[GRASS-SVN] r36381 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sat Mar 14 15:29:22 EDT 2009
Author: martinl
Date: 2009-03-14 15:29:22 -0400 (Sat, 14 Mar 2009)
New Revision: 36381
Added:
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
wxGUI: dialogs from dbm moved to dbm_dialogs
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2009-03-14 14:37:27 UTC (rev 36380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py	2009-03-14 19:29:22 UTC (rev 36381)
@@ -1,6 +1,7 @@
 all = [
     "colorrules.py",
     "dbm.py",
+    "dbm_dialogs.py",
     "debug.py",
     "disp_print.py",
     "gcmd.py",
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-03-14 14:37:27 UTC (rev 36380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-03-14 19:29:22 UTC (rev 36381)
@@ -17,11 +17,9 @@
  - Log
  - VirtualAttributeList
  - AttributeManager
- - DisplayAttributesDialog
  - VectorDBInfo
- - ModifyTableRecord
-(C) 2007-2008 by the GRASS Development Team
+(C) 2007-2009 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -48,14 +46,14 @@
 import wx
 import wx.lib.mixins.listctrl as listmix
 import wx.lib.flatnotebook as FN
-import wx.lib.scrolledpanel as scrolled
 import sqlbuilder
 import gcmd
 import utils
 import gdialogs
 import gselect
-from debug import Debug as Debug
+from debug import Debug
+from dbm_dialogs import ModifyTableRecord
 from preferences import globalSettings as UserSettings
 def unicodeValue(value):
@@ -2894,460 +2892,6 @@
         event.Skip()
-class DisplayAttributesDialog(wx.Dialog):
-    Standard dialog used to add/update/display attributes linked
-    to the vector map.
-    Attribute data can be selected based on layer and category number
-    or coordinates.
-    @param parent
-    @param map vector map
-    @param query query coordinates and distance (used for v.edit)
-    @param cats {layer: cats}
-    @param line feature id (requested for cats)
-    @param style
-    @param pos
-    @param action (add, update, display)
-    def __init__(self, parent, map,
-                 query=None, cats=None, line=None,
-                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
-                 pos=wx.DefaultPosition,
-                 action="add"):
-        self.parent = parent # mapdisplay.BufferedWindow
-        self.map    = map
-        self.action = action
-        # ids/cats of selected features
-        # fid : {layer : cats}
-        self.cats = {}
-        self.fid = -1 # feature id
-        # get layer/table/column information
-        self.mapDBInfo = VectorDBInfo(self.map)
-        layers = self.mapDBInfo.layers.keys() # get available layers
-        # check if db connection / layer exists
-        if len(layers) <= 0:
-            label = _("Database connection "
-                      "is not defined in DB file.")
-            wx.MessageBox(parent=self.parent,
-                          message=_("No attribute table linked to "
-                                    "vector map <%(vector)s> found. %(msg)s"
-                                    "\nYou can disable this message from digitization settings. Or "
-                                    "you can create and link attribute table to the vector map "
-                                    "using Attribute Table Manager.") %
-                          {'vector' : self.map, 'msg' : label},
-                          caption=_("Message"), style=wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
-            self.mapDBInfo = None
-        wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY,
-                           title="", style=style, pos=pos)
-        # dialog body
-        mainSizer = wx.BoxSizer(wx.VERTICAL)
-        # notebook
-        self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
-        self.closeDialog = wx.CheckBox(parent=self, id=wx.ID_ANY,
-                                       label=_("Close dialog on submit"))
-        self.closeDialog.SetValue(True)
-        # feature id (text/choice for duplicates)
-        self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
-                                  size=(150, -1))
-        self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
-        self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
-        self.noFoundMsg = wx.StaticText(parent=self, id=wx.ID_ANY,
-                                        label=_("No attributes found"))
-        self.UpdateDialog(query=query, cats=cats)
-        # set title
-        if self.action == "update":
-            self.SetTitle(_("Update attributes"))
-        elif self.action == "add":
-            self.SetTitle(_("Add attributes"))
-        else:
-            self.SetTitle(_("Display attributes"))
-        # buttons
-        btnCancel = wx.Button(self, wx.ID_CANCEL)
-        btnReset  = wx.Button(self, wx.ID_UNDO, _("&Reload"))
-        btnSubmit = wx.Button(self, wx.ID_OK, _("&Submit"))
-        btnSizer = wx.StdDialogButtonSizer()
-        btnSizer.AddButton(btnCancel)
-        btnSizer.AddButton(btnReset)
-        btnSizer.SetNegativeButton(btnReset)
-        btnSubmit.SetDefault()
-        btnSizer.AddButton(btnSubmit)
-        btnSizer.Realize()
-        mainSizer.Add(item=self.noFoundMsg, proportion=0,
-                      flag=wx.EXPAND | wx.ALL, border=5)
-        mainSizer.Add(item=self.notebook, proportion=1,
-        fidSizer = wx.BoxSizer(wx.HORIZONTAL)
-        fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
-                                        label=_("Feature id:")),
-                     proportion=0, border=5,
-                     flag=wx.ALIGN_CENTER_VERTICAL)
-        fidSizer.Add(item=self.fidMulti, proportion=0,
-        fidSizer.Add(item=self.fidText, proportion=0,
-        mainSizer.Add(item=fidSizer, proportion=0,
-                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
-        mainSizer.Add(item=self.closeDialog, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT,
-                      border=5)
-        mainSizer.Add(item=btnSizer, proportion=0,
-                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
-        # bindigs
-        btnReset.Bind(wx.EVT_BUTTON, self.OnReset)
-        btnSubmit.Bind(wx.EVT_BUTTON, self.OnSubmit)
-        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
-        self.SetSizer(mainSizer)
-        mainSizer.Fit(self)
-        # set min size for dialog
-        w, h = self.GetBestSize()
-        if h < 200:
-            self.SetMinSize((w, 200))
-        else:
-            self.SetMinSize(self.GetBestSize())
-        if self.notebook.GetPageCount() == 0:
-            Debug.msg(2, "DisplayAttributesDialog(): Nothing found!")
-            ### self.mapDBInfo = None
-    def __SelectAttributes(self, layer):
-        """Select attributes"""
-        pass
-    def OnSQLStatement(self, event):
-        """Update SQL statement"""
-        pass
-    def GetSQLString(self, updateValues=False):
-        """Create SQL statement string based on self.sqlStatement
-        If updateValues is True, update dataFrame according to values
-        in textfields.
-        sqlCommands = []
-        # find updated values for each layer/category
-        for layer in self.mapDBInfo.layers.keys(): # for each layer
-            table = self.mapDBInfo.layers[layer]["table"]
-            key = self.mapDBInfo.layers[layer]["key"]
-            columns = self.mapDBInfo.tables[table]
-            for idx in range(len(columns[key]['values'])): # for each category
-                updatedColumns = []
-                updatedValues = []
-                for name in columns.keys():
-                    if name == key:
-                        cat = columns[name]['values'][idx]
-                        continue
-                    type  = columns[name]['type']
-                    value = columns[name]['values'][idx]
-                    id    = columns[name]['ids'][idx]
-                    try:
-                        newvalue = self.FindWindowById(id).GetValue()
-                    except:
-                        newvalue = self.FindWindowById(id).GetLabel()
-                    if newvalue == '':
-                        newvalue = None
-                    if newvalue != value:
-                        updatedColumns.append(name)
-                        if newvalue is None:
-                            updatedValues.append('NULL')
-                        else:
-                            if type != 'character':
-                                updatedValues.append(newvalue)
-                            else:
-                                updatedValues.append("'" + newvalue + "'")
-                        columns[name]['values'][idx] = newvalue
-                if self.action != "add" and len(updatedValues) == 0:
-                    continue
-                if self.action == "add":
-                    sqlString = "INSERT INTO %s (%s," % (table, key)
-                else:
-                    sqlString = "UPDATE %s SET " % table
-                for idx in range(len(updatedColumns)):
-                    name = updatedColumns[idx]
-                        sqlString += name + ","
-                    else:
-                        sqlString += name + "=" + updatedValues[idx] + ","
-                sqlString = sqlString[:-1] # remove last comma
-                    sqlString += ") VALUES (%s," % cat
-                    for value in updatedValues:
-                        sqlString += str(value) + ","
-                    sqlString += ")"
-                else:
-                    sqlString += " WHERE cat=%s" % cat
-                sqlCommands.append(sqlString)
-            # for each category
-        # for each layer END
-        Debug.msg(3, "DisplayAttributesDialog.GetSQLString(): %s" % sqlCommands)
-        return sqlCommands
-    def OnReset(self, event):
-        """Reset form"""
-                    try:
-                    except IndexError:
-                        id = wx.NOT_FOUND
-                    if name != key and id != wx.NOT_FOUND:
-                        self.FindWindowById(id).SetValue(str(value))
-    def OnCancel(self, event):
-        """Cancel button pressed"""
-        self.parent.parent.dialogs['attributes'] = None
-        if self.parent.parent.digit:
-            self.parent.parent.digit.driver.SetSelected([])
-            self.parent.UpdateMap(render=False)
-        else:
-            self.parent.parent.OnRender(None)
-        self.Close()
-    def OnSubmit(self, event):
-        """Submit records"""
-        for sql in self.GetSQLString(updateValues=True):
-            enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
-            if not enc and \
-                    os.environ.has_key('GRASS_DB_ENCODING'):
-                enc = os.environ['GRASS_DB_ENCODING']
-            if enc:
-                sql = sql.encode(enc)
-            gcmd.RunCommand('db.execute',
-                            quiet = True,
-                            stdin = sql)
-        if self.closeDialog.IsChecked():
-            self.OnCancel(event)
-    def OnFeature(self, event):
-        self.fid = int(event.GetString())
-        self.UpdateDialog(cats=self.cats, fid=self.fid)
-    def GetCats(self):
-        """Get id of selected vector object or 'None' if nothing selected
-        @param id if true return ids otherwise cats
-        if self.fid < 0:
-            return None
-        return self.cats[self.fid]
-    def GetFid(self):
-        """Get selected feature id"""
-        return self.fid
-    def UpdateDialog(self, map=None, query=None, cats=None, fid=-1):
-        """Update dialog
-        Return True if updated otherwise False
-        if map:
-            self.map = map
-        if not self.mapDBInfo:
-            return False
-        self.mapDBInfo.Reset()
-        # id of selected line
-        if query: # select by position
-            data = self.mapDBInfo.SelectByPoint(query[0],
-                                                query[1])
-            self.cats = {}
-            if data and data.has_key('Layer'):
-                idx = 0
-                for layer in data['Layer']:
-                    layer = int(layer)
-                    if data.has_key('Id'):
-                        tfid = int(data['Id'][idx])
-                    else:
-                        tfid = 0 # Area / Volume
-                    if not self.cats.has_key(tfid):
-                        self.cats[tfid] = {}
-                    if not self.cats[tfid].has_key(layer):
-                        self.cats[tfid][layer] = []
-                    cat = int(data['Category'][idx])
-                    self.cats[tfid][layer].append(cat)
-                    idx += 1
-        else:
-            self.cats = cats
-        if fid > 0:
-            self.fid = fid
-        elif len(self.cats.keys()) > 0:
-            self.fid = self.cats.keys()[0]
-        else:
-            self.fid = -1
-        if len(self.cats.keys()) == 1:
-            self.fidMulti.Show(False)
-            self.fidText.Show(True)
-            if self.fid > 0:
-                self.fidText.SetLabel("%d" % self.fid)
-            else:
-                self.fidText.SetLabel(_("Unknown"))
-        else:
-            self.fidMulti.Show(True)
-            self.fidText.Show(False)
-            choices = []
-            for tfid in self.cats.keys():
-                choices.append(str(tfid))
-            self.fidMulti.SetItems(choices)
-            self.fidMulti.SetStringSelection(str(self.fid))
-        # reset notebook
-        self.notebook.DeleteAllPages()
-        for layer in layers: # for each layer
-            if not query: # select by layer/cat
-                if self.fid > 0 and self.cats[self.fid].has_key(layer):
-                    for cat in self.cats[self.fid][layer]:
-                        nselected = self.mapDBInfo.SelectFromTable(layer,
-        where="%s=%d" % \
-        (self.mapDBInfo.layers[layer]['key'],
-        cat))
-                else:
-                    nselected = 0
-            # if nselected <= 0 and self.action != "add":
-            #    continue # nothing selected ...
-                if nselected <= 0:
-                    if self.cats[self.fid].has_key(layer):
-                            if name == key:
-                                    self.mapDBInfo.tables[table][name]['values'].append(cat)
-                            else:
-                                self.mapDBInfo.tables[table][name]['values'].append(None)
-                else: # change status 'add' -> 'update'
-                    self.action = "update"
-                    if name == key:
-                        cat = int(columns[name]['values'][idx])
-                        break
-                # use scrolled panel instead (and fix initial max height of the window to 480px)
-                panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
-                                               size=(-1, 150))
-                panel.SetupScrolling(scroll_x=False)
-                self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
-        _("Category"), cat))
-                # notebook body
-                border = wx.BoxSizer(wx.VERTICAL)
-                flexSizer = wx.FlexGridSizer (cols=4, hgap=3, vgap=3)
-                flexSizer.AddGrowableCol(3)
-                # columns (sorted by index)
-                names = [''] * len(columns.keys())
-                    names[columns[name]['index']] = name
-                for name in names:
-                    if name == key: # skip key column (category)
-                        continue
-                    vtype  = columns[name]['type']
-                    if columns[name]['values'][idx] is not None:
-                        if columns[name]['ctype'] != type(''):
-                            value = str(columns[name]['values'][idx])
-                        else:
-                    else:
-                        value = ''
-                    colName = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                            label=name)
-                    colType = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                            label="[" + vtype.lower() + "]")
-                    delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
-                    colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value)
-                    colValue.SetName(name)
-                    self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
-                    flexSizer.Add(colName, proportion=0,
-                                  flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
-                    flexSizer.Add(colType, proportion=0,
-                    flexSizer.Add(delimiter, proportion=0,
-                    flexSizer.Add(colValue, proportion=1,
-                                  flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
-                    # add widget reference to self.columns
-                    columns[name]['ids'].append(colValue.GetId()) # name, type, values, id
-                # for each attribute (including category) END
-                border.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
-                panel.SetSizer(border)
-            # for each category END
-            self.noFoundMsg.Show(True)
-        else:
-            self.noFoundMsg.Show(False)
-        self.Layout()
-        return True
 class VectorDBInfo(gselect.VectorDBInfo):
     """Class providing information about attribute tables
     linked to the vector map"""
@@ -3471,156 +3015,6 @@
         return nselected
-class ModifyTableRecord(wx.Dialog):
-    """Dialog for inserting/updating table record"""
-    def __init__(self, parent, id, title, data, keyEditable=(-1, True),
-                style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
-        Notes:
-         'Data' is a list: [(column, value)]
-         'KeyEditable' (id, editable?) indicates if textarea for key column
-          is editable(True) or not.
-        wx.Dialog.__init__(self, parent, id, title, style=style)
-        self.keyId = keyEditable[0]
-        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
-        self.dataPanel = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY,
-                                            style=wx.TAB_TRAVERSAL)
-        self.dataPanel.SetupScrolling(scroll_x=False)
-        # buttons
-        self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
-        self.btnSubmit = wx.Button(self.panel, wx.ID_OK, _("Submit"))
-        self.btnSubmit.SetDefault()
-        # data area
-        self.widgets = []
-        id = 0
-        self.box = False
-        self.cat = None
-        for column, value in data:
-            if keyEditable[0] == id:
-                self.cat = int(value)
-                if keyEditable[1] == False:
-                    self.box = True
-                    id += 1
-                    continue
-                else:
-                    valueWin = wx.SpinCtrl(parent=self.dataPanel, id=wx.ID_ANY,
-                                           value=value, min=-1e9, max=1e9, size=(250, -1))
-            else:
-                valueWin = wx.TextCtrl(parent=self.dataPanel, id=wx.ID_ANY,
-                                       value=value, size=(250, -1))
-            label = wx.StaticText(parent=self.dataPanel, id=wx.ID_ANY,
-                                  label=column + ":")
-            self.widgets.append((label.GetId(),
-                                 valueWin.GetId()))
-            id += 1
-        self.__Layout()
-        # winSize = self.GetSize()
-        # fix height of window frame if needed
-        # if winSize[1] > 480:
-        #    winSize[1] = 480
-        #    self.SetSize(winSize)
-        # self.SetMinSize(winSize)
-    def __Layout(self):
-        """Do layout"""
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        if self.box:
-            box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
-                               label=" %s %d " % (_("Category"), self.cat))
-            boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        # data area
-        dataSizer = wx.FlexGridSizer (cols=2, hgap=3, vgap=3)
-        dataSizer.AddGrowableCol(1)
-        for labelId, valueId in self.widgets:
-            label = self.FindWindowById(labelId)
-            value = self.FindWindowById(valueId)
-            dataSizer.Add(label, proportion=0,
-            dataSizer.Add(value, proportion=0,
-        self.dataPanel.SetAutoLayout(True)
-        self.dataPanel.SetSizer(dataSizer)
-        dataSizer.Fit(self.dataPanel)
-        if self.box:
-            boxSizer.Add(item=self.dataPanel, proportion=1,
-        # buttons
-        btnSizer.AddButton(self.btnCancel)
-        btnSizer.AddButton(self.btnSubmit)
-        if not self.box:
-            sizer.Add(item=self.dataPanel, proportion=1,
-        else:
-            sizer.Add(item=boxSizer, proportion=1,
-        sizer.Add(item=btnSizer, proportion=0,
-        #sizer.SetSizeHints(self.panel)
-        self.panel.SetAutoLayout(True)
-        self.panel.SetSizer(sizer)
-        sizer.Fit(self.panel)
-        self.Layout()
-        # set window frame size (min & max)
-        minFrameHeight = 150
-        maxFrameHeight = 2 * minFrameHeight
-        if self.GetSize()[1] > minFrameHeight:
-            self.SetMinSize((self.GetSize()[0], minFrameHeight))
-        else:
-            self.SetMinSize(self.GetSize())
-        if self.GetSize()[1] > maxFrameHeight:
-            self.SetSize((self.GetSize()[0], maxFrameHeight))
-        else:
-            self.SetSize(self.panel.GetSize())
-    def GetValues(self, columns=None):
-        """Return list of values (casted to string).
-        If columns is given (list), return only values of given columns.
-        valueList = []
-            column = self.FindWindowById(labelId).GetLabel().replace(':', '')
-            if columns is None or column in columns:
-                value = str(self.FindWindowById(valueId).GetValue())
-                valueList.append(value)
-        # add key value
-        if self.box:
-            valueList.insert(self.keyId, str(self.cat))
-        return valueList
 def main(argv=None):
     if argv is None:
         argv = sys.argv
Added: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py	2009-03-14 19:29:22 UTC (rev 36381)
@@ -0,0 +1,635 @@
+ at package dbm_dialogs.py
+ at brief DBM-related dialogs
+List of classes:
+ - DisplayAttributesDialog
+ - ModifyTableRecord
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+    globalvar.CheckForWx()
+import wx
+import wx.lib.scrolledpanel as scrolled
+import dbm
+import gcmd
+from preferences import globalSettings as UserSettings
+class DisplayAttributesDialog(wx.Dialog):
+    Standard dialog used to add/update/display attributes linked
+    to the vector map.
+    Attribute data can be selected based on layer and category number
+    or coordinates.
+    @param parent
+    @param map vector map
+    @param query query coordinates and distance (used for v.edit)
+    @param cats {layer: cats}
+    @param line feature id (requested for cats)
+    @param style
+    @param pos
+    @param action (add, update, display)
+    def __init__(self, parent, map,
+                 query=None, cats=None, line=None,
+                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+                 pos=wx.DefaultPosition,
+                 action="add"):
+        self.parent = parent # mapdisplay.BufferedWindow
+        self.map    = map
+        self.action = action
+        # ids/cats of selected features
+        # fid : {layer : cats}
+        self.cats = {}
+        self.fid = -1 # feature id
+        # get layer/table/column information
+        self.mapDBInfo = dbm.VectorDBInfo(self.map)
+        layers = self.mapDBInfo.layers.keys() # get available layers
+        # check if db connection / layer exists
+        if len(layers) <= 0:
+            label = _("Database connection "
+                      "is not defined in DB file.")
+            wx.MessageBox(parent=self.parent,
+                          message=_("No attribute table linked to "
+                                    "vector map <%(vector)s> found. %(msg)s"
+                                    "\nYou can disable this message from digitization settings. Or "
+                                    "you can create and link attribute table to the vector map "
+                                    "using Attribute Table Manager.") %
+                          {'vector' : self.map, 'msg' : label},
+                          caption=_("Message"), style=wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
+            self.mapDBInfo = None
+        wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY,
+                           title="", style=style, pos=pos)
+        # dialog body
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        # notebook
+        self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        self.closeDialog = wx.CheckBox(parent=self, id=wx.ID_ANY,
+                                       label=_("Close dialog on submit"))
+        self.closeDialog.SetValue(True)
+        # feature id (text/choice for duplicates)
+        self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
+                                  size=(150, -1))
+        self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
+        self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
+        self.noFoundMsg = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label=_("No attributes found"))
+        self.UpdateDialog(query=query, cats=cats)
+        # set title
+        if self.action == "update":
+            self.SetTitle(_("Update attributes"))
+        elif self.action == "add":
+            self.SetTitle(_("Add attributes"))
+        else:
+            self.SetTitle(_("Display attributes"))
+        # buttons
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnReset  = wx.Button(self, wx.ID_UNDO, _("&Reload"))
+        btnSubmit = wx.Button(self, wx.ID_OK, _("&Submit"))
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(btnCancel)
+        btnSizer.AddButton(btnReset)
+        btnSizer.SetNegativeButton(btnReset)
+        btnSubmit.SetDefault()
+        btnSizer.AddButton(btnSubmit)
+        btnSizer.Realize()
+        mainSizer.Add(item=self.noFoundMsg, proportion=0,
+                      flag=wx.EXPAND | wx.ALL, border=5)
+        mainSizer.Add(item=self.notebook, proportion=1,
+        fidSizer = wx.BoxSizer(wx.HORIZONTAL)
+        fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label=_("Feature id:")),
+                     proportion=0, border=5,
+                     flag=wx.ALIGN_CENTER_VERTICAL)
+        fidSizer.Add(item=self.fidMulti, proportion=0,
+        fidSizer.Add(item=self.fidText, proportion=0,
+        mainSizer.Add(item=fidSizer, proportion=0,
+                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
+        mainSizer.Add(item=self.closeDialog, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT,
+                      border=5)
+        mainSizer.Add(item=btnSizer, proportion=0,
+                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+        # bindigs
+        btnReset.Bind(wx.EVT_BUTTON, self.OnReset)
+        btnSubmit.Bind(wx.EVT_BUTTON, self.OnSubmit)
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+        # set min size for dialog
+        w, h = self.GetBestSize()
+        if h < 200:
+            self.SetMinSize((w, 200))
+        else:
+            self.SetMinSize(self.GetBestSize())
+        if self.notebook.GetPageCount() == 0:
+            Debug.msg(2, "DisplayAttributesDialog(): Nothing found!")
+            ### self.mapDBInfo = None
+    def __SelectAttributes(self, layer):
+        """Select attributes"""
+        pass
+    def OnSQLStatement(self, event):
+        """Update SQL statement"""
+        pass
+    def GetSQLString(self, updateValues=False):
+        """Create SQL statement string based on self.sqlStatement
+        If updateValues is True, update dataFrame according to values
+        in textfields.
+        sqlCommands = []
+        # find updated values for each layer/category
+        for layer in self.mapDBInfo.layers.keys(): # for each layer
+            table = self.mapDBInfo.layers[layer]["table"]
+            key = self.mapDBInfo.layers[layer]["key"]
+            columns = self.mapDBInfo.tables[table]
+            for idx in range(len(columns[key]['values'])): # for each category
+                updatedColumns = []
+                updatedValues = []
+                for name in columns.keys():
+                    if name == key:
+                        cat = columns[name]['values'][idx]
+                        continue
+                    type  = columns[name]['type']
+                    value = columns[name]['values'][idx]
+                    id    = columns[name]['ids'][idx]
+                    try:
+                        newvalue = self.FindWindowById(id).GetValue()
+                    except:
+                        newvalue = self.FindWindowById(id).GetLabel()
+                    if newvalue == '':
+                        newvalue = None
+                    if newvalue != value:
+                        updatedColumns.append(name)
+                        if newvalue is None:
+                            updatedValues.append('NULL')
+                        else:
+                            if type != 'character':
+                                updatedValues.append(newvalue)
+                            else:
+                                updatedValues.append("'" + newvalue + "'")
+                        columns[name]['values'][idx] = newvalue
+                if self.action != "add" and len(updatedValues) == 0:
+                    continue
+                if self.action == "add":
+                    sqlString = "INSERT INTO %s (%s," % (table, key)
+                else:
+                    sqlString = "UPDATE %s SET " % table
+                for idx in range(len(updatedColumns)):
+                    name = updatedColumns[idx]
+                        sqlString += name + ","
+                    else:
+                        sqlString += name + "=" + updatedValues[idx] + ","
+                sqlString = sqlString[:-1] # remove last comma
+                    sqlString += ") VALUES (%s," % cat
+                    for value in updatedValues:
+                        sqlString += str(value) + ","
+                    sqlString += ")"
+                else:
+                    sqlString += " WHERE cat=%s" % cat
+                sqlCommands.append(sqlString)
+            # for each category
+        # for each layer END
+        Debug.msg(3, "DisplayAttributesDialog.GetSQLString(): %s" % sqlCommands)
+        return sqlCommands
+    def OnReset(self, event):
+        """Reset form"""
+                    try:
+                    except IndexError:
+                        id = wx.NOT_FOUND
+                    if name != key and id != wx.NOT_FOUND:
+                        self.FindWindowById(id).SetValue(str(value))
+    def OnCancel(self, event):
+        """Cancel button pressed"""
+        self.parent.parent.dialogs['attributes'] = None
+        if self.parent.parent.digit:
+            self.parent.parent.digit.driver.SetSelected([])
+            self.parent.UpdateMap(render=False)
+        else:
+            self.parent.parent.OnRender(None)
+        self.Close()
+    def OnSubmit(self, event):
+        """Submit records"""
+        for sql in self.GetSQLString(updateValues=True):
+            enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+            if not enc and \
+                    os.environ.has_key('GRASS_DB_ENCODING'):
+                enc = os.environ['GRASS_DB_ENCODING']
+            if enc:
+                sql = sql.encode(enc)
+            gcmd.RunCommand('db.execute',
+                            quiet = True,
+                            stdin = sql)
+        if self.closeDialog.IsChecked():
+            self.OnCancel(event)
+    def OnFeature(self, event):
+        self.fid = int(event.GetString())
+        self.UpdateDialog(cats=self.cats, fid=self.fid)
+    def GetCats(self):
+        """Get id of selected vector object or 'None' if nothing selected
+        @param id if true return ids otherwise cats
+        if self.fid < 0:
+            return None
+        return self.cats[self.fid]
+    def GetFid(self):
+        """Get selected feature id"""
+        return self.fid
+    def UpdateDialog(self, map=None, query=None, cats=None, fid=-1):
+        """Update dialog
+        Return True if updated otherwise False
+        if map:
+            self.map = map
+            self.mapDBInfo = VectorDBInfo(self.map)
+        if not self.mapDBInfo:
+            return False
+        self.mapDBInfo.Reset()
+        # id of selected line
+        if query: # select by position
+            data = self.mapDBInfo.SelectByPoint(query[0],
+                                                query[1])
+            self.cats = {}
+            if data and data.has_key('Layer'):
+                idx = 0
+                for layer in data['Layer']:
+                    layer = int(layer)
+                    if data.has_key('Id'):
+                        tfid = int(data['Id'][idx])
+                    else:
+                        tfid = 0 # Area / Volume
+                    if not self.cats.has_key(tfid):
+                        self.cats[tfid] = {}
+                    if not self.cats[tfid].has_key(layer):
+                        self.cats[tfid][layer] = []
+                    cat = int(data['Category'][idx])
+                    self.cats[tfid][layer].append(cat)
+                    idx += 1
+        else:
+            self.cats = cats
+        if fid > 0:
+            self.fid = fid
+        elif len(self.cats.keys()) > 0:
+            self.fid = self.cats.keys()[0]
+        else:
+            self.fid = -1
+        if len(self.cats.keys()) == 1:
+            self.fidMulti.Show(False)
+            self.fidText.Show(True)
+            if self.fid > 0:
+                self.fidText.SetLabel("%d" % self.fid)
+            else:
+                self.fidText.SetLabel(_("Unknown"))
+        else:
+            self.fidMulti.Show(True)
+            self.fidText.Show(False)
+            choices = []
+            for tfid in self.cats.keys():
+                choices.append(str(tfid))
+            self.fidMulti.SetItems(choices)
+            self.fidMulti.SetStringSelection(str(self.fid))
+        # reset notebook
+        self.notebook.DeleteAllPages()
+        for layer in layers: # for each layer
+            if not query: # select by layer/cat
+                if self.fid > 0 and self.cats[self.fid].has_key(layer):
+                    for cat in self.cats[self.fid][layer]:
+                        nselected = self.mapDBInfo.SelectFromTable(layer,
+        where="%s=%d" % \
+        (self.mapDBInfo.layers[layer]['key'],
+        cat))
+                else:
+                    nselected = 0
+            # if nselected <= 0 and self.action != "add":
+            #    continue # nothing selected ...
+                if nselected <= 0:
+                    if self.cats[self.fid].has_key(layer):
+                            if name == key:
+                                    self.mapDBInfo.tables[table][name]['values'].append(cat)
+                            else:
+                                self.mapDBInfo.tables[table][name]['values'].append(None)
+                else: # change status 'add' -> 'update'
+                    self.action = "update"
+                    if name == key:
+                        cat = int(columns[name]['values'][idx])
+                        break
+                # use scrolled panel instead (and fix initial max height of the window to 480px)
+                panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
+                                               size=(-1, 150))
+                panel.SetupScrolling(scroll_x=False)
+                self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
+        _("Category"), cat))
+                # notebook body
+                border = wx.BoxSizer(wx.VERTICAL)
+                flexSizer = wx.FlexGridSizer (cols=4, hgap=3, vgap=3)
+                flexSizer.AddGrowableCol(3)
+                # columns (sorted by index)
+                names = [''] * len(columns.keys())
+                    names[columns[name]['index']] = name
+                for name in names:
+                    if name == key: # skip key column (category)
+                        continue
+                    vtype  = columns[name]['type']
+                    if columns[name]['values'][idx] is not None:
+                        if columns[name]['ctype'] != type(''):
+                            value = str(columns[name]['values'][idx])
+                        else:
+                    else:
+                        value = ''
+                    colName = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                            label=name)
+                    colType = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                            label="[" + vtype.lower() + "]")
+                    delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
+                    colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value)
+                    colValue.SetName(name)
+                    self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
+                    flexSizer.Add(colName, proportion=0,
+                                  flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+                    flexSizer.Add(colType, proportion=0,
+                    flexSizer.Add(delimiter, proportion=0,
+                    flexSizer.Add(colValue, proportion=1,
+                                  flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+                    # add widget reference to self.columns
+                    columns[name]['ids'].append(colValue.GetId()) # name, type, values, id
+                # for each attribute (including category) END
+                border.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+                panel.SetSizer(border)
+            # for each category END
+            self.noFoundMsg.Show(True)
+        else:
+            self.noFoundMsg.Show(False)
+        self.Layout()
+        return True
+class ModifyTableRecord(wx.Dialog):
+    """Dialog for inserting/updating table record"""
+    def __init__(self, parent, id, title, data, keyEditable=(-1, True),
+                style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+        Notes:
+         'Data' is a list: [(column, value)]
+         'KeyEditable' (id, editable?) indicates if textarea for key column
+          is editable(True) or not.
+        wx.Dialog.__init__(self, parent, id, title, style=style)
+        self.keyId = keyEditable[0]
+        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+        self.dataPanel = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY,
+                                            style=wx.TAB_TRAVERSAL)
+        self.dataPanel.SetupScrolling(scroll_x=False)
+        # buttons
+        self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
+        self.btnSubmit = wx.Button(self.panel, wx.ID_OK, _("Submit"))
+        self.btnSubmit.SetDefault()
+        # data area
+        self.widgets = []
+        id = 0
+        self.box = False
+        self.cat = None
+        for column, value in data:
+            if keyEditable[0] == id:
+                self.cat = int(value)
+                if keyEditable[1] == False:
+                    self.box = True
+                    id += 1
+                    continue
+                else:
+                    valueWin = wx.SpinCtrl(parent=self.dataPanel, id=wx.ID_ANY,
+                                           value=value, min=-1e9, max=1e9, size=(250, -1))
+            else:
+                valueWin = wx.TextCtrl(parent=self.dataPanel, id=wx.ID_ANY,
+                                       value=value, size=(250, -1))
+            label = wx.StaticText(parent=self.dataPanel, id=wx.ID_ANY,
+                                  label=column + ":")
+            self.widgets.append((label.GetId(),
+                                 valueWin.GetId()))
+            id += 1
+        self.__Layout()
+        # winSize = self.GetSize()
+        # fix height of window frame if needed
+        # if winSize[1] > 480:
+        #    winSize[1] = 480
+        #    self.SetSize(winSize)
+        # self.SetMinSize(winSize)
+    def __Layout(self):
+        """Do layout"""
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        if self.box:
+            box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                               label=" %s %d " % (_("Category"), self.cat))
+            boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        # data area
+        dataSizer = wx.FlexGridSizer (cols=2, hgap=3, vgap=3)
+        dataSizer.AddGrowableCol(1)
+        for labelId, valueId in self.widgets:
+            label = self.FindWindowById(labelId)
+            value = self.FindWindowById(valueId)
+            dataSizer.Add(label, proportion=0,
+            dataSizer.Add(value, proportion=0,
+        self.dataPanel.SetAutoLayout(True)
+        self.dataPanel.SetSizer(dataSizer)
+        dataSizer.Fit(self.dataPanel)
+        if self.box:
+            boxSizer.Add(item=self.dataPanel, proportion=1,
+        # buttons
+        btnSizer.AddButton(self.btnCancel)
+        btnSizer.AddButton(self.btnSubmit)
+        if not self.box:
+            sizer.Add(item=self.dataPanel, proportion=1,
+        else:
+            sizer.Add(item=boxSizer, proportion=1,
+        sizer.Add(item=btnSizer, proportion=0,
+        #sizer.SetSizeHints(self.panel)
+        self.panel.SetAutoLayout(True)
+        self.panel.SetSizer(sizer)
+        sizer.Fit(self.panel)
+        self.Layout()
+        # set window frame size (min & max)
+        minFrameHeight = 150
+        maxFrameHeight = 2 * minFrameHeight
+        if self.GetSize()[1] > minFrameHeight:
+            self.SetMinSize((self.GetSize()[0], minFrameHeight))
+        else:
+            self.SetMinSize(self.GetSize())
+        if self.GetSize()[1] > maxFrameHeight:
+            self.SetSize((self.GetSize()[0], maxFrameHeight))
+        else:
+            self.SetSize(self.panel.GetSize())
+    def GetValues(self, columns=None):
+        """Return list of values (casted to string).
+        If columns is given (list), return only values of given columns.
+        valueList = []
+            column = self.FindWindowById(labelId).GetLabel().replace(':', '')
+            if columns is None or column in columns:
+                value = str(self.FindWindowById(valueId).GetValue())
+                valueList.append(value)
+        # add key value
+        if self.box:
+            valueList.insert(self.keyId, str(self.cat))
+        return valueList
Property changes on: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
___________________________________________________________________
   + text/x-python
   + Author Date Id
   + native
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2009-03-14 14:37:27 UTC (rev 36380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2009-03-14 19:29:22 UTC (rev 36381)
@@ -57,6 +57,7 @@
 import disp_print
 import gcmd
 import dbm
+import dbm_dialogs
 import histogram
 import profile
 import globalvar
@@ -1200,11 +1201,12 @@
         mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
         if self.dialogs['attributes'] is None:
-            self.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self.MapWindow,
-        map=mapName,
-        query=((east, north), qdist),
-        pos=posWindow,
-        action="update")
+            self.dialogs['attributes'] = \
+                dbm_dialogs.DisplayAttributesDialog(parent=self.MapWindow,
+                                                    map=mapName,
+                                                    query=((east, north), qdist),
+                                                    pos=posWindow,
+                                                    action="update")
         else:
             # selection changed?
             if not self.dialogs['attributes'].mapDBInfo or \
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-03-14 14:37:27 UTC (rev 36380)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-03-14 19:29:22 UTC (rev 36381)
@@ -25,6 +25,7 @@
 import wx
 import dbm
+import dbm_dialogs
 import gdialogs
 import gcmd
 import utils
@@ -1139,10 +1140,10 @@
                 posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
                                                  self.mouse['end'][1] + self.dialogOffset))
-                addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=mapLayer,
-                                                           cats=cats,
-                                                           pos=posWindow,
-                                                           action="add")
+                addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
+        cats=cats,
+        pos=posWindow,
+        action="add")
                 if addRecordDlg.mapDBInfo and \
                         addRecordDlg.ShowModal() == wx.ID_OK:
                     sqlfile = tempfile.NamedTemporaryFile(mode="w")
@@ -1234,9 +1235,10 @@
         if digitToolbar.GetAction() == "displayAttrs":
             # select attributes based on coordinates (all layers)
             if self.parent.dialogs['attributes'] is None:
-                self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=mapLayer,
-        cats=cats,
-        action="update")
+                self.parent.dialogs['attributes'] = \
+                    dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
+                                                        cats=cats,
+                                                        action="update")
             else:
                 # upgrade dialog
                 self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
@@ -1925,10 +1927,10 @@
                                     (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
-                        addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
-        cats=cats,
-        pos=posWindow,
-        action="add")
+                        addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
+        cats=cats,
+        pos=posWindow,
+        action="add")
