[GRASS-SVN] r38129 - in grass/trunk: include lib/raster ps/ps.map raster/r.info raster/r.los raster/r.param.scale raster/r.support
Tue Jun 30 13:25:24 EDT 2009
Author: martinl
Date: 2009-06-30 13:25:23 -0400 (Tue, 30 Jun 2009)
New Revision: 38129
   grass/trunk/include/raster.h
   grass/trunk/lib/raster/raster_metadata.c
   grass/trunk/ps/ps.map/ps_fclrtbl.c
   grass/trunk/raster/r.info/main.c
   grass/trunk/raster/r.los/main.c
   grass/trunk/raster/r.param.scale/close_down.c
   grass/trunk/raster/r.support/main.c
rasterlib: fns from raster_metadata.c renamed, see
http://trac.osgeo.org/grass/wiki/Grass7/RasterLib
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/include/raster.h	2009-06-30 17:25:23 UTC (rev 38129)
@@ -479,13 +479,10 @@
 DCELL Rast_get_d_value(const void *, RASTER_MAP_TYPE);
 /* raster_metadata.c */
-int Rast_read_raster_units(const char *, const char *, char *);
-int Rast_read_raster_vdatum(const char *, const char *, char *);
-int Rast_write_raster_units(const char *, const char *);
-int Rast_write_raster_vdatum(const char *, const char *);
-int Rast__raster_misc_read_line(const char *, const char *, const char *,
-			     char *);
-int Rast__raster_misc_write_line(const char *, const char *, const char *);
+int Rast_read_units(const char *, const char *, char *);
+int Rast_read_vdatum(const char *, const char *, char *);
+int Rast_write_units(const char *, const char *);
+int Rast_write_vdatum(const char *, const char *);
 /* reclass.c */
 int Rast_is_reclass(const char *, const char *, char *, char *);
Modified: grass/trunk/lib/raster/raster_metadata.c
--- grass/trunk/lib/raster/raster_metadata.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/lib/raster/raster_metadata.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -1,15 +1,17 @@
-/* raster_metadata.c
- * PURPOSE: functions to read and write raster "units" and "vertical datum"
- *              meta-data info
- *   Copyright (C) 2007 by Hamish Bowman, and the GRASS Development Team
- *   Author(s): Hamish Bowman, Dunedin, New Zealand
- *   This program is free software under the GNU General Public
- *   License (>=v2). Read the file COPYING that comes with GRASS
- *   for details.
+  \file raster/raster_metadata.c
+  \brief Raster library - Functions to read and write raster "units"
+  and "vertical datum" meta-data info
+  (C) 2007-2009 by Hamish Bowman, and the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2).  Read the file COPYING that comes with GRASS for details.
+  \author Hamish Bowman
 #include <stdio.h>
 #include <string.h>
@@ -17,74 +19,79 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
+static int misc_read_line(const char *, const char *,
+			  const char *, char *);
+static int misc_write_line(const char *, const char *,
+			   const char *);
  * \brief Get a raster map's units metadata string
  * Read the raster's units metadata file and put string in str
- * \param name
- * \param mapset
- * \param *str  string to be populated with data
+ * \param name raster map name
+ * \param mapset mapset name
+ * \param str  string to be populated with data
  * \return 0 on success
  * \return -1, EOF (fclose() result) on error
-int Rast_read_raster_units(const char *name, const char *mapset, char *str)
+int Rast_read_units(const char *name, const char *mapset, char *str)
-    return Rast__raster_misc_read_line("units", name, mapset, str);
+    return misc_read_line("units", name, mapset, str);
  * \brief Write a string to a raster map's units metadata file
- * Map must exist in the current mapset.
+ * Raster map must exist in the current mapset.
- * \param name
- * \param *str  string containing data to be written
+ * \param str  string containing data to be written
-int Rast_write_raster_units(const char *name, const char *str)
+int Rast_write_units(const char *name, const char *str)
-    return Rast__raster_misc_write_line("units", name, str);
+    return misc_write_line("units", name, str);
  * \brief Get a raster map's vertical datum metadata string
  * Read the raster's vertical datum metadata file and put string in str
- * \param name
- * \param mapset
-int Rast_read_raster_vdatum(const char *name, const char *mapset, char *str)
+int Rast_read_vdatum(const char *name, const char *mapset, char *str)
-    return Rast__raster_misc_read_line("vertical_datum", name, mapset, str);
+    return misc_read_line("vertical_datum", name, mapset, str);
  * \brief Write a string into a raster's vertical datum metadata file
- * \param name
-int Rast_write_raster_vdatum(const char *name, const char *str)
+int Rast_write_vdatum(const char *name, const char *str)
-    return Rast__raster_misc_write_line("vertical_datum", name, str);
+    return misc_write_line("vertical_datum", name, str);
  * \brief Read the first line of a file in cell_misc/
@@ -97,8 +104,8 @@
-int Rast__raster_misc_read_line(const char *elem, const char *name,
-			     const char *mapset, char *str)
+int misc_read_line(const char *elem, const char *name,
+		   const char *mapset, char *str)
     FILE *fd;
     char buff[GNAME_MAX];
@@ -110,7 +117,8 @@
     fd = G_fopen_old_misc("cell_misc", elem, name, mapset);
     if (!fd) {
-	G_warning(_("Can't read %s for [%s in %s]"), elem, name, mapset);
+	G_warning(_("Unable to read %s for raster map <%s@%s>"),
+		  elem, name, mapset);
 	return -1;
     if (G_getl2(buff, sizeof(buff) - 1, fd) == 0) {
@@ -136,14 +144,14 @@
-int Rast__raster_misc_write_line(const char *elem, const char *name,
-			      const char *str)
+int misc_write_line(const char *elem, const char *name,
+		    const char *str)
     FILE *fd;
     fd = G_fopen_new_misc("cell_misc", elem, name);
     if (fd == NULL) {
-	G_warning(_("Can't create %s metadata file for [%s in %s]"),
+	G_warning(_("Unable to create %s metadata file for raster map <%s@%s>"),
 		  elem, name, G_mapset());
 	return -1;
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -249,7 +249,7 @@
     /* print units label, if present */
-    if (Rast_read_raster_units(ct.name, ct.mapset, units) != 0)
+    if (Rast_read_units(ct.name, ct.mapset, units) != 0)
         units[0] = '\0';
     if(strlen(units)) {
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/raster/r.info/main.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -125,9 +125,9 @@
     is_reclass = Rast_get_reclass(name, "", &reclass);
     data_type = Rast_map_type(name, "");
-    if (Rast_read_raster_units(name, "", units) != 0)
+    if (Rast_read_units(name, "", units) != 0)
 	units[0] = '\0';
-    if (Rast_read_raster_vdatum(name, "", vdatum) != 0)
+    if (Rast_read_vdatum(name, "", vdatum) != 0)
 	vdatum[0] = '\0';
     /*Check the Timestamp */
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/raster/r.los/main.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -413,7 +413,7 @@
     sprintf(title, "Line of sight %.2fm above %s", obs_elev, opt3->answer);
     Rast_put_cell_title(out_layer, title);
-    Rast_write_raster_units(out_layer, "degrees");
+    Rast_write_units(out_layer, "degrees");
     Rast_short_history(out_layer, "raster", &history);
     Rast_command_history(&history);
Modified: grass/trunk/raster/r.param.scale/close_down.c
--- grass/trunk/raster/r.param.scale/close_down.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/raster/r.param.scale/close_down.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -37,7 +37,7 @@
     case SLOPE:
 	strcpy(map_type, "Magnitude of maximum gradient");
-	Rast_write_raster_units(rast_out_name, "degrees");
+	Rast_write_units(rast_out_name, "degrees");
 	strcpy(history.edhist[0],
 	    "Slope is given for steepest slope angle and measured in degrees.");
@@ -46,7 +46,7 @@
     case ASPECT:
 	strcpy(map_type, "Direction of maximum gradient");
 	    "Flow direction (aspect): W=0, E=180, N=+90, S=-90 degrees");
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c	2009-06-30 16:53:15 UTC (rev 38128)
+++ grass/trunk/raster/r.support/main.c	2009-06-30 17:25:23 UTC (rev 38129)
@@ -241,10 +241,10 @@
     if (units_opt->answer)
-	Rast_write_raster_units(raster->answer, units_opt->answer);
+	Rast_write_units(raster->answer, units_opt->answer);
     if (vdatum_opt->answer)
-	Rast_write_raster_vdatum(raster->answer, vdatum_opt->answer);
+	Rast_write_vdatum(raster->answer, vdatum_opt->answer);
     if (datasrc1_opt->answer || datasrc2_opt->answer || datadesc_opt->answer) {
 	Rast_read_history(raster->answer, "", &hist);
