[GRASS-SVN] r36160 - grass/branches/develbranch_6/raster/r.los
Sun Mar 1 07:18:15 EST 2009
Author: hamish
Date: 2009-03-01 07:18:15 -0500 (Sun, 01 Mar 2009)
New Revision: 36160
   grass/branches/develbranch_6/raster/r.los/delete.c
   grass/branches/develbranch_6/raster/r.los/main.c
   grass/branches/develbranch_6/raster/r.los/point.h
   grass/branches/develbranch_6/raster/r.los/pts_elim.c
bugfix for #111 by Benjamin Ducke; fix for calc'ing cell neighbourhoods in combination with raster masks by Mark Lake
Modified: grass/branches/develbranch_6/raster/r.los/delete.c
--- grass/branches/develbranch_6/raster/r.los/delete.c	2009-03-01 11:50:49 UTC (rev 36159)
+++ grass/branches/develbranch_6/raster/r.los/delete.c	2009-03-01 12:18:15 UTC (rev 36160)
@@ -33,18 +33,61 @@
     segment_put(seg_out_p, value,
 		row_viewpt - PT_TO_DELETE_Y, PT_TO_DELETE_X + col_viewpt);
-    if (PT_TO_DELETE == head) {	/*  first one ?  */
+    /* If first and last point. This fixes a bug in r.los. See pts_elim.c for details */
+    if ((PT_TO_DELETE == head) && (PT_NEXT_TO_DELETED == NULL)) {
 	NEXT_PT_BACK_PTR = NULL;
 	head = PT_NEXT_TO_DELETED;
 	G_free(PT_TO_DELETE);
 	return (head);
+    if (PT_TO_DELETE == head) { /*  first one ?  */
+	NEXT_PT_BACK_PTR = NULL;
+	head = PT_NEXT_TO_DELETED;
+	   We cannot delete this point right now, as pts_elim.c might still
+	   reference it. Thus, we only mark it for deletion now by pointing
+	   the global DELAYED_DELETE to it and free it the next time we
+	   get here!
+	if ( DELAYED_DELETE != NULL ) {
+	    G_free ( DELAYED_DELETE );
+	    DELAYED_DELETE = NULL;
+	} else {
+	    if ( PT_TO_DELETE != NULL ) {
+	        DELAYED_DELETE = PT_TO_DELETE;
+	return (head);
+    /* If last point. This fixes a bug in r.los. See pts_elim.c for details */
+    if (PT_NEXT_TO_DELETED == NULL) {
+        PREVIOUS_PT_NEXT_PTR = PT_NEXT_TO_DELETED;
+	G_free(PT_TO_DELETE);
+	return (head);
     /*  otherwise  */
     NEXT_PT_BACK_PTR = PT_PREVIOUS_TO_DELETED;
-    G_free(PT_TO_DELETE);
+	get here!
+    } else {
     return (head);
Modified: grass/branches/develbranch_6/raster/r.los/main.c
--- grass/branches/develbranch_6/raster/r.los/main.c	2009-03-01 11:50:49 UTC (rev 36159)
+++ grass/branches/develbranch_6/raster/r.los/main.c	2009-03-01 12:18:15 UTC (rev 36160)
@@ -125,6 +125,8 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    /* initialize delayed point deletion */
     G_scan_easting(opt3->answers[0], &east, G_projection());
     G_scan_northing(opt3->answers[1], &north, G_projection());
@@ -410,5 +412,10 @@
     G_command_history(&history);
     G_write_history(out_layer, &history);
+    /* release that last tiny bit of memory ... */
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/raster/r.los/point.h
--- grass/branches/develbranch_6/raster/r.los/point.h	2009-03-01 11:50:49 UTC (rev 36159)
+++ grass/branches/develbranch_6/raster/r.los/point.h	2009-03-01 12:18:15 UTC (rev 36160)
@@ -48,6 +48,12 @@
 struct point *segment(int, int, int, double, double,
 		      int, int, int, int, SEGMENT *, SEGMENT *, SEGMENT *,
 		      int, int, int, int, double);
+	For delayed deletion of points (see delete3.c).
+	Initially set to NULL in main.c.
+struct point *DELAYED_DELETE;
 #endif
Modified: grass/branches/develbranch_6/raster/r.los/pts_elim.c
--- grass/branches/develbranch_6/raster/r.los/pts_elim.c	2009-03-01 11:50:49 UTC (rev 36159)
+++ grass/branches/develbranch_6/raster/r.los/pts_elim.c	2009-03-01 12:18:15 UTC (rev 36160)
@@ -198,7 +198,20 @@
 	    segment_get(seg_patt_p, &mask, row_viewpt - BLOCKING_PT_Y,
 			col_viewpt + BLOCKING_PT_X);
 	    if (mask == 0 || G_is_null_value(&mask, CELL_TYPE)) {
-		if (NEXT_BLOCKING_PT != NULL)
+	      /* Commenting out the following fixes a bug in r.los.
+		 In that program the 8 cells around the viewpoint
+		 are marked as visible (when visible)
+		 even if they fall outside the area of interest
+		 specified by the patt_map.  This occurs because
+		 these cells are always the last blocking points
+		 on the segment lists, and therefore don't get
+		 deleted when they should.  This fix allows them
+		 to be deleted, but it required modifications
+		 to delete.c.  MWL 25/6/99 */
+		/* if (NEXT_BLOCKING_PT != NULL) */
 		    head = delete(BLOCKING_PT, head, seg_out_p,
 				  row_viewpt, col_viewpt);
