[GRASS-SVN] r36242 - in grass/branches/releasebranch_6_4: locale/po vector/v.surf.rst
Sun Mar 8 01:13:56 EST 2009
Author: neteler
Date: 2009-03-08 01:13:52 -0500 (Sun, 08 Mar 2009)
New Revision: 36242
   grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
   grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
msg cosmetics
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7262,7 +7262,7 @@
 msgstr "المشتقات الجزئية المخرجة"
 #: ../vector/v.surf.rst/main.c:206 ../vector/lidar/v.surf.bspline/main.c:145
-msgid "Field value. If set to 0, z coordinates are used. (3D vector only)"
+msgid "If set to 0, z coordinates are used. (3D vector only)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:214
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -23512,7 +23512,7 @@
 msgstr "Pou¾ij napìtí závislé na mìøítku"
 #: ../vector/v.surf.rst/main.c:206 ../vector/lidar/v.surf.bspline/main.c:147
 msgstr ""
 "Èíslo vrstvy. Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D "
 "vektorù)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -16242,8 +16242,8 @@
 msgstr "Name der Karte, die Interpolationsfehler enthält."
 #: ../vector/lidar/v.surf.bspline/main.c:145 ../vector/v.surf.rst/main.c:206
-msgstr "Feldwert. Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
+msgstr "Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
 #: ../vector/lidar/v.surf.bspline/main.c:155
 msgid "Attribute table column with values to interpolate (if layer>0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -6858,7 +6858,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7342,10 +7342,9 @@
 msgstr "Producir derivadas parciales en vez de parámetros topográficos"
 msgstr ""
-"Valor de campo. Si se establece a 0, se usarán las coordenadas Z (sólo "
-"vectoriales 3D)"
+"Si se establece a 0, se usarán las coordenadas Z (sólo vectoriales 3D)"
 msgid ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -20698,10 +20698,9 @@
 msgstr "Utiliser une tension dépendante de l'échelle"
 msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+"Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
 msgid ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7391,7 +7391,7 @@
 #, fuzzy
 msgstr "फील्ड सेट ज़ेड"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7226,7 +7226,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7351,7 +7351,7 @@
 #, fuzzy
 msgstr "���"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -6980,7 +6980,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7200,7 +7200,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7039,7 +7039,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7365,7 +7365,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7509,10 +7509,9 @@
 msgstr "Gera derivadas parciais em vez"
 msgstr ""
-"Valor do campo. Se definido em 0, coordenadas z serão usadas. (vetor 3D "
-"apenas)"
+"Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
 #, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7520,10 +7520,9 @@
 msgstr ""
-"apenas)"
 #, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7282,10 +7282,9 @@
 msgstr "Вывод частных производных вместо топографических параметров"
 msgstr ""
-"Значение поля. Если установлено в 0, используются координаты z (только 3D "
-"вектор)"
+"Если установлено в 0, используются координаты z (только 3D вектор)"
 msgid ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7305,7 +7305,7 @@
 msgstr "Izhodni rastrski sloj z morfometriènimi parametri"
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7162,8 +7162,8 @@
 msgstr "ออกผลลัพธ์ partial derivatives แทน ตัวแปร topographic"
-msgstr "ค่า Field. ถ้ากำหนดเป็น 0, จะใช้ค่าพิกัด z แทน. (เท่านั้น 3D vector)"
+msgstr "ถ้ากำหนดเป็น 0, จะใช้ค่าพิกัด z แทน. (เท่านั้น 3D vector)"
 msgid ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -6989,7 +6989,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7484,9 +7484,9 @@
 msgstr "Các đạo hàm riêng ở đầu ra thay vì các tham số địa hình"
 msgstr ""
-"Giá trị trường. Nếu là 0, các tọa độ z được dùng. (Chỉ áp dụng cho vector 3D)"
+"Nếu là 0, các tọa độ z được dùng. (Chỉ áp dụng cho vector 3D)"
 msgid ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po	2009-03-08 06:13:52 UTC (rev 36242)
@@ -7253,7 +7253,7 @@
 msgstr "输出偏导数而不是地形参数"
 msgstr "字段值。如果设置为0,则表明使用 z 坐标。(仅用于 3D 矢量)"
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c	2009-03-08 06:13:40 UTC (rev 36241)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c	2009-03-08 06:13:52 UTC (rev 36242)
@@ -203,7 +203,7 @@
     parm.field = G_define_standard_option(G_OPT_V_FIELD);
     parm.field->description =
-	_("Field value. If set to 0, z coordinates are used. (3D vector only)");
+	_("If set to 0, z coordinates are used. (3D vector only)");
     parm.field->answer = "1";
     parm.zcol = G_define_option();
