[GRASS-SVN] r36384 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Mar 15 01:27:48 EDT 2009
Author: cmbarton
Date: 2009-03-15 01:27:48 -0400 (Sun, 15 Mar 2009)
New Revision: 36384
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
Multiple fixes for Mac functioning and other fixes:
1) Fixed problem with no numeric data loading to attribute browse list on Mac
2) Fixed casting problems in editing values or entering new values
3) Fixed mouse locked out of staticbox in editing dialog on Mac
4) Fixed editing dialog sizing broken
5) Made a few error dialogs more understandable.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-03-14 22:27:56 UTC (rev 36383)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-03-15 05:27:48 UTC (rev 36384)
@@ -31,6 +31,7 @@
 import sys
 import os
+import platform
 import locale
 import tempfile
 import copy
@@ -253,7 +254,10 @@
                 # casting ...
                 if self.columns[columns[j]]['ctype'] != type(''):
                     try:
-                        self.itemDataMap[i].append(self.columns[columns[j]]['ctype'] (value))
+                        if platform.system() == "Darwin":
+                            self.itemDataMap[i].append(value)
+                        else:
+                            self.itemDataMap[i].append(self.columns[columns[j]]['ctype'](value))
                     except ValueError:
                         self.itemDataMap[i].append('')
                 else:
@@ -270,7 +274,7 @@
                         cat = -1
                         wx.MessageBox(parent=self,
                                       message=_("Error loading attribute data. "
-                                                "Record number: %(rec)d. Unable to cast value '%(val)s' in "
+                                                "Record number: %(rec)d. Unable to convert value '%(val)s' in "
                                                 "key column (%(key)s) to integer.\n\n"
                                                 "Details: %(detail)s") % \
                                           { 'rec' : i + 1, 'val' : value,
@@ -1256,9 +1260,15 @@
                             continue
                     try:
-                        values[i] = list.columns[columnName[i]]['ctype'] (values[i])
+                        if list.columns[columnName[i]]['ctype'] == int:
+                            # values[i] is stored as text.
+                            value = float(values[i])
+                        else:
+                            value = values[i]
+                        values[i] = list.columns[columnName[i]]['ctype'] (value)
                     except:
-                        raise ValueError(_("Casting value '%(value)s' to %(type)s failed.") %
+                        raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") %
                                          {'value' : str(values[i]),
                                           'type' : list.columns[columnName[i]]['type']})
                     columnsString += '%s,' % columnName[i]
@@ -1356,12 +1366,16 @@
                                 else:
                                     idx = i
                                 if list.columns[columnName[i]]['ctype'] != type(''):
+                                    else:
+                                        value = values[i]
                                     list.itemDataMap[item][idx] = \
-                                        list.columns[columnName[i]]['ctype'] (values[i])
+                                        list.columns[columnName[i]]['ctype'] (value)
                                 else:
                                     list.itemDataMap[item][idx] = values[i]
                             except:
-                                raise ValueError(_("Casting value '%(value)s' to %(type)s failed.") % \
+                                raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") % \
@@ -1371,6 +1385,7 @@
                                 updateString += "%s=%s," % (columnName[i], values[i])
                         else: # NULL
                             updateString += "%s=NULL," % (columnName[i])
             except ValueError, err:
                               message="%s%s%s" % (_("Unable to update existing record."),
@@ -1383,7 +1398,9 @@
                                                     (table, updateString.strip(','),
                                                      keyColumn, cat))
                 self.ApplyCommands()
+            list.Update(self.mapDBInfo)
     def OnDataReload(self, event):
         """Reload list of records"""
         self.OnApplySqlStatement(None)
