[GRASS-SVN] r36243 - in grass/trunk: locale/po vector/v.surf.rst
Sun Mar 8 01:19:05 EST 2009
Author: neteler
Date: 2009-03-08 01:19:00 -0500 (Sun, 08 Mar 2009)
New Revision: 36243
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/vector/v.surf.rst/main.c
msg cosmetics
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_ar.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9036,7 +9036,7 @@
 msgstr "المشتقات الجزئية المخرجة"
 #: ../vector/v.surf.rst/main.c:174 ../vector/lidar/v.surf.bspline/main.c:147
-msgid "Field value. If set to 0, z coordinates are used. (3D vector only)"
+msgid "If set to 0, z coordinates are used. (3D vector only)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:182
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_cs.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -22010,10 +22010,9 @@
 msgstr "Pou¾ij napìtí závislé na mìøítku"
 #: ../vector/v.surf.rst/main.c:174 ../vector/lidar/v.surf.bspline/main.c:149
 msgstr ""
-"Èíslo vrstvy. Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D "
-"vektorù)"
+"Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D vektorù)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_de.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8921,9 +8921,9 @@
 "Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
 msgstr ""
-"Feldwert. Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
+"Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
 msgid ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_el.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8481,7 +8481,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_es.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9073,10 +9073,9 @@
 msgstr "Producir derivadas parciales en vez de parámetros topográficos"
 msgstr ""
-"Valor de campo. Si se establece a 0, se usarán las coordenadas Z (sólo "
-"vectoriales 3D)"
+"Si se establece a 0, se usarán las coordenadas Z (sólo vectoriales 3D)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_fr.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9706,10 +9706,9 @@
 "Affiche les dérivées partielles à la place des paramètres topographiques"
 msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+"Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_hi.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9162,7 +9162,7 @@
 #, fuzzy
 msgstr "फील्ड सेट ज़ेड"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_it.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8997,7 +8997,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_ja.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9128,7 +9128,7 @@
 #, fuzzy
 msgstr "���"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_ko.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8620,7 +8620,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_lv.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8969,7 +8969,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_mr.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8707,7 +8707,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_pl.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9088,7 +9088,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_pt.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9394,10 +9394,9 @@
 msgstr "Gera derivadas parciais em vez"
 msgstr ""
-"Valor do campo. Se definido em 0, coordenadas z serão usadas. (vetor 3D "
-"apenas)"
+"Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9408,10 +9408,9 @@
 msgstr ""
-"apenas)"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_ru.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8984,10 +8984,9 @@
 msgstr "Вывод частных производных вместо топографических параметров"
 msgstr ""
-"Значение поля. Если установлено в 0, используются координаты z (только 3D "
-"вектор)"
+"Если установлено в 0, используются координаты z (только 3D вектор)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_sl.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9095,7 +9095,7 @@
 msgstr "Izhodni rastrski sloj z morfometriènimi parametri"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_th.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8822,8 +8822,8 @@
 msgstr "ออกผลลัพธ์ partial derivatives แทน ตัวแปร topographic"
-msgstr "ค่า Field. ถ้ากำหนดเป็น 0, จะใช้ค่าพิกัด z แทน. (เท่านั้น 3D vector)"
+msgstr "ถ้ากำหนดเป็น 0, จะใช้ค่าพิกัด z แทน. (เท่านั้น 3D vector)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_tr.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -8598,7 +8598,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_vi.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9314,9 +9314,9 @@
 msgstr "Các đạo hàm riêng ở đầu ra thay vì các tham số địa hình"
 msgstr ""
-"Giá trị trường. Nếu là 0, các tọa độ z được dùng. (Chỉ áp dụng cho vector 3D)"
+"Nếu là 0, các tọa độ z được dùng. (Chỉ áp dụng cho vector 3D)"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/locale/po/grassmods_zh.po	2009-03-08 06:19:00 UTC (rev 36243)
@@ -9031,7 +9031,7 @@
 msgstr "输出偏导数而不是地形参数"
 msgstr "字段值。如果设置为0,则表明使用 z 坐标。(仅用于 3D 矢量)"
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2009-03-08 06:13:52 UTC (rev 36242)
+++ grass/trunk/vector/v.surf.rst/main.c	2009-03-08 06:19:00 UTC (rev 36243)
@@ -171,7 +171,7 @@
     parm.field = G_define_standard_option(G_OPT_V_FIELD);
     parm.field->description =
-	_("Field value. If set to 0, z coordinates are used. (3D vector only)");
+	_("If set to 0, z coordinates are used. (3D vector only)");
     parm.field->answer = "1";
     parm.zcol = G_define_option();
