[GRASS-SVN] r36435 - grass/branches/releasebranch_6_4
Fri Mar 20 08:42:35 EDT 2009
Author: neteler
Date: 2009-03-20 08:42:35 -0400 (Fri, 20 Mar 2009)
New Revision: 36435
   grass/branches/releasebranch_6_4/SUBMITTING_DOCS
say how the docs are handled and generated
Modified: grass/branches/releasebranch_6_4/SUBMITTING_DOCS
--- grass/branches/releasebranch_6_4/SUBMITTING_DOCS	2009-03-20 12:42:27 UTC (rev 36434)
+++ grass/branches/releasebranch_6_4/SUBMITTING_DOCS	2009-03-20 12:42:35 UTC (rev 36435)
@@ -13,6 +13,24 @@
 [ see SUBMITTING_PYTHON for Python code hints ]
+0. Introduction
+   There are two types of documentation
+   - Libraries programmers docs: we use doxygen and document the functions
+      directly in the source code. See lib/*/*.c and lib/*/*.dox for examples
+   - User manual: we write it in simple HTML, storing the manual in a
+      file "description.html" within the subdirectory of the module.
+      The file contains no header nor footer. The complete HTML file is
+      autogenerated during the compilation process (indeed, it is generated
+      in a virtual session directly after compilation of the module).
+      In this virtual session the module is called internally with
+      --html-description which generates the parameters/flags list in
+      HTML format, along with "description.html", HTML header and footer
+      the final HTML manual page is created and stored in the target
+      binaries directory. In a separate process the MAN format is
+      generated from the complete HTML files.
 1. Editing of HTML pages
    To avoid insertion of too complicated HTML tags (see also below),
    we strongly suggest to use a plain text editor rather than a
