[GRASS-SVN] r38091 - grass/trunk/gui/wxpython/gui_modules
Sat Jun 27 06:14:11 EDT 2009
Author: martinl
Date: 2009-06-27 06:14:10 -0400 (Sat, 27 Jun 2009)
New Revision: 38091
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: indicate if MASK is available (change mapdisplay title)
minor doxygen updates
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-06-26 23:14:44 UTC (rev 38090)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-06-27 10:14:10 UTC (rev 38091)
@@ -109,7 +109,8 @@
         self.page       = page      # Notebook page holding the layer tree
         self.layerbook  = notebook  # Layer Manager layer tree notebook
         self.parent     = parent
+        self.title      = title
         # available cursors
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-26 23:14:44 UTC (rev 38090)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-27 10:14:10 UTC (rev 38091)
@@ -1,4 +1,4 @@
 @package mapdisp_window.py
 @brief GIS map display canvas, buffered window.
@@ -25,6 +25,8 @@
 import wx
+import grass.script as grass
 import dbm
 import dbm_dialogs
 import gdialogs
@@ -42,7 +44,7 @@
 from vdigit import PseudoDC
 class MapWindow(object):
     Abstract map window class
     Parent for BufferedWindow class (2D display mode) and
@@ -67,13 +69,13 @@
     def EraseMap(self):
         Erase the canvas (virtual method)
         pass
     def UpdateMap(self):
         Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
@@ -95,7 +97,7 @@
         pass
     def GetSelectedLayer(self, type = 'layer', multi = False):
         Get selected layer from layer tree
         @param type 'item' / 'layer' / 'nviz'
@@ -142,7 +144,7 @@
         return ret
 class BufferedWindow(MapWindow, wx.Window):
     A Buffered window class.
     When the drawing needs to change, you app needs to call the
@@ -244,7 +246,7 @@
         self.lastpos  = (0, 0)
     def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
         Draws map and overlay decorations
         if drawid == None:
@@ -379,7 +381,7 @@
         return drawid
     def TextBounds(self, textinfo):
         Return text boundary data
         @param textinfo text metadata (text, font, color, rotation)
@@ -414,7 +416,7 @@
         return coords, boxw, boxh
     def OnPaint(self, event):
         Draw PseudoDC's to buffered paint DC
         self.pdc for background and decorations
@@ -496,7 +498,7 @@
             self.redrawAll = False
     def OnSize(self, event):
         Scale map image so that it is
         the same size as the Window
@@ -532,7 +534,7 @@
         self.parent.StatusbarUpdate()
     def OnIdle(self, event):
         Only re-render a composite map image from GRASS during
         idle time instead of multiple times during resizing.
@@ -542,7 +544,7 @@
         event.Skip()
     def SaveToFile(self, FileName, FileType):
         This draws the psuedo DC to a buffer that
         can be saved to a file.
@@ -553,7 +555,7 @@
         self.buffer.SaveFile(FileName, FileType)
     def GetOverlay(self):
         Converts rendered overlay files to wx.Image
         Updates self.imagedict
@@ -571,7 +573,7 @@
         return imgs
     def GetImage(self):
         Converts redered map files to wx.Image
         Updates self.imagedict (id=99)
@@ -590,7 +592,7 @@
         return img
     def UpdateMap(self, render=True, renderVector=True):
@@ -622,7 +624,7 @@
         # update layer dictionary if there has been a change in layers
         if self.tree and self.tree.reorder == True:
             self.tree.ReorderLayers()
         # reset flag for auto-rendering
         if self.tree:
             self.tree.rerender = False
@@ -663,7 +665,7 @@
                 return False
             self.Draw(self.pdc, self.img, drawid=id)
         # render vector map layer
@@ -709,10 +711,10 @@
         for id in self.textdict.keys():
             self.Draw(self.pdc, img=self.textdict[id], drawid=id,
                       pdctype='text', coords=[10, 10, 10, 10])
         # optionally draw computational extent box
         self.DrawCompRegionExtent()
         # redraw pdcTmp if needed
@@ -731,7 +733,6 @@
         # clear measurement
         if self.mouse["use"] == "measure":
             self.ClearLines(pdc=self.pdcTmp)
             self.polycoords = []
@@ -741,25 +742,30 @@
             self.SetCursor(self.parent.cursors["default"])
         stop = time.clock()
         # hide process bar
         self.parent.onRenderGauge.Hide()
-        # update statusbar
+        # update statusbar
         ### self.Map.SetRegion()
+        if grass.find_file(name = 'MASK', element = 'cell')['name']:
+            # mask found
+            self.parent.SetTitle(self.parent.title + _(' (masked)'))
+        else:
+            self.parent.SetTitle(self.parent.title)
         Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
                    (render, renderVector, (stop-start)))
         return True
     def DrawCompRegionExtent(self):
         Draw computational region extent in the display
         Display region is drawn as a blue box inside the computational region,
@@ -787,7 +793,7 @@
             self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
     def IsInRegion(self, region, refRegion):
         Test if 'region' is inside of 'refRegion'
         @param region input region
@@ -805,7 +811,7 @@
         return False
     def EraseMap(self):
         Erase the canvas
         self.Draw(self.pdc, pdctype='clear')
@@ -817,7 +823,7 @@
         self.Draw(self.pdcTmp, pdctype='clear')
     def DragMap(self, moveto):
         Drag the entire map image for panning.
@@ -836,7 +842,7 @@
         return True
     def DragItem(self, id, event):
         Drag an overlay decoration item
         if id == 99 or id == '' or id == None: return
@@ -867,7 +873,7 @@
         self.lastpos = (event.GetX(), event.GetY())
     def MouseDraw(self, pdc=None, begin=None, end=None):
         Mouse box or line from 'begin' to 'end'
         If not given from self.mouse['begin'] to self.mouse['end'].
@@ -918,7 +924,7 @@
             self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
     def DrawLines(self, pdc=None, polycoords=None):
         Draw polyline in PseudoDC
         Set self.pline to wx.NEW_ID + 1
@@ -989,7 +995,7 @@
         return self.lineid
     def MouseActions(self, event):
         Mouse motion and button click notifier
         if not self.processMouse:
@@ -1036,7 +1042,7 @@
 #        event.Skip()
     def OnMouseWheel(self, event):
         Mouse wheel moved
         self.processMouse = False
@@ -1070,7 +1076,7 @@
 #        event.Skip()
     def OnDragging(self, event):
         Mouse dragging with left button down
         Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
@@ -1107,7 +1113,7 @@
 #        event.Skip()
     def OnLeftDownVDigitAddLine(self, event):
         Left mouse button down - vector digitizer add new line
         action
@@ -1262,7 +1268,7 @@
                 atm.LoadData(layer)
     def OnLeftDownVDigitEditLine(self, event):
         Left mouse button down - vector digitizer edit linear feature
         - add new vertex.
@@ -1274,7 +1280,7 @@
         self.DrawLines(pdc=self.pdcTmp)
     def OnLeftDownVDigitMoveLine(self, event):
         Left mouse button down - vector digitizer move feature/vertex,
         edit linear feature
@@ -1298,7 +1304,7 @@
             self.pdcTmp.SetPen(self.polypen)
     def OnLeftDownVDigitDisplayCA(self, event):
         Left mouse button down - vector digitizer display categories
         or attributes action
@@ -1379,7 +1385,7 @@
         self.UpdateMap(render=False)
     def OnLeftDownVDigitCopyCA(self, event):
         Left mouse button down - vector digitizer copy categories
@@ -1393,7 +1399,7 @@
             self.mouse['box'] = 'box'
     def OnLeftDownVDigitCopyLine(self, event):
         Left mouse button down - vector digitizer copy lines action
         digitToolbar = self.parent.toolbars['vdigit']
@@ -1404,7 +1410,7 @@
             self.layerTmp = None
     def OnLeftDownVDigitBulkLine(self, event):
         Left mouse button down - vector digitizer label 3d vector
         lines
@@ -1425,7 +1431,7 @@
             self.DrawLines(self.pdcTmp, begin, end)
     def OnLeftDown(self, event):
         Left mouse button pressed
         Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
@@ -1520,7 +1526,7 @@
         event.Skip()
     def OnLeftUpVDigitVarious(self, event):
         Left mouse button up - vector digitizer various actions
@@ -1654,7 +1660,7 @@
                 self.UpdateMap(render=False, renderVector=False)
     def OnLeftUpVDigitModifyLine(self, event):
         Left mouse button up - vector digitizer split line, add/remove
         vertex action
@@ -1692,7 +1698,7 @@
     def OnLeftUpVDigitCopyLine(self, event):
         Left mouse button up - vector digitizer copy feature action
@@ -1745,7 +1751,7 @@
             self.redrawAll = None
     def OnLeftUpVDigitBulkLine(self, event):
         Left mouse button up - vector digitizer z-bulk line action
@@ -1765,7 +1771,7 @@
     def OnLeftUpVDigitConnectLine(self, event):
         Left mouse button up - vector digitizer connect line action
@@ -1775,7 +1781,7 @@
     def OnLeftUp(self, event):
         Left mouse button released
         Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
@@ -1896,7 +1902,7 @@
             self.currtxtid = None
     def OnButtonDClick(self, event):
         Mouse button double click
         Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
@@ -1938,7 +1944,7 @@
                 self.parent.OnAddLegend(None)
     def OnRightDown(self, event):
         Right mouse button pressed
         Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
@@ -1975,7 +1981,7 @@
         event.Skip()
     def OnRightUp(self, event):
         Right mouse button released
         Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
@@ -2159,7 +2165,7 @@
         event.Skip()
     def OnMiddleDown(self, event):
         Middle mouse button pressed
@@ -2224,7 +2230,7 @@
             self.redrawAll = True
     def OnMouseMoving(self, event):
         Motion event and no mouse buttons were pressed
@@ -2291,7 +2297,7 @@
         event.Skip()
     def ClearLines(self, pdc=None):
         Clears temporary drawn lines from PseudoDC
         if not pdc:
@@ -2316,7 +2322,7 @@
         return True
     def Pixel2Cell(self, (x, y)):
         Convert image coordinates to real word coordinates
         Input : int x, int y
@@ -2347,7 +2353,7 @@
         return (east, north)
     def Cell2Pixel(self, (east, north)):
         Convert real word coordinates to image coordinates
@@ -2374,7 +2380,7 @@
         return (x, y)
     def Zoom(self, begin, end, zoomtype):
         Calculates new region while (un)zoom/pan-ing
         x1, y1 = begin
@@ -2450,7 +2456,7 @@
     def ZoomBack(self):
         Zoom to previous extents in zoomhistory list
@@ -2476,7 +2482,7 @@
     def ZoomHistory(self, n, s, e, w):
         Manages a list of last 10 zoom extents
         Return removed history item if exists
@@ -2497,20 +2503,20 @@
         return removed
     def OnZoomToMap(self, event):
         Set display extents to match selected raster (including NULLs)
         or vector map.
         self.ZoomToMap()
     def OnZoomToRaster(self, event):
         Set display extents to match selected raster map (ignore NULLs)
         self.ZoomToMap(ignoreNulls = True)
     def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
         or vector map(s).
@@ -2557,7 +2563,7 @@
     def ZoomToWind(self, event):
         Set display geometry to match computational
         region settings (set with g.region)
@@ -2572,7 +2578,7 @@
     def ZoomToDefault(self, event):
         Set display geometry to match default region settings
         self.Map.region = self.Map.GetRegion(default=True)
@@ -2586,7 +2592,7 @@
     def DisplayToWind(self, event):
         Set computational region (WIND file) to
         match display extents
@@ -2611,7 +2617,7 @@
             os.environ["GRASS_REGION"] = tmpreg
     def ZoomToSaved(self, event):
         Set display geometry to match extents in
         saved region file
@@ -2658,7 +2664,7 @@
         dlg.Destroy()
     def SaveDisplayRegion(self, event):
         Save display extents to named region file.
@@ -2690,7 +2696,7 @@
         dlg.Destroy()
     def SaveRegion(self, wind):
         Save region settings
         new = self.Map.AlignResolution()
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2009-06-26 23:14:44 UTC (rev 38090)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2009-06-27 10:14:10 UTC (rev 38091)
@@ -108,10 +108,10 @@
                                            Map=self.Map, auimgr=self.auimgr)
         # title
-        self.mapdisplay.SetTitle(_("GRASS GIS Map Display: " +
-                                   str(self.disp_idx + 1) +
-                                   " - Location: " + grass.gisenv()["LOCATION_NAME"]))
+        self.mapdisplay.title = _("GRASS GIS Map Display: %d  - Location: %s") % \
+            (self.disp_idx + 1, grass.gisenv()["LOCATION_NAME"])
+        self.mapdisplay.SetTitle(self.mapdisplay.title)
         # show new display
         if kargs['showMapDisplay'] is True:
             self.mapdisplay.Show()
