[GRASS-SVN] r36170 - grass/branches/releasebranch_6_4/scripts/d.rast.edit
Sun Mar 1 23:44:06 EST 2009
Author: hamish
Date: 2009-03-01 23:44:06 -0500 (Sun, 01 Mar 2009)
New Revision: 36170
   grass/branches/releasebranch_6_4/scripts/d.rast.edit/description.html
merge and update docs from old xdriver version (trac #86; merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/d.rast.edit/description.html
--- grass/branches/releasebranch_6_4/scripts/d.rast.edit/description.html	2009-03-02 04:42:19 UTC (rev 36169)
+++ grass/branches/releasebranch_6_4/scripts/d.rast.edit/description.html	2009-03-02 04:44:06 UTC (rev 36170)
@@ -4,13 +4,117 @@
 edit cell category values in a raster map layer displayed to the
 graphics monitor using a mouse cursor.
+<H2>USAGE</H2>
+<H3>Overview window</H3>
+An overview window shows the entire map with a box showing the current
+editing region. The edit window shows the cells within the selected area.
+Click on a new spot on the overview window to move the editing area.
+Moving the editing view can take a while.
+<H3>Mouse and menus</H3>
+Cell editing is done using a mouse cursor to choose menu selections
+and indicate areas on the displayed raster map that are to be edited.
+<P>
+Selections available at the top of the edit window are <b>Save</b> and
+<b>Exit</b>.
+<P>
+As the mouse travels over the cells in the edit window you are shown the
+current coordinates and current cell values under the cursor.
+<P>
+To change the value of a cell put the new value to use in the "New value"
+box at the bottom left of the edit window under the coordinate information
+bar. A value of "*" indicates a NULL value should be used.
+<H3>Arrows</H3>
+This function is available for users editing aspect maps.  The
+<EM><A HREF="d.rast.arrow.html">d.rast.arrow</A></EM> program is
+called, which draws arrows over the displayed
+cells to indicate the downslope direction of the cell.
+You can set the aspect map to use on the command line.
+Aspect maps are expected to be in regular "GRASS" format, as produced by
+<EM><A HREF="r.slope.aspect.html">r.slope.aspect</A></EM>; i.e. degrees
+counter-clockwise from east.
+<H2>NOTES</H2>
+There is no "undo" command or way to exit edit mode without saving
+changes.
+<P>
+Any MASK in place will be respected when writing the new raster map layer,
+including any edits to the MASKed areas.
+<H3>Geographic Region Concerns</H3>
+<EM>d.rast.edit</EM> reads the region definition for the raster map layer
+being edited from its internal cell header file. The new, edited copy of
+the raster layer will be created with the same resolution and region
+dimensions.
+<P>
+The primary bane of the <EM>d.rast.edit</EM> program involves large map
+layers with lots of rows and columns) and/or slow computers,
+since the program must read and write raster map layers row by row for
+the full size of the map layer as dictated by its region size and resolution.
+(The current region settings of north, south, east, and west
+will not limit the size of the edited copy of the map layer,
+since by use of the overview selection these values may change several
+times during the editing session).
+<H2>TODO</H2>
+<!-- not true, but it would be nice
+<EM>d.rast.edit</EM> will not create a new raster map layer if
+the user makes no cell edits while running the program.
+<P>
+It would be nice to incorporate a scrollable version of <EM>
+<A HREF="d.legend.html">d.legend</A>
+</EM>
+(such that one could see a label legend for files with many categories on
+a standard size sub-frame).  It would be even nicer to be able
+to select the category values from a graphical legend when editing
+cell values (thereby saving a trip to the text frame to type in the
+new value).
+<P>
+Perhaps method(s) for multiple  or mass cell edits would be useful.
+This could be done by providing modes in which the user may:<BR>
+1) edit a block of cells to a given value by drawing a box;<BR>
+2) be able to choose a given value which is automatically used as
+the new value on each cell chosen until a different value is desired.
+<P>
+There is no interrupt handling. <!-- ?? --> This could leave files in .tmp
+or (rarely) result in half-baked raster maps.  The original file
+would survive unscathed by an interrupt at most any point in execution.
+Beware of exiting the program
+by means other than using <EM>exit</EM> on the <EM>Main Menu</EM>.
 <H2>SEE ALSO</H2>
-<em><a href="d.rast.arrow.html">d.rast.arrow</a></em>,
-<em><a href="d.rast.num.html">d.rast.num</a></em>
+<em>
+<a href="d.rast.arrow.html">d.rast.arrow</a>,
+<a href="d.rast.num.html">d.rast.num</a>
+</em>
 <H2>AUTHOR</H2>
-Glynn Clements
+Tcl/Tk version: Glynn Clements<BR>
+<BR>
+Replaces Xdriver version in C by Chris Rewerts,
+Agricultural Engineering,
+Purdue University
 <p>
 <i>Last changed: $Date$</i>
