[GRASS-SVN] r36437 - grass/branches/develbranch_6/gui/wxpython/docs
Fri Mar 20 09:55:41 EDT 2009
Author: martinl
Date: 2009-03-20 09:55:41 -0400 (Fri, 20 Mar 2009)
New Revision: 36437
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
wxGUI: note "experimental prototype in manual pages of vdigit and nviz extensions"
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2009-03-20 12:43:27 UTC (rev 36436)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2009-03-20 13:55:41 UTC (rev 36437)
@@ -251,6 +251,10 @@
   <li>...</li>
 </ul>
+<p>
+<b>Please note that the wxGUI Nviz extension is under active development and
+distributed as &quot;Experimental Prototype&quot;.</b>
 <h2>SEE ALSO</h2>
 See also <a href="http://grass.osgeo.org/wiki/WxNVIZ">Wiki</a> page.
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html	2009-03-20 12:43:27 UTC (rev 36436)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html	2009-03-20 13:55:41 UTC (rev 36437)
@@ -34,27 +34,8 @@
 digitizer toolbar also allows switching easily between vector maps to be
 edited.
-<h2>NOTES</h2>
+<h3>DIGITIZER TOOLBAR</h3>
-<i>Dead (deleted)</i> are internally only marked in the geometry file
-as 'dead' but it remains there and occupies space. Any vector module
-used afterwards on this vector map which really reads and writes
-vector geometry (so not <em><a href="g.copy.html">g.copy</a></em>)
-will writes only features which are 'alive'.
-<p>
-<i>Added or modified</i> vector features are <i>snapped</i> to
-existing vector features ('Settings-&gt;General-&gt;Snapping', nodes or vertices)
-based on 'Settings-&gt;General-&gt;Snapping threshold' value. To
-disable snapping set the snapping threshold to '0'.
-<p>
-If the digitizer crashes for some reason you can repair the vector map
-which was left open with the <em>v.build</em> module.
-<h2>Digitizer toolbar</h2>
 <center>
 <br><img src="wxGUI_vector_digitizer_toolbar.jpg" border="1"><br><br>
 </center>
@@ -221,6 +202,28 @@
 </dl>
+<h2>NOTES</h2>
+<i>Dead (deleted)</i> are internally only marked in the geometry file
+as 'dead' but it remains there and occupies space. Any vector module
+used afterwards on this vector map which really reads and writes
+vector geometry (so not <em><a href="g.copy.html">g.copy</a></em>)
+will writes only features which are 'alive'.
+<p>
+<i>Added or modified</i> vector features are <i>snapped</i> to
+existing vector features ('Settings-&gt;General-&gt;Snapping', nodes or vertices)
+based on 'Settings-&gt;General-&gt;Snapping threshold' value. To
+disable snapping set the snapping threshold to '0'.
+<p>
+If the digitizer crashes for some reason you can repair the vector map
+which was left open with the <em>v.build</em> module.
+<p>
+<b>Please note that vector digitizer is under active development and
 <h2>SEE ALSO</h2>
 <em>
