trunk/vector/v.generalize/point.c
   grass/trunk/vector/v.generalize/point.h
   grass/trunk/vector/v.generalize/pq.h
   grass/trunk/vector/v.generalize/simplification.c
   grass/trunk/vector/v.generalize/smoothing.c
   grass/trunk/vector/v.hull/chull.c
   grass/trunk/vector/v.hull/chull.h
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.in.ascii/a2b.c
   grass/trunk/vector/v.in.ascii/head.c
   grass/trunk/vector/v.in.ascii/main.c
   grass/trunk/vector/v.in.ascii/points.c
   grass/trunk/vector/v.in.db/main.c
   grass/trunk/vector/v.in.dwg/entity.c
   grass/trunk/vector/v.in.dwg/main.c
   grass/trunk/vector/v.in.dxf/global.h
   grass/trunk/vector/v.in.ogr/geom.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.in.region/main.c
   grass/trunk/vector/v.in.sites/main.c
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.kernel/function.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.label.sa/labels.h
   grass/trunk/vector/v.label/main.c
   grass/trunk/vector/v.lrs/v.lrs.create/main.c
   grass/trunk/vector/v.lrs/v.lrs.label/main.c
   grass/trunk/vector/v.lrs/v.lrs.segment/main.c
   grass/trunk/vector/v.lrs/v.lrs.where/main.c
   grass/trunk/vector/v.mkgrid/main.c
   grass/trunk/vector/v.mkgrid/write_grid.c
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/vector/v.net.alloc/main.c
   grass/trunk/vector/v.net.iso/main.c
   grass/trunk/vector/v.net.path/main.c
   grass/trunk/vector/v.net.path/path.c
   grass/trunk/vector/v.net.salesman/main.c
   grass/trunk/vector/v.net.steiner/main.c
   grass/trunk/vector/v.net.visibility/geometry.h
   grass/trunk/vector/v.net.visibility/main.c
   grass/trunk/vector/v.net.visibility/visibility.h
   grass/trunk/vector/v.net/arcs.c
   grass/trunk/vector/v.net/args.c
   grass/trunk/vector/v.net/connect.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.net/nodes.c
   grass/trunk/vector/v.net/report.c
   grass/trunk/vector/v.normal/main.c
   grass/trunk/vector/v.out.ascii/b2a.c
   grass/trunk/vector/v.out.ascii/head.c
   grass/trunk/vector/v.out.ascii/main.c
   grass/trunk/vector/v.out.dxf/main.c
   grass/trunk/vector/v.out.ogr/main.c
   grass/trunk/vector/v.out.pov/main.c
   grass/trunk/vector/v.out.svg/main.c
   grass/trunk/vector/v.out.vtk/head.c
   grass/trunk/vector/v.out.vtk/main.c
   grass/trunk/vector/v.out.vtk/writeVTK.c
   grass/trunk/vector/v.overlay/area_area.c
   grass/trunk/vector/v.overlay/line_area.c
   grass/trunk/vector/v.overlay/main.c
   grass/trunk/vector/v.overlay/util.c
   grass/trunk/vector/v.parallel/main.c
   grass/trunk/vector/v.patch/main.c
   grass/trunk/vector/v.perturb/main.c
   grass/trunk/vector/v.proj/main.c
   grass/trunk/vector/v.qcount/count.c
   grass/trunk/vector/v.qcount/findquads.c
   grass/trunk/vector/v.qcount/indices.c
   grass/trunk/vector/v.qcount/main.c
   grass/trunk/vector/v.random/main.c
   grass/trunk/vector/v.reclass/main.c
   grass/trunk/vector/v.reclass/reclass.c
   grass/trunk/vector/v.sample/main.c
   grass/trunk/vector/v.segment/main.c
   grass/trunk/vector/v.select/args.c
   grass/trunk/vector/v.select/geos.c
   grass/trunk/vector/v.select/main.c
   grass/trunk/vector/v.select/overlap.c
   grass/trunk/vector/v.split/main.c
   grass/trunk/vector/v.support/main.c
   grass/trunk/vector/v.surf.idw/read_sites.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.3d/local_proto.h
   grass/trunk/vector/v.to.3d/main.c
   grass/trunk/vector/v.to.3d/trans2.c
   grass/trunk/vector/v.to.3d/trans3.c
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.points/main.c
   grass/trunk/vector/v.to.rast/do_areas.c
   grass/trunk/vector/v.to.rast/do_lines.c
   grass/trunk/vector/v.to.rast/local.h
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.to.rast/raster.c
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
   grass/trunk/vector/v.to.rast3/main.c
   grass/trunk/vector/v.transform/creat_trans.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.transform/trans_digit.c
   grass/trunk/vector/v.type/main.c
   grass/trunk/vector/v.univar/main.c
   grass/trunk/vector/v.vol.rst/main.c
   grass/trunk/vector/v.vol.rst/user1.c
   grass/trunk/vector/v.vol.rst/user3.c
   grass/trunk/vector/v.vol.rst/userglobs.h
   grass/trunk/vector/v.vol.rst/vector.c
   grass/trunk/vector/v.voronoi/dt_write.c
   grass/trunk/vector/v.voronoi/main.c
   grass/trunk/vector/v.voronoi/sw_main.c
   grass/trunk/vector/v.voronoi/sw_output.c
   grass/trunk/vector/v.voronoi/vo_extend.c
   grass/trunk/vector/v.voronoi/vo_write.c
   grass/trunk/vector/v.what.rast/main.c
   grass/trunk/vector/v.what/main.c
   grass/trunk/vector/v.what/what.c
   grass/trunk/visualization/nviz/src/pg.h
   grass/trunk/visualization/nviz/src/pick_vect_commands.c
   grass/trunk/visualization/nviz/src/query_vect.c
   grass/trunk/visualization/nviz/src/site_attr_commands.c
Vect.h renamed to vector.h
grass_vect -> grass_vector
Modified: grass/trunk/display/d.extract/extract.c
--- grass/trunk/display/d.extract/extract.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.extract/extract.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -5,7 +5,7 @@
 #include <grass/gis.h>
 #include <grass/display.h>
 #include <grass/colors.h>
-#include <grass/Vect.h>
+#include <grass/vector.h>
 #include <grass/glocale.h>
 #define WDTH 5
Modified: grass/trunk/display/d.extract/main.c
--- grass/trunk/display/d.extract/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.extract/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <grass/dbmi.h>
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.path/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <grass/raster.h>
 #include "proto.h"
Modified: grass/trunk/display/d.path/select.c
--- grass/trunk/display/d.path/select.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.path/select.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <math.h>
 #include "proto.h"
Modified: grass/trunk/display/d.thematic.area/area.c
--- grass/trunk/display/d.thematic.area/area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.thematic.area/area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <string.h>
 #include <stdlib.h>
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.thematic.area/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
Modified: grass/trunk/display/d.thematic.area/plot1.c
--- grass/trunk/display/d.thematic.area/plot1.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.thematic.area/plot1.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <string.h>
 #include "plot.h"
 #include "local_proto.h"
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -5,7 +5,7 @@
 #include <string.h>
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/attr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <string.h>
Modified: grass/trunk/display/d.vect/dir.c
--- grass/trunk/display/d.vect/dir.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/dir.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 #include "plot.h"
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/label.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <grass/symbol.h>
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/plot1.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <string.h>
 #include "plot.h"
Modified: grass/trunk/display/d.vect/topo.c
--- grass/trunk/display/d.vect/topo.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/topo.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/utils.c
--- grass/trunk/display/d.vect/utils.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/utils.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/zcoor.c
--- grass/trunk/display/d.vect/zcoor.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect/zcoor.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 /* Print z coordinate value for each node */
 #include "plot.h"
Modified: grass/trunk/display/d.vect.chart/bar.c
--- grass/trunk/display/d.vect.chart/bar.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect.chart/bar.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect.chart/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
Modified: grass/trunk/display/d.vect.chart/pie.c
--- grass/trunk/display/d.vect.chart/pie.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect.chart/pie.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <math.h>
Modified: grass/trunk/display/d.vect.chart/plot.c
--- grass/trunk/display/d.vect.chart/plot.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.vect.chart/plot.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.what.vect/main.c
--- grass/trunk/display/d.what.vect/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.what.vect/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -29,7 +29,7 @@
 #include "what.h"
Modified: grass/trunk/display/d.what.vect/what.c
--- grass/trunk/display/d.what.vect/what.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.what.vect/what.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <grass/form.h>
 #include "what.h"
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/display/d.zoom/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -24,7 +24,7 @@
 #include <string.h>
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/doc/vector/v.example/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdio.h>
 #include <stdlib.h>
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/general/g.region/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <grass/G3d.h>
Modified: grass/trunk/general/manage/lister/vector.c
--- grass/trunk/general/manage/lister/vector.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/general/manage/lister/vector.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 int main(int argc, char *argv[])
Modified: grass/trunk/gui/wxpython/vdigit/digit.i
--- grass/trunk/gui/wxpython/vdigit/digit.i	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/gui/wxpython/vdigit/digit.i	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <grass/gisdefs.h>
 #include <grass/vect/dig_structs.h>
 #include "driver.h"
 #include "digit.h"
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -28,7 +28,7 @@
 extern "C" {
 class DisplayDriver
Modified: grass/trunk/gui/wxpython/vdigit/setup.py
--- grass/trunk/gui/wxpython/vdigit/setup.py	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/gui/wxpython/vdigit/setup.py	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 	    os.path.join(os.path.normpath(os.getenv('GISBASE')), 'lib')]
 libs = ['grass_dbmibase',
         'grass_dbmiclient',
-        'grass_vect',
+        'grass_vector',
         'grass_gis',
         'grass_vedit']
 extras = []
Modified: grass/trunk/imagery/i.vpoints/drawvect.c
--- grass/trunk/imagery/i.vpoints/drawvect.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/imagery/i.vpoints/drawvect.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <string.h>
 #include "vectpoints.h"
 #include "globals.h"
 #define VFILES 12
Modified: grass/trunk/imagery/i.vpoints/plot.c
--- grass/trunk/imagery/i.vpoints/plot.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/imagery/i.vpoints/plot.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <unistd.h>
Modified: grass/trunk/imagery/i.vpoints/vectpoints.h
--- grass/trunk/imagery/i.vpoints/vectpoints.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/imagery/i.vpoints/vectpoints.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
 /* plot.c */
 int plot(char *, char *, struct line_pnts *);
 int plot_warp(char *, char *, struct line_pnts *, double[], double[], int);
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/include/Make/Grass.make	2009-06-22 11:56:33 UTC (rev 38026)
@@ -146,7 +146,7 @@
 # Vector
 DIG_LIBNAME           = grass_dig
 DIG2_LIBNAME          = grass_dig2
-VECTR_LIBNAME         = grass_vect
+VECTOR_LIBNAME        = grass_vector
 TRANS_LIBNAME         = grass_trans
 SHAPE_LIBNAME         = grass_shape
@@ -251,22 +251,22 @@
 # Vector
 DIGLIB        = -l$(DIG_LIBNAME)
 DIG2LIB       = -l$(DIG2_LIBNAME) $(GISLIB) $(RTREELIB)
-VECTRLIB      = -l$(VECTR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GRAPHLIB) $(DIG2LIB) $(GISLIB) $(LINKMLIB) $(RTREELIB)
+VECTORLIB      = -l$(VECTOR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GRAPHLIB) $(DIG2LIB) $(GISLIB) $(LINKMLIB) $(RTREELIB)
 TRANSLIB      = -l$(TRANS_LIBNAME)
 SHAPELIB      = -l$(SHAPE_LIBNAME)
 GRAPHLIB      = -l$(GRAPH_LIBNAME)
 RTREELIB      = -l$(RTREE_LIBNAME)
-VEDITLIB      = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTRLIB)
-VECTLIB       = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS) $(GEOSLIBS)
+VEDITLIB      = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTORLIB)
+VECTLIB       = $(VECTORLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS) $(GEOSLIBS)
 # Interpolation
 INTERPDATALIB = -l$(INTERPDATA_LIBNAME)
-INTERPFLLIB   = -l$(INTERPFL_LIBNAME) $(BITMAPLIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(INTERPDATALIB) $(QTREELIB) $(VECTRLIB)
+INTERPFLLIB   = -l$(INTERPFL_LIBNAME) $(BITMAPLIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(INTERPDATALIB) $(QTREELIB) $(VECTORLIB)
 QTREELIB      = -l$(QTREE_LIBNAME)
 # NVIZ related
-OGSFLIB       = -l$(OGSF_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(SITESLIB) $(VECTRLIB)
-NVIZLIB       = -l$(NVIZ_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(VECTRLIB)
+OGSFLIB       = -l$(OGSF_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(SITESLIB) $(VECTORLIB)
+NVIZLIB       = -l$(NVIZ_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(VECTORLIB)
 # triangulation libraries
 SOSLIB        = -l$(SOS_LIBNAME)
@@ -284,13 +284,13 @@
 CDHCLIB       = -l$(CDHC_LIBNAME)
 # Lidar
-LIDARLIB      = -l$(LIDAR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(VECTRLIB)
+LIDARLIB      = -l$(LIDAR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(VECTORLIB)
 # Raster/SIMWE
 SIMLIB        = -l$(SIM_LIBNAME) $(GISLIB) $(SITESLIB)
 # Sites (legacy)
-SITESLIB      = -l$(SITES_LIBNAME) $(DATETIMELIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(VECTRLIB)
+SITESLIB      = -l$(SITES_LIBNAME) $(DATETIMELIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(VECTORLIB)
 # LRS
 LRSLIB        = -l$(LRS_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB)
@@ -347,13 +347,13 @@
 # Vector
 DIGDEP      = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DIG_LIBNAME)$(LIB_SUFFIX)
 DIG2DEP     = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DIG2_LIBNAME)$(LIB_SUFFIX)
-VECTRDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(VECTR_LIBNAME)$(LIB_SUFFIX)
+VECTORDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(VECTOR_LIBNAME)$(LIB_SUFFIX)
 TRANSDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(TRANS_LIBNAME)$(LIB_SUFFIX)
 SHAPEDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(SHAPE_LIBNAME)$(LIB_SUFFIX)
 GRAPHDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(GRAPH_LIBNAME)$(LIB_SUFFIX)
 RTREEDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(RTREE_LIBNAME)$(LIB_SUFFIX)
 VEDITDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(VEDIT_LIBNAME)$(LIB_SUFFIX)
-VECTDEP     = $(VECTRDEP) $(DIG2DEP) $(GRAPHDEP) $(RTREEDEP) $(LINKMDEP) $(DBMIDEP)
+VECTDEP     = $(VECTORDEP) $(DIG2DEP) $(GRAPHDEP) $(RTREEDEP) $(LINKMDEP) $(DBMIDEP)
 # Interpolation
 INTERPDATADEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(INTERPDATA_LIBNAME)$(LIB_SUFFIX)
Modified: grass/trunk/include/V_.h
--- grass/trunk/include/V_.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/include/V_.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #ifndef _STDIO_H
 #include "stdio.h"
 #endif
 #define MODE_READ  0
Deleted: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/include/Vect.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,481 +0,0 @@
-#ifndef GRASS_VECT_H
-#define GRASS_VECT_H
-#include <grass/gis.h>
-#include <grass/vect/digit.h>
-#ifdef HAVE_GEOS
-#include <geos_c.h>
-#endif
-/* --- ANSI prototypes for the lib/vector/Vlib functions --- */
- * "Public" functions, for use in modules
-/* Points (line) */
-struct line_pnts *Vect_new_line_struct(void);
-int Vect_append_point(struct line_pnts *, double, double, double);
-int Vect_append_points(struct line_pnts *, const struct line_pnts *, int);
-int Vect_line_insert_point(struct line_pnts *, int, double, double, double);
-int Vect_line_delete_point(struct line_pnts *, int);
-int Vect_line_prune(struct line_pnts *);
-int Vect_line_prune_thresh(struct line_pnts *, double);
-void Vect_line_reverse(struct line_pnts *);
-int Vect_copy_xyz_to_pnts(struct line_pnts *, const double *, const double *, const double *,
-			  int);
-int Vect_copy_pnts_to_xyz(const struct line_pnts *, double *, double *, double *,
-			  int *);
-int Vect_reset_line(struct line_pnts *);
-int Vect_destroy_line_struct(struct line_pnts *);
-int Vect_point_on_line(const struct line_pnts *, double, double *, double *,
-		       double *, double *, double *);
-int Vect_line_segment(const struct line_pnts *, double, double, struct line_pnts *);
-double Vect_line_length(const struct line_pnts *);
-double Vect_area_perimeter(const struct line_pnts *);
-double Vect_line_geodesic_length(const struct line_pnts *);
-int Vect_line_distance(const struct line_pnts *, double, double, double, int,
-		       double *, double *, double *, double *, double *,
-		       double *);
-int Vect_line_box(const struct line_pnts *, BOUND_BOX *);
-void Vect_line_parallel(struct line_pnts *, double, double, int,
-			struct line_pnts *);
-void Vect_line_parallel2(struct line_pnts *, double, double,
-			 double, int, int, double,
-void Vect_line_buffer(const struct line_pnts *, double, double, struct line_pnts *);
-void Vect_line_buffer2(const struct line_pnts *, double, double,
-		       struct line_pnts **,
-		       struct line_pnts ***, int *);
-void Vect_area_buffer2(const struct Map_info *, int, double, double,
-void Vect_point_buffer2(double, double, double, double,
-			double, int, double,
-			struct line_pnts **);
-/* Categories */
-struct line_cats *Vect_new_cats_struct(void);
-int Vect_cat_set(struct line_cats *, int, int);
-int Vect_cat_get(const struct line_cats *, int, int *);
-int Vect_cat_del(struct line_cats *, int);
-int Vect_field_cat_del(struct line_cats *, int, int);
-int Vect_field_cat_get(const struct line_cats *, int, struct ilist *);
-int Vect_cat_in_array(int, const int *, int);
-int Vect_reset_cats(struct line_cats *);
-int Vect_destroy_cats_struct(struct line_cats *);
-int Vect_get_area_cats(const struct Map_info *, int, struct line_cats *);
-int Vect_get_area_cat(const struct Map_info *, int, int);
-int Vect_get_line_cat(const struct Map_info *, int, int);
-/* List of categories */
-struct cat_list *Vect_new_cat_list(void);
-int Vect_str_to_cat_list(const char *, struct cat_list *);
-int Vect_array_to_cat_list(const int *, int, struct cat_list *);
-int Vect_cat_in_cat_list(int, const struct cat_list *);
-int Vect_destroy_cat_list(struct cat_list *);
-/* Vector array */
-VARRAY *Vect_new_varray(int);
-int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
-				    int, VARRAY *);
-int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
-				  int, int, VARRAY *);
-int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
-			    VARRAY *);
-/* DB connection - field info */
-struct dblinks *Vect_new_dblinks_struct(void);
-void Vect_reset_dblinks(struct dblinks *);
-int Vect_add_dblink(struct dblinks *, int, const char *,
-		    const char *, const char *, const char *, const char *);
-int Vect_check_dblink(const struct dblinks *, int);
-int Vect_map_add_dblink(struct Map_info *, int, const char *,
-			const char *);
-int Vect_map_del_dblink(struct Map_info *, int);
-int Vect_map_check_dblink(const struct Map_info *, int);
-int Vect_read_dblinks(struct Map_info *);
-int Vect_write_dblinks(struct Map_info *);
-struct field_info *Vect_default_field_info(struct Map_info *, int,
-					   const char *, int);
-struct field_info *Vect_get_dblink(const struct Map_info *, int);
-struct field_info *Vect_get_field(const struct Map_info *, int);
-void Vect_set_db_updated(struct Map_info *);
-const char *Vect_get_column_names(const struct Map_info *, int);
-const char *Vect_get_column_types(const struct Map_info *, int);
-const char *Vect_get_column_names_types(const struct Map_info *, int);
-/* List of FID (feature ID) (integers) */
-struct ilist *Vect_new_list(void);
-int Vect_list_append(struct ilist *, int);
-int Vect_list_append_list(struct ilist *, const struct ilist *);
-int Vect_list_delete(struct ilist *, int);
-int Vect_list_delete_list(struct ilist *, const struct ilist *);
-int Vect_val_in_list(const struct ilist *, int);
-int Vect_reset_list(struct ilist *);
-int Vect_destroy_list(struct ilist *);
-/* Bounding box (MBR) */
-int Vect_point_in_box(double, double, double, const BOUND_BOX *);
-int Vect_box_overlap(const BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_copy(BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_extend(BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_clip(double *, double *, double *, double *, const BOUND_BOX *);
-int Vect_region_box(const struct Cell_head *, BOUND_BOX *);
-/* Spatial index */
-void Vect_spatial_index_init(SPATIAL_INDEX *);
-void Vect_spatial_index_destroy(SPATIAL_INDEX *);
-void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
-void Vect_spatial_index_del_item(SPATIAL_INDEX *, int);
-int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
-/* Category index */
-int Vect_cidx_get_num_fields(const struct Map_info *);
-int Vect_cidx_get_field_number(const struct Map_info *, int);
-int Vect_cidx_get_field_index(const struct Map_info *, int);
-int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *, int);
-int Vect_cidx_get_num_cats_by_index(const struct Map_info *, int);
-int Vect_cidx_get_num_types_by_index(const struct Map_info *, int);
-int Vect_cidx_get_type_count_by_index(const struct Map_info *, int, int, int *,
-				      int *);
-int Vect_cidx_get_type_count(const struct Map_info *, int, int);
-int Vect_cidx_get_cat_by_index(const struct Map_info *, int, int, int *, int *,
-			       int *);
-int Vect_cidx_find_next(const struct Map_info *, int, int, int, int, int *, int *);
-void Vect_cidx_find_all(const struct Map_info *, int, int, int, struct ilist *);
-int Vect_cidx_dump(const struct Map_info *, FILE *);
-int Vect_cidx_save(struct Map_info *);
-int Vect_cidx_open(struct Map_info *, int);
-/* Set/get map header info */
-int Vect_read_header(struct Map_info *);
-int Vect_write_header(const struct Map_info *);
-const char *Vect_get_name(const struct Map_info *);
-const char *Vect_get_mapset(const struct Map_info *);
-const char *Vect_get_full_name(const struct Map_info *);
-int Vect_is_3d(const struct Map_info *);
-int Vect_set_organization(struct Map_info *, const char *);
-const char *Vect_get_organization(const struct Map_info *);
-int Vect_set_date(struct Map_info *, const char *);
-const char *Vect_get_date(const struct Map_info *);
-int Vect_set_person(struct Map_info *, const char *);
-const char *Vect_get_person(const struct Map_info *);
-int Vect_set_map_name(struct Map_info *, const char *);
-const char *Vect_get_map_name(const struct Map_info *);
-int Vect_set_map_date(struct Map_info *, const char *);
-const char *Vect_get_map_date(const struct Map_info *);
-int Vect_set_comment(struct Map_info *, const char *);
-const char *Vect_get_comment(const struct Map_info *);
-int Vect_set_scale(struct Map_info *, int);
-int Vect_get_scale(const struct Map_info *);
-int Vect_set_zone(struct Map_info *, int);
-int Vect_get_zone(const struct Map_info *);
-int Vect_get_proj(const struct Map_info *);
-const char *Vect_get_proj_name(const struct Map_info *);
-int Vect_set_thresh(struct Map_info *, double);
-double Vect_get_thresh(const struct Map_info *);
-int Vect_get_constraint_box(const struct Map_info *, BOUND_BOX *);
-/* Get map level 2 informations */
-int Vect_level(const struct Map_info *);
-int Vect_get_num_nodes(const struct Map_info *);
-int Vect_get_num_primitives(const struct Map_info *, int);
-int Vect_get_num_lines(const struct Map_info *);
-int Vect_get_num_areas(const struct Map_info *);
-int Vect_get_num_faces(const struct Map_info *);
-int Vect_get_num_islands(const struct Map_info *);
-int Vect_get_line_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_area_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_isle_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_map_box(const struct Map_info *, BOUND_BOX *);
-int V__map_overlap(struct Map_info *, double, double, double, double);
-void Vect_set_release_support(struct Map_info *);
-void Vect_set_category_index_update(struct Map_info *);
-/* Set/get fatal error behaviour */
-int Vect_set_fatal_error(int);
-int Vect_get_fatal_error();
-/* Open/close/rewind/set_constraints for map */
-int Vect_check_input_output_name(const char *, const char *, int);
-int Vect_legal_filename(const char *);
-int Vect_set_open_level(int);
-int Vect_open_old(struct Map_info *, const char *, const char *);
-int Vect_open_old_head(struct Map_info *, const char *, const char *);
-int Vect_open_new(struct Map_info *, const char *, int);
-int Vect_open_update(struct Map_info *, const char *, const char *);
-int Vect_open_update_head(struct Map_info *, const char *, const char *);
-int Vect_copy_head_data(const struct Map_info *, struct Map_info *);
-int Vect_build(struct Map_info *);
-int Vect_get_built(const struct Map_info *);
-int Vect_build_partial(struct Map_info *, int);
-int Vect_set_constraint_region(struct Map_info *, double, double, double,
-			       double, double, double);
-int Vect_set_constraint_type(struct Map_info *, int);
-int Vect_remove_constraints(struct Map_info *);
-int Vect_rewind(struct Map_info *);
-int Vect_close(struct Map_info *);
-/* Read/write lines, nodes, areas */
-/* Level 1 and 2 */
-int Vect_read_next_line(const struct Map_info *, struct line_pnts *,
-			struct line_cats *);
-off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
-		      const struct line_cats *);
-int Vect_get_num_dblinks(const struct Map_info *);
-/* Level 2 only */
-int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
-		   int);
-int Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
-int Vect_delete_line(struct Map_info *, int);
-int Vect_restore_line(struct Map_info *, int, off_t);
-int Vect_line_alive(const struct Map_info *, int);
-int Vect_node_alive(const struct Map_info *, int);
-int Vect_area_alive(const struct Map_info *, int);
-int Vect_isle_alive(const struct Map_info *, int);
-int Vect_get_line_nodes(const struct Map_info *, int, int *, int *);
-int Vect_get_line_areas(const struct Map_info *, int, int *, int *);
-off_t Vect_get_line_offset(const struct Map_info *, int);
-int Vect_get_node_coor(const struct Map_info *, int, double *, double *, double *);
-int Vect_get_node_n_lines(const struct Map_info *, int);
-int Vect_get_node_line(const struct Map_info *, int, int);
-float Vect_get_node_line_angle(const struct Map_info *, int, int);
-int Vect_get_area_points(const struct Map_info *, int, struct line_pnts *);
-int Vect_get_area_centroid(const struct Map_info *, int);
-int Vect_get_area_num_isles(const struct Map_info *, int);
-int Vect_get_area_isle(const struct Map_info *, int, int);
-double Vect_get_area_area(const struct Map_info *, int);
-int Vect_get_area_boundaries(const struct Map_info *, int, struct ilist *);
-int Vect_get_isle_points(const struct Map_info *, int, struct line_pnts *);
-int Vect_get_isle_area(const struct Map_info *, int);
-int Vect_get_isle_boundaries(const struct Map_info *, int, struct ilist *);
-int Vect_get_centroid_area(const struct Map_info *, int);
-/* Level 2 update only */
-int Vect_get_num_updated_lines(const struct Map_info *);
-int Vect_get_updated_line(const struct Map_info *, int);
-int Vect_get_num_updated_nodes(const struct Map_info *);
-int Vect_get_updated_node(const struct Map_info *, int);
-/* History */
-int Vect_hist_command(struct Map_info *);
-int Vect_hist_write(struct Map_info *, const char *);
-int Vect_hist_copy(const struct Map_info *, struct Map_info *);
-void Vect_hist_rewind(struct Map_info *);
-char *Vect_hist_read(char *, int, const struct Map_info *);
-/* Selecting features */
-int Vect_select_lines_by_box(struct Map_info *, const BOUND_BOX *, int,
-			     struct ilist *);
-int Vect_select_areas_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
-int Vect_select_isles_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
-int Vect_select_nodes_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
-int Vect_find_node(struct Map_info *, double, double, double, double, int);
-int Vect_find_line(struct Map_info *, double, double, double, int, double,
-		   int, int);
-int Vect_find_line_list(struct Map_info *, double, double, double, int,
-			double, int, const struct ilist *, struct ilist *);
-int Vect_find_area(struct Map_info *, double, double);
-int Vect_find_island(struct Map_info *, double, double);
-int Vect_select_lines_by_polygon(struct Map_info *, struct line_pnts *, int,
-				 struct line_pnts **, int, struct ilist *);
-int Vect_select_areas_by_polygon(struct Map_info *, struct line_pnts *, int,
-				 struct line_pnts **, struct ilist *);
-/* Analysis */
-int Vect_point_in_area(const struct Map_info *, int, double, double);
-int Vect_tin_get_z(struct Map_info *, double, double, double *, double *,
-		   double *);
-int Vect_get_point_in_area(const struct Map_info *, int, double *, double *);
-/* int Vect_point_in_islands (struct Map_info *, int, double, double); */
-int Vect_find_poly_centroid(const struct line_pnts *, double *, double *);
-int Vect_get_point_in_poly_isl(const struct line_pnts *, const struct line_pnts **, int,
-			       double *, double *);
-int Vect__intersect_line_with_poly(const struct line_pnts *, double,
-int Vect_get_point_in_poly(const struct line_pnts *, double *, double *);
-int Vect_point_in_poly(double, double, const struct line_pnts *);
-int Vect_point_in_area_outer_ring(double, double, const struct Map_info *, int);
-int Vect_point_in_island(double, double, const struct Map_info *, int);
-/* Cleaning */
-void Vect_break_lines(struct Map_info *, int, struct Map_info *);
-int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
-			  int, struct Map_info *);
-int Vect_merge_lines(struct Map_info *, int, int *, struct Map_info *);
-void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
-void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
-int Vect_line_check_duplicate(const struct line_pnts *,
-			      const struct line_pnts *, int);
-void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
-void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
-			  struct Map_info *);
-void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
-void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
-void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
-void Vect_remove_bridges(struct Map_info *, struct Map_info *);
-void Vect_chtype_bridges(struct Map_info *, struct Map_info *);
-int Vect_remove_small_areas(struct Map_info *, double, struct Map_info *,
-			    double *);
-int Vect_clean_small_angles_at_nodes(struct Map_info *, int,
-/* Overlay */
-int Vect_overlay_str_to_operator(const char *);
-int Vect_overlay(struct Map_info *, int, struct ilist *, struct ilist *,
-		 struct Map_info *, int, struct ilist *, struct ilist *,
-int Vect_overlay_and(struct Map_info *, int, struct ilist *,
-		     struct ilist *, struct Map_info *, int,
-		     struct ilist *, struct ilist *, struct Map_info *);
-/* Graph */
-void Vect_graph_init(GRAPH *, int);
-void Vect_graph_build(GRAPH *);
-void Vect_graph_add_edge(GRAPH *, int, int, double, int);
-void Vect_graph_set_node_costs(GRAPH *, int, double);
-int Vect_graph_shortest_path(GRAPH *, int, int, struct ilist *, double *);
-/* Network (graph) */
-int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
-			 const char *, const char *, int, int);
-int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
-			   double *);
-int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
-int Vect_net_get_node_cost(const struct Map_info *, int, double *);
-int Vect_net_nearest_nodes(struct Map_info *, double, double, double, int,
-			   double, int *, int *, int *, double *, double *,
-			   struct line_pnts *, struct line_pnts *, double *);
-int Vect_net_shortest_path_coor(struct Map_info *, double, double, double,
-				double, double, double, double, double,
-				double *, struct line_pnts *, struct ilist *,
-/* Miscellaneous */
-int Vect_topo_dump(const struct Map_info *, FILE *);
-double Vect_points_distance(double, double, double, double, double, double,
-			    int);
-int Vect_option_to_types(const struct Option *);
-int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
-int Vect_copy(const char *, const char *, const char *);
-int Vect_rename(const char *, const char *);
-int Vect_copy_table(const struct Map_info *, struct Map_info *, int, int,
-int Vect_copy_table_by_cats(const struct Map_info *, struct Map_info *, int, int,
-			    const char *, int, int *, int);
-int Vect_copy_tables(const struct Map_info *, struct Map_info *, int);
-int Vect_delete(const char *);
-int Vect_segment_intersection(double, double, double, double, double, double,
-			      double, double, double, double, double, double,
-			      double *, double *, int);
-int Vect_line_intersection(struct line_pnts *, struct line_pnts *,
-			   struct line_pnts ***, struct line_pnts ***, int *,
-			   int *, int);
-int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
-int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
-				struct line_pnts *, int);
-char *Vect_subst_var(const char *, const struct Map_info *);
- * Internal functions, MUST NOT be used in modules
-int Vect_print_header(const struct Map_info *);
-int Vect__init_head(struct Map_info *);
-/* Open/close/rewind map */
-int Vect_coor_info(const struct Map_info *, struct Coor_info *);
-const char *Vect_maptype_info(const struct Map_info *);
-int Vect_open_topo(struct Map_info *, int);
-int Vect_save_topo(struct Map_info *);
-int Vect_open_spatial_index(struct Map_info *);
-int Vect_save_spatial_index(struct Map_info *);
-int Vect_spatial_index_dump(struct Map_info *, FILE *);
-int Vect_build_sidx_from_topo(struct Map_info *);
-int Vect_build_spatial_index(struct Map_info *);
-int Vect__write_head(const struct Map_info *);
-int Vect__read_head(struct Map_info *);
-int V1_open_old_nat(struct Map_info *, int);
-int V1_open_old_ogr(struct Map_info *, int);
-int V2_open_old_ogr(struct Map_info *);
-int V1_open_new_nat(struct Map_info *, const char *, int);
-int V1_rewind_nat(struct Map_info *);
-int V1_rewind_ogr(struct Map_info *);
-int V2_rewind_nat(struct Map_info *);
-int V2_rewind_ogr(struct Map_info *);
-int V1_close_nat(struct Map_info *);
-int V1_close_ogr(struct Map_info *);
-int V2_close_ogr(struct Map_info *);
-/* Read/write lines */
-int V1_read_line_nat(struct Map_info *, struct line_pnts *,
-		     struct line_cats *, off_t);
-int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
-int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
-int V2_read_line_nat(struct Map_info *, struct line_pnts *,
-		     struct line_cats *, int);
-int V2_read_line_ogr(struct Map_info *, struct line_pnts *,
-int V2_read_next_line_nat(struct Map_info *, struct line_pnts *,
-int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
-int V1_delete_line_nat(struct Map_info *, off_t);
-int V2_delete_line_nat(struct Map_info *, int);
-int V1_restore_line_nat(struct Map_info *, off_t);
-int V2_restore_line_nat(struct Map_info *, int, off_t);
-off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
-off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
-#if 0
-long V1_write_line_ogr(struct Map_info *, int, struct line_pnts *,
-#endif
-off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
-			  const struct line_pnts *, const struct line_cats *);
-int V2_rewrite_line_nat(struct Map_info *, int, int,
-#if 0
-long V1_rewrite_line_ogr(struct Map_info *, long offset, int type,
-			 struct line_pnts *, struct line_cats *);
-#endif
-    /* Miscellaneous */
-int Vect_build_nat(struct Map_info *, int);
-int Vect_build_ogr(struct Map_info *, int);
-int Vect_build_line_area(struct Map_info *, int, int);
-int Vect_isle_find_area(struct Map_info *, int);
-int Vect_attach_isle(struct Map_info *, int);
-int Vect_attach_isles(struct Map_info *, const BOUND_BOX *);
-int Vect_attach_centroids(struct Map_info *, const BOUND_BOX *);
-    /* GEOS support */
-#ifdef HAVE_GEOS
-GEOSGeometry *Vect_read_line_geos(struct Map_info *, int, int*);
-GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
-GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
-GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
-GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
-#endif
-#endif /* GRASS_VECT_H */
Copied: grass/trunk/include/vector.h (from rev 38019, grass/trunk/include/Vect.h)
--- grass/trunk/include/vector.h	                        (rev 0)
+++ grass/trunk/include/vector.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -0,0 +1,481 @@
+#ifndef GRASS_VECT_H
+#define GRASS_VECT_H
+#include <grass/gis.h>
+#include <grass/vect/digit.h>
+#ifdef HAVE_GEOS
+#include <geos_c.h>
+#endif
+/* --- ANSI prototypes for the lib/vector/Vlib functions --- */
+ * "Public" functions, for use in modules
+/* Points (line) */
+struct line_pnts *Vect_new_line_struct(void);
+int Vect_append_point(struct line_pnts *, double, double, double);
+int Vect_append_points(struct line_pnts *, const struct line_pnts *, int);
+int Vect_line_insert_point(struct line_pnts *, int, double, double, double);
+int Vect_line_delete_point(struct line_pnts *, int);
+int Vect_line_prune(struct line_pnts *);
+int Vect_line_prune_thresh(struct line_pnts *, double);
+void Vect_line_reverse(struct line_pnts *);
+int Vect_copy_xyz_to_pnts(struct line_pnts *, const double *, const double *, const double *,
+			  int);
+int Vect_copy_pnts_to_xyz(const struct line_pnts *, double *, double *, double *,
+			  int *);
+int Vect_reset_line(struct line_pnts *);
+int Vect_destroy_line_struct(struct line_pnts *);
+int Vect_point_on_line(const struct line_pnts *, double, double *, double *,
+		       double *, double *, double *);
+int Vect_line_segment(const struct line_pnts *, double, double, struct line_pnts *);
+double Vect_line_length(const struct line_pnts *);
+double Vect_area_perimeter(const struct line_pnts *);
+double Vect_line_geodesic_length(const struct line_pnts *);
+int Vect_line_distance(const struct line_pnts *, double, double, double, int,
+		       double *, double *, double *, double *, double *,
+		       double *);
+int Vect_line_box(const struct line_pnts *, BOUND_BOX *);
+void Vect_line_parallel(struct line_pnts *, double, double, int,
+			struct line_pnts *);
+void Vect_line_parallel2(struct line_pnts *, double, double,
+			 double, int, int, double,
+void Vect_line_buffer(const struct line_pnts *, double, double, struct line_pnts *);
+void Vect_line_buffer2(const struct line_pnts *, double, double,
+		       struct line_pnts **,
+		       struct line_pnts ***, int *);
+void Vect_area_buffer2(const struct Map_info *, int, double, double,
+void Vect_point_buffer2(double, double, double, double,
+			double, int, double,
+			struct line_pnts **);
+/* Categories */
+struct line_cats *Vect_new_cats_struct(void);
+int Vect_cat_set(struct line_cats *, int, int);
+int Vect_cat_get(const struct line_cats *, int, int *);
+int Vect_cat_del(struct line_cats *, int);
+int Vect_field_cat_del(struct line_cats *, int, int);
+int Vect_field_cat_get(const struct line_cats *, int, struct ilist *);
+int Vect_cat_in_array(int, const int *, int);
+int Vect_reset_cats(struct line_cats *);
+int Vect_destroy_cats_struct(struct line_cats *);
+int Vect_get_area_cats(const struct Map_info *, int, struct line_cats *);
+int Vect_get_area_cat(const struct Map_info *, int, int);
+int Vect_get_line_cat(const struct Map_info *, int, int);
+/* List of categories */
+struct cat_list *Vect_new_cat_list(void);
+int Vect_str_to_cat_list(const char *, struct cat_list *);
+int Vect_array_to_cat_list(const int *, int, struct cat_list *);
+int Vect_cat_in_cat_list(int, const struct cat_list *);
+int Vect_destroy_cat_list(struct cat_list *);
+/* Vector array */
+VARRAY *Vect_new_varray(int);
+int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
+				    int, VARRAY *);
+int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
+				  int, int, VARRAY *);
+int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
+			    VARRAY *);
+/* DB connection - field info */
+struct dblinks *Vect_new_dblinks_struct(void);
+void Vect_reset_dblinks(struct dblinks *);
+int Vect_add_dblink(struct dblinks *, int, const char *,
+		    const char *, const char *, const char *, const char *);
+int Vect_check_dblink(const struct dblinks *, int);
+int Vect_map_add_dblink(struct Map_info *, int, const char *,
+			const char *);
+int Vect_map_del_dblink(struct Map_info *, int);
+int Vect_map_check_dblink(const struct Map_info *, int);
+int Vect_read_dblinks(struct Map_info *);
+int Vect_write_dblinks(struct Map_info *);
+struct field_info *Vect_default_field_info(struct Map_info *, int,
+					   const char *, int);
+struct field_info *Vect_get_dblink(const struct Map_info *, int);
+struct field_info *Vect_get_field(const struct Map_info *, int);
+void Vect_set_db_updated(struct Map_info *);
+const char *Vect_get_column_names(const struct Map_info *, int);
+const char *Vect_get_column_types(const struct Map_info *, int);
+const char *Vect_get_column_names_types(const struct Map_info *, int);
+/* List of FID (feature ID) (integers) */
+struct ilist *Vect_new_list(void);
+int Vect_list_append(struct ilist *, int);
+int Vect_list_append_list(struct ilist *, const struct ilist *);
+int Vect_list_delete(struct ilist *, int);
+int Vect_list_delete_list(struct ilist *, const struct ilist *);
+int Vect_val_in_list(const struct ilist *, int);
+int Vect_reset_list(struct ilist *);
+int Vect_destroy_list(struct ilist *);
+/* Bounding box (MBR) */
+int Vect_point_in_box(double, double, double, const BOUND_BOX *);
+int Vect_box_overlap(const BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_copy(BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_extend(BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_clip(double *, double *, double *, double *, const BOUND_BOX *);
+int Vect_region_box(const struct Cell_head *, BOUND_BOX *);
+/* Spatial index */
+void Vect_spatial_index_init(SPATIAL_INDEX *);
+void Vect_spatial_index_destroy(SPATIAL_INDEX *);
+void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
+void Vect_spatial_index_del_item(SPATIAL_INDEX *, int);
+int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
+/* Category index */
+int Vect_cidx_get_num_fields(const struct Map_info *);
+int Vect_cidx_get_field_number(const struct Map_info *, int);
+int Vect_cidx_get_field_index(const struct Map_info *, int);
+int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_types_by_index(const struct Map_info *, int);
+int Vect_cidx_get_type_count_by_index(const struct Map_info *, int, int, int *,
+				      int *);
+int Vect_cidx_get_type_count(const struct Map_info *, int, int);
+int Vect_cidx_get_cat_by_index(const struct Map_info *, int, int, int *, int *,
+			       int *);
+int Vect_cidx_find_next(const struct Map_info *, int, int, int, int, int *, int *);
+void Vect_cidx_find_all(const struct Map_info *, int, int, int, struct ilist *);
+int Vect_cidx_dump(const struct Map_info *, FILE *);
+int Vect_cidx_save(struct Map_info *);
+int Vect_cidx_open(struct Map_info *, int);
+/* Set/get map header info */
+int Vect_read_header(struct Map_info *);
+int Vect_write_header(const struct Map_info *);
+const char *Vect_get_name(const struct Map_info *);
+const char *Vect_get_mapset(const struct Map_info *);
+const char *Vect_get_full_name(const struct Map_info *);
+int Vect_is_3d(const struct Map_info *);
+int Vect_set_organization(struct Map_info *, const char *);
+const char *Vect_get_organization(const struct Map_info *);
+int Vect_set_date(struct Map_info *, const char *);
+const char *Vect_get_date(const struct Map_info *);
+int Vect_set_person(struct Map_info *, const char *);
+const char *Vect_get_person(const struct Map_info *);
+int Vect_set_map_name(struct Map_info *, const char *);
+const char *Vect_get_map_name(const struct Map_info *);
+int Vect_set_map_date(struct Map_info *, const char *);
+const char *Vect_get_map_date(const struct Map_info *);
+int Vect_set_comment(struct Map_info *, const char *);
+const char *Vect_get_comment(const struct Map_info *);
+int Vect_set_scale(struct Map_info *, int);
+int Vect_get_scale(const struct Map_info *);
+int Vect_set_zone(struct Map_info *, int);
+int Vect_get_zone(const struct Map_info *);
+int Vect_get_proj(const struct Map_info *);
+const char *Vect_get_proj_name(const struct Map_info *);
+int Vect_set_thresh(struct Map_info *, double);
+double Vect_get_thresh(const struct Map_info *);
+int Vect_get_constraint_box(const struct Map_info *, BOUND_BOX *);
+/* Get map level 2 informations */
+int Vect_level(const struct Map_info *);
+int Vect_get_num_nodes(const struct Map_info *);
+int Vect_get_num_primitives(const struct Map_info *, int);
+int Vect_get_num_lines(const struct Map_info *);
+int Vect_get_num_areas(const struct Map_info *);
+int Vect_get_num_faces(const struct Map_info *);
+int Vect_get_num_islands(const struct Map_info *);
+int Vect_get_line_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_area_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_isle_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_map_box(const struct Map_info *, BOUND_BOX *);
+int V__map_overlap(struct Map_info *, double, double, double, double);
+void Vect_set_release_support(struct Map_info *);
+void Vect_set_category_index_update(struct Map_info *);
+/* Set/get fatal error behaviour */
+int Vect_set_fatal_error(int);
+int Vect_get_fatal_error();
+/* Open/close/rewind/set_constraints for map */
+int Vect_check_input_output_name(const char *, const char *, int);
+int Vect_legal_filename(const char *);
+int Vect_set_open_level(int);
+int Vect_open_old(struct Map_info *, const char *, const char *);
+int Vect_open_old_head(struct Map_info *, const char *, const char *);
+int Vect_open_new(struct Map_info *, const char *, int);
+int Vect_open_update(struct Map_info *, const char *, const char *);
+int Vect_open_update_head(struct Map_info *, const char *, const char *);
+int Vect_copy_head_data(const struct Map_info *, struct Map_info *);
+int Vect_build(struct Map_info *);
+int Vect_get_built(const struct Map_info *);
+int Vect_build_partial(struct Map_info *, int);
+int Vect_set_constraint_region(struct Map_info *, double, double, double,
+			       double, double, double);
+int Vect_set_constraint_type(struct Map_info *, int);
+int Vect_remove_constraints(struct Map_info *);
+int Vect_rewind(struct Map_info *);
+int Vect_close(struct Map_info *);
+/* Read/write lines, nodes, areas */
+/* Level 1 and 2 */
+int Vect_read_next_line(const struct Map_info *, struct line_pnts *,
+			struct line_cats *);
+off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
+		      const struct line_cats *);
+int Vect_get_num_dblinks(const struct Map_info *);
+/* Level 2 only */
+int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
+		   int);
+int Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
+int Vect_delete_line(struct Map_info *, int);
+int Vect_restore_line(struct Map_info *, int, off_t);
+int Vect_line_alive(const struct Map_info *, int);
+int Vect_node_alive(const struct Map_info *, int);
+int Vect_area_alive(const struct Map_info *, int);
+int Vect_isle_alive(const struct Map_info *, int);
+int Vect_get_line_nodes(const struct Map_info *, int, int *, int *);
+int Vect_get_line_areas(const struct Map_info *, int, int *, int *);
+off_t Vect_get_line_offset(const struct Map_info *, int);
+int Vect_get_node_coor(const struct Map_info *, int, double *, double *, double *);
+int Vect_get_node_n_lines(const struct Map_info *, int);
+int Vect_get_node_line(const struct Map_info *, int, int);
+float Vect_get_node_line_angle(const struct Map_info *, int, int);
+int Vect_get_area_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_area_centroid(const struct Map_info *, int);
+int Vect_get_area_num_isles(const struct Map_info *, int);
+int Vect_get_area_isle(const struct Map_info *, int, int);
+double Vect_get_area_area(const struct Map_info *, int);
+int Vect_get_area_boundaries(const struct Map_info *, int, struct ilist *);
+int Vect_get_isle_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_isle_area(const struct Map_info *, int);
+int Vect_get_isle_boundaries(const struct Map_info *, int, struct ilist *);
+int Vect_get_centroid_area(const struct Map_info *, int);
+/* Level 2 update only */
+int Vect_get_num_updated_lines(const struct Map_info *);
+int Vect_get_updated_line(const struct Map_info *, int);
+int Vect_get_num_updated_nodes(const struct Map_info *);
+int Vect_get_updated_node(const struct Map_info *, int);
+/* History */
+int Vect_hist_command(struct Map_info *);
+int Vect_hist_write(struct Map_info *, const char *);
+int Vect_hist_copy(const struct Map_info *, struct Map_info *);
+void Vect_hist_rewind(struct Map_info *);
+char *Vect_hist_read(char *, int, const struct Map_info *);
+/* Selecting features */
+int Vect_select_lines_by_box(struct Map_info *, const BOUND_BOX *, int,
+			     struct ilist *);
+int Vect_select_areas_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_select_isles_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_select_nodes_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_find_node(struct Map_info *, double, double, double, double, int);
+int Vect_find_line(struct Map_info *, double, double, double, int, double,
+		   int, int);
+int Vect_find_line_list(struct Map_info *, double, double, double, int,
+			double, int, const struct ilist *, struct ilist *);
+int Vect_find_area(struct Map_info *, double, double);
+int Vect_find_island(struct Map_info *, double, double);
+int Vect_select_lines_by_polygon(struct Map_info *, struct line_pnts *, int,
+				 struct line_pnts **, int, struct ilist *);
+int Vect_select_areas_by_polygon(struct Map_info *, struct line_pnts *, int,
+				 struct line_pnts **, struct ilist *);
+/* Analysis */
+int Vect_point_in_area(const struct Map_info *, int, double, double);
+int Vect_tin_get_z(struct Map_info *, double, double, double *, double *,
+		   double *);
+int Vect_get_point_in_area(const struct Map_info *, int, double *, double *);
+/* int Vect_point_in_islands (struct Map_info *, int, double, double); */
+int Vect_find_poly_centroid(const struct line_pnts *, double *, double *);
+int Vect_get_point_in_poly_isl(const struct line_pnts *, const struct line_pnts **, int,
+			       double *, double *);
+int Vect__intersect_line_with_poly(const struct line_pnts *, double,
+int Vect_get_point_in_poly(const struct line_pnts *, double *, double *);
+int Vect_point_in_poly(double, double, const struct line_pnts *);
+int Vect_point_in_area_outer_ring(double, double, const struct Map_info *, int);
+int Vect_point_in_island(double, double, const struct Map_info *, int);
+/* Cleaning */
+void Vect_break_lines(struct Map_info *, int, struct Map_info *);
+int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
+			  int, struct Map_info *);
+int Vect_merge_lines(struct Map_info *, int, int *, struct Map_info *);
+void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
+void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
+int Vect_line_check_duplicate(const struct line_pnts *,
+			      const struct line_pnts *, int);
+void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
+void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
+			  struct Map_info *);
+void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
+void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
+void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
+void Vect_remove_bridges(struct Map_info *, struct Map_info *);
+void Vect_chtype_bridges(struct Map_info *, struct Map_info *);
+int Vect_remove_small_areas(struct Map_info *, double, struct Map_info *,
+			    double *);
+int Vect_clean_small_angles_at_nodes(struct Map_info *, int,
+/* Overlay */
+int Vect_overlay_str_to_operator(const char *);
+int Vect_overlay(struct Map_info *, int, struct ilist *, struct ilist *,
+		 struct Map_info *, int, struct ilist *, struct ilist *,
+int Vect_overlay_and(struct Map_info *, int, struct ilist *,
+		     struct ilist *, struct Map_info *, int,
+		     struct ilist *, struct ilist *, struct Map_info *);
+/* Graph */
+void Vect_graph_init(GRAPH *, int);
+void Vect_graph_build(GRAPH *);
+void Vect_graph_add_edge(GRAPH *, int, int, double, int);
+void Vect_graph_set_node_costs(GRAPH *, int, double);
+int Vect_graph_shortest_path(GRAPH *, int, int, struct ilist *, double *);
+/* Network (graph) */
+int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
+			 const char *, const char *, int, int);
+int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
+			   double *);
+int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
+int Vect_net_get_node_cost(const struct Map_info *, int, double *);
+int Vect_net_nearest_nodes(struct Map_info *, double, double, double, int,
+			   double, int *, int *, int *, double *, double *,
+			   struct line_pnts *, struct line_pnts *, double *);
+int Vect_net_shortest_path_coor(struct Map_info *, double, double, double,
+				double, double, double, double, double,
+				double *, struct line_pnts *, struct ilist *,
+/* Miscellaneous */
+int Vect_topo_dump(const struct Map_info *, FILE *);
+double Vect_points_distance(double, double, double, double, double, double,
+			    int);
+int Vect_option_to_types(const struct Option *);
+int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
+int Vect_copy(const char *, const char *, const char *);
+int Vect_rename(const char *, const char *);
+int Vect_copy_table(const struct Map_info *, struct Map_info *, int, int,
+int Vect_copy_table_by_cats(const struct Map_info *, struct Map_info *, int, int,
+			    const char *, int, int *, int);
+int Vect_copy_tables(const struct Map_info *, struct Map_info *, int);
+int Vect_delete(const char *);
+int Vect_segment_intersection(double, double, double, double, double, double,
+			      double, double, double, double, double, double,
+			      double *, double *, int);
+int Vect_line_intersection(struct line_pnts *, struct line_pnts *,
+			   struct line_pnts ***, struct line_pnts ***, int *,
+			   int *, int);
+int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
+int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
+				struct line_pnts *, int);
+char *Vect_subst_var(const char *, const struct Map_info *);
+ * Internal functions, MUST NOT be used in modules
+int Vect_print_header(const struct Map_info *);
+int Vect__init_head(struct Map_info *);
+/* Open/close/rewind map */
+int Vect_coor_info(const struct Map_info *, struct Coor_info *);
+const char *Vect_maptype_info(const struct Map_info *);
+int Vect_open_topo(struct Map_info *, int);
+int Vect_save_topo(struct Map_info *);
+int Vect_open_spatial_index(struct Map_info *);
+int Vect_save_spatial_index(struct Map_info *);
+int Vect_spatial_index_dump(struct Map_info *, FILE *);
+int Vect_build_sidx_from_topo(struct Map_info *);
+int Vect_build_spatial_index(struct Map_info *);
+int Vect__write_head(const struct Map_info *);
+int Vect__read_head(struct Map_info *);
+int V1_open_old_nat(struct Map_info *, int);
+int V1_open_old_ogr(struct Map_info *, int);
+int V2_open_old_ogr(struct Map_info *);
+int V1_open_new_nat(struct Map_info *, const char *, int);
+int V1_rewind_nat(struct Map_info *);
+int V1_rewind_ogr(struct Map_info *);
+int V2_rewind_nat(struct Map_info *);
+int V2_rewind_ogr(struct Map_info *);
+int V1_close_nat(struct Map_info *);
+int V1_close_ogr(struct Map_info *);
+int V2_close_ogr(struct Map_info *);
+/* Read/write lines */
+int V1_read_line_nat(struct Map_info *, struct line_pnts *,
+		     struct line_cats *, off_t);
+int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
+int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
+int V2_read_line_nat(struct Map_info *, struct line_pnts *,
+		     struct line_cats *, int);
+int V2_read_line_ogr(struct Map_info *, struct line_pnts *,
+int V2_read_next_line_nat(struct Map_info *, struct line_pnts *,
+int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
+int V1_delete_line_nat(struct Map_info *, off_t);
+int V2_delete_line_nat(struct Map_info *, int);
+int V1_restore_line_nat(struct Map_info *, off_t);
+int V2_restore_line_nat(struct Map_info *, int, off_t);
+off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+#if 0
+long V1_write_line_ogr(struct Map_info *, int, struct line_pnts *,
+#endif
+off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
+			  const struct line_pnts *, const struct line_cats *);
+int V2_rewrite_line_nat(struct Map_info *, int, int,
+#if 0
+long V1_rewrite_line_ogr(struct Map_info *, long offset, int type,
+			 struct line_pnts *, struct line_cats *);
+#endif
+    /* Miscellaneous */
+int Vect_build_nat(struct Map_info *, int);
+int Vect_build_ogr(struct Map_info *, int);
+int Vect_build_line_area(struct Map_info *, int, int);
+int Vect_isle_find_area(struct Map_info *, int);
+int Vect_attach_isle(struct Map_info *, int);
+int Vect_attach_isles(struct Map_info *, const BOUND_BOX *);
+int Vect_attach_centroids(struct Map_info *, const BOUND_BOX *);
+    /* GEOS support */
+#ifdef HAVE_GEOS
+GEOSGeometry *Vect_read_line_geos(struct Map_info *, int, int*);
+GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
+#endif
+#endif /* GRASS_VECT_H */
Modified: grass/trunk/include/vedit.h
--- grass/trunk/include/vedit.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/include/vedit.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #define GRASS_VEDIT_H
 #define NO_SNAP    0		/* snapping disabled */
 #define SNAP       1		/* snapping enabled for nodes */
Modified: grass/trunk/lib/manage/do_copy.c
--- grass/trunk/lib/manage/do_copy.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/manage/do_copy.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include <string.h>
 #include <unistd.h>
 #include "list.h"
Modified: grass/trunk/lib/manage/do_remove.c
--- grass/trunk/lib/manage/do_remove.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/manage/do_remove.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <string.h>
 #include "list.h"
Modified: grass/trunk/lib/manage/do_rename.c
--- grass/trunk/lib/manage/do_rename.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/manage/do_rename.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "list.h"
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/ogsf/Gp3.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <grass/site.h>
 #include <grass/gstypes.h>
Modified: grass/trunk/lib/ogsf/Gv3.c
--- grass/trunk/lib/ogsf/Gv3.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/ogsf/Gv3.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/rst/interp_float/interpf.h
--- grass/trunk/lib/rst/interp_float/interpf.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/rst/interp_float/interpf.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
  * modified by Brown in June 1999 - added elatt & smatt
  * modified by Mitasova Nov. 9, 1999 - added parameter for dtens to output2d
 #include <grass/bitmap.h>
 #include <grass/dataquad.h>
 #include <grass/qtree.h>
Modified: grass/trunk/lib/rst/interp_float/point2d.c
--- grass/trunk/lib/rst/interp_float/point2d.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/rst/interp_float/point2d.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -27,7 +27,7 @@
 #include <unistd.h>
 #define	POINT2D_C
Modified: grass/trunk/lib/rst/interp_float/vinput2d.c
--- grass/trunk/lib/rst/interp_float/vinput2d.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/rst/interp_float/vinput2d.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <grass/linkm.h>
 #include <grass/interpf.h>
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/sites/sites.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
Modified: grass/trunk/lib/vector/Vlib/Makefile
--- grass/trunk/lib/vector/Vlib/Makefile	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/Makefile	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 EXTRA_CFLAGS = $(ZLIBINCPATH) $(VECT_CFLAGS)
 EXTRA_LIBS=$(GISLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS) $(GEOSLIBS)
-LIB_NAME = $(VECTR_LIBNAME)
+LIB_NAME = $(VECTOR_LIBNAME)
 DEPENDENCIES =  $(ARCH_INCDIR)/Vect.h $(ARCH_INCDIR)/V_.h \
 		$(ARCH_INCDIR)/vect/dig_defines.h \
 		$(ARCH_INCDIR)/vect/dig_macros.h $(ARCH_INCDIR)/vect/dig_structs.h \
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <grass/config.h>
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/array.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/box.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
    \brief Tests for point in box
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/break_lines.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include <grass/vect/rbtree.h>
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/bridges.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
-#include <grass/Vect.h>
+#include <grass/vector.h>
 #include <grass/glocale.h>
 static void
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/buffer.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <math.h>
 #define LENGTH(DX, DY)  (  sqrt( (DX*DX)+(DY*DY) )  )
Modified: grass/trunk/lib/vector/Vlib/buffer2.c
--- grass/trunk/lib/vector/Vlib/buffer2.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/buffer2.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/build.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <stdarg.h>
 #ifndef HAVE_OGR
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/build_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <sys/types.h>
    \brief Build area on given side of line (GV_LEFT or GV_RIGHT)
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <stdio.h>
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/cats.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
 static int cmp(const void *pa, const void *pb);
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <sys/stat.h>
 #include <unistd.h>
 static int cmp_cat(const void *pa, const void *pb);
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/close.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <unistd.h>
 static int clo_dummy()
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/close_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -14,7 +14,7 @@
    \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
 #ifdef HAVE_OGR
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/constraint.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
    \date 2001-2008
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/dangles.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
 #define REMOVE_DANGLE 0
Modified: grass/trunk/lib/vector/Vlib/dbcolumns.c
--- grass/trunk/lib/vector/Vlib/dbcolumns.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/dbcolumns.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <grass/dbmi.h>
Modified: grass/trunk/lib/vector/Vlib/dgraph.c
--- grass/trunk/lib/vector/Vlib/dgraph.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/dgraph.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #include <stdlib.h>
 #include "dgraph.h"
Modified: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/error.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <string.h>
 static int fatal_err = GV_FATAL_EXIT;
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/field.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
 #ifdef HAVE_GDAL
 #include <gdal_version.h>	/* needed for FID detection */
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/find.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <math.h>
 #ifndef HUGE_VAL
 #define HUGE_VAL 9999999999999.0
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/geos.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #ifdef HAVE_GEOS
Modified: grass/trunk/lib/vector/Vlib/graph.c
--- grass/trunk/lib/vector/Vlib/graph.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/graph.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <string.h>
 static int From_node;		/* from node set in SP and used by clipper for first arc */
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/header.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
 static int lookup(const char *file, const char *key, char *value, size_t len);
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/hist.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
    \brief Write command info to history file
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/init_head.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <string.h>
    \brief Initialize head structure
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/intersect.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -69,7 +69,7 @@
 #include <stdlib.h>
 #include <math.h>
 /* function prototypes */
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -14,7 +14,7 @@
 #include <string.h>
Modified: grass/trunk/lib/vector/Vlib/level.c
--- grass/trunk/lib/vector/Vlib/level.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/level.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -12,7 +12,7 @@
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/level_two.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/line.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/lib/vector/Vlib/list.c
--- grass/trunk/lib/vector/Vlib/list.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/list.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/map.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -26,7 +26,7 @@
 #include <fcntl.h>
Modified: grass/trunk/lib/vector/Vlib/merge_lines.c
--- grass/trunk/lib/vector/Vlib/merge_lines.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/merge_lines.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/net.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <fcntl.h>
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/open.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #define MAX_OPEN_LEVEL 2
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
Modified: grass/trunk/lib/vector/Vlib/overlap.c
--- grass/trunk/lib/vector/Vlib/overlap.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/overlap.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
   Check if region overlaps with map extent.
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/overlay.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <string.h>
 int Vect_overlay_and(struct Map_info *, int, struct ilist *, struct ilist *,
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/poly.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <math.h>
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/read.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 static int read_next_dummy()
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/read_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 static int
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #ifdef HAVE_OGR
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/rewind.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -14,7 +14,7 @@
Modified: grass/trunk/lib/vector/Vlib/rewind_nat.c
--- grass/trunk/lib/vector/Vlib/rewind_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/rewind_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -14,7 +14,7 @@
   \brief Rewind vector data file to cause reads to start at beginning (level 1)
Modified: grass/trunk/lib/vector/Vlib/rewind_ogr.c
--- grass/trunk/lib/vector/Vlib/rewind_ogr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/rewind_ogr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #ifdef HAVE_OGR
 #include <ogr_api.h>
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/select.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
    \brief Select lines by box.
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/sindex.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/snap.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/lib/vector/Vlib/tin.c
--- grass/trunk/lib/vector/Vlib/tin.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/tin.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -13,7 +13,7 @@
    \author Radim Blazek
    \brief Calculates z coordinate for point from TIN
Modified: grass/trunk/lib/vector/Vlib/type.c
--- grass/trunk/lib/vector/Vlib/type.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/type.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
    \brief Get types from options
Modified: grass/trunk/lib/vector/Vlib/window.c
--- grass/trunk/lib/vector/Vlib/window.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/window.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -12,7 +12,7 @@
    int
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/write.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 static off_t write_dummy()
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -27,7 +27,7 @@
 #include <math.h>
Modified: grass/trunk/lib/vector/diglib/allocation.c
--- grass/trunk/lib/vector/diglib/allocation.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/allocation.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <unistd.h>
 #include <stdlib.h>
 /*  functions - alloc_space(), falloc(), frealloc() _falloc() _frealloc() */
Modified: grass/trunk/lib/vector/diglib/angle.c
--- grass/trunk/lib/vector/diglib/angle.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/angle.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
 #include <stdio.h>
 #include <math.h>
 static double d_atan2(double, double);
Modified: grass/trunk/lib/vector/diglib/box.c
--- grass/trunk/lib/vector/diglib/box.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/box.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
  *  dig_line_box ()
Modified: grass/trunk/lib/vector/diglib/cindex.c
--- grass/trunk/lib/vector/diglib/cindex.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/cindex.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
  *  dig_cidx_init ()
Modified: grass/trunk/lib/vector/diglib/cindex_rw.c
--- grass/trunk/lib/vector/diglib/cindex_rw.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/cindex_rw.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 int dig_write_cidx_head(GVFILE * fp, struct Plus_head *plus)
Modified: grass/trunk/lib/vector/diglib/file.c
--- grass/trunk/lib/vector/diglib/file.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/file.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/frmt.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <string.h>
 #include <stdio.h>
 /* Read vector format.
Modified: grass/trunk/lib/vector/diglib/head.c
--- grass/trunk/lib/vector/diglib/head.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/head.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 int dig__write_head(struct Map_info *Map)
Modified: grass/trunk/lib/vector/diglib/inside.c
--- grass/trunk/lib/vector/diglib/inside.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/inside.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 double
 dig_x_intersect(double beg_x,
Modified: grass/trunk/lib/vector/diglib/list.c
--- grass/trunk/lib/vector/diglib/list.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/list.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 /* Init int_list */
 int dig_init_list(struct ilist *list)
Modified: grass/trunk/lib/vector/diglib/plus.c
--- grass/trunk/lib/vector/diglib/plus.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/plus.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <stdio.h>
Modified: grass/trunk/lib/vector/diglib/plus_area.c
--- grass/trunk/lib/vector/diglib/plus_area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/plus_area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/plus_line.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 static int add_line(struct Plus_head *plus, int lineid, int type, const struct line_pnts *Points,
 		    off_t offset)
Modified: grass/trunk/lib/vector/diglib/plus_node.c
--- grass/trunk/lib/vector/diglib/plus_node.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/plus_node.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 #include <math.h>
 static double dist_squared(double, double, double, double);
Modified: grass/trunk/lib/vector/diglib/plus_struct.c
--- grass/trunk/lib/vector/diglib/plus_struct.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/plus_struct.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
  * Routines for reading and writing Dig+ structures.
Modified: grass/trunk/lib/vector/diglib/poly.c
--- grass/trunk/lib/vector/diglib/poly.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/poly.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <math.h>
 #ifndef HUGE_VAL
Modified: grass/trunk/lib/vector/diglib/port_init.c
--- grass/trunk/lib/vector/diglib/port_init.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/port_init.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -79,7 +79,7 @@
 #include <stdio.h>
 #define TEST_PATTERN 1.3333
Modified: grass/trunk/lib/vector/diglib/port_test.c
--- grass/trunk/lib/vector/diglib/port_test.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/port_test.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdio.h>
  **  Written by Dave Gerdes  9/1988
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/portable.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <string.h>
 extern void port_init(void);
Modified: grass/trunk/lib/vector/diglib/prune.c
--- grass/trunk/lib/vector/diglib/prune.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/prune.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -69,7 +69,7 @@
 #include <stdio.h>
 #include <math.h>
 int dig_prune(struct line_pnts *points, double thresh)
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/spindex.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/lib/vector/diglib/struct_alloc.c
--- grass/trunk/lib/vector/diglib/struct_alloc.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/struct_alloc.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 /*  These routines all eventually call calloc() to allocate and zero
  **  the new space.  BUT It is not neccessarily safe to assume that
Modified: grass/trunk/lib/vector/diglib/test.c
--- grass/trunk/lib/vector/diglib/test.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/test.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <stdio.h>
 /* Test portable r/w functions */
Modified: grass/trunk/lib/vector/diglib/type.c
--- grass/trunk/lib/vector/diglib/type.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/type.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
    \brief Convert type to store type
Modified: grass/trunk/lib/vector/diglib/update.c
--- grass/trunk/lib/vector/diglib/update.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/lib/vector/diglib/update.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
    \brief Reset number of updated lines
Modified: grass/trunk/ps/ps.map/catval.c
--- grass/trunk/ps/ps.map/catval.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/catval.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/do_vectors.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -9,7 +9,7 @@
 #include <string.h>
 #include <grass/symbol.h>
 #include "clr.h"
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/ps_vareas.c
--- grass/trunk/ps/ps.map/ps_vareas.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/ps_vareas.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -7,7 +7,7 @@
 #include <grass/raster.h>
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/ps_vlines.c
--- grass/trunk/ps/ps.map/ps_vlines.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/ps_vlines.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -8,7 +8,7 @@
 #include "ps_info.h"
Modified: grass/trunk/ps/ps.map/ps_vpoints.c
--- grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -5,7 +5,7 @@
  ** modified to use G_plot_line() by Olga Waupotitsch on dec,93
Modified: grass/trunk/ps/ps.map/r_vareas.c
--- grass/trunk/ps/ps.map/r_vareas.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/r_vareas.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/r_vlines.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -8,7 +8,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "vector.h"
 #include "local_proto.h"
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/r_vpoints.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -11,7 +11,7 @@
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/symbol.c
--- grass/trunk/ps/ps.map/symbol.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/symbol.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
  ** Author: Radim Blazek
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/vect.c
--- grass/trunk/ps/ps.map/vect.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/ps/ps.map/vect.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -6,7 +6,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include "vector.h"
Modified: grass/trunk/raster/r.carve/enforce.h
--- grass/trunk/raster/r.carve/enforce.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.carve/enforce.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <stdio.h>
 #define APP_VERSION 1.0
Modified: grass/trunk/raster/r.contour/cont.c
--- grass/trunk/raster/r.contour/cont.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.contour/cont.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -27,7 +27,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.contour/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -47,7 +47,7 @@
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.drain/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -43,7 +43,7 @@
 #define DEBUG
 #include "tinf.h"
Modified: grass/trunk/raster/r.flow/r.flow.h
--- grass/trunk/raster/r.flow/r.flow.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.flow/r.flow.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
 #include <math.h>
 #include <grass/segment.h>
 #ifndef hypot
Modified: grass/trunk/raster/r.le/r.le.setup/sample.c
--- grass/trunk/raster/r.le/r.le.setup/sample.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.le/r.le.setup/sample.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <stdlib.h>
 #include <grass/display.h>
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.random/random.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
Modified: grass/trunk/raster/r.random/support.c
--- grass/trunk/raster/r.random/support.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.random/support.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.region/main.c
--- grass/trunk/raster/r.region/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.region/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 static int nsew(const char *, const char *, const char *, const char *);
Modified: grass/trunk/raster/r.to.vect/areas_io.c
--- grass/trunk/raster/r.to.vect/areas_io.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.to.vect/areas_io.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include "global.h"
Modified: grass/trunk/raster/r.to.vect/lines_io.c
--- grass/trunk/raster/r.to.vect/lines_io.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.to.vect/lines_io.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -35,7 +35,7 @@
 #include "global.h"
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.to.vect/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include "global.h"
Modified: grass/trunk/raster/r.to.vect/points.c
--- grass/trunk/raster/r.to.vect/points.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.to.vect/points.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -7,7 +7,7 @@
 #include "global.h"
Modified: grass/trunk/raster/r.to.vect/util.c
--- grass/trunk/raster/r.to.vect/util.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/r.to.vect/util.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include "global.h"
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -70,7 +70,7 @@
 #include <unistd.h>
 #endif
 /*#include <grass/site.h> */
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/raster/simwe/r.sim.water/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -77,7 +77,7 @@
 #include <unistd.h>
 #endif
 /* #include <grass/site.h> */
Modified: grass/trunk/swig/include/vector.i
--- grass/trunk/swig/include/vector.i	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/swig/include/vector.i	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,10 +2,10 @@
 %include "common.i"
 #include <grass/vect/dig_structs.h>
-%include "grass/Vect.h"
+%include "grass/vector.h"
 %include "grass/vect/dig_structs.h"
 %include "grass/vect/dig_defines.h"
Modified: grass/trunk/swig/python/Makefile
--- grass/trunk/swig/python/Makefile	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/swig/python/Makefile	2009-06-22 11:56:33 UTC (rev 38026)
@@ -91,7 +91,7 @@
 proj_wrap.c: $(GISBASE)/include/grass/gprojects.h
 imagery_wrap.c: $(GISBASE)/include/grass/imagedefs.h
 imagery_wrap.c: $(GISBASE)/include/grass/imagery.h
-vector_wrap.c: $(GISBASE)/include/grass/Vect.h
+vector_wrap.c: $(GISBASE)/include/grass/vector.h
 vector_wrap.c: $(GISBASE)/include/grass/vect/dig_defines.h
 vector_wrap.c: $(GISBASE)/include/grass/vect/dig_structs.h
 display_wrap.c: $(GISBASE)/include/grass/display.h
Modified: grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
--- grass/trunk/vector/lidar/lidarlib/PolimiFunct.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/lidarlib/PolimiFunct.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <grass/gmath.h>
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/lidarlib/raster.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <string.h>
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/lidarlib/zones.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <string.h>
 #include <math.h>
 #include "correction.h"
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.h
--- grass/trunk/vector/lidar/v.lidar.correction/correction.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <assert.h>
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <math.h>
 #include <grass/PolimiFunct.h>
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -28,7 +28,7 @@
 #include <string.h>
 #include <math.h>
     /* #include <grass/PolimiFunct.h> */
 #include "edgedetection.h"
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -24,7 +24,7 @@
  /*INCLUDES*/
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -27,7 +27,7 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.growing/growing.c
--- grass/trunk/vector/lidar/v.lidar.growing/growing.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.growing/growing.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include "growing.h"
Modified: grass/trunk/vector/lidar/v.lidar.growing/growing.h
--- grass/trunk/vector/lidar/v.lidar.growing/growing.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.growing/growing.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <assert.h>
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -26,7 +26,7 @@
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <string.h>
 #include <math.h>
 #include "outlier.h"
Modified: grass/trunk/vector/lidar/v.outlier/outlier.h
--- grass/trunk/vector/lidar/v.outlier/outlier.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.outlier/outlier.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 #include <grass/gis.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/bspline.h
--- grass/trunk/vector/lidar/v.surf.bspline/bspline.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.surf.bspline/bspline.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <math.h>
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.buffer/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.build/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 int main(int argc, char *argv[])
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.build.polylines/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -73,7 +73,7 @@
 #include <stdio.h>
 #include <string.h>
 #include "walk.h"
Modified: grass/trunk/vector/v.build.polylines/walk.c
--- grass/trunk/vector/v.build.polylines/walk.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.build.polylines/walk.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "walk.h"
 /* find next line for given line and node
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.category/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 #define O_ADD  1
 #define O_DEL  2
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.class/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/arraystats.h>
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.clean/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <string.h>
 #include <stdio.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.clean/prune.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.clean/rmdac.c
--- grass/trunk/vector/v.clean/rmdac.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.clean/rmdac.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
 int rmdac(struct Map_info *Out, struct Map_info *Err)
Modified: grass/trunk/vector/v.clean/rmline.c
--- grass/trunk/vector/v.clean/rmline.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.clean/rmline.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 int remove_zero_line(struct Map_info *Map, int otype, struct Map_info *Err)
Modified: grass/trunk/vector/v.clean/test/topocheck.c
--- grass/trunk/vector/v.clean/test/topocheck.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.clean/test/topocheck.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.convert/att.c
--- grass/trunk/vector/v.convert/att.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/att.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -5,7 +5,7 @@
 /* *  convert dig_cats to database table
Modified: grass/trunk/vector/v.convert/dist.c
--- grass/trunk/vector/v.convert/dist.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/dist.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/main.c
--- grass/trunk/vector/v.convert/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/old2new.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/read.c
--- grass/trunk/vector/v.convert/read.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/read.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "conv.h"
Modified: grass/trunk/vector/v.convert/type.c
--- grass/trunk/vector/v.convert/type.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.convert/type.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
 #include "conv.h"
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.db.connect/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -24,7 +24,7 @@
 #include <ctype.h>
 #include <math.h>
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.db.select/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <math.h>
Modified: grass/trunk/vector/v.delaunay/defs.h
--- grass/trunk/vector/v.delaunay/defs.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.delaunay/defs.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 #ifdef MAIN
Modified: grass/trunk/vector/v.delaunay/in_out.c
--- grass/trunk/vector/v.delaunay/in_out.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.delaunay/in_out.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <math.h>
 #include <unistd.h>
 #include "data_types.h"
 #include "memory.h"
Modified: grass/trunk/vector/v.delaunay/main.c
--- grass/trunk/vector/v.delaunay/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.delaunay/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "memory.h"
Modified: grass/trunk/vector/v.delaunay/memory.c
--- grass/trunk/vector/v.delaunay/memory.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.delaunay/memory.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.distance/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -26,7 +26,7 @@
 /* TODO: support all types (lines, boundaries, areas for 'from' (from_type) */
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.drape/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -31,7 +31,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.edit/global.h
--- grass/trunk/vector/v.edit/global.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.edit/global.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -5,7 +5,7 @@
 # include <stdlib.h>
 # include <string.h>
 # include <grass/gis.h>
-# include <grass/Vect.h>
+# include <grass/vector.h>
 # include <grass/glocale.h>
 # include <grass/vedit.h>
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.external/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <unistd.h>
 #include "ogr_api.h"
Modified: grass/trunk/vector/v.extract/extract.c
--- grass/trunk/vector/v.extract/extract.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.extract/extract.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include <string.h>
 #include <stdlib.h>
 static int *cats_array;
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.extract/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -29,7 +29,7 @@
 #include <unistd.h>
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.extrude/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -24,7 +24,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.generalize/displacement.c
--- grass/trunk/vector/v.generalize/displacement.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/displacement.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include "point.h"
 #include "matrix.h"
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "misc.h"
 #include "operators.h"
Modified: grass/trunk/vector/v.generalize/matrix.h
--- grass/trunk/vector/v.generalize/matrix.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/matrix.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #ifndef MATRIX_H
 #define MATRIX_H
 typedef struct
Modified: grass/trunk/vector/v.generalize/misc.c
--- grass/trunk/vector/v.generalize/misc.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/misc.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include "misc.h"
Modified: grass/trunk/vector/v.generalize/misc.h
--- grass/trunk/vector/v.generalize/misc.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/misc.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #ifndef MISC_H_
 #define MISC_H_
 /* returns bitmask for all the types specified in type_opt
  * e.g GV_LINE | GV_BOUNDARY
Modified: grass/trunk/vector/v.generalize/network.c
--- grass/trunk/vector/v.generalize/network.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/network.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
 typedef struct
Modified: grass/trunk/vector/v.generalize/point.c
--- grass/trunk/vector/v.generalize/point.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/point.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <math.h>
 #include "point.h"
Modified: grass/trunk/vector/v.generalize/point.h
--- grass/trunk/vector/v.generalize/point.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/point.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #ifndef POINT_H
 #define POINT_H
 typedef struct
Modified: grass/trunk/vector/v.generalize/pq.h
--- grass/trunk/vector/v.generalize/pq.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/pq.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #ifndef PQ_H
 #define PQ_H
 /* None of the functions below tests overflows,
  * only extract_max treats underflow */
Modified: grass/trunk/vector/v.generalize/simplification.c
--- grass/trunk/vector/v.generalize/simplification.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/simplification.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include "point.h"
 #include "pq.h"
Modified: grass/trunk/vector/v.generalize/smoothing.c
--- grass/trunk/vector/v.generalize/smoothing.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.generalize/smoothing.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include "point.h"
 #include "matrix.h"
Modified: grass/trunk/vector/v.hull/chull.c
--- grass/trunk/vector/v.hull/chull.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.hull/chull.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -24,7 +24,7 @@
 #include <math.h>
 #include "globals.h"
Modified: grass/trunk/vector/v.hull/chull.h
--- grass/trunk/vector/v.hull/chull.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.hull/chull.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
 int make3DHull(double *X, double *Y, double *Z, int num_points,
 	       struct Map_info *Map);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.hull/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
 #include <stdio.h>
 #include <assert.h>
 #include "chull.h"
Modified: grass/trunk/vector/v.in.ascii/a2b.c
--- grass/trunk/vector/v.in.ascii/a2b.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ascii/a2b.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdio.h>
 #include <string.h>
 #define BUFFSIZE 128
Modified: grass/trunk/vector/v.in.ascii/head.c
--- grass/trunk/vector/v.in.ascii/head.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ascii/head.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ascii/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.in.ascii/points.c
--- grass/trunk/vector/v.in.ascii/points.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ascii/points.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <ctype.h>
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.db/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <ctype.h>
Modified: grass/trunk/vector/v.in.dwg/entity.c
--- grass/trunk/vector/v.in.dwg/entity.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.dwg/entity.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -47,7 +47,7 @@
 #include <unistd.h>
 #include "ad2.h"
 #include "global.h"
Modified: grass/trunk/vector/v.in.dwg/main.c
--- grass/trunk/vector/v.in.dwg/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.dwg/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -36,7 +36,7 @@
 #include <unistd.h>
 #include "ad2.h"
 #include "io/odio.h"
Modified: grass/trunk/vector/v.in.dxf/global.h
--- grass/trunk/vector/v.in.dxf/global.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.dxf/global.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <stdio.h>
 struct dxf_file
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ogr/geom.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <string.h>
 #include "global.h"
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.ogr/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
 #include <string.h>
 #include <grass/gprojects.h>
 #include <gdal_version.h>	/* needed for OFTDate */
Modified: grass/trunk/vector/v.in.region/main.c
--- grass/trunk/vector/v.in.region/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.region/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.in.sites/main.c
--- grass/trunk/vector/v.in.sites/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.in.sites/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -26,7 +26,7 @@
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.info/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <string.h>
 #include <stdlib.h>
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.kcv/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -29,7 +29,7 @@
 #include <math.h>
 #include "kcv.h"
Modified: grass/trunk/vector/v.kernel/function.c
--- grass/trunk/vector/v.kernel/function.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.kernel/function.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <math.h>
 #include "global.h"
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.kernel/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include "global.h"
Modified: grass/trunk/vector/v.label/main.c
--- grass/trunk/vector/v.label/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.label/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <math.h>
Modified: grass/trunk/vector/v.label.sa/labels.h
--- grass/trunk/vector/v.label.sa/labels.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.label.sa/labels.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -12,7 +12,7 @@
 #include <grass/fontcap.h>
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -29,7 +29,7 @@
 #include <time.h>
 #include <math.h>
 #include "../lib/lrs.h"
Modified: grass/trunk/vector/v.lrs/v.lrs.label/main.c
--- grass/trunk/vector/v.lrs/v.lrs.label/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.lrs/v.lrs.label/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -30,7 +30,7 @@
 #include <time.h>
 #include <math.h>
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -31,7 +31,7 @@
 #include <time.h>
 #include <math.h>
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -28,7 +28,7 @@
 #include <string.h>
 #include <time.h>
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.mkgrid/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <math.h>
 #include "grid_structs.h"
Modified: grass/trunk/vector/v.mkgrid/write_grid.c
--- grass/trunk/vector/v.mkgrid/write_grid.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.mkgrid/write_grid.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdio.h>
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.neighbors/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <unistd.h>
 /* TODO: add more methods */
Modified: grass/trunk/vector/v.net/arcs.c
--- grass/trunk/vector/v.net/arcs.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/arcs.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/args.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
 #include "proto.h"
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/connect.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdio.h>
 #include <string.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.net/nodes.c
--- grass/trunk/vector/v.net/nodes.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/nodes.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.net/report.c
--- grass/trunk/vector/v.net/report.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net/report.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "proto.h"
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.alloc/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include <time.h>
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.iso/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include <time.h>
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.path/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 int path(struct Map_info *, struct Map_info *, char *, int, double, int);
Modified: grass/trunk/vector/v.net.path/path.c
--- grass/trunk/vector/v.net.path/path.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.path/path.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <unistd.h>
 #include <math.h>
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.salesman/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include <time.h>
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.steiner/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include <time.h>
Modified: grass/trunk/vector/v.net.visibility/geometry.h
--- grass/trunk/vector/v.net.visibility/geometry.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.visibility/geometry.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <assert.h>
 #include "rotation_tree.h"
 int point_inside(struct Point *p, double x, double y);
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.visibility/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -16,7 +16,7 @@
 #include <stdlib.h>
 #include "visibility.h"
 #include "proto.h"
Modified: grass/trunk/vector/v.net.visibility/visibility.h
--- grass/trunk/vector/v.net.visibility/visibility.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.net.visibility/visibility.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <assert.h>
 #include "data_structures.h"
 #include "geometry.h"
Modified: grass/trunk/vector/v.normal/main.c
--- grass/trunk/vector/v.normal/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.normal/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -36,7 +36,7 @@
 #include <math.h>
 #include <grass/cdhc.h>
Modified: grass/trunk/vector/v.out.ascii/b2a.c
--- grass/trunk/vector/v.out.ascii/b2a.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.ascii/b2a.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
Modified: grass/trunk/vector/v.out.ascii/head.c
--- grass/trunk/vector/v.out.ascii/head.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.ascii/head.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <stdio.h>
 int write_head(FILE * dascii, struct Map_info *Map)
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.ascii/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -23,7 +23,7 @@
 #include <unistd.h>
 #include <string.h>
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.dxf/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include "global.h"
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.ogr/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <string.h>
 #include <grass/config.h>
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.pov/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.svg/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #define SVG_NS   "http://www.w3.org/2000/svg"
 #define XLINK_NS "http://www.w3.org/1999/xlink"
Modified: grass/trunk/vector/v.out.vtk/head.c
--- grass/trunk/vector/v.out.vtk/head.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.vtk/head.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.vtk/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <unistd.h>
 #include <string.h>
-#include <grass/Vect.h>
+#include <grass/vector.h>
 #include <grass/glocale.h>
 #include <string.h>
Modified: grass/trunk/vector/v.out.vtk/writeVTK.c
--- grass/trunk/vector/v.out.vtk/writeVTK.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.out.vtk/writeVTK.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -15,7 +15,7 @@
 #include <stdlib.h>
 #include "writeVTK.h"
Modified: grass/trunk/vector/v.overlay/area_area.c
--- grass/trunk/vector/v.overlay/area_area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.overlay/area_area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -11,7 +11,7 @@
 #include <stdio.h>
 #include "local.h"
Modified: grass/trunk/vector/v.overlay/line_area.c
--- grass/trunk/vector/v.overlay/line_area.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.overlay/line_area.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include <stdio.h>
 #include "local.h"
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.overlay/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <stdio.h>
 #include "local.h"
Modified: grass/trunk/vector/v.overlay/util.c
--- grass/trunk/vector/v.overlay/util.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.overlay/util.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include <stdio.h>
 #include "local.h"
 /* Compare by cat */
Modified: grass/trunk/vector/v.parallel/main.c
--- grass/trunk/vector/v.parallel/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.parallel/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.patch/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/vector/v.perturb/main.c
--- grass/trunk/vector/v.perturb/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.perturb/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -35,7 +35,7 @@
 #include <math.h>
 #include "perturb.h"
 #include "zufall.h"
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.proj/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -26,7 +26,7 @@
 #include <fcntl.h>
 #include <string.h>
Modified: grass/trunk/vector/v.qcount/count.c
--- grass/trunk/vector/v.qcount/count.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.qcount/count.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include <math.h>
 #include <stdlib.h>
 #include "quaddefs.h"
 void count_sites(COOR * quads, int nquads, int *counts, double radius,
Modified: grass/trunk/vector/v.qcount/findquads.c
--- grass/trunk/vector/v.qcount/findquads.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.qcount/findquads.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -11,7 +11,7 @@
 #include <stdlib.h>
 #include <math.h>
 #ifndef RAND_MAX
Modified: grass/trunk/vector/v.qcount/indices.c
--- grass/trunk/vector/v.qcount/indices.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.qcount/indices.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -7,7 +7,7 @@
 void qindices(int *cnt, int n, double *fisher, double *david, double *douglas,
Modified: grass/trunk/vector/v.qcount/main.c
--- grass/trunk/vector/v.qcount/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.qcount/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -37,7 +37,7 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.random/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -36,7 +36,7 @@
 #include <unistd.h>
 #include <string.h>
 #include <grass/dbmi.h>
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.reclass/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/v.reclass/reclass.c
--- grass/trunk/vector/v.reclass/reclass.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.reclass/reclass.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 int reclass(struct Map_info *In, struct Map_info *Out, int type, int field,
 	    dbCatValArray * cvarr, int dissolve)
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.sample/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -46,7 +46,7 @@
 int main(int argc, char **argv)
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.segment/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <math.h>
 #include <time.h>
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.select/args.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 #include "proto.h"
Modified: grass/trunk/vector/v.select/geos.c
--- grass/trunk/vector/v.select/geos.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.select/geos.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include "proto.h"
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.select/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include "proto.h"
Modified: grass/trunk/vector/v.select/overlap.c
--- grass/trunk/vector/v.select/overlap.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.select/overlap.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include "proto.h"
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.split/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -18,7 +18,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.support/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/vector/v.surf.idw/read_sites.c
--- grass/trunk/vector/v.surf.idw/read_sites.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.surf.idw/read_sites.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include "proto.h"
 /* 1/2001 added field parameter MN
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.surf.rst/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
 #include <math.h>
Modified: grass/trunk/vector/v.to.3d/local_proto.h
--- grass/trunk/vector/v.to.3d/local_proto.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.3d/local_proto.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 struct opts {
   struct Flag *reverse, *table;
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.3d/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -17,7 +17,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.to.3d/trans2.c
--- grass/trunk/vector/v.to.3d/trans2.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.3d/trans2.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/vector/v.to.3d/trans3.c
--- grass/trunk/vector/v.to.3d/trans3.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.3d/trans3.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.db/global.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,5 +1,5 @@
 struct value
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.points/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdlib.h>
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast/do_lines.c
--- grass/trunk/vector/v.to.rast/do_lines.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/do_lines.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <math.h>
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast/local.h
--- grass/trunk/vector/v.to.rast/local.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/local.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #undef DEBUG
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <string.h>
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast/raster.c
--- grass/trunk/vector/v.to.rast/raster.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/raster.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/support.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -10,7 +10,7 @@
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast/vect2rast.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include "local.h"
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.to.rast3/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -20,7 +20,7 @@
 #include <grass/G3d.h>
Modified: grass/trunk/vector/v.transform/creat_trans.c
--- grass/trunk/vector/v.transform/creat_trans.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.transform/creat_trans.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -25,7 +25,7 @@
 #include <stdlib.h>
 #include "trans.h"
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.transform/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -34,7 +34,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "trans.h"
Modified: grass/trunk/vector/v.transform/trans_digit.c
--- grass/trunk/vector/v.transform/trans_digit.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.transform/trans_digit.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -19,7 +19,7 @@
 #include <math.h>
 #include <grass/libtrans.h>
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.type/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <stdlib.h>
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.univar/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -21,7 +21,7 @@
 #include <string.h>
 #include <math.h>
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.vol.rst/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -35,7 +35,7 @@
 #include "userglobs.h"
 /* include G3d defs */
Modified: grass/trunk/vector/v.vol.rst/user1.c
--- grass/trunk/vector/v.vol.rst/user1.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.vol.rst/user1.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
 #include <grass/bitmap.h>
 #include "oct.h"
Modified: grass/trunk/vector/v.vol.rst/user3.c
--- grass/trunk/vector/v.vol.rst/user3.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.vol.rst/user3.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -33,7 +33,7 @@
 #include <fcntl.h>
Modified: grass/trunk/vector/v.vol.rst/userglobs.h
--- grass/trunk/vector/v.vol.rst/userglobs.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.vol.rst/userglobs.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #define __USERGLOBS_H__
 extern double /* pargr */ xmin, xmax, ymin, ymax, zmin, zmax, wmin, wmax;
Modified: grass/trunk/vector/v.vol.rst/vector.c
--- grass/trunk/vector/v.vol.rst/vector.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.vol.rst/vector.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -32,7 +32,7 @@
 #include <unistd.h>
 #include <fcntl.h>
Modified: grass/trunk/vector/v.voronoi/dt_write.c
--- grass/trunk/vector/v.voronoi/dt_write.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/dt_write.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -3,7 +3,7 @@
 #include <math.h>
 #include <float.h>
 #include "sw_defs.h"
 #include "defs.h"
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -41,7 +41,7 @@
 #include <math.h>
 #include "defs.h"
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/sw_main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "defs.h"
Modified: grass/trunk/vector/v.voronoi/sw_output.c
--- grass/trunk/vector/v.voronoi/sw_output.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/sw_output.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,7 +1,7 @@
 #include <stdio.h>
 #include <math.h>
 #include <float.h>
 #include "write.h"
Modified: grass/trunk/vector/v.voronoi/vo_extend.c
--- grass/trunk/vector/v.voronoi/vo_extend.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/vo_extend.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,6 +1,6 @@
 #include <stdio.h>
 #include <math.h>
 #include "defs.h"
 #include "write.h"
Modified: grass/trunk/vector/v.voronoi/vo_write.c
--- grass/trunk/vector/v.voronoi/vo_write.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.voronoi/vo_write.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -2,7 +2,7 @@
 #include <math.h>
 #include <float.h>
 #include "defs.h"
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.what/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 #include <string.h>
Modified: grass/trunk/vector/v.what/what.c
--- grass/trunk/vector/v.what/what.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.what/what.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 #include <grass/colors.h>
 #include "what.h"
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/vector/v.what.rast/main.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -22,7 +22,7 @@
 struct order
Modified: grass/trunk/visualization/nviz/src/pg.h
--- grass/trunk/visualization/nviz/src/pg.h	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/visualization/nviz/src/pg.h	2009-06-22 11:56:33 UTC (rev 38026)
@@ -1,4 +1,4 @@
 #define QRY_LENGTH 1024
 struct Sql
Modified: grass/trunk/visualization/nviz/src/pick_vect_commands.c
--- grass/trunk/visualization/nviz/src/pick_vect_commands.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/visualization/nviz/src/pick_vect_commands.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -116,7 +116,7 @@
 #include <grass/form.h>
 #include <stdlib.h>
 #include "interface.h"
Modified: grass/trunk/visualization/nviz/src/query_vect.c
--- grass/trunk/visualization/nviz/src/query_vect.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/visualization/nviz/src/query_vect.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -4,7 +4,7 @@
 char *query_vect(char *name, double x, double y)
Modified: grass/trunk/visualization/nviz/src/site_attr_commands.c
--- grass/trunk/visualization/nviz/src/site_attr_commands.c	2009-06-22 11:50:10 UTC (rev 38025)
+++ grass/trunk/visualization/nviz/src/site_attr_commands.c	2009-06-22 11:56:33 UTC (rev 38026)
@@ -147,7 +147,7 @@
 #include <stdio.h>
 #include <string.h>
 #include <stdlib.h>
 #define	R_G_B_2_RGB(r,g,b) ((b) & 0xff) | (((g) & 0xff) << 8) | (((r) & 0xff) << 16)
