[GRASS-SVN] r38075 - grass/branches/develbranch_6/swig/python/examples
Thu Jun 25 14:25:15 EDT 2009
Author: martinl
Date: 2009-06-25 14:25:15 -0400 (Thu, 25 Jun 2009)
New Revision: 38075
Added:
   grass/branches/develbranch_6/swig/python/examples/m.distance.py
Removed:
m.distance renamed
Deleted: grass/branches/develbranch_6/swig/python/examples/m.distance
--- grass/branches/develbranch_6/swig/python/examples/m.distance	2009-06-25 18:22:52 UTC (rev 38074)
+++ grass/branches/develbranch_6/swig/python/examples/m.distance	2009-06-25 18:25:15 UTC (rev 38075)
@@ -1,202 +0,0 @@
-#!/usr/bin/python
-# MODULE:       m.distance
-# AUTHOR(S):    Hamish Bowman, Dunedin, New Zealand
-# PURPOSE:      Find distance between two points
-#               If the projection is latitude-longitude, this distance
-#                 is measured along the geodesic.
-#               Demonstrates GRASS SWIG-Python interface
-# COPYRIGHT:    (c) 2008 Hamish Bowman, and The GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-# Requires GRASS SWIG-Python interface
-# Requires Numeric module (NumPy) from  http://numpy.scipy.org/
-# Requires NumPrt module from  http://geosci.uchicago.edu/csc/numptr/
-#%Module
-#%  label: Finds the distance between two or more points.
-#%  description: If the projection is latitude-longitude, this distance is measured along the geodesic.
-#%  keywords: miscellaneous, distance, measure
-#%End
-#%Option
-#%  key: coord
-#%  type: string
-#%  required: no
-#%  multiple: yes
-#%  key_desc: x,y
-#%  description: Comma separated list of coordinate pairs
-#%End
-#%Flag
-#%  key: i
-#%  description: Read coordinate pairs from stdin
-#%End
-import os, sys
-if not os.environ.has_key("GISBASE"):
-    print "You must be in GRASS GIS to run this program."
-    sys.exit(1)
-def main():
-    #### add your code here ####
-    # run this before starting python to append module search path:
-    #   export PYTHONPATH=/usr/src/grass63/swig/python
-    #   check with "import sys; sys.path"
-    # or:
-    sys.path.append("/usr/src/grass63/swig/python")
-    # FIXME: install the g6lib.py bindings in $GISBASE/lib/ ?
-    import python_grass6 as g6lib
-    # for passing pointers
-    import Numeric
-    import NumPtr
-    g6lib.G_gisinit('m.distance')
-    # returns 0 on success
-    ### calc distance ###
-    proj_type = g6lib.G_begin_distance_calculations()
-    # returns 0 if projection has no metrix (ie. imagery)
-    # returns 1 if projection is planimetric
-    # returns 2 if projection is latitude-longitude
-    # parser always creates at least an empty variable, and sys.argv is
-    #  toast, so no way to check if option was given. So it hangs if
-    #  --q was the only option given and there is no data from stdin.
-    coord_ans  = os.getenv("GIS_OPT_COORD")
-    stdin_flag = bool(int(os.getenv("GIS_FLAG_I")))
-    if stdin_flag is True:
-        coords = []
-        # read line by line from stdin
-        while 1:
-            line = sys.stdin.readline().strip()
-            if not line:   # EOF
-                break
-            else:
-                coords += line.split(',')
-    else:
-        # read from coord= command line option
-        coords = coord_ans.split(',')
-    if len(coords) < 4:
-       print "A minimum of two input coordinate pairs are needed"
-       return
-    # init variables
-    overall_distance = 0.0
-    if proj_type == 2:
-        # lat/lon scan for DDD:MM:SS.SSSS
-        easting = Numeric.array(0., Numeric.Float64)
-        eastPtr = NumPtr.getpointer(easting)
-        northing = Numeric.array(0., Numeric.Float64)
-        northPtr = NumPtr.getpointer(northing)
-        # TODO: for clarity, figure out how to replace "3" with
-        #       the defined LOCATION_LL constant from gis.i
-        g6lib.G_scan_easting(coords[0], eastPtr, 3)
-        g6lib.G_scan_northing(coords[1], northPtr, 3)
-        x1 = float(easting)
-        y1 = float(northing)
-    else:
-        # plain old coordinates
-        x1 = float(coords[0])
-        y1 = float(coords[1])
-    x = [x1]
-    y = [y1]
-    for i in range(1, (len(coords) / 2)):
-            g6lib.G_scan_easting (coords[ i*2 + 0 ], eastPtr, 3)
-            g6lib.G_scan_northing(coords[ i*2 + 1 ], northPtr, 3)
-            x2 = float(easting)
-            y2 = float(northing)
-        else:
-            x2 = float(coords[ i*2 + 0 ])
-            y2 = float(coords[ i*2 + 1 ])
-        segment_distance = g6lib.G_distance(x1, y1, x2, y2)
-        overall_distance += segment_distance
-        print "segment %d distance is %.2f meters" % (i, segment_distance)
-        # add to the area array
-        # setup for the next loop
-        x1 = x2
-        y1 = y2
-        x += [x2]
-        y += [y2]
-    print
-    print " total distance is %.2f meters" % overall_distance
-    print
-    ### calc area ###
-    if len(coords) < 6:
-        return
-    g6lib.G_begin_polygon_area_calculations()
-    # returns 0 if the projection is not measurable (ie. imagery or xy)
-    # returns 1 if the projection is planimetric (ie. UTM or SP)
-    # returns 2 if the projection is non-planimetric (ie. latitude-longitude)
-    # do not need to close polygon (but it doesn't hurt if you do)
-    npoints = len(x)
-    # unset variables:
-    #del [Xs, Xptr, Ys, Yptr]
-    #   or
-    #Xs = Xptr = Ys = Yptr = None
-    Xs = Numeric.array(x, Numeric.Float64)
-    Xptr = NumPtr.getpointer(Xs)
-    Ys = Numeric.array(y, Numeric.Float64)
-    Yptr = NumPtr.getpointer(Ys)
-    area = g6lib.G_area_of_polygon(Xptr, Yptr, npoints)
-    print "AREA:  %10.2f square meters" % area
-    print
-    # we don't need this, but just to have a look
-    if False:
-        if proj_type == 1:
-            g6lib.G_database_units_to_meters_factor()
-            # 1.0
-        print "Location units are", g6lib.G_database_unit_name(True)
-    #### end of your code ####
-    return
-if __name__ == "__main__":
-    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
-        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
-    else:
-        main();
Copied: grass/branches/develbranch_6/swig/python/examples/m.distance.py (from rev 38073, grass/branches/develbranch_6/swig/python/examples/m.distance)
--- grass/branches/develbranch_6/swig/python/examples/m.distance.py	                        (rev 0)
+++ grass/branches/develbranch_6/swig/python/examples/m.distance.py	2009-06-25 18:25:15 UTC (rev 38075)
@@ -0,0 +1,202 @@
+#!/usr/bin/python
+# MODULE:       m.distance
+# AUTHOR(S):    Hamish Bowman, Dunedin, New Zealand
+# PURPOSE:      Find distance between two points
+#               If the projection is latitude-longitude, this distance
+#                 is measured along the geodesic.
+#               Demonstrates GRASS SWIG-Python interface
+# COPYRIGHT:    (c) 2008 Hamish Bowman, and The GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# Requires GRASS SWIG-Python interface
+# Requires Numeric module (NumPy) from  http://numpy.scipy.org/
+# Requires NumPrt module from  http://geosci.uchicago.edu/csc/numptr/
+#%Module
+#%  label: Finds the distance between two or more points.
+#%  description: If the projection is latitude-longitude, this distance is measured along the geodesic.
+#%  keywords: miscellaneous, distance, measure
+#%End
+#%Option
+#%  key: coord
+#%  type: string
+#%  required: no
+#%  multiple: yes
+#%  key_desc: x,y
+#%  description: Comma separated list of coordinate pairs
+#%End
+#%Flag
+#%  key: i
+#%  description: Read coordinate pairs from stdin
+#%End
+import os, sys
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+    #### add your code here ####
+    # run this before starting python to append module search path:
+    #   export PYTHONPATH=/usr/src/grass63/swig/python
+    #   check with "import sys; sys.path"
+    # or:
+    sys.path.append("/usr/src/grass63/swig/python")
+    # FIXME: install the g6lib.py bindings in $GISBASE/lib/ ?
+    import python_grass6 as g6lib
+    # for passing pointers
+    import Numeric
+    import NumPtr
+    g6lib.G_gisinit('m.distance')
+    # returns 0 on success
+    ### calc distance ###
+    proj_type = g6lib.G_begin_distance_calculations()
+    # returns 0 if projection has no metrix (ie. imagery)
+    # returns 1 if projection is planimetric
+    # returns 2 if projection is latitude-longitude
+    # parser always creates at least an empty variable, and sys.argv is
+    #  toast, so no way to check if option was given. So it hangs if
+    #  --q was the only option given and there is no data from stdin.
+    coord_ans  = os.getenv("GIS_OPT_COORD")
+    stdin_flag = bool(int(os.getenv("GIS_FLAG_I")))
+    if stdin_flag is True:
+        coords = []
+        # read line by line from stdin
+        while 1:
+            line = sys.stdin.readline().strip()
+            if not line:   # EOF
+                break
+            else:
+                coords += line.split(',')
+    else:
+        # read from coord= command line option
+        coords = coord_ans.split(',')
+    if len(coords) < 4:
+       print "A minimum of two input coordinate pairs are needed"
+       return
+    # init variables
+    overall_distance = 0.0
+    if proj_type == 2:
+        # lat/lon scan for DDD:MM:SS.SSSS
+        easting = Numeric.array(0., Numeric.Float64)
+        eastPtr = NumPtr.getpointer(easting)
+        northing = Numeric.array(0., Numeric.Float64)
+        northPtr = NumPtr.getpointer(northing)
+        # TODO: for clarity, figure out how to replace "3" with
+        #       the defined LOCATION_LL constant from gis.i
+        g6lib.G_scan_easting(coords[0], eastPtr, 3)
+        g6lib.G_scan_northing(coords[1], northPtr, 3)
+        x1 = float(easting)
+        y1 = float(northing)
+    else:
+        # plain old coordinates
+        x1 = float(coords[0])
+        y1 = float(coords[1])
+    x = [x1]
+    y = [y1]
+    for i in range(1, (len(coords) / 2)):
+            g6lib.G_scan_easting (coords[ i*2 + 0 ], eastPtr, 3)
+            g6lib.G_scan_northing(coords[ i*2 + 1 ], northPtr, 3)
+            x2 = float(easting)
+            y2 = float(northing)
+        else:
+            x2 = float(coords[ i*2 + 0 ])
+            y2 = float(coords[ i*2 + 1 ])
+        segment_distance = g6lib.G_distance(x1, y1, x2, y2)
+        overall_distance += segment_distance
+        print "segment %d distance is %.2f meters" % (i, segment_distance)
+        # add to the area array
+        # setup for the next loop
+        x1 = x2
+        y1 = y2
+        x += [x2]
+        y += [y2]
+    print
+    print " total distance is %.2f meters" % overall_distance
+    print
+    ### calc area ###
+    if len(coords) < 6:
+        return
+    g6lib.G_begin_polygon_area_calculations()
+    # returns 0 if the projection is not measurable (ie. imagery or xy)
+    # returns 1 if the projection is planimetric (ie. UTM or SP)
+    # returns 2 if the projection is non-planimetric (ie. latitude-longitude)
+    # do not need to close polygon (but it doesn't hurt if you do)
+    npoints = len(x)
+    # unset variables:
+    #del [Xs, Xptr, Ys, Yptr]
+    #   or
+    #Xs = Xptr = Ys = Yptr = None
+    Xs = Numeric.array(x, Numeric.Float64)
+    Xptr = NumPtr.getpointer(Xs)
+    Ys = Numeric.array(y, Numeric.Float64)
+    Yptr = NumPtr.getpointer(Ys)
+    area = g6lib.G_area_of_polygon(Xptr, Yptr, npoints)
+    print "AREA:  %10.2f square meters" % area
+    print
+    # we don't need this, but just to have a look
+    if False:
+        if proj_type == 1:
+            g6lib.G_database_units_to_meters_factor()
+            # 1.0
+        print "Location units are", g6lib.G_database_unit_name(True)
+    #### end of your code ####
+    return
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+        main();
