[GRASS-SVN] r36331 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Mar 11 06:16:33 EDT 2009
Author: martinl
Date: 2009-03-11 06:16:33 -0400 (Wed, 11 Mar 2009)
New Revision: 36331
   grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
clean r36317, don't use grass.run_command() - use gcmd.RunCommand()
instead
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-03-11 10:09:18 UTC (rev 36330)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-03-11 10:16:33 UTC (rev 36331)
@@ -1861,12 +1861,19 @@
                 os.mkdir(database)
             # change to new GISDbase directory
-            grass.run_command('g.gisenv', set='GISDBASE=%s' % database)
+            gcmd.RunCommand('g.gisenv',
+                            parent = self.wizard,
+                            set='GISDBASE=%s' % database)
             wx.MessageBox(parent=self.wizard,
-                                message=_("You will need to change the default GIS data directory in the GRASS startup screen"),
-                                caption=("Location <%s> will be created in GIS data directory <%s>") % \
-                                    (location,database), style=wx.OK | wx.ICON_ERROR)
+                          message=_("Location <%(loc)s> will be created "
+                                    "in GIS data directory <%(dir)s>."
+                                    "You will need to change the default GIS "
+                                    "data directory in the GRASS startup screen.") % \
+                              { 'loc' : location, 'dir' : database},
+                          caption=_("New GIS data directory"),
+                          style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
         if coordsys == "xy":
             success = self.XYCreate()
         elif coordsys == "latlong":
